Текущее время: Сб авг 29, 2026 22:15
Начать новую тему Ответить на тему  [ Сообщений: 408 ]  На страницу Пред.  1 ... 15, 16, 17, 18, 19, 20, 21 ... 28  След.
 Заголовок сообщения: Точка доступа у 604T
СообщениеДобавлено: Сб мар 25, 2006 13:23
Начала отваливаться точка доступа у 604T
Логи:
Mar 25 13:12:11> wdrv_DDA_restart_setEvent ..........
Mar 25 13:12:11> deleting timer 0xc006ec74
Mar 25 13:12:11> deleting timer 0xc007093c
Mar 25 13:12:11> deleting timer 0xc0075af4
Mar 25 13:12:11> deleting timer 0xc007577c
Mar 25 13:12:11> @@@@@@@@@@@@ TIME SINCE BOOT: 0[d]:12[h]:48[m]:13[s] @@@@@@@@@@@@
Mar 25 13:12:11> Resetting the remote device.
Mar 25 13:12:11> Un-resetting the remote device.
Mar 25 13:12:11> About to re-init the VLYNQ.
Mar 25 13:12:11> Re-initialized the VLYNQ.
Mar 25 13:12:11> Freed MSDUs count = 2
Mar 25 13:12:11> Freed MSDUs count = 0
Mar 25 13:12:11> AcxRegAddr = 0xA4040000, AcxMemAddr = 0xA4000000
Mar 25 13:12:11>
Mar 25 13:12:11>
Mar 25 13:12:11> Hidden SSID is activated
Mar 25 13:12:11> whal_acxProcInitiate: found DEVICE_VENDOR ID = 0x9066104c
Mar 25 13:12:11> whal_acxProcInitiate: Cpu halt -} download code
Mar 25 13:12:11> whal_acxProcLoadFwImage: 0xa4000000, 0x0
Mar 25 13:12:11> whal_acxProcLoadFwImage() -- Loading FW image460932: Compiled for RADIA (bg) radio
Mar 25 13:12:11> whal_acxProcLoadFwImage: 1, pBuf=0xc00a7000, len=0x15564. Extra pBuf=0x0, len=0x3
Mar 25 13:12:11> whal_acxProcLoadFwImage: 2, pBuf=0xc00a7000, len=0x15564. Extra pBuf=0x0, len=0x3
Mar 25 13:12:11> whal_acxProcLoadFwImage: 3, pBuf=0xc00a7000, len=0x15564, DataLen=0x1555c
Mar 25 13:12:11> whal_acxProcLoadFwImage: 4, pBuf=0xc00a7000, len=0x15564
Mar 25 13:12:11> whal_acxProcLoadFwImage: Checksum, calc=0x71e76f, file=0x71e76f
Mar 25 13:12:12> whal_acxProcInitiate: run
Mar 25 13:12:12> whal_acxProcWaitInitComplete:
Mar 25 13:12:12> whal_acxMboxInit: pCmdMbox=0xa401dd00, pInfoMbox=0xa401de88
Mar 25 13:12:12> ----------------------------------------------------------------
Mar 25 13:12:12> ACX Firmaware Version = Rev 1.6.0.24
Mar 25 13:12:12> whal_acxProcConfigure: templates (beacon, probe response, tim) for [0] Network
Mar 25 13:12:12> whal_acxProcConfigure: Host Queue is in 0x94E30020
Mar 25 13:12:12> TxQueue[0] NumDesc = 32
Mar 25 13:12:12> TxQueue[0] Priority = 0
Mar 25 13:12:12> TxQueue[1] NumDesc = 32
Mar 25 13:12:12> TxQueue[1] Priority = 129
Mar 25 13:12:12>
Mar 25 13:12:12> whal_acxConfigMemory() --
Mar 25 13:12:12> HostRxDescriptorsAddr = 14e30020
Mar 25 13:12:12> RxQueue NumDesc = 32
Mar 25 13:12:12> RxQueue Priority = 0
Mar 25 13:12:12> RxQueue type = 7
Mar 25 13:12:12> whal_acxProcConfigure: read queue heads
Mar 25 13:12:12> whal_acxConfigRead_QueueHead() -
Mar 25 13:12:12> RxMemBlkQ - 00016940
Mar 25 13:12:12> RxQueueHead - 00013f34
Mar 25 13:12:12> TxMemBlkQ - 0001b340
Mar 25 13:12:12> TxMemBlkQ[0]- 000145b4
Mar 25 13:12:12> TxMemBlkQ[1]- 00014c34
Mar 25 13:12:12> 460942: whal_acxProcConfigure: configure RxQueue/TxQueue objects
Mar 25 13:12:12> whal_txQueue_Init: [Qid=0] HwBaseAddr=0xa40145b4, NumDesc=32
