Текущее время: Пт окт 30, 2026 10:25
 Заголовок сообщения: firmware in this router DVG-G5402SP - cannot be upgraded
СообщениеДобавлено: Чт май 28, 2009 19:43
Hello,
I have a Dlink DVG-G5402SP, that came with firmware Version: RU_1.00 installed that i bought in Moscow. It won't upgrade.
here is what i did,
On the PC:
I downloaded from ftp.dlink.ru the following file DVG-x5402SP_1.2.38.32_drv_0.10.26, and then unpacked it into a directory for the TFTP program. 5 or 6 files all in the correct directory are displayed. I start the TFTP program, its solar winds.
On the router:
I log into the router, in the firmware upgrade section i enter my IP address. click start, get the
"VoIP Router Upgrade - don't power down"message.
progress bar goes through to 70 then 80 then 90 etc 100%, then get the VoIP Router Reboot message.
on the PC:
The TFTP programs shows two files have been transferred
v82sipg.pack
v82sipgXXXX-266.pack.app
so all looks good here.
But the firmware still displays Firmware Version: RU_1.00, there was never any kind of message to say "upgrade complete" either.
so, how do i upgrade? is there some known problem here?
has anyone had success upgrading the firmware?
any help would be appreciated.
СообщениеДобавлено: Пт май 29, 2009 09:51
Модератор
Модератор
Dear phi1ip,
all is ok since RU_1.00 it's just region version and you should check diver version on status page. It must be 0.10.26.
BR,
Victor
Виктор Колосов
cron
