Текущее время: Чт сен 10, 2026 11:33
 Заголовок сообщения: DG 104SH и факс.
СообщениеДобавлено: Пн май 22, 2006 08:53
PROM Version: 1.0B20-G
RUNTIME Version: 1.0B58-G
h323 display_name = 'DG-104SH'
h323 h323_ID = 'DEFAULT_H323_ID'
h323 h245_term_type = 40
h323 rtp_port_base = 30000
h323 rtp_tos = 8
h323 ras_tos = 4
h323 h225h245_tos = 4
h323 fast_start = on
h323 t38 = on
h323 t38_req_initiater = caller
h323 gk_mode = off
h323 no_ans_callfwd_time = 10
h323 h235_token = off
h323 h235_token_password =
Configuration for coding profile id 6:
Tx Coding = T.38 FAX
Rx Coding = T.38 FAX
Coding profile for fax
Tx VIF size = 288 (bits)
Rx VIF size = 288 (bits)
VAD = Disabled
VAD threshold = Adaptive VAD
Playout nominal delay = 300 (msec)
Playout maximum delay = 300 (msec)
Playout minimum delay = 20 (msec)
Adaptive Playout = Disabled
Rate = 14400
DTMF Relay = Disabled
Tone detect = Enabled
Call Progress Tone detect = Disabled
V.18 Tone detect = Disabled
SS7 COT Tone detect = Disabled
SF Sig Tone detect = Disabled
EC = Disabled
EC NL = Disabled
EC NL Sens = 0
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
EC Auto Update = Disabled
EC Auto Search = Disabled
EC Search Freeze = Disabled
Modem TX level = -10 (dB)
Modem CD threshold = 1
Modem no activity timeout = 30 (sec)
Silence detection time = 0 (msec)
Silence detection level = 0 (dB)
Fax debug level = 0
TCF handling = Method 2 (Sent over the network)
Max low speed packetization = 1 (bytes)
Tx network timeout = 150 (sec)
Eflag start timer = 2600 (ms)
Eflag stop timer = 2300 (ms)
Scan line fix up = Enabled
Eflags for fast DIS = Enabled
TFOP proto enhancement = Enabled
NSF override = Disabled
T30 ECM = Enabled
T30 MR page compression = Disabled
T.38 Fax Parameters
Fax high-speed packet rate = 10 (msec)
Fax low-speed redundancy for T.38 UDP = 3
Fax high-speed redundancy for T.38 UDP = 0
Caller ID Support = Disabled
Resampling = Disabled
EC Config = NLP_FIXED
NLP Confort Noise = 0
SID Retx Rate = 2000
Encapsulation = UDP
Нет возможности отправить факс. Прием факса и голос в оба конца - ОК
Вот трейс неудачной попытки отправки:
ggdbg>spy hsmu 0
ggdbg>000095231 HSMU: Enter call_profile->capabilities
000095231 HSMU: t.38 codec found at profile 6
000095231 HSMU: Exit call_profile->capabilities.
000095231 HSMU 1: Process outgoing H.323 Fast Start call.
000095242 Dialing DEST = TA:XXX.XXX.XXX.XXX:1720,TEL:5556
000095242 SOURCE = NAME:DEFAULT_H323_ID,TEL:7601
000095243 USER_TO_USER = CID_NAME:FAX, CID_NUM:7601 SETUP
000095243 hsmup_open_rtp_sockets: nw_open(RTP1), port=30002, call_num=1
000095243 hsmup_open_rtp_sockets: nw_open(RTCP2), call_num=1, port=30003
000095243 HSMU 1: set timer for 50000 in state hsmup_state_h225_wait_alerting
000095302 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=fa
000095302 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000095303 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000095303 HSMU 1: Product ID = "Avaya Multivantage"