Mar 25 13:12:12> whal_txQueue_Init: [Qid=1] HwBaseAddr=0xa4014c34, NumDesc=32
Mar 25 13:12:12> whal_ParamsPrintMemMap:
Mar 25 13:12:12> Code (0x00000000, 0x0001250c)
Mar 25 13:12:12> Wep (0x0001280c, 0x0001291c)
Mar 25 13:12:12> Sta (0x0001291c, 0x00013f04)
Mar 25 13:12:12> Tmpl (0x00012524, 0x000125b9)
Mar 25 13:12:12> Queue (0x00013f34, 0x000152b4)
Mar 25 13:12:12> Pool (0x00016940, 0x0001c740)
Mar 25 13:12:12> whal_apiConfig: beaconInterval = 200
Mar 25 13:12:12> WATCH_DOG_TIMER_VAL = 520
Mar 25 13:12:12> wd_beacon_limiter = 1
Mar 25 13:12:12> whal_apiStartBss: Enable Tx, Rx and Start the Bss
Mar 25 13:12:12> START BSS, SSID=Mirinet, BSSID=00-11-95-96-5E-F2
Mar 25 13:12:12> AP Power Level = 1
Mar 25 13:12:12> Regulatory Domain = ETSI
Mar 25 13:12:12> Net[0] : Channel=12
Mar 25 13:12:12> FW Watchdog is Enabled
В работу вмешивался тока 1 раз перезапуском - сэйв энд рестарт.
Прошивка декабрьская...
СообщениеДобавлено: Пн мар 27, 2006 22:19
Имею следующую конфигурацию:
Gateway V1.00B02T02.RU.20050921
ATM Driver 4.01.00.00
DSL HAL 1.01.00.00
DSL Datapumps 1.01.00.00 Annex A
SAR HAL 01.06.06 s
PDSP Firmware 0.49
Wireless Firmware 0.3.16.13
Wireless APDK 5.5.4.24
Wireless Driver 1.1.2
Boot Loader 0.22.02
имеет ли смысл перепрошивать на последнюю версию доступную на ftp??? По идеи и эта устраивает, если какие либо радикальные отличия в новой версии (ADSL2 не в счет, он мне не нужен) Спасибо.
СообщениеДобавлено: Ср мар 29, 2006 08:15
В ADSL2 прошивке изменен DSL Datapumps на версию 4 там с чемто не помню всех ноликов :lol: а так вобще ничего поразительного больше. Если уж прошивать то не просто так а со смыслом если прошивка твоя тебя устраивает то не стоит, прошивать так прошивать на неофициальную от МсМСС постабильней будет и пофункциональней много всяких примочек.
P.S. Еще про ADSL2 пршивку - с DSLAM'om вяжется довольно долго так что подождешь минутку другую пока приконектится :lol:
СообщениеДобавлено: Чт май 11, 2006 20:59
парни помогите засунуть в прошивку прокси сервер, или раскажите как можно его на старую залить, прошивка родная стоит 2004 года. Может ктонибуть эксперементировал ? даите совет [/url]
СообщениеДобавлено: Пт май 19, 2006 17:33
Есть два модема и две сети в которых они и стоят. Сколько не пытались по WI-FI их стыкавать не как не выходило :evil: . Кто может подсказать возможно ли это зделать :?: и каким образом :idea: , а если и не возможно то что нужно докупить чтоб ето было реально по WI - Fi обеспечить связь как меж локалками так и итеном.
растояние не важно
настройка сетки также недолго перебить
СообщениеДобавлено: Пт май 19, 2006 21:32
Прошил роутер версией V2.01B01T01.RU.20060109.
Подключен к стриму.
После выключения/включения настройки соединения PPPoE возвращаются в исходные пароль/логин и т.п. VPI/VCI : 8/35.
Как эту беду побороть?
Кто еще с эти сталкивался?
Дело в том, что мне эти версии нужны из-за наличия в них Parent Control (URL Blocking & Domain Blocking), чтобы ребенок не нарвался на всякую чернуху.
СообщениеДобавлено: Пн май 22, 2006 08:58
Подключен к стриму.
