Текущее время: Чт сен 24, 2026 08:06
Начать новую тему Ответить на тему  [ Сообщений: 39 ]  На страницу Пред.  1, 2, 3
СообщениеДобавлено: Пн май 15, 2006 01:54
В режиме РРРоЕ коннект так и продолжает слетать. Поддержка, есть мысли?
Вот логи:
Sep 8 12:00:06> Valid Configuration Tree
Sep 8 12:00:11> Firewall NAT service started
Sep 8 12:00:11> Bridge Created: br0
Aug 9 12:01:00> Bridge Interface Added: eth0
Aug 9 12:01:01> pppd 2.4.1 started by root, uid 0
Aug 9 12:01:03> DSL Carrier is training
Aug 9 12:01:11> Connecting PPPoE socket: 00:30:88:01:15:86 d90e nas0 0x1000d3b8
Aug 9 12:01:11> Connect: ppp0 {--} nas0
Aug 9 12:01:11> default route ioctl(SIOCADDRT): Network is unreachable(128)
Aug 9 12:01:11> WAN IP address 83.237.232.5
Aug 9 12:01:11> PPPoE Connect with IP Address 83.237.232.5
Aug 9 12:01:11> WAN gateway 83.237.232.1
Aug 9 12:01:11> PPPoE Connection Successfully Established
Aug 9 12:01:11> PPPoE Connect with Gateway IP Address: 83.237.232.1
Aug 9 12:01:11> primary DNS address 212.188.4.10
Aug 9 12:01:11> secondary DNS address 195.34.32.116
Aug 9 12:01:13> DSL Carrier is up
Aug 9 16:50:27> Connection terminated.
Aug 9 16:50:29> Doing disconnect
Aug 10 01:44:00> pppd 2.4.1 started by root, uid 0
Aug 10 01:44:01> Connecting PPPoE socket: 00:30:88:01:15:86 b109 nas0 0x1000d3b8
Aug 10 01:44:01> Connect: ppp0 {--} nas0
Aug 10 01:44:01> default route ioctl(SIOCADDRT): Network is unreachable(128)
Aug 10 01:44:01> WAN IP address 83.237.188.25
Aug 10 01:44:01> PPPoE Connect with IP Address 83.237.188.25
Aug 10 01:44:01> WAN gateway 83.237.188.1
Aug 10 01:44:01> PPPoE Connection Successfully Established
Aug 10 01:44:01> PPPoE Connect with Gateway IP Address: 83.237.188.1
Aug 10 01:44:01> primary DNS address 212.188.4.10
Aug 10 01:44:01> secondary DNS address 195.34.32.116
Aug 10 01:44:05> Connection terminated.
Aug 10 01:44:07> Doing disconnect
Aug 10 01:44:08> pppd 2.4.1 started by root, uid 0
Aug 10 01:44:08> Connecting PPPoE socket: 00:30:88:01:15:86 2300 nas0 0x1000d3b8
Aug 10 01:44:08> Connect: ppp0 {--} nas0
Aug 10 01:44:08> default route ioctl(SIOCADDRT): Network is unreachable(128)
Aug 10 01:44:08> WAN IP address 83.237.188.25
Aug 10 01:44:08> PPPoE Connect with IP Address 83.237.188.25
Aug 10 01:44:08> WAN gateway 83.237.188.1
Aug 10 01:44:08> PPPoE Connection Successfully Established
Aug 10 01:44:08> PPPoE Connect with Gateway IP Address: 83.237.188.1
Aug 10 01:44:08> primary DNS address 212.188.4.10
Aug 10 01:44:08> secondary DNS address 195.34.32.116
Aug 10 08:30:58> Connection terminated.
Aug 10 08:31:01> Doing disconnect
Aug 10 12:21:59> pppd 2.4.1 started by root, uid 0
Aug 10 12:21:59> Connecting PPPoE socket: 00:30:88:01:15:86 1105 nas0 0x1000d3b8
Aug 10 12:21:59> Connect: ppp0 {--} nas0
Aug 10 12:22:00> default route ioctl(SIOCADDRT): Network is unreachable(128)
Aug 10 12:22:00> WAN IP address 83.237.232.154
Aug 10 12:22:00> PPPoE Connect with IP Address 83.237.232.154
Aug 10 12:22:00> WAN gateway 83.237.232.1
Aug 10 12:22:00> PPPoE Connection Successfully Established
Aug 10 12:22:00> PPPoE Connect with Gateway IP Address: 83.237.232.1
Aug 10 12:22:00> primary DNS address 212.188.4.10
Aug 10 12:22:00> secondary DNS address 195.34.32.116
СообщениеДобавлено: Ср май 17, 2006 08:17
Попробуй вот эту прогу НЕОФИЦАЛЬНУЮ
http://zyxmon.streamclub.ru/other.php#DlMon
А также пройдись от розетке где сплиттер до коробки распределительной телефонной. Если не поможет то звоните на атс и просите проверить линию на сопротивление.
СообщениеДобавлено: Ср май 17, 2006 15:46
Demius-80:
Да уж скачал, только что-то ума не хватает её правильно настроить.
И по проводке прошёлся - писал уже выше и логи состяния линии приводил - получше стало. Только в бридже как слетал коннект, так и слетает, мать его. Правда В РРРоЕ не видно слётов, но по айпишнику судя, если и бывает, то гораздо реже.
Поддержка, у вас-то хоть есть какие идеи? Если нет, то хоть скажите об этом, я ждать не буду.
СообщениеДобавлено: Ср май 17, 2006 15:55
Поробуйте отключить всё от телефонной линии и потключить телефон с внешним питанием и послушайте после нажатия одной цифры звучание есть ли помехи.
СообщениеДобавлено: Ср май 17, 2006 16:43
Сделано. Никаких существенных помех в линии не слышно.
СообщениеДобавлено: Чт май 18, 2006 06:10
Тогда только инженеров атс вызвать пусть сами посмотрят. А модем на другой линии пробовали? или другой?
СообщениеДобавлено: Чт май 18, 2006 09:39
C ADSL проблем нет, и это видно из логов. Проблемы с ppp на стороне провайдера. Узнайте причину по которой их pppoe сервер разрывает соединение.
СообщениеДобавлено: Чт май 18, 2006 11:47
Я уж и так им все мозги высушил. Что они только не делали. Правда, надо отдать должное, хоть и говорили, что у них регистрируется физический разрыв связи(от меня), но на модем не валили. Просто, как я вижу, в бридже слёты учащаются, а в РРРоЕ гораздо реже. Короче, надо так понимать, что с модемом делать ничего не надо, надо продолжать ковырять мозги провайдеру?
Demius-80:
Нет, не пробовал. Хотя поддержка прова это и советовала, когда на пару дней насnупило улучшение.
СообщениеДобавлено: Сб май 20, 2006 15:54
Ну вот, наконец Стримовская поддержка и посоветовала мне посмотреть проводку. А вы говорите - " Проблемы с ppp на стороне провайдера". А вот они уже так не считают.
US Margin 11
DS Margin 22
Modulation T1413
DS Line Attenuation 29
US Line Attenuation 21
