Текущее время: Пн ноя 02, 2026 12:48
 Заголовок сообщения: G604T - разрывы связи??
СообщениеДобавлено: Вс окт 14, 2007 15:32
Собственно все было нормально, но в последние два дня связь просто ужасна. На самом модеме - лампочка ADSL горит (в тех.поддержку звонил - инженер перегрузил оборудование на стороне провайдера - лампочка моргала - сообщение в логе другое) - а так полный лог вот такого:
Oct 14 14:47:34> Doing disconnect
Oct 14 14:47:34> pppd 2.4.1 started by root, uid 0
Oct 14 14:49:14> System Call Error
Oct 14 14:49:14> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 14:49:14> Couldn't get channel number: Transport endpoint is not connected
Oct 14 14:49:14> Doing disconnect
Oct 14 14:49:14> pppd 2.4.1 started by root, uid 0
Oct 14 14:50:54> System Call Error
Oct 14 14:50:54> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 14:50:54> Couldn't get channel number: Transport endpoint is not connected
Oct 14 14:50:54> Doing disconnect
Oct 14 14:50:55> pppd 2.4.1 started by root, uid 0
Oct 14 14:52:35> System Call Error
Oct 14 14:52:35> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 14:52:35> Couldn't get channel number: Transport endpoint is not connected
Oct 14 14:52:35> Doing disconnect
Oct 14 14:52:35> pppd 2.4.1 started by root, uid 0
Oct 14 14:54:15> System Call Error
Oct 14 14:54:15> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 14:54:15> Couldn't get channel number: Transport endpoint is not connected
Oct 14 14:54:15> Doing disconnect
Oct 14 14:54:15> pppd 2.4.1 started by root, uid 0
Oct 14 14:55:55> System Call Error
Oct 14 14:55:55> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 14:55:55> Couldn't get channel number: Transport endpoint is not connected
Oct 14 14:55:55> Doing disconnect
Oct 14 14:55:56> pppd 2.4.1 started by root, uid 0
Oct 14 14:57:36> System Call Error
Oct 14 14:57:36> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 14:57:36> Couldn't get channel number: Transport endpoint is not connected
Oct 14 14:57:36> Doing disconnect
Oct 14 14:57:36> pppd 2.4.1 started by root, uid 0
Oct 14 14:59:16> System Call Error
Oct 14 14:59:16> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 14:59:16> Couldn't get channel number: Transport endpoint is not connected
Oct 14 14:59:16> Doing disconnect
Oct 14 14:59:16> pppd 2.4.1 started by root, uid 0
Oct 14 15:00:56> System Call Error
Oct 14 15:00:56> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 15:00:56> Couldn't get channel number: Transport endpoint is not connected
Oct 14 15:00:56> Doing disconnect
Oct 14 15:00:57> pppd 2.4.1 started by root, uid 0
Oct 14 15:02:37> System Call Error
Oct 14 15:02:37> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 15:02:37> Couldn't get channel number: Transport endpoint is not connected
Oct 14 15:02:37> Doing disconnect
Oct 14 15:02:37> pppd 2.4.1 started by root, uid 0
Oct 14 15:04:17> System Call Error
Oct 14 15:04:17> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 15:04:17> Couldn't get channel number: Transport endpoint is not connected
Oct 14 15:04:17> Doing disconnect
Oct 14 15:04:17> pppd 2.4.1 started by root, uid 0
Oct 14 15:05:57> System Call Error
Oct 14 15:05:57> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 15:05:57> Couldn't get channel number: Transport endpoint is not connected
Oct 14 15:05:57> Doing disconnect
Oct 14 15:05:58> pppd 2.4.1 started by root, uid 0
Oct 14 15:07:38> System Call Error
Oct 14 15:07:38> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 15:07:38> Couldn't get channel number: Transport endpoint is not connected
Oct 14 15:07:38> Doing disconnect
Oct 14 15:07:38> pppd 2.4.1 started by root, uid 0
Oct 14 15:09:18> System Call Error
Oct 14 15:09:18> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 15:09:18> Couldn't get channel number: Transport endpoint is not connected
Oct 14 15:09:18> Doing disconnect
Oct 14 15:09:18> pppd 2.4.1 started by root, uid 0
Oct 14 15:10:58> System Call Error
Oct 14 15:10:58> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 15:10:58> Couldn't get channel number: Transport endpoint is not connected
Oct 14 15:10:58> Doing disconnect
Oct 14 15:10:59> pppd 2.4.1 started by root, uid 0
Oct 14 15:11:05> Got group error |Bad username/password|
Oct 14 15:12:39> System Call Error
Oct 14 15:12:39> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 15:12:39> Couldn't get channel number: Transport endpoint is not connected
Oct 14 15:12:39> Doing disconnect
Oct 14 15:12:39> pppd 2.4.1 started by root, uid 0
Oct 14 15:14:19> System Call Error
Oct 14 15:14:19> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Oct 14 15:14:19> Couldn't get channel number: Transport endpoint is not connected
Oct 14 15:14:19> Doing disconnect
при этом страницы открываются через раз, про нормальную скорость говорить не приходится
Провайдер: Стрим (Москва)
Software Version V1.00B02T02.RU.20041014 (уже пора обновлять?)
СообщениеДобавлено: Вт окт 16, 2007 01:43
проблема решилась
установкой новой прошивки
и уменьшением кол-ва открытых соединений в используемом софте :idea:
пока стабильно все
после перепрошивки - надо обязательно сбрасывать настройки к заводским - без этого настроивать модем не удалось (ни опера ни firefox не работают корректно с последней прошивкой) - хорошо что на ноутбуке есть винда - но вообще это конечно не гуманно так делать - старая версия прошивки была в этом плане кросс-платформенной
попутно замечу - что с версией 2.0EU - не работал virtual server (просто не слушался порт снаружи и все)
вообще я бы предпочел не кликать по интерфейсу, а скачал файл - поправил - загрузил - перегрузил модем и все готово.
