Текущее время: Чт июн 25, 2026 01:31
СообщениеДобавлено: Ср июн 18, 2014 19:16
Для сети небольшого (пока начинающего) провайдера (планируется до 1500 пользователей), что посоветуете включать??
Есть два DGS-3420-28SC в стеке.
DGS-3420-28SC:admin#show tech_support
Command: show tech_support
#                     DGS-3420-28SC Gigabit Ethernet Switch
#                         Technical Support Information
#                           Firmware: Build 1.70.B019
#          Copyright(C) 2013  D-Link Corporation. All rights reserved.
********************   Basic System Information   ********************
[SYS 2014-6-18 19:15:05]
Boot Time           : 3 Jun 2014  11:57:21
RTC Time            : 2014/06/18 16:15:05
Boot PROM Version   : Build 1.00.006
Firmware Version    : Build 1.70.B019
Hardware Version    : B1
Serial number       : R37Y4DA000482
MAC Address         : 9C-D6-43-04-52-00
MAC Address Number  : 512
[STACKING 2014-6-18 19:15:05]
 #Topology Information
 Stable Topology:
 My Box ID : 1              Role          : Master
 Box Cnt   : 2              Topology Type : Duplex Ring
 Unit  Prio-                                      Device Runtime   Stacking
 ID    rity  Role           MAC        Type       option version   version
 1     32 32 Master  9C-D6-43-04-52-00 DGS-3420-28SC 0x0000 1.70.B019 2.0.1
 2     32 32 BMaster 9C-D6-43-04-6E-00 DGS-3420-28SC 0x0000 1.70.B019 2.0.1
 3     NOT EXIST
 4     NOT EXIST
 5     NOT EXIST
 6     NOT EXIST
 7     NOT EXIST
 8     NOT EXIST
 9     NOT EXIST
 10    NOT EXIST
 11    NOT EXIST
 12    NOT EXIST
 *(S) means static box ID
 Temporary Topology:
 Stable Cnt : 48          Hot Swap Type : Stable
 Kept list
 SIO-   Unit Prio-                              Device Runtime   Stacking
 index  ID   rity        MAC           Type     option version   version
 Myself 0    32 32 9C-D6-43-04-52-00 DGS-3420-28SC 0x0000 1.70.B019 2.0.1
 1-1  0  32 32    9C-D6-43-04-6E-00 DGS-3420-28SC 0x0000 1.70.B019 2.0.1
 2-1  0  32 32    9C-D6-43-04-6E-00 DGS-3420-28SC 0x0000 1.70.B019 2.0.1
 Temp list
 SIO Ports:
 Port  Link Status  Hello reply
 1     TRUE         1
 2     TRUE         1
 #State Machine
 master_cofig_state : 10     cofig_hello_state : 4
 stack_elect_mode   : 1      st_hot_swap_state : 5
 stack_reset_state  : 0
 st_stack_ready     : TRUE   down_complete     : TRUE
 wait_passive_ack   : FALSE  execute_cfg       : FALSE
 Unit  Configure  Configure  BoxType  Init
 ID    status     Type       match    status
 [1 ]  16         0          TRUE     1
 [2 ]  15         0          TRUE     1
 [3 ]  NOT EXIST
 [4 ]  NOT EXIST
 [5 ]  NOT EXIST
 [6 ]  NOT EXIST
 [7 ]  NOT EXIST
 [8 ]  NOT EXIST
 [9 ]  NOT EXIST
 [10]  NOT EXIST
 [11]  NOT EXIST
 [12]  NOT EXIST
СообщениеДобавлено: Ср июн 18, 2014 19:18
Используется RSTP и DHCP Relay
Комментарий к файлу: Конфиг
DGS-3420.txt [63.91 KiB]
СообщениеДобавлено: Сб июн 21, 2014 11:25
СообщениеДобавлено: Пн июн 23, 2014 12:03
мьсье думает, что тут форум телепатов?
СообщениеДобавлено: Пн июн 23, 2014 17:26
я вроде бы все написал что есть :)
Готов ответить на вопросы :)
СообщениеДобавлено: Вт июн 24, 2014 07:17
Что вы вообще хотите?
СообщениеДобавлено: Вт июн 24, 2014 16:42
ну например защиту от "паразитных" DHCP...
Что еще посоветуете?
RSTP запустил, работает...
СообщениеДобавлено: Ср июн 25, 2014 10:25
Защиту от левых DHCP надо настраивать на доступе, а не на агрегации/ядре.
Сейчас этот форум просматривают: Google [Bot] и гости: 15
