Текущее время: Вт авг 18, 2026 22:09
 Заголовок сообщения: Проблема с DDM на DGS-1210-20/ME
СообщениеДобавлено: Вс авг 09, 2020 12:59
Добрый день! Коллеги подскажите есть
Device Type : DGS-1210-20/ME
System Boot Version : 1.00.023
System Firmware Version : 6.14.B020
System Hardware Version : A1
В логах
494    Aug  9 12:54:35:DDM-6: Bias_current of port 20 is over High alarm threshold!
493    Aug  9 12:54:35:DDM-6: Bias_current of port 19 is over High alarm threshold!
492    Aug  9 12:54:35:DDM-6: Bias_current of port 18 is over High alarm threshold!
491    Aug  9 12:54:20:DDM-6: Bias_current of port 20 is over High alarm threshold!
490    Aug  9 12:54:20:DDM-6: Bias_current of port 19 is over High alarm threshold!
489    Aug  9 12:54:20:DDM-6: Bias_current of port 18 is over High alarm threshold!
488    Aug  9 12:54:05:DDM-6: Bias_current of port 20 is over High alarm threshold!
487    Aug  9 12:54:05:DDM-6: Bias_current of port 19 is over High alarm threshold!
486    Aug  9 12:54:05:DDM-6: Bias_current of port 18 is over High alarm threshold!
485    Aug  9 12:53:50:DDM-6: Bias_current of port 20 is over High alarm threshold!
484    Aug  9 12:53:50:DDM-6: Bias_current of port 19 is over High alarm threshold!
483    Aug  9 12:53:50:DDM-6: Bias_current of port 18 is over High alarm threshold!
482    Aug  9 12:53:35:DDM-6: Bias_current of port 20 is over High alarm threshold!
По DDM такое
Command: show ddm ports 18-20 status
 Port   Temperature    Voltage   Bias-Current   TX-Power   RX-Power
        (in Celsius)   (Volts)   (mA)           (Dbm)      (Dbm)
  18     +48.480        3.30      25.1            -6.4     -9.2
  19     +48.516        3.30      27.8            -6.6     -7.2
  20     +47.848        3.29      20.1            -5.4     -5.8
Модули стоят такие
Command: show ddm ports 18-20 vendor_info
 Port            : 18
 Connect Type    : SFP - SC
 Fiber Type      : Single Mode
 TX Wavelength   : 1550
 BR, Nominal     : 1G
 Vendor OUI      : 00:00:00
 Vendor Name     : XBIT
 Vendor PN       : SFP-1G-20SC-B
 Vendor Rev      : A0
 Vendor SN       : PT20030102905L
 Date Code       : 200312
 Port            : 19
 BR, Nominal     : 1G
 Vendor Name     : XBIT
 Vendor Rev      : A0
 Vendor SN       : PT20030102904L
 Date Code       : 200312
 Port            : 20
 TX Wavelength   : 1310
 BR, Nominal     : 1G
 Vendor Name     : XBIT
 Vendor PN       : SFP-1G-20SC-A
 Vendor Rev      : A0
 Vendor SN       : PT20030102281L
 Date Code       : 200312
Что значит DDM-6: Bias_current of port <номер порта> is over High alarm threshold! ? Как это лечить?
 Заголовок сообщения: Re: Проблема с DDM на DGS-1210-20/ME
СообщениеДобавлено: Пн авг 10, 2020 06:07
config ddm ports 18-20 state disable
Или менять модули, причина в них.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 10