000095303 HSMU 1: Version ID = "R012i.01.1.414.1"
000095303 HSMU 1: abort timer in state hsmup_state_h225_wait_alerting
000095303 HSMU 1: set timer for 2000 in state hsmup_state_h225_wait_immediate_connect
000095303 HSMU 1: cmControlStateFastStart
000095303 HSMU 1: Starting Capabilities Exchange, capabilities_send=0
000095303 HSMU 1: Sending local capabilities.
000095303 HSMU 1: abort timer in state hsmup_state_h225_wait_immediate_connect
000095303 HSMU 1: set timer for 2000 in state hsmup_state_fast_start_alerting_info
000095303 HSMU 1: Chan 0o cmEvChannelSetRTCPAddress_msg IP = 172.17.55.161, Port = 2225
000095303 HSMU 1: Chan 0o cmEvChannelSetAddress_msg IP = 172.17.55.161, Port = 2224
000095303 HSMU 1: Chan 0o - cmChannelStateConnected "g711Alaw64k"
local RTCP = 0, remote RTCP =2225, RTP = 172.17.55.161:2224
000095303 HSMU 1: Chan 0i cmEvChannelSetRTCPAddress_msg IP = 172.17.55.161, Port = 2225
000095303 HSMU 1: Chan 0i - cmChannelStateConnected "g711Alaw64k"
local RTCP = 0, remote RTCP =2225, RTP = 0.0.0.0:0
000095303 HSMU 1: FS Chan 0i - offering channel "g711Alaw64k"
000095303 HSMU 1: FS Chan 0i: Opened RTP socket = 1, cmChannel = 30002
000095303 HSMU 1: Chan 0i: Opened RTCP socket = 2, port 30003
000095303 HSMU 1: abort timer in state hsmup_state_fast_start_alerting_info
000095303 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=fa
000095303 HSMU 1: set timer for 300 in state hsmup_state_fast_start_wait_complete
000095303 HSMU 1: abort timer in state hsmup_state_fast_start_wait_complete
000095303 HSMU 1: set timer for 1000 in state hsmup_state_wait_set_coding_resp
000095307 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=fa
000095307 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000095312 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=fa
000095312 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000095317 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=fa
000095317 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000095323 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=fa
000095323 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000095328 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=fa
000095328 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000095333 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=fa
000095333 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000095384 HSMU 1: abort timer in state hsmup_state_wait_set_coding_resp
000095384 HSMU 1: VOICE CONNECTED, coding=g711Alaw64k, FAST START mode, originating
000095384 HSMU 1: set timer for 30000 in state hsmup_state_voice_connected
000096583 DIM: 0:3 - dim_rx_pkt_violation suggests swo
000098384 HSMU 1: timer triggered in state hsmup_state_voice_connected
000098384 HSMU 1: abort timer in state hsmup_state_voice_connected
000098384 HSMU 1: set timer for 30000 in state hsmup_state_voice_connected
000099467 HSMU 1: abort timer in state hsmup_state_voice_connected
000099467 HSMU 1: set timer for 10000 in state hsmup_state_fax_channel
000099468 HSMU 1: abort timer in state hsmup_state_fax_channel
000099468 HSMU 1: H.323 release (IF)
000099519 HSMU 1: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP1, RTCP2)
000099519 HSMU 1: nw_close(inchan local RTCP2, RTP1)
000099519 HSMU 1: nw_close(inchan local RTCP65535, RTP65535)
000099519 HSMU 1: nw_close(outchan local RTCP65535)
Что подправить в консерватории -)))
 Заголовок сообщения: Re: DG 104SH и факс.
СообщениеДобавлено: Пн май 22, 2006 09:56
Модератор
Модератор
h323 rtp_tos = 8
h323 ras_tos = 4
h323 t38 = on
h323 gk_mode = off
VAD = Disabled
Rate = 14400
EC = Disabled
EC NL = Disabled
EC NL Sens = 0
EC Tail = 8 (msec)
EC Refresh = Update
EC Coeffs = Normal
Fax debug level = 0
T30 ECM = Enabled
T.38 Fax Parameters
Encapsulation = UDP
ggdbg>spy hsmu 0
О проблемах с факсом, уже неоднократно писалось на данном форуме, воспользуйтесь поиском.
Виктор Колосов
СообщениеДобавлено: Пн май 22, 2006 10:54
Читали. Ничего вразумительного кроме обновления прошивок нет.-(((
Не поясните, что означает:
Спасибо.
СообщениеДобавлено: Вт май 23, 2006 10:05
IP-PBX member
здесь читали?
http://dlink.ru/tests/test_24.php
Даешь связистов без брака!
AB4790-RIPE
СообщениеДобавлено: Вт май 23, 2006 11:37
Прочел. Ну и...????
Буду гадать -))) - это единственный способ заставить ходить факсы?(через цепочку делинков) - не интересно.
Вообще схема иная чем АТС ---Н.323---DG104--- факс не рассматривается.
Всетаки вопрос к спецам, что означает строчка:
ЗЫ. кроме команды spy hsmu 0 есть что-нибудь способное пролить свет в моей ситуации. Может зря DG 104 терзаем? Может дело не в бабине-)))
