Текущее время: Вт сен 29, 2026 13:18
СообщениеДобавлено: Сб июн 16, 2007 14:20
0x0x0x0x0
Последний раз редактировалось smirn Ср дек 23, 2009 17:30, всего редактировалось 1 раз.
СообщениеДобавлено: Сб июн 16, 2007 14:22
Вот лог который выдает модем:
Jan 1 00:00:11 user warn kernel: Can't analyze prologue code at 8014aa34
Jan 1 00:00:11 user info kernel: PPP generic driver version 2.4.2
Jan 1 00:00:11 user info kernel: NET: Registered protocol family 24
Jan 1 00:00:11 user warn kernel: Using noop io scheduler
Jan 1 00:00:11 user warn kernel: bcm963xx_mtd driver v1.0
Jan 1 00:00:11 user warn kernel: brcmboard: brcm_board_init entry
Jan 1 00:00:11 user warn kernel: bcm963xx_serial driver v2.0
Jan 1 00:00:11 user info kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 00:00:11 user info kernel: TCP: Hash tables configured (established 512 bind 1024)
Jan 1 00:00:11 user info kernel: NET: Registered protocol family 1
Jan 1 00:00:11 user info kernel: NET: Registered protocol family 17
Jan 1 00:00:11 user notice kernel: Ebtables v2.0 registered
Jan 1 00:00:11 user info kernel: NET: Registered protocol family 8
Jan 1 00:00:11 user info kernel: NET: Registered protocol family 20
Jan 1 00:00:11 user info kernel: 802.1Q VLAN Support v1.8 Ben Greear
Jan 1 00:00:11 user info kernel: All bugs added by David S. Miller
Jan 1 00:00:11 user warn kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:11 user info kernel: Freeing unused kernel memory: 64k freed
Jan 1 00:00:11 user warn kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:11 user warn kernel: atmapi: module license 'Proprietary' taints kernel.
Jan 1 00:00:11 user warn kernel: blaadd: blaa_detect entry
Jan 1 00:00:11 user warn kernel: adsl: adsl_init entry
Jan 1 00:00:11 user info kernel: Broadcom BCMPROCFS v1.0 initialized
Jan 1 00:00:11 user warn kernel: Broadcom BCM6338A2 Ethernet Network Device v0.3
Jan 1 00:00:11 user warn kernel: Config Ethernet Switch Through SPI Slave Select 0
Jan 1 00:00:11 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: eth0 registered
Jan 1 00:00:11 user warn kernel: eth0: MAC Address: 00:19:5B:C0:CF:37
Jan 1 00:00:11 user warn kernel: BcmAdsl_Initialize=0xC00673B8, g_pFnNotifyCallback=0xC007E4E4
Jan 1 00:00:11 user warn kernel: pSdramPHY=0xA07FFFF8, 0x51B79F2 0xDEADBEEF
Jan 1 00:00:11 user warn kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA07FB114
Jan 1 00:00:11 user warn kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Jan 1 00:00:11 user warn kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 00:00:11 user warn kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 368 bytes per conntrack
Jan 1 00:00:11 user crit kernel: eth0 Link UP.
Jan 1 00:00:11 user warn kernel: ip_conntrack_pptp version 2.1 loaded
Jan 1 00:00:11 user warn kernel: ip_nat_pptp version 2.0 loaded
Jan 1 00:00:11 user warn kernel: ip_conntrack_h323: init
Jan 1 00:00:11 user warn kernel: ip_nat_h323: initialize the module!
Jan 1 00:00:11 user crit kernel: ADSL G.994 training
Jan 1 00:00:11 user crit kernel: ADSL G.992 started
Jan 1 00:00:11 user info kernel: device eth0 entered promiscuous mode
Jan 1 00:00:11 user info kernel: br0: port 1(eth0) entering learning state
Jan 1 00:00:11 user info kernel: br0: topology change detected, propagating
Jan 1 00:00:11 user info kernel: br0: port 1(eth0) entering forwarding state
Jan 1 00:00:11 user info kernel: device nas_0_33 entered promiscuous mode
Jan 1 00:00:11 user info kernel: br0: port 2(nas_0_33) entering learning state
Jan 1 00:00:11 user info kernel: br0: port 2(nas_0_33) entering forwarding state
Jan 1 00:00:11 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:00:11 user debug syslog: bftpd
Jan 1 00:00:11 user debug syslog: tftpd
Jan 1 00:00:12 user debug syslog: pppd
Jan 1 00:00:12 user debug syslog: ifconfig nas_0_33 mtu 1444
Jan 1 00:00:12 daemon notice pppd[262]: pppd 2.4.1 started by admin, uid 0
Jan 1 00:00:15 user crit kernel: ADSL link up, interleaved, us=64, ds=64
Jan 1 00:00:15 user warn kernel: ATM Soft SAR: ATM link connected.
Jan 1 00:00:16 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 169.254.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:00:17 daemon notice pppd[262]: PPP: Start to connect ...
