Текущее время: Сб ноя 07, 2026 22:21
СообщениеДобавлено: Чт мар 01, 2007 12:52
Здравствуйте!
Помогите решить следующую проблему – не устанавливается тоннель между DFL-200 и Cisco PIX 515. Все делал по FAQ для связи циски с DI-804.
IKE устанавливается, а вот IPSec почемуто не работает :(
Конфиг для Cisco:
: Saved
: Written by enable_15 at 09:13:04.700 UTC Thu Mar 1 2007
PIX Version 7.2(2)
hostname pixfirewall
domain-name office.ru
enable password * encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address A.A.A.A 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.21.1 255.255.255.0
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
passwd * encrypted
ftp mode passive
dns server-group DefaultDNS
access-list outside_20_cryptomap extended permit ip 192.168.21.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list outside_nat0_outbound extended permit ip 192.168.21.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list 101 extended permit ip 192.168.21.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list 101 extended deny ip any any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm
asdm history enable
arp timeout 14400
nat (inside) 0 0.0.0.0 0.0.0.0
nat (outside) 0 access-list outside_nat0_outbound
route outside 0.0.0.0 0.0.0.0 B.B.B.B 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
aaa-server RADIUS protocol radius
aaa-server TASACS+ protocol tacacs+
no eou allow clientless
http server enable
http 192.168.21.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set MySet esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto map outside_map 20 match address outside_20_cryptomap
crypto map outside_map 20 set peer B.B.B.B
crypto map outside_map 20 set transform-set MySet ESP-DES-SHA
crypto map outside_map interface outside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash md5
group 2
lifetime 14400
crypto isakmp policy 30
encryption des
hash sha
group 2
lifetime 14400
tunnel-group B.B.B.B type ipsec-l2l
tunnel-group B.B.B.B ipsec-attributes
pre-shared-key 123456
chain
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.21.2-192.168.21.50 inside
dhcpd dns 195.14.50.1 195.14.50.21 interface inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:2179bf7db366f592ecc9bc1edd0395aa
: end
Конфиг для длинки:
BASE
LAN: 192.168.20.1
WAN: B.B.B.B
Gateway: A.A.A.A
VPN
Local Net: 192.168.20.0/24
Authentication
Pre Shared Key: 123456
LanToLan tunnel:
Remote net: 192.168.21.0 - 192.168.21.254
Remote gateway: A.A.A.A
ADVANCED:
MTU: 1500
IKE mode: main
IKE DH group: 2 – modp 1024-bit
NAT traversal: On if supported and needed (NAT detected between gateways)
Keepaives: no keepalives
IKE proposal list:
DES SHA-1 14400
DES MD5 14400
IPSec proposal list:
DES SHA-1 28800
DES MD5 28800
Длинка в логах пишет следующее:
[2007-03-02 12:06:29] <6>EFW: IPSEC: prio=1 Phase-2 [initiator] for ipv4(icmp:0,[0..3]=192.168.20.2) and ipv4(icmp:0,[0..3]=192.168.21.1) failed; Aborted notification.
[2007-03-02 12:06:29] <4>EFW: IPSEC: prio=3 Authenticated notify "Responder lifetime notification" from A.A.A.A:500 for protocol ISAKMP spi[0..16]=f3 16 65 33 f4 43 9d 44 0b dd af e3 44 84 88 70
[2007-03-02 12:06:29] <6>EFW: IPSEC: prio=1 Phase-1 [initiator] between ipv4(udp:500,[0..3]=B.B.B.B) and ipv4(udp:500,[0..3]=A.A.A.A) done.
Хочу узнать почему не коннектится?
Время в группах вроде правильно стоит. Может в аксесс листе циски что не так?
Помогите плиз.
PS: да, и еще проблема – пинги от длинки до циски ходят, а наоборот нет. Где галку в циске поставить?
СообщениеДобавлено: Чт мар 01, 2007 13:10
Дебаг IPSEC
IPSEC: Received a PFKey message from IKE
IPSEC: Parsing PFKey GETSPI message
IPSEC: Creating IPsec SA
IPSEC: Getting the inbound SPI
IPSEC: New embryonic SA created @ 0x019D8608,
SCB: 0x01980670,
Direction: inbound
SPI : 0x423C6783
Session ID: 0x0000010B
VPIF num : 0x00000002
Tunnel type: l2l
Protocol : esp
Lifetime : 240 seconds
IPSEC: New embryonic SA created @ 0x027CDAD0,
SCB: 0x02815640,
Direction: inbound
SPI : 0x08BF8B53
Tunnel type: l2l
Protocol : esp
И через некоторое время:
IPSEC: Destroy current inbound SPI: 0x423C6783
IPSEC: Destroy current inbound SPI: 0x08BF8B53
СообщениеДобавлено: Чт мар 01, 2007 15:40
С PIX дело не имел, но вот конфиг для 1750:
cisco_settings.doc [49 KiB]
СообщениеДобавлено: Пт мар 09, 2007 10:40
Уряяяя! Заработало!!! :)
Вот конфиг Cisco PIX-515:
: Saved
: Written by enable_15 at 07:31:09.263 UTC Fri Mar 9 2007
PIX Version 7.2(2)
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
passwd * encrypted
ftp mode passive
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
icmp permit any outside
icmp permit any inside
no asdm history enable
arp timeout 14400
http server enable
crypto map outside_map 20 set pfs
crypto map outside_map 20 set transform-set ESP-DES-MD5
encryption des
hash md5
group 2
lifetime 14400
no vpn-addr-assign aaa
no vpn-addr-assign local
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
Cryptochecksum:*
: end
трабл был вроде на самом деле в длинке - заменил
на
Remote net: 192.168.21.0/24
и все заработало.