Tools/System/Save&Reeboot
СообщениеДобавлено: Пн май 22, 2006 09:16
растояние не важно
Во всех ADSL модемах встроена точка доступа, которая предназначена для подключения беспроводных клиентов. Две точки доступа друг с другом работать не могут.
СообщениеДобавлено: Ср май 24, 2006 13:17
Прошивка V2.01B01T01.RU.20060109.
Не работает Parent Control. Вернее невозможно добавить ни один URL/domain для блокировки. Пробовал и IE, firefox и оперу. Безрезультатно. Ничего не происходит. При этом в логах появляется:
Jan 1 23:21:54> set error: message= :Bad key 'settings/categoryN/add' in 'fdb':
Должна ли эта фича работать в данной версии? Что сделать чтобы заработала? Помогите, пожалуйста, разобраться!
СообщениеДобавлено: Пт июн 02, 2006 10:21
Господа,
Что делать если роутер не ресетиться и не отвечяет, хотя как хаб работает исправно)
хтмл страничка то-же не доступна!
СообщениеДобавлено: Пт июн 02, 2006 11:10
d12 писал(а):
Господа,
Индикатор Status себя как ведет? Модель устройства?
 Заголовок сообщения: DSL out of sync, DSL in Sync...
СообщениеДобавлено: Ср июн 21, 2006 12:58
Господа, никто не нашел решение этой проблемы в логе? А то все чисто, кроме такой же ситуации:
Jan 1 13:28:13> DSL out of sync
Jan 1 13:28:13> DSL in Sync
Jan 1 13:28:41> DSL out of sync
Jan 1 13:28:41> DSL in Sync
Судя повсему отсюда следует другая проблема:
Display Receive and Transmit packages through ADSL
Transmit
Tx PDU's 123607
Tx Total Bytes 12931873
Tx Total Error Counts 0
Receive
Rx PDU's 153154
Rx Total Bytes 180742765
Rx Total Error Counts 7718
ADSL status shows the ADSL physical layer status.
ADSL Firmware Version: 4.03.03.00 - 3.02.00.03 - 3.02.06.00 Annex A - 01.07.02 - 0.49
ADSL Software Version: V2.00B01T01.EU.20050930
Line State Connected
Modulation T1.413
Annex Mode ANNEX_A
Max Tx Power -38 dBm/Hz
Item Downstream Upstream Unit
SNR Margin 0 8 dB
Line Attenuation 14 6 dB
Data Rate 12448 1088 kbps
Прошивки:
Как купил, сразу перепрошил на DSL-G604T_ V2.01.B01T01RU.20060109
Посмотрел лог, перепрошил обратно на DLinkEU_DSL-G604T_V2.00B01T01.EU.20050930, ситуация не поменялась...
Оператор - Питерский "Авангард", настройка согласно доке http://www.dlink.ru/technical/faq_xdsl_83.php Изменение типа модуляции проблему не решает.
Броузер: Internet Explorer, Opera.
СообщениеДобавлено: Пн июн 26, 2006 13:22
то ли руки кривые то ли плохо поиск юзаю но вот вопрос и ответа я пока не нашел:
есть g 604 t купленная года полтора назад работала идеально все это время (были мелкие огрехи, но про них я уже прочитал на этом форуме, типа не ресетится, возвращается к старом паролю, иногда сам по себе менялся пароль на ван порте) но недавно начались глюки поинтереснее. точка является выходом в инет по адсл к точке подключена 2 компа по утп и один через вифи. неожиданно пропадает инет. смотрю а пароль поменялся, ну да ладно думаю, может друг решил поэкпериментировать и наломал дров, поменял обратно. на след день обнаружил то же самое, и на всякий случай перепрошил новой прошивкой которая лежала 3 дня назад здесь на фтп (не проверял, наверное и сйечас лежит) и вроде бы глюк ушел. но вот что странно если на точка соединяется с дсламом по pppoe и при этом сервак пускает меня дальшеи отдает значение ok то точка тут же пишет в логах
Aug 9 12:20:32> Connecting PPPoE socket: 00:0f:23:89:b1:38 a0fd nas0 0x1000d3b8
Aug 9 12:20:32> Connect: ppp0 {--} nas0
Aug 9 12:20:34> PAP authentication failed
Aug 9 12:20:34> Failed to Authenicate
Aug 9 12:20:34> Connection terminated.
