Текущее время: Пт окт 16, 2026 08:40
СообщениеДобавлено: Вт апр 07, 2015 11:48
Когда появится прошивка которая не будет самопроизвольно ребутиться?
DAP-2690/A1 - проблема есть и уже никогда не будет исправлена.
DAP-2690/B1 - прошивка 3.00 работает и ребуты не часто, но есть другие проблемы.
Прошивки 3.01 и 3.11 ребутятся регулярно.
на 3.11 по несколько раз в день.
ls-1207.ap.local.log:Apr  6 15:20:02 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 2.4G:Initiate Wireless success
ls-1207.ap.local.log:Apr  6 15:20:02 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 5G:Initiate Wireless success
ls-1207.ap.local.log:Apr  6 15:20:56 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 2.4G:Initiate Wireless success
ls-1207.ap.local.log:Apr  6 15:20:56 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 5G:Initiate Wireless success
ls-1207.ap.local.log:Apr  6 16:17:54 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 2.4G:Initiate Wireless success
ls-1207.ap.local.log:Apr  6 16:17:55 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 5G:Initiate Wireless success
ls-1207.ap.local.log:Apr  6 16:18:48 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 2.4G:Initiate Wireless success
ls-1207.ap.local.log:Apr  6 16:18:48 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 5G:Initiate Wireless success
ls-1207.ap.local.log:Apr  7 10:44:54 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 2.4G:Initiate Wireless success
ls-1207.ap.local.log:Apr  7 10:44:55 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 5G:Initiate Wireless success
ls-1207.ap.local.log:Apr  7 10:45:49 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 2.4G:Initiate Wireless success
ls-1207.ap.local.log:Apr  7 10:45:49 ls-1207.ap.local [C8: D3:A3:42:5F:10] [Wireless] 5G:Initiate Wireless success
bm-5221.ap.local.log:Apr  6 10:41:16 bm-5221.ap.local [C8: D3:A3:42:5B:E0] [Wireless] 2.4G:Initiate Wireless success
bm-5221.ap.local.log:Apr  6 10:41:16 bm-5221.ap.local [C8: D3:A3:42:5B:E0] [Wireless] 5G:Initiate Wireless success
bm-5221.ap.local.log:Apr  6 10:42:09 bm-5221.ap.local [C8: D3:A3:42:5B:E0] [Wireless] 2.4G:Initiate Wireless success
bm-5221.ap.local.log:Apr  6 10:42:09 bm-5221.ap.local [C8: D3:A3:42:5B:E0] [Wireless] 5G:Initiate Wireless success
bm-5221.ap.local.log:Apr  6 14:10:17 bm-5221.ap.local [C8: D3:A3:42:5B:E0] [Wireless] 2.4G:Initiate Wireless success
bm-5221.ap.local.log:Apr  6 14:10:17 bm-5221.ap.local [C8: D3:A3:42:5B:E0] [Wireless] 5G:Initiate Wireless success
bm-5221.ap.local.log:Apr  6 14:11:12 bm-5221.ap.local [C8: D3:A3:42:5B:E0] [Wireless] 2.4G:Initiate Wireless success
bm-5221.ap.local.log:Apr  6 14:11:12 bm-5221.ap.local [C8: D3:A3:42:5B:E0] [Wireless] 5G:Initiate Wireless success
На 3.00 точка кроме периодических перезагрузок еще и периодически перестает работать. т.е. wifi сеть видна, к ней можно подключиться (open/wpa2-enterprise), но трафик не ходит. Перезагрузка точки исправляет ситуацию.
Точка выпускается не менее 3-х лет, а прошивок рабочих до сих пор нет!
Если сами не можете написать прошивку, то помогите проекту OpenWRT.
СообщениеДобавлено: Чт апр 23, 2015 10:52
I put the contents in this website for everyone to get to know, like me.
maxbet
СообщениеДобавлено: Вт апр 28, 2015 16:25
Есть здесь представители D-Link или нет ? За последний месяц ни одного ответа.
СообщениеДобавлено: Пт май 22, 2015 14:05
Есть здесь представители D-Link или нет ? За полтора месяца ни одного ответа.
СообщениеДобавлено: Пт май 22, 2015 17:04
Напишите вот сюда: mlesnikov@dlink.ru, быстрее получите ответ.
СообщениеДобавлено: Вт июн 09, 2015 17:04
Есть здесь представители D-Link или нет ? Уже ДВА месяца ни одного ответа.
СообщениеДобавлено: Вт июл 07, 2015 12:02
СообщениеДобавлено: Вт июл 07, 2015 15:42
Добрый день,
Разработчики будут делать прошивку с исправлениями проблемы только после того, как они смогут подтвердить эту проблему (воспроизвести на стенде, отследить по логам и т.п.) и найти причину.
На данный момент проблему с перезагрузкой точки DAP-2690 B1 (так же и на DAP-2690 A1) воспроизвести не удается.
Возможно, для DAP-2690 A1 проблема будет решена, если обновить версию WLAN драйвера Atheros, но проверить это мы не можем.
Я вижу только один путь для локализации этой проблемы: нужны дампы трафика (из беспроводной сети и из проводной (зеркало с порта коммутатора, к которому подключена точка)) + конфиг точки доступа.
Если таким образом получится воспроизвести проблему, то можно уже будет ждать прошивку с исправлениями.
PS: Лучше пишите в почту (mlesnikov@dlink.ru)
СообщениеДобавлено: Вт сен 15, 2015 15:17
На одной точке поставил для тестрования 3.15rc91
Прошивка проработала меньше суток: точка впала в странное состояние - на ip/arp не откликается, но видна в эфире и при этом на нее не подключиться. Помогло выключение питания.
До этого они хоть сами перегружались, а здесь полный привет!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 63