Jan 1 00:00:19 daemon crit pppd[262]: PPP server detected.
Jan 1 00:00:19 daemon crit pppd[262]: PPP session established.
Jan 1 00:00:20 daemon crit pppd[262]: PPP LCP UP.
Jan 1 00:00:20 daemon crit pppd[262]: Received valid IP address from server. Connection UP.
Jan 1 00:00:20 user debug syslog: route add default gw 81.20.168.160 2>/dev/null
Jan 1 00:00:20 user debug syslog: iptables -A FORWARD -o ppp_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --set-mss 1396
Jan 1 00:00:20 user debug syslog: iptables -A FORWARD -i ppp_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --set-mss 1396
Jan 1 00:00:20 user debug syslog: echo > /proc/net/ip_conntrack
Jan 1 00:00:20 user debug syslog: echo "512" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:00:20 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 169.254.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:00:20 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_33_1 -s 169.254.0.0/255.255.0.0 -j MASQUERADE 2>/dev/null
Jan 1 00:00:20 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_33_1 -s 169.254.0.0/255.255.0.0 -j MASQUERADE
Jan 1 00:00:20 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 169.254.1.1 -p udp --dport 53 -j DNAT --to 81.20.168.10 2>/dev/null
Jan 1 00:00:20 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 169.254.1.1 -p udp --dport 53 -j DNAT --to 81.20.168.10
Jan 1 00:00:20 user debug syslog: /bin/dnsprobe &
Jan 1 00:00:20 user debug syslog: upnp -L br0 -W ppp_0_33_1 -D
Jan 1 00:00:20 user notice dnsprobe[468]: dnsprobe started!
Jan 1 00:00:21 user debug syslog: iptables -t filter -I OUTPUT -o ppp_0_33_1 -d 239.255.255.250 -j DROP 2>/dev/null
Jun 16 17:12:45 user debug igmp[497]: iptables -t filter -I FORWARD 1 -i br0 -d 224.0.0.22 -j DROP 2>/dev/null
Jun 16 17:12:45 user debug igmp[499]: iptables -t filter -D FORWARD -i br0 -d 224.0.0.22 -j ACCEPT 2>/dev/null
Jun 16 17:15:02 user warn dnsprobe[468]: dns query failed
Jun 16 17:15:04 user warn dnsprobe[468]: dns query failed
Jun 16 17:15:06 user warn dnsprobe[468]: dns query failed
Jun 16 17:15:06 user notice dnsprobe[468]: Primary DNS server Is Down... Switching To Secondary DNS server
Jun 16 17:15:38 user warn dnsprobe[468]: dns query failed
СообщениеДобавлено: Пн июн 18, 2007 12:24
smirn писал(а):
Здравствуйте!
Я недавно купил модем ADSL D-Link DSL-2540U Нормально проработал он у меня дней 20. После этого, т.е. сегодня уже, он начал глючить. Смысл глюка заключается в том, что при включение он работает (предоставляет доступ к Интернету) в течение 10 минут и после этого все лампочки по прежнему на нем горят и сайт для конфигурации модема работает так же, и показывает, что я в Интернете. НО при прохождение 10 мин. после включения модема Интернет отрубается ПОЛНОСТЬЮ. Т.е. как я понял, модем не хочет давать мне трафик интернетовский после 10 минут. Не получается не пропинговать, не протресийть маршруты(при трейсинге даже в начальном пути модем не дает отклик). В общем модем сам блокирует интернетовский трафик на моей компьютер и на компьютеры в Локальной сети, которые к нему тоже подключены. Я хочу у Вас поинтересоваться, кроме того, чтоб нести модем в сервесный центр на ремонт, можно ли с ним мне самому что-нибудь сделать.
З.Ы. Перезагружать и возвращаться к заводским настройкам уже пробовал. Версия прошивки установлена последняя. . Фаервол как на компе так и на модеме отключены. Нет установленных на компе не антивирусов, не антихакеров всяких.
Звонил в тех.подержку нечем не помогли, может ты что подскажешь. У меня инет работает от 3 – 10 минуты, потом модем перезагружаешь он опять работает 3- 10 мин. И так постоянно. Проверил ЛОГ файл модема, я понял, что через некоторое время 3-10 минут. Модем теряет связь с первым ДНС адресом потом в течение 10 секунд он пробует подсоединится через второй ДНС адрес, но опять не удачно. И после этого он опять пытается подсоединиться каждые 2 секунды к ДНС, но неудачно. Меня интересует – ЭТО НЕИСПРАВНЫЙ МОДЕМ ИЛИ ВОЗМОЖНО ОШИБКИ НА АТС?? И Что теперь делать, модем уже 3 дня так работает.
Надеюсь получить ответ в течение 24 часа!
С уважением, Алексей Смирнов.
Gta-ns@mail.ru ICQ: 444478049
1. Абонентом какого оператора Вы являетесь?
2. Используются ли Вами p2p приложения?
3. Опишите настройку DNS на модеме.
С уважением, Давыдов Денис.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 49
