Текущее время: Вс ноя 01, 2026 12:02
Начать новую тему Ответить на тему  [ Сообщений: 1383 ]  На страницу Пред.  1 ... 44, 45, 46, 47, 48, 49, 50 ... 93  След.
СообщениеДобавлено: Чт дек 08, 2016 11:41
Alexandr Zaitsev писал(а):
Shift+6 при загрузке
Model_Name: DGS-1210-20/ME
Hit any key to stop autoboot: 0
Please input the password : admin
DGS-1210-20/ME>
base - print or set address offset
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
chpart - change active partition
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
dhcp - boot image via network using DHCP/TFTP protocol
echo - echo args to console
env - environment handling commands
exit - exit script
false - do nothing, unsuccessfully
go - start application at address 'addr'
help - print command description/usage
itest - return true/false on integer compare
license - print GPL license text
loop - infinite loop on address range
md - memory display
mdc - memory display cyclic
mdk - mdk commands:
mii - MII utility commands
mm - memory modify (auto-incrementing address)
mtdparts- define flash/nand partitions
mtest - simple RAM read/write test
mw - memory write (fill)
mwc - memory write cyclic
nm - memory modify (constant address)
pci - list and access PCI Configuration Space
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv - set environment variables
sf - SPI flash sub-system
showvar - print local hushshell variables
sleep - delay execution for some time
source - run script from memory
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true - do nothing, successfully
version - print monitor, compiler and linker version
или это не то меню?
СообщениеДобавлено: Чт дек 08, 2016 12:02
Это не то меню, пусть таймер дойдёт до конца, нажимайте позже, когда коммутатор загружаться начнёт
СообщениеДобавлено: Чт дек 08, 2016 12:28
спасибо!
пробовала, не получилось. попробую еще раз.
СообщениеДобавлено: Вт дек 13, 2016 10:57
DGS-1210-28XS/ME
Boot Version 1.01.033
Firmware Version 7.02.B002
Ошибка "Cannot Set Data" при попытке добавить VLAN через web-интерфейс. После чего при попытке добавить его через консоль, пишет что такой vlan уже существует. Хотя ни в консоли ни в вебе он не отображается.
СообщениеДобавлено: Вт дек 13, 2016 11:03
спасибо, все получилось!
СообщениеДобавлено: Вт дек 13, 2016 12:35
Сегодня 2 коммутатора DGS-1210-28P/ME FW 6.12.B041 на ровном месте без сбоев питания сбросили свои настройки до заводских, в том числе и MAC адреса до 00:01:02:03:04:05
После восстановления конфига MSTP не смогло сойтись (и это логично, т.к. 2 коммутатора в одном кольце с одинаковым МАК-адресом). И из-за этого все коммутаторы между ними тоже сошли с ума и притушили все свои порты.
Подскажите, как вернуть всю эту кучу железа в норму??
СообщениеДобавлено: Вт дек 13, 2016 15:14
Поясните пожалуйста про версии DGS-1210-10 и DGS-1210-20
Есть B1, есть С1, есть /ME
Они аппаратно разные? Прошивки на них разные или взаимозаменяемые?
СообщениеДобавлено: Ср дек 14, 2016 05:00
Добрый день, небольшой багрепорт:
имеем
Device Type                       : DGS-1210-52/ME
System Boot Version               : 1.00.023
System Firmware Version           : 6.12.B049
Включена авторизация TACACSом
делаем
config traffic control 2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52 broadcast enable multicast enable unicast enable action drop threshold 64
Через несколько секунд загрузка cpu растет до 96%, пропадает управление (и телнет и консоль). Но на пинг отвечает, только время ответа вырастает до 500-1000мс, спасает только ребут по питанию.
Однако, если сделать
config traffic control 2-52 broadcast enable multicast enable unicast enable action drop threshold 64
Проблема не проявляется.
При отключении авторизации TACACSом проблема так же не проявляется.
СообщениеДобавлено: Ср дек 14, 2016 11:11
Аппаратные различия есть, прошивки также разные и не взаимнозаменяемые.
СообщениеДобавлено: Ср дек 14, 2016 17:20
DGS-1210-28/ME
System Boot Version               : 1.00.024
System Hardware Version           : A2
BUG: через консоль show vlan показывает все вланы как статические, веб интерфейс отображает правильно
иногда зависает web-сессия, висит часами, присоединится по web и ssh невозможно. не нашел информации, можно ли убить сессию через консоль? иначе помогает только перезагрузка.
 Заголовок сообщения: DGS-1210-28P/ME - проблемы и пожелания
СообщениеДобавлено: Чт дек 15, 2016 17:24
День добрый!
Имеется коммутатор
D-Link DGS-1210-28P/ME
Boot Version 1.00.023
Hardware Version A1
Serial Number S3221DC000654
Ранее были прошивка Boot Version 1.00.012 и Firmware Version 6.00.025
В субботу, 10.12.2016 обновил прошивку до актуальной Firmware Version 6.13.B005
Вопросы. А, думаю, что и баг-репорты по Web-интерфейсу:
1. При попытке сохранить конфигурацию (Save - Save configuration - далее кнопка Save Config) получаем "пилюлю"
Текст из Mozilla 50.0.2:
Соединение было сброшено
Во время загрузки страницы соединение с сервером было сброшено.
    Возможно, сайт временно недоступен или перегружен запросами. Подождите некоторое время и попробуйте снова.
