Текущее время: Вс окт 04, 2026 14:30
 Заголовок сообщения: Проблема с dsl 300T.
СообщениеДобавлено: Вт авг 08, 2006 19:20
Вот лог модема:
Jan 1 12:28:43> Doing disconnect
Jan 1 12:28:43> pppd 2.4.1 started by root, uid 0
Jan 1 12:30:23> System Call Error
Jan 1 12:30:23> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d388
Jan 1 12:30:23> Couldn't get channel number: Transport endpoint is not connected
Jan 1 12:30:23> Doing disconnect
Jan 1 12:30:24> pppd 2.4.1 started by root, uid 0
Jan 1 12:32:04> System Call Error
Jan 1 12:32:04> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d388
Jan 1 12:32:04> Couldn't get channel number: Transport endpoint is not connected
Jan 1 12:32:04> Doing disconnect
Jan 1 12:32:04> pppd 2.4.1 started by root, uid 0
Jan 1 12:33:44> System Call Error
Jan 1 12:33:44> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d388
Jan 1 12:33:44> Couldn't get channel number: Transport endpoint is not connected
Jan 1 12:33:44> Doing disconnect
Jan 1 12:33:44> pppd 2.4.1 started by root, uid 0
Jan 1 12:35:24> System Call Error
Jan 1 12:35:24> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d388
Jan 1 12:35:24> Couldn't get channel number: Transport endpoint is not connected
Jan 1 12:35:24> Doing disconnect
Jan 1 12:35:24> pppd 2.4.1 started by root, uid 0
Jan 1 12:37:04> System Call Error
Jan 1 12:37:04> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d388
Jan 1 12:37:05> Couldn't get channel number: Transport endpoint is not connected
Jan 1 12:37:05> Doing disconnect
Jan 1 12:37:05> pppd 2.4.1 started by root, uid 0
Jan 1 12:38:45> System Call Error
Jan 1 12:38:45> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d388
Jan 1 12:38:45> Couldn't get channel number: Transport endpoint is not connected
Jan 1 12:38:45> Doing disconnect
Jan 1 12:38:45> pppd 2.4.1 started by root, uid 0
У провайдера все подключено. Сейчас стоит прошивка V2.00B01T01.EU.20050606. Хотел поменять на прошивку с буквами RU, но через веб интерфейс не получилось. Хотелось бы получить подробную инструкцию по обновлению прошивки через ftp или может лучше модем обратно в магазин отнести?
СообщениеДобавлено: Вт авг 08, 2006 20:34
1) Возврат на прошивку V1.xxxxxxx.RU только через СЦ.
2) Попробуте жестко задать модуляцию и у Вас и у провайдера на G.dmt.
СообщениеДобавлено: Ср авг 09, 2006 17:21
У меня по умолчанию стоит прошивка EU, так и должно быть?
СообщениеДобавлено: Ср авг 09, 2006 18:31
To bloodsoul
Дело не в прошивке... По каким то причинам недоступен PPP сервер провайдера.
С уважением, Давыдов Денис.
СообщениеДобавлено: Ср авг 09, 2006 19:35
С провайдером все нормально. Читал на форумах, что некоторым помогло обновление прошивки, что я и хочу сделать перед сдачей модема в магазин. Какой пароль для входа в ftp модема?
СообщениеДобавлено: Чт авг 10, 2006 09:15
Привозите устройство в СЦ - проверим в вашем присутствии.
СообщениеДобавлено: Чт авг 10, 2006 10:33
Я бы, конечно, привез, только вот живу не в Москве. В магазине, где брал модем, условий для проверки нет. Там сказали, что при отправки модема в СЦ нужно точно указать неисправность, иначе модем могут вернуть как исправныой. В этой ветке разбиралась аналогичная проблема: http://www.dlink.ru/phorum/viewtopic.ph ... +connected
Прочитайте и скажите, что указать в качестве неисправности (там что-то с мак адресами).[/url]
СообщениеДобавлено: Чт авг 10, 2006 13:01
В описании неисправности можно написать "Нет соединения с провайдером по PPPoE протоколу (в качестве клиента выступает модем)". Мы всесторонне протестируем устройство.
Сейчас этот форум просматривают: Bing [Bot] и гости: 77
