Текущее время: Вт сен 01, 2026 06:56
СообщениеДобавлено: Сб сен 09, 2006 02:30
:lol: Недавно нашел и скачал прошивку версии V1.43b03 для ревизии C.
Ссылку тут выкладывать не буду так как только поставил себе на свой страх и риск проверяю и тестирую.
DI-804HV Firmware Release Notes
1.43
1. DI-804HV L2TP server and client reconnection fix.
2. Keepalive with ARP added.
3. WAN IP and WAN gateway subnet check.
4. Not allow IP addresses "X.X.X.255" or "X.X.X.0" in UI.
5. Fixed VPN IP Sec DDoS Issue 1.
1.42b06
1. Fix: Cannot forward ports when using auto-backup function with dial-up.
2. Add the check-box " Do not change the TTL value ".
2. Add QoS function.
3. Static and dynamic VPN connection priority fix.
4. VPN Traversal fix.
5. Dynamic VPN server with Extended Authentication fix.
6. Remote Management port field added.
7. Fragment packets that are fragmented by PPTP server fix.
8. Add an “Auto-connect” option for VPN.
1.41b07
1. Router’s WAN IP can respond “Ping” packet that is sent out by UI’s Ping tool.
2. The feature of NAT-Traversal would be enabled only if both VPN endpoints support it.
3. VPN client behind a NAT router (with IPSec passthrough) can establish IPSec tunnel with DI-804HV without setting any local ID or remote ID.
4. Add XBOX Enable/Disable option.
5. URL blocking fix.
6. Add “Active sessions” page.
7. Add local and remote ID options on VPN configuration page.
8. Support for GPRS modem.
9. Support RTP traffic pass-through.
10. Add authentication method (including Auto, PAP, CHAP, MS_CHAPv1; Default is Auto) at the Dial-up WAN configuration page.
1.37 (Backwards compatible with rev.A)
1.Fix UI error when switch VPN configuration pages.
2.Fix mail alert function can't transfer mail with some SMTP servers
3.Replace real key value with asterisks in VPN configuration pages.
4.Support SMTP authentication with mail alert function.
Shipped f/w 1.36
Пока никаких сбоев в ней не было работает как часы да и пока нет проблемы с ошибкой 112 как это нестранно даже ради проверки поставил на Maximum Idle Time 5 Minutes и коннект всегда как мне надо без пауз. Я уже както писал про проблему ошибки 112 сейчас ее нет. Буду проверять дальше позже кину ссылку. Маршрутизация в сеть за Ван портом идет. Нет игры работают.
СообщениеДобавлено: Сб сен 09, 2006 11:31
как там с MSCHAP2 и MPPE 128 ?
СообщениеДобавлено: Пн сен 11, 2006 09:56
2Deonis
Мпешу сообщить, что ещё есть 1.43b06, но достоянием общественности станет только 1.44(в будующем)
