Текущее время: Вт окт 27, 2026 13:57
 Заголовок сообщения: Проблема с подключением к DG-104SH
СообщениеДобавлено: Вт фев 28, 2006 10:57
Привет всем. Не могу подключиться к устройству через консоль. Используется Hiperterminal. 9600 8-N-1. Консольный кабель из комплекта. В процессе загрузки нажимаю Ctr-C, но без толку.
Power On Self-Test
* Testing Device Hardware: DRAM Test ..... PASSED
* Testing Device Hardware: PROM Code Checksum(Image 1) ..... PASSED
* Testing Device Hardware: Runtime Code Checksum ..... PASSED
* Testing Device Hardware: FLASH Integration Checksum ..... PASSED
PROM Version: 1.0B20-G RUNTIME Version: 1.0B53-G
D-Link DG-104SH: Initializing Device OS
-> DUPLICATED IP CHECKING: (Hit CTRL-C to stop system boot/load )
.. IP Address: 10.1.5.55
.. Subnet Mask: 255.255.255.0
ARP Req Send ARP Reply ARP Retry Time (Sec)
1 0 0 0
2 0 1 0
-> DOWNLOAD RUN TIME IMAGE FROM FLASH: (Hit CTRL-C to stop system boot/load )
Decompress Run Time Image :
System Driver Initialization is Ready
External Switch should be Provided
In MXP Root before lock
In MXP Root after lock
After mem init
After hwu_init
NWIF: hwu_get_mac_address()=00:0f:3d:f7:ba:ec
After nw_create
Change Customer ID success.
After nwdb_create
After telnet_create
After Web_create
After Tftp_create
After Snmp_create
After Dhcpserv_create
After Nat_create
After CpeFind_create
After ntp_create
After PPPoE_create
After gg_app_create
After unlock
000000333 NMM: ATPM Update Database Granted
000000396 NMM: ATPM Configured From Flash
000000396 NMM: ATPM Update database done
000000396 TSG: 0, Switched CAS, FXS Loop Start
000000396 NMM: 0, Set Channel State Done (SUCCESS)
000000396 NMM: 0, Channel Config Done (SUCCESS)
000000396 TSG: 1, Switched CAS, FXS Loop Start
000000396 NMM: 1, Set Channel State Done (SUCCESS)
000000396 NMM: 1, Channel Config Done (SUCCESS)
000000396 TSG: 2, Switched CAS, FXS Loop Start
000000396 NMM: 2, Set Channel State Done (SUCCESS)
000000396 NMM: 2, Channel Config Done (SUCCESS)
000000396 TSG: 3, Switched CAS, FXS Loop Start
000000396 NMM: 3, Set Channel State Done (SUCCESS)
000000396 NMM: 3, Channel Config Done (SUCCESS)
000000396 HSMU: Created.
000000396 Manual GK discovery mode (IP = 84.204.136.65; Port = 1719).
000000396 Registering E.164 alias "223111".
000000396 Reporting configured profiles(1-5):
000000396 Profile # 1, "g711Ulaw64k", VIF = 1280, VAD = on
000000396 Profile # 2, "g711Alaw64k", VIF = 1280, VAD = on
000000396 Profile # 3, "g7231", VIF = 192, VAD = on
000000396 Profile # 4, "g7231", VIF = 192, VAD = on
000000396 Profile # 5, "g729AnnexA", VIF = 160, VAD = on
Username:
И дальше все. На нажатия клавиш не реиагирует.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 17
