Текущее время: Ср сен 30, 2026 16:12
Начать новую тему Ответить на тему  [ Сообщений: 82 ]  На страницу Пред.  1, 2, 3, 4, 5, 6  След.
СообщениеДобавлено: Сб дек 24, 2005 14:34
Connection Status Connected
Upstream Rate (Kbps) 768
Downstream Rate (Kbps) 6144
US Margin 11
DS Margin 20
Modulation GDMT
LOS Errors 0
DS Line Attenuation 31
US Line Attenuation 30
Path Mode Interleaved
# ifconfig
br0 Link encap:Ethernet HWaddr 00:0F:3D:88:CF:FA
inet addr:192.168.9.200 Bcast:192.168.9.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:21649 errors:0 dropped:0 overruns:0 frame:0
TX packets:3788 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:23420179 (22.3 Mb) TX bytes:2931004 (2.7 Mb)
eth0 Link encap:Ethernet HWaddr 00:0F:3D:88:CF:FA
RX packets:5639 errors:0 dropped:0 overruns:0 frame:0
TX packets:20589 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:998006 (974.6 kb) TX bytes:25711115 (24.5 Mb)
Base address:0x2800
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
nas0 Link encap:Ethernet HWaddr 00:0F:3D:88:CF:FA
RX packets:3675 errors:0 dropped:0 overruns:0 frame:0
TX packets:2806 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2622481 (2.5 Mb) TX bytes:496603 (484.9 kb)
nas1 Link encap:Ethernet HWaddr 00:AA:BB:CC:DD:11
RX packets:16801 errors:0 dropped:0 overruns:0 frame:0
TX packets:2303 errors:33 dropped:0 overruns:33 carrier:0
RX bytes:22544897 (21.5 Mb) TX bytes:223039 (217.8 kb)
nas2 Link encap:Ethernet HWaddr 00:AA:BB:CC:DD:12
TX packets:4871 errors:14267 dropped:0 overruns:14267 carrier:0
RX bytes:0 (0.0 b) TX bytes:3761854 (3.5 Mb)
ppp0 Link encap:Point-Point Protocol
inet addr:85.140.30.204 P-t-P:85.140.30.1 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1492 Metric:1
RX packets:3476 errors:0 dropped:0 overruns:0 frame:0
TX packets:2767 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:2577665 (2.4 Mb) TX bytes:406440 (396.9 kb)
декодера пока нет тестирую на VLC, если не переключать канал то и инет и тв показывает, стоит переключить канал все опадает...
СообщениеДобавлено: Сб дек 24, 2005 23:41
dolph писал(а):
US Margin 11
DS Margin 20
Ну я конечно не доктор, но по моему проблема в не очень хорошей линии. Т.е. при таких значениях Line Attenuation и Margin 6144/768 плохо работает.
Вот чаго знающие люди пишут:
Margin - соотношение сигнал/шум, чем больше тем лучше..
40db это очень хорошо,
30db - нормально
Attenuation - затухание сигнала, чем меньше тем лучше.
26db это нормальный показатель.
10-20db это хорошо.
Варианты решения проблемы:
0. Перетянуть кабель до АТС. (Шутка, хотя тоже решение)
0,5. Перетянуть кабель от щитка (Это не шутка, в ряде случает меняет картину кардинально). При соединении в щитке использовать паяльник!!! Скрутки - враг ADSL.
0,9. Проверить совковые розетки на наличие конденсаторов. Если есть - отправить их на помойку. В обязательном порядке использовать сплиттер и фильтры на паралельных телефонах.
1. Попробовать разные модуляции: gdmt, t1.413, .....
2. Перепрошить модем и еще раз настроить (всякое бывает)
3. Попросить ТП снизить UP скорость
4. Попросить ТП снизить DOWN скорость
Хочу только отметить, что я описал только несколько путей решения проблемы и не факт что поможет, потому как могут быть баги на стороне провайдера (бажный DSLAM, бета версии драйверов руки.vxd у техников на АТС и т.д. и т.п.).
