Текущее время: Пт окт 02, 2026 14:19
 Заголовок сообщения: DFL100 connect (VPN) DFL600
СообщениеДобавлено: Вт май 16, 2006 15:44
Local0.Info 192.168.1.1 EFW: IPSEC: prio=1 Phase-1 [initiator] between ipv4(udp:500,[0..3]=192.168.105.2) and ipv4(udp:500,[0..3]=192.168.105.3) failed; Aborted notification.
2006-04-21 15:26:29 Local0.Notice 192.168.1.1 EFW: DROP: prio=2 rule=Drop_standart action=drop recvif=LAN srcip=192.168.1.3 destip=205.188.248.198 ipproto=TCP ipdatalen=28 srcport=3399 destport=80 tcphdrlen=28 syn=1
2006-04-21 15:26:31 Local0.Info 192.168.1.1 EFW: IPSEC: prio=1 Phase-1 [initiator] between ipv4(udp:500,[0..3]=192.168.105.2) and ipv4(udp:500,[0..3]=192.168.105.3) failed; Aborted notification.
2006-04-21 15:26:32 Local0.Notice 192.168.1.1 EFW: DROP: prio=2 rule=Drop_standart action=drop recvif=LAN srcip=192.168.1.3 destip=205.188.248.198 ipproto=TCP ipdatalen=28 srcport=3399 destport=80 tcphdrlen=28 syn=1
2006-04-21 15:26:37 Local0.Info 192.168.1.1 EFW: IPSEC: prio=1 Phase-1 [initiator] between ipv4(udp:500,[0..3]=192.168.105.2) and ipv4(udp:500,[0..3]=192.168.105.3) failed; Aborted notification.
2006-04-21 15:26:38 Local0.Notice 192.168.1.1 EFW: DROP: prio=2 rule=Drop_standart action=drop recvif=LAN srcip=192.168.1.3 destip=205.188.248.198 ipproto=TCP ipdatalen=28 srcport=3399 destport=80 tcphdrlen=28 syn=1
2006-04-21 15:26:42 Local0.Info 192.168.1.1 EFW: IPSEC: prio=1 Phase-1 [initiator] between ipv4(udp:500,[0..3]=192.168.105.2) and ipv4(udp:500,[0..3]=192.168.105.3) failed; Aborted notification.
2006-04-21 15:26:50 Local0.Notice 192.168.1.1 EFW: DROP: prio=2 rule=Drop_standart action=drop recvif=LAN srcip=192.168.1.3 destip=205.188.248.198 ipproto=TCP ipdatalen=28 srcport=3399 destport=80 tcphdrlen=28 syn=1
2006-04-21 15:26:51 Local0.Info 192.168.1.1 EFW: CONN: prio=1 rule=ToVPN conn=close connipproto=ICMP connrecvif=LAN connsrcip=192.168.1.2 connsrcid=512 conndestif=Kolbasa conndestip=192.168.0.50 conndestid=512 origsent=240 termsent=0
2006-04-21 15:26:54 Local0.Notice 192.168.1.1
Хотелось бы узнать по чему нет конекта? ,
СообщениеДобавлено: Вт май 16, 2006 16:10
Удаленные системы не могут договориться о SA.
Возможно неверно указаны методы шифрования и аутификации.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 68