Aug 9 12:20:34> Doing disconnect
Aug 9 12:20:35> pppd 2.4.1 started by root, uid 0
Aug 9 12:20:35> Connecting PPPoE socket: 00:0f:23:89:b1:38 a1fd nas0 0x1000d3b8
Aug 9 12:20:35> Connect: ppp0 {--} nas0
и после этого реконнектиться. при всем при этом пакеты все таки проходят и инет как бы работает но очень уж нестабильно и медленно. связывался с админами на другом конце, у них все ок, ниче не меняли, сервак меня пускает нормально без вопросов да и вообще грят мы не прикасались в последнее время к серваку (на серваке онима стоит). решил попробовать соединение через бридж и действительно все работает пркрасно и никаких глюков.
ВОТ ПОДСКАЖИТЕ МНЕ В ЧЕМ ПРОБЛЕМА. ну не было никакого головняка до сегодняшнего момента и тут вдруг на тебе саня, тра....... что н-ся.
ЗЫ советов типа ну так и юзай бридж не надо, не для того я покупал такой девайс чтоб иметь такой головняк, купил бы тогда че нить типа 300 + 2100ап и мозги не парил бы
 Заголовок сообщения: Re: DSL out of sync, DSL in Sync...
СообщениеДобавлено: Пн июн 26, 2006 13:48
Transmit
Tx PDU's 123607
Receive
Rx PDU's 153154
Modulation T1.413
Annex Mode ANNEX_A
SNR Margin 0 8 dB
Прошивки:
Н-да, так как техподдержка на нас забила, отвечаю сам на свой вопрос:
Синхронизация терялась из-за этого параметра:
SNR Margin Downstream 0 dB
После поисков по форумам проблема решилась звонком по 057 и просьбой уменьшить скорость физического соединения.
Теперь имею такую ситуацию и ни одной ошибки в логе:
SNR Margin 31 21 dB
Data Rate 2590 800 kbps
СообщениеДобавлено: Вт июл 04, 2006 09:35
Всем доброго дня.
Вчера вечером (весь день работал без сбоев) отвалился интернет.
Модем DSL-604T
Статус модема:
Line State: Connected
Modulation: Multi-mode
Annex Mode: ANNEX_A
Max Tx Power: -38 dBm/Hz
SNR Margin 11 9
Line Attenuation 30 23
Data Rate 6142 766
Лог после перезагрузки модема:
Jan 1 12:00:44> pppd 2.4.1 started by root, uid 0
Jan 1 12:00:45> Got connection: 8716
Jan 1 12:00:45> Saved Session ID: 0
Jan 1 12:00:45> Connecting PPPoE socket: 00:30:88:00:25:31 8716 nas0 0x1000d378
Jan 1 12:00:45> Connect: ppp0 {--} nas0
Jan 1 12:00:45> CHAP authentication failed
Jan 1 12:00:45> Connection terminated.
Jan 1 12:00:45> Doing disconnect
Jan 1 12:00:46> pppd 2.4.1 started by root, uid 0
Jan 1 12:00:46> Got connection: e404
Jan 1 12:00:46> Saved Session ID: 0
Jan 1 12:00:46> Connecting PPPoE socket: 00:30:88:00:25:31 e404 nas0 0x1000d378
Jan 1 12:00:46> Connect: ppp0 {--} nas0
Jan 1 12:00:53> CHAP authentication failed
Jan 1 12:00:53> Connection terminated.
Jan 1 12:00:53> Doing disconnect
Jan 1 12:00:53> pppd 2.4.1 started by root, uid 0
Jan 1 12:00:53> Got connection: 8735
Jan 1 12:00:53> Saved Session ID: 0
Jan 1 12:00:53> Connecting PPPoE socket: 00:30:88:00:25:31 8735 nas0 0x1000d378
Jan 1 12:00:53> Connect: ppp0 {--} nas0
Jan 1 12:01:03> CHAP authentication failed
Jan 1 12:01:03> Connection terminated.
Jan 1 12:01:03> Doing disconnect
Jan 1 12:01:06> pppd 2.4.1 started by root, uid 0
Jan 1 12:01:07> Got connection: e442
Jan 1 12:01:07> Saved Session ID: 0
Jan 1 12:01:07> Connecting PPPoE socket: 00:30:88:00:25:31 e442 nas0 0x1000d378
Jan 1 12:01:07> Connect: ppp0 {--} nas0
Jan 1 12:01:07> CHAP authentication failed
Jan 1 12:01:07> Connection terminated.
Jan 1 12:01:07> Doing disconnect
Сброс модема в дефолт ничего не дал, сегодня утром ситуация не изменилась. Прошу подсказать, что могло случиться.