P.S. Приведу на всякий случай свои параметры:
Item Downstream Upstream Unit
SNR Margin 24 24 dB
Line Attenuation 19 10 dB
Data Rate 6144 512 kbps
СообщениеДобавлено: Пн дек 26, 2005 04:10
noiseman - прошу твоей помощи. У меня D-Link 504T, все сделал В ТОЧНОСТИ по твоей инструкции описанной в теме, причем ПОВТОРИЛ эту процедуру аж 3 РАЗА. (Перепрошил сначало 630 потом 930 прошивку. Все получилось. Далее настроил 3 PVC конекшена 1/50 Ppoe, 1/91 Bridge, 1/92 Bridge. Отключил DHCP, прописал лан клиента своей локальной машины, выставил время и сохранил и перегрузился.) И ничего у меня не заработало. После перезагрузки с этими настройками при подсоединении всех трех конекшенов (смотрю их в меню STATUS/device info) примерно через 1-2 минуты перестает работать инет, а amino пишет что "не может получить ip-шник". При этом что удивительно - в статусе все 3 PVC выдают что они connected. Начал копаться дальше - взял отключил pvc2 конекнш (сделал HOME/WAN -> pvc2 -> Virtual Circuit - Disabled). И вдруг у меня заработало Стрим ТВ. Я активировал карту вошел в МЕНЮ стримТВ и смог по нему лазить и выбирать каналы. Ну а самого ТВ(картинки) конечно нету, т.к. нету конекшена pvc2. Насколько я понял конекшен pvc1 отвечает за как раз само меню ТВ, а pvc2 за изображение ТВ. Дальше я прочитал твое сообщение о качестве ADSL линии у меня оказались очень плохие параметры , но приних работает инет. ПАРАМЕТРЫ такие:
SNR Margin 9 7 dB
Line Attenuation 43 24 dB
Data Rate 6142 766 kbps
Далее, я поступил радикально - я взял у друга ADSL Router - Asus AAM6020VI - это полный аналог Paradyna 62**. С этим модемом у меня все на раз запустилось - и инет и ТВ. Все шикарно заработало.
Отсюда я сделал вывод что с приставкой Amino и с линией у меня все нормально. Значит проблема с модемом D-Linkом 504t. Есть ли какие нить соображения (очень не хочется покупать новый модем) ? Можешь ли ты на всякий случай мне прислать твой config модема. Я попробую залить твои настройки.
Заранее благодарен.
СообщениеДобавлено: Пн дек 26, 2005 15:11
noiseman писал(а):
8. Последний рывок. Топаем Advanced->Virtual Server и настраиваем проброс портов (если необходимо). Описывать эту процедуру не буду, потому как эти настройки сугубо индивидуальны.
P.S. Да и настройка проброса портов связана как нибудь с стрим тв - я их не настраивал - мне не нужно перенаправлять порты. Может у меня из -за этого какие то проблемы??? Если да - то подскажите что куда и зачем перенаправлять для Стрим ТВ???
СообщениеДобавлено: Пн дек 26, 2005 16:07
Vitty, смотрю на ваши значения скорости - модем завязался скорее всего на АДСЛ2+. Поставь модуляцию gdmt или ansi-t1.413. Лучше первое, у нас чаще всего на 6144 на неё стоит приоритет.
С одной из этих модуляций картина изменится и будет всё так же, как и на Парадайне.
Изображение DSL 504T [VX.XXXXXXXX.RU.XXXXXXXX]
СообщениеДобавлено: Пн дек 26, 2005 16:11
И еще - если удалили bridge 1/91 и bridge 1/92 - верните их.
Если эти соединения есть + загрузилось само меню, то смена модуляций поможет.
А вот если пробема с тем что неполучен ip-adress. То либо у вас АДСЛ мигает, либо присавка загрузилась быстрее чем модем нашёл АДСЛ, либо на модеме dhcp включен =)
СообщениеДобавлено: Вт дек 27, 2005 02:22
Изменение модуляций не помогло.