    Если вы не можете загрузить ни одну страницу – проверьте настройки соединения с Интернетом.
    Если ваш компьютер или сеть защищены межсетевым экраном или прокси-сервером – убедитесь, что Firefox разрешён выход в Интернет.
Из IE8 результат аналогичный.
Приходится подключаться через телнет и выполнять save config ...
2. После включения LLDP глобально отключить его невозможно - в LLDP - LLDP Global settings просто нет такого пункта.
3. При просмотре LLDP Remote Port Table при выборе некоторых портов после нажатия кнопки Find пропадает номер выбранного порта и вообще весь выпадающий список выбора портов.
4. При просмотре System - Firmware Information:
ID   Version   Size (B)   Update Time   From   User
 *1     6.13.B005     14079328     01/01/2016 05:52:17     10.90.90.77     Anonymous (web)
 1     0��     N/A     N/A     N/A     N/A
Что это во второй (со спецсимволами) строке?
5. При попытке применить настройки уведомлений по SMTP та же "пилюля", что и в п.1:
Причем, Mozilla уже обновлена до 50.1.0
Это я что-то не так делаю или в фирмваре "так получилось"?
Спасибо!
Собственно, обновиться сподвигло то, что в плане LLDP было много правок с выхода заводской версии, а мне как раз надо бы упростить подключение телефонов DPH-150SE к этому коммутатору.
И еще вопрос. Можно ли без сброса конфига положить рядом какую-нибудь стабильную предыдущую прошивку (какую порекомендуете?) и указать загрузку с нее?
PS Да! самое-то главное. Уж так совпало, что после обновления прошивки этого коммутатора у меня на вышестоящем устройстве (Cisco 2801 + HWIC-D-9ESW) стала странным образом пропадать связь со всеми устройствами, подключенными в HWIC, куда, собственно, приходит и этот коммутатор. Причем shut/no shut портов hwic'а результата не дает, только релоад. Ошибок на роутере не вижу. Скорее всего, конечно HWIC-D-9ESW помирает, но, повторюсь, совпало с перепрошивкой коммутатора: в субботу вечером прошил, в понедельник под нагрузкой началось. Каждый день по нескольку раз. Пока вынужден спасаться автоматической перезагрузкой циски по одновременной недоступности нескольких контрольных узлов. В ближайшее время все равно планировалось переключить этот DGS-1210 к другой такой же циске с такой же платой HWIC. Если после переподключения "вдруг" и на ней начнуться такие же проблемы, это однозначно покажет вину коммутатора или мою в его конфигурировании (в чем я мог так провиниться?!. О_О).
СообщениеДобавлено: Пт дек 16, 2016 19:19
Всем привет.
Обнаружился очередной глюк. При попытке выполнения команды
DGS-1210-52/ME:5# show utilization ports
Command: show utilization ports
Моментально вышибает из консоли (при подключении путти по ssh) с сообщением о неизвестной сетевой ошибке. Работоспособность устройства в целом вроде как сохраняется, т.к. дает вполне к себе переподключиться заново.
Прошивка вот такая.
System Hardware Version : A1
Чего делать? А то так помониторить загрузку портов хочется и нельзя никак посмотреть....Не, по консоли все корректно отображает, но это неудобно.
СообщениеДобавлено: Пн дек 19, 2016 10:16
Подскажите, пожалуйста, как перезагрузить DGS-1210-20/ME H/W:A1 F/W:6-13-B002 по SNMP
СообщениеДобавлено: Вт дек 20, 2016 22:48
ДД!
DGS-1210-12TS/ME FW 7.02.B005
При любой попытке внести изменения через WebUI в 802.1Q VLAN получаем Cannot Set Data.
Через cli добавил.
Далее 18 vlan через WebUI не виден, тем не менее в конфиге он есть:
DGS-1210-12TS/ME:5# show config current_config include vlan
Command: show config current_config include vlan
disable asymmetric_vlan
config vlan default delete 1-12
config vlan default add tagged 1-12 advertisement enable
create vlan LAN1 tag 2
create vlan VoIP1 tag 4
create vlan Security tag 5
create vlan LAN3 tag 8
create vlan VoIP3 tag 9
create vlan LAN4 tag 10
create vlan VoIP4 tag 11
create vlan wifi tag 17
create vlan mp tag 18
config vlan LAN1 add tagged 6-8,11-12 advertisement disable
config vlan VoIP1 add tagged 6-8,11-12 advertisement disable
config vlan Security add tagged 1-8,11-12 advertisement disable
config vlan LAN3 add tagged 3-5,11-12 advertisement disable
config vlan VoIP3 add tagged 3-5,11-12 advertisement disable
config vlan LAN4 add tagged 1-2,11-12 advertisement disable
config vlan VoIP4 add tagged 1-2,11-12 advertisement disable
config vlan wifi add tagged 6,11-12 advertisement disable
СообщениеДобавлено: Вс дек 25, 2016 22:16
Подскажите пожалуйста последнюю версию прошивки для DGS-1210/ME (A1) с нормально работающим LACP.
В данный момент использую 6.12.B018 - всё прекрасно работает.
Попробовал 6.12.B049 - LACP не работает вообще.
Попробовал v.6.13.B002 - LACP вроде работает, но весь сетевой траффик как бы "замирает" с периодичностью раз в 10-15 секунд.
Проверено на DGS-1210-28P/ME (A1) и DGS-1210-52/ME (A1).
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 172
