Текущее время: Ср сен 30, 2026 07:52
 Заголовок сообщения: DSL-604T, проблемы со связью
СообщениеДобавлено: Вт июл 04, 2006 10:43
Всем доброго дня.
Вчера вечером (весь день работал без сбоев) отвалился интернет.
Модем DSL-604T
Статус модема:
ADSL Firmware Version: 4.03.03.00 - 3.02.00.03 - 3.02.06.00 Annex A - 01.07.02 - 0.49
ADSL Software Version: V2.00B01T01.EU.20050930
Line State: Connected
Modulation: Multi-mode
Annex Mode: ANNEX_A
Max Tx Power: -38 dBm/Hz
Item Downstream Upstream
SNR Margin 11 9
Line Attenuation 30 23
Data Rate 6142 766
Лог после перезагрузки модема:
Jan 1 12:00:44> pppd 2.4.1 started by root, uid 0
Jan 1 12:00:45> Got connection: 8716
Jan 1 12:00:45> Saved Session ID: 0
Jan 1 12:00:45> Connecting PPPoE socket: 00:30:88:00:25:31 8716 nas0 0x1000d378
Jan 1 12:00:45> Connect: ppp0 {--} nas0
Jan 1 12:00:45> CHAP authentication failed
Jan 1 12:00:45> Connection terminated.
Jan 1 12:00:45> Doing disconnect
Jan 1 12:00:46> pppd 2.4.1 started by root, uid 0
Jan 1 12:00:46> Got connection: e404
Jan 1 12:00:46> Saved Session ID: 0
Jan 1 12:00:46> Connecting PPPoE socket: 00:30:88:00:25:31 e404 nas0 0x1000d378
Jan 1 12:00:46> Connect: ppp0 {--} nas0
Jan 1 12:00:53> CHAP authentication failed
Jan 1 12:00:53> Connection terminated.
Jan 1 12:00:53> Doing disconnect
Jan 1 12:00:53> pppd 2.4.1 started by root, uid 0
Jan 1 12:00:53> Got connection: 8735
Jan 1 12:00:53> Saved Session ID: 0
Jan 1 12:00:53> Connecting PPPoE socket: 00:30:88:00:25:31 8735 nas0 0x1000d378
Jan 1 12:00:53> Connect: ppp0 {--} nas0
Jan 1 12:01:03> CHAP authentication failed
Jan 1 12:01:03> Connection terminated.
Jan 1 12:01:03> Doing disconnect
Jan 1 12:01:06> pppd 2.4.1 started by root, uid 0
Jan 1 12:01:07> Got connection: e442
Jan 1 12:01:07> Saved Session ID: 0
Jan 1 12:01:07> Connecting PPPoE socket: 00:30:88:00:25:31 e442 nas0 0x1000d378
Jan 1 12:01:07> Connect: ppp0 {--} nas0
Jan 1 12:01:07> CHAP authentication failed
Jan 1 12:01:07> Connection terminated.
Jan 1 12:01:07> Doing disconnect
Сброс модема в дефолт ничего не дал, сегодня утром ситуация не изменилась. Прошу подсказать, что могло случиться.
СообщениеДобавлено: Вт июл 04, 2006 10:51
Судя по этой строке лога (Jan 1 12:01:07> CHAP authentication failed) ваше устройство не может пройти аутентификацию на PPP сервере провайдера. Попробуйте прописать заново логин/пароль в настройках устройства. Если не поможет, звоните провайдеру.
С уважением, Давыдов Денис.
СообщениеДобавлено: Вт июл 04, 2006 10:58
Пароль и логин вводил заново, не помогло :(
Т.е. скорее всего проблемы на стороне провайдера?
СообщениеДобавлено: Вт июл 04, 2006 11:13
Именно так.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 54