С модуляцией - T1.413 - соединение ADSL теряется (лампочка ADSL начинает сначало медленно мигать, потом очень очень быстро, а потом тухнет - т.е. я так понимаю сигнал ADSL не держится, а мотом эта процедура повторяется). Когда лампочка мигает параметры такие:
SNR Margin 13 17 dB
Line Attenuation 49 19 dB
Data Rate 6144 768 kbps
С модуляцией - G.dmt , сигнал восстанавливается с такими параметрами:
SNR Margin 10 11 dB
А с модуляцией - G.lite - такие:
SNR Margin 6 8 dB
Line Attenuation 46 19 dB
Data Rate 3872 768 kbps
А насчет меню - у меня оно появляется только когда есть 1 bridge соединение (1/91), ну и плюс еще инет PPOE 1/50. Как только я добавляю третье соединение (bridge 1/92) - так сразу и инет отрубается и amino не может получить IPшник.
Люди добрые помогите - неужели Paradyne лучше D-linka? Что я еще не учел? Кто может выслать мне config? СПАСИБО......
СообщениеДобавлено: Вт дек 27, 2005 15:17
Смотря какая модель...
Вы не сказали версию прошивки....
СообщениеДобавлено: Вт дек 27, 2005 22:31
McMCC! Ты конечно очень уважаемый человек и я понимаю что новый год на носу, но несколькими постами выше vitty написал ответы на эти вопросы. У него 504T c прошивкой 0930.
vitty
Куда тебе прислать конфиг? И еще. Ты уверен что у тебя с кабелями сетевыми все в поряде? Просто есть общеизвестный глюк у хреново обжатых кабелей: маленькую нагрузку они пропускают, а большую нет. И еще надо обратить внимание на разводку кабеля, желательно что бы она была одинаковой в пределах одного устройства, в данном случае - модема.
СообщениеДобавлено: Ср дек 28, 2005 06:14
У меня патч корды покупные, обжатые в заводских условиях. Попробую поменять, но врят ли - ведь с этими же патч кордами модем Asus (аналог Paradyne) завелся с пол оборота и все запахало. И соответственно разводка одинаковая.
А конфиг плиз мне выслать на мыло - vitty@nm.ru. Спасибо.
И еще вопрос:
- может ли быть такое что из-за плохих показателей моей линии один модем - Asus (аналог Paradyne) держит большую нагрузку, а другой модем - в частности мой D-link 504T при большой нагрузке теряет линию и подвисает.
Это я спрашиваю к тому, что стоит ли мне заморачиваться перетяжкой телефонного провода напрямую от щитка или нет (вроде как сигнал должен улучшится)?
 Заголовок сообщения: Благодарность
СообщениеДобавлено: Пт дек 30, 2005 17:33
Огромное спасибо noiseman за неоценимою помощь и потрясающую инструкцию. Просто здорово. Очень очень помогло. Все что нужно просто четко пользоваться Вашей инструкцией. И будет Счастье!!! ВСЕХ с Наступающим Новым годом. Также спасибо технической подерже компании D-link которая также оказала помощь.
 Заголовок сообщения: СПАСИБО!!! noiseman
СообщениеДобавлено: Пн янв 16, 2006 20:32
СПАСИБО!!! noiseman
dlink g604t,line362,2kompa,всё работает правда прошивка 604я(ADSL2+)
СообщениеДобавлено: Вт янв 17, 2006 12:35
Amino110 вкл только при отсутствии инета, т.е. сначала вкл-приставку, вкл полноэкр режим и далее кн +/- можно перекл программы, при попытке уйти в режим миниокна приставка гарантированно виснет
Не удается создать подкл PPPoA только Bridge, все время пишет ошибку авторизации в логе, кстати нашел случайно прогу DlinkMon, которая сама PPP соед делает.
Скорость скач увел с 27 kB до 32.3-32.6 kB per second
СообщениеДобавлено: Вт янв 17, 2006 13:17
alma
А DHCP точно отключен?[/quote]
СообщениеДобавлено: Вт янв 17, 2006 13:57
Точнее не бывает :) Я где то читал что надо на каком то PVC (92 наверное) откл multicast... может из-за этого
Кстати прошивки от McMCC выложены на ftp.dlink.ru !!!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 77
