Текущее время: Ср ноя 04, 2026 04:04
 Заголовок сообщения: DI-808HV и FreeBSD VPN
СообщениеДобавлено: Ср мар 01, 2006 16:05
Не работает соединение в логах пишет
Wednesday March 01, 2006 14:42:58 Send IKE M1(INIT) : x.x.x.x --> y.y.y.y
Wednesday March 01, 2006 14:42:58 Receive IKE M2(RESP) : y.y.y.y --> x.x.x.x
Wednesday March 01, 2006 14:42:58 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Wednesday March 01, 2006 14:42:58 Send IKE M3(KEYINIT) : x.x.x.x --> y.y.y.y
Wednesday March 01, 2006 14:42:58 Receive IKE M4(KEYRESP) : y.y.y.y --> x.x.x.x
Wednesday March 01, 2006 14:42:58 Send IKE M5(IDINIT) : x.x.x.x --> y.y.y.y
Wednesday March 01, 2006 14:43:04 IKED re-TX : IDINIT to y.y.y.y
Wednesday March 01, 2006 14:43:09 IKED re-TX : IDINIT to y.y.y.y
Wednesday March 01, 2006 14:43:09 receiving a re-Tx MM msg, response the last msg
Wednesday March 01, 2006 14:43:09 IKED re-TX : MM to y.y.y.y
Wednesday March 01, 2006 14:43:19 IKED re-TX : IDINIT to y.y.y.y
Wednesday March 01, 2006 14:43:19 receiving a re-Tx MM msg, response the last msg
Wednesday March 01, 2006 14:43:19 IKED re-TX : MM to y.y.y.y
Wednesday March 01, 2006 14:43:20 Send IKE (INFO) : delete x.x.x.x -> y.y.y.y phase 1
Wednesday March 01, 2006 14:43:20 IKE phase1 (ISAKMP SA) remove : x.x.x.x <-> y.y.y.y
СообщениеДобавлено: Ср мар 01, 2006 20:54
можно ли отключить в DI-808HV при VPN соединении проверку LocalID и RemoteId
