Текущее время: Вт сен 01, 2026 21:17
Начать новую тему Ответить на тему  [ Сообщений: 21 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Пт июн 09, 2006 16:34
vov4uk писал(а):
Сегоня вообще вот что стало писать в лог.
Jun  9 18:14:02> Connecting PPPoE socket: 00:00:00:00:00:00 0000  0x1000d388
Jun  9 18:14:02> Couldn't get channel number: Transport endpoint is not connected
Jun  9 18:14:02> Doing disconnect
Jun  9 18:14:02> System Call Error
Jun  9 18:14:05> pppd 2.4.1 started by root, uid 0
Jun  9 18:15:45> System Call Error
Jun  9 18:15:45> Connecting PPPoE socket: 00:00:00:00:00:00 0000  0x1000d388
Jun  9 18:15:45> Couldn't get channel number: Transport endpoint is not connected
Jun  9 18:15:45> Doing disconnect
Недоступен PPP сервер провайдера...
Jun  9 18:15:45> pppd 2.4.1 started by root, uid 0
Jun  9 18:15:45> Got connection: 8642
Jun  9 18:15:45> Saved Session ID: 0
Jun  9 18:15:45> Connecting PPPoE socket: 00:08:21:7b:b0:12 8642 nas0 0x1000d388
Jun  9 18:15:45> Connect: ppp0 {--} nas0
Jun  9 18:16:18> PPP Negotiation Failed
Jun  9 18:16:18> LCP: timeout sending Config-Requests
Jun  9 18:16:18> Connection terminated.
Jun  9 18:16:18> Doing disconnect
Jun  9 18:16:18> pppd 2.4.1 started by root, uid 0
Jun  9 18:16:19> Got connection: 8c42
Jun  9 18:16:19> Saved Session ID: 0
Jun  9 18:16:19> Connecting PPPoE socket: 00:08:21:7b:b0:12 8c42 nas0 0x1000d388
Jun  9 18:16:19> Connect: ppp0 {--} nas0
Jun  9 18:16:21> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jun  9 18:16:21> WAN IP address 212.96.222.181
Jun  9 18:16:21> PPPoE Connect with IP Address 212.96.222.181
Jun  9 18:16:21> PPPoE Connection Successfully Established
Jun  9 18:16:21> PPPoE Connect with Gateway IP Address: 217.20.83.121
Jun  9 18:16:21> WAN gateway 217.20.83.121
Jun  9 18:16:21> primary   DNS address 217.20.83.123
Jun  9 18:16:21> secondary DNS address 217.20.82.4
..а сейчас подключился нормально..
С уважением, Давыдов Денис.
СообщениеДобавлено: Пт июн 09, 2006 18:44
Странно всё это если качать или играть всё время то инет не пропадает, тока прекращается обмениваться пакетами сразу обрывается связь. Если стоит в покое то появляется этак мин через 20-40.
И что то я ненашёл опцию On Demand может она включена но её невидать.
СообщениеДобавлено: Пн июн 12, 2006 00:13
GosuInDaHouse писал(а):
да не может быть, чтобы это из-за провайдера было! у всех, чтоли, провайдеры глючные ? ЭТО ЧТО-ТО С МОДЕМОМ. Надо было zyxel брать...
оффтоп, но все же
на работе стоит zyxel omni LAN, настроен на pppoa,
после недельки работы начинает тормозить до безобразия и терять пакеты, помогает только рестарт устройства. вот вам и зюхель
СообщениеДобавлено: Пн июн 12, 2006 00:37
тут проблем не меньше :cry:
СообщениеДобавлено: Пн июн 12, 2006 12:05
я уже пользую устройство 504Т в течении года, проблем практически небыло, а то что было, были проблемами собственных кривых рук
СообщениеДобавлено: Сб июн 17, 2006 01:43
Незнаю как так но работает уже долго и всё нормально, обычно дисконекты шли минут через 5 простоя, лог записал как обычно подключение прошло и всё такое. Disconnec'ов, больше небыло. А может и провайдер чего то сделал но я не обращался по данному вопросу. Замечу что провайдером выдается из 3х диапазонов ip
62.105.11.xxx
212.96.200.xxx
212.96.222.xxx
Поменял только.
DHCP Settings:
Lease Time - 86400 (24 часа)
После этого дисконекты поропали.
лог:
Jun 17 00:27:13> Firewall rules flushed
Jun 17 00:27:16> Firewall rules flushed
Jun 17 00:27:17> pppd 2.4.1 started by root, uid 0
Jun 17 00:27:27> Got connection: aa6a
Jun 17 00:27:27> Saved Session ID: 0
Jun 17 00:27:27> Connecting PPPoE socket: 00:08:21:7b:b0:12 aa6a nas0 0x1000d388
Jun 17 00:27:27> Connect: ppp0 {--} nas0
Jun 17 00:27:29> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jun 17 00:27:29> WAN IP address 212.96.200.65
Jun 17 00:27:29> PPPoE Connect with IP Address 212.96.200.65
Jun 17 00:27:29> PPPoE Connection Successfully Established
Jun 17 00:27:29> PPPoE Connect with Gateway IP Address: 217.20.83.121
Jun 17 00:27:29> WAN gateway 217.20.83.121
Jun 17 00:27:30> primary DNS address 217.20.83.123
Jun 17 00:27:30> secondary DNS address 217.20.82.4
