Текущее время: Чт окт 01, 2026 00:20
СообщениеДобавлено: Вт май 23, 2006 22:05
Sep 8 12:00:06> Valid Configuration Tree
Sep 8 12:00:11> Firewall NAT service started
Sep 8 12:00:12> Bridge Created: br0
Aug 9 12:01:01> Bridge Interface Added: eth0
Aug 9 12:01:02> pppd 2.4.1 started by root, uid 0
Aug 9 12:01:02> DSL Carrier is training
Aug 9 12:01:05> pppd 2.4.1 started by root, uid 0
Aug 9 12:01:10> Bridge Interface Added: tiwlan0
Aug 9 12:01:12> DSL Carrier is up
Aug 9 12:01:16> Connecting PPPoE socket: 00:30:88:00:73:ce 080b nas0 0x1000d3b8
Aug 9 12:01:16> Connect: ppp0 {--} nas0
Aug 9 12:01:16> WAN IP address 85.140.8.86
Aug 9 12:01:16> WAN gateway 85.140.8.1
Aug 9 12:01:16> primary DNS address 212.188.4.10
Aug 9 12:01:16> secondary DNS address 195.34.32.116
Aug 9 12:01:16> PPPoE Connect with IP Address 85.140.8.86
Aug 9 12:01:16> PPPoE Connection Successfully Established
Aug 9 12:01:16> PPPoE Connect with Gateway IP Address: 85.140.8.1
Aug 9 12:02:41> System Call Error
Aug 9 12:02:41> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Aug 9 12:02:41> Couldn't get channel number: Transport endpoint is not connected
Aug 9 12:02:41> Doing disconnect
Aug 9 12:02:41> pppd 2.4.1 started by root, uid 0
Aug 9 12:04:22> System Call Error
Aug 9 12:04:22> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Aug 9 12:04:22> Couldn't get channel number: Transport endpoint is not connected
Aug 9 12:04:22> Doing disconnect
Aug 9 12:04:22> pppd 2.4.1 started by root, uid 0
Aug 9 12:06:02> System Call Error
Aug 9 12:06:02> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Aug 9 12:06:02> Couldn't get channel number: Transport endpoint is not connected
Aug 9 12:06:02> Doing disconnect
Aug 9 12:06:02> pppd 2.4.1 started by root, uid 0
Aug 9 12:07:42> System Call Error
Aug 9 12:07:42> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Aug 9 12:07:42> Couldn't get channel number: Transport endpoint is not connected
Aug 9 12:07:42> Doing disconnect
Aug 9 12:07:43> pppd 2.4.1 started by root, uid 0
Как-то инет нестабильно работает. ТП стрима говорят что у них всё в норме. Заранее спасибо
СообщениеДобавлено: Ср май 24, 2006 11:11
Назовите модель устройства и версию прошивки.
СообщениеДобавлено: Ср май 24, 2006 12:17
G604t
V1.00B02T02.RU.20041014
СообщениеДобавлено: Ср май 24, 2006 14:03
Проблема в PPP сервере провайдера.
СообщениеДобавлено: Ср май 24, 2006 14:25
Стало быть звонить с ними разбираться?
СообщениеДобавлено: Чт май 25, 2006 10:38
Именно так.
СообщениеДобавлено: Сб май 27, 2006 11:08
Именно так.
Позвонил в ТП Стрима, проверили сказали что у них всё ОК, но мой модем на аплоад подсоединяется на 288, хотя каналка у меня открыта на 768.
СообщениеДобавлено: Пн май 29, 2006 09:18
Тип модуляции какой включен?
СообщениеДобавлено: Пн май 29, 2006 10:02
Gdmt. В стриме подтвердили, что у них такая же прописана.
Часть моей проблемы решилась. Сообщений по поводу PPP сервера нет, но всё равно подсоединяется на аплоад на 288.
СообщениеДобавлено: Пн май 29, 2006 10:05
Обновите прошивку на эту: ftp://dlink.ru/pub/ADSL/DSL-G604T/Firmw ... adeB10.exe
После чего на эту: ftp://dlink.ru/pub/ADSL/DSL-G604T/Firmw ... 060109.zip
Руководство по перепрошивке: ftp://dlink.ru/pub/ADSL/DSL-G604T/Firmw ... l_ver3.pdf
Если не поможет, привозите устройство в сервис.
СообщениеДобавлено: Пн май 29, 2006 17:35
У Стрима пппое серверов не очень много на все 300 тысяч клиентов (можно перещитать). И вы слишком громко заявляете, что проблема с пппое сервером. Когда такие проблемы возникают - очень большая часть Москвы наших клиентов без инета остаётся, в этом случае ТП сразу скажет, что трабл со стороны провайдера.
з.ы. по проблеме - настраивайте модем в режим бридж и пробуйте.
Изображение DSL 504T [VX.XXXXXXXX.RU.XXXXXXXX]
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 54
