Текущее время: Ср сен 23, 2026 19:17
 Заголовок сообщения: DVG-6004S RingBack
СообщениеДобавлено: Пт авг 24, 2012 13:59
Здравствуйте!
Не распознается нормально входящий сигнал вызова с АТС
Подскажите какие параметры крутить?
13:54:30 *** SLMON start to log ***
13:54:40 [014779] Receive Cmd=1100, ParaLen=5, Para=[Login]
13:54:40 [014779] Login == Ver(1.02.38.43.9367 2009/08/25 17:45:23) PId(242.DLink.NoPrefix.drtp.vlan) Drv(0.9.5.1.1928) Hw(SA7O4) == 0.6.7-1
13:54:46 [014846] 0: Fxo Ringing
13:54:46 [014847] 0: RingTime(56) First Stop
13:54:49 [014876] 0: RingTime(358) Second Ring
13:54:52 [014900] 0: CallerId=
13:54:52 [014900] 0: ==17:WaitAnswerDeviceOk
13:54:52 [014900] 0: HotLineEnabled with [0701]
13:54:52 [014900] 0: End Input Default Route [0]
13:54:52 [014900] 0: Call Proxy with [0701]
13:54:52 [014900] 0: ==7:Inviting
13:54:52 [014900] 0: VoIP CallOut, Invite <sip:0701@172.16.16.92;user=phone>
13:54:52 [014901] 0: 701=DIALING
13:54:52 [014904] 0: 701=PROCEEDING
13:54:52 [014905] 0: 701=RINGBACK
13:54:52 [014905] 0: ==8:RingBack
13:54:56 [014940] 0: RingTime Stopped
13:54:56 [014940] 0: Cancel at Ringback
13:54:56 [014940] 0: 701=CANCEL
13:54:56 [014940] 0: ==15:PlayBusyTone
13:54:56 [014941] DSP_ch0_check=0
13:54:56 [014941] 0: FxoHookOn
13:54:56 [014941] 0: ==3:Idle
13:54:56 [014941] 0: SetInputGain(4)
13:54:56 [014941] 0: SetFax(1)=0
13:54:56 [014941] 0: 701=DISCONNECT
13:54:56 [014941] 0: Release Old Dlg #2
13:55:04 [015019] 0: Fxo Ringing
13:55:04 [015020] 0: RingTime(138) First Stop
13:55:11 [015089] 0: RingTime Stopped
13:55:11 [015089] 0: ==3:Idle
13:55:11 [015089] 0: SetInputGain(4)
13:55:11 [015089] 0: SetFax(1)=0
13:55:17 [015148] 0: Fxo Ringing
13:55:17 [015149] 0: RingTime(137) First Stop
13:55:23 [015213] 0: RingTime(138) Second Ring
13:55:24 [015223] 0: CallerId=
13:55:24 [015223] 0: ==17:WaitAnswerDeviceOk
13:55:24 [015223] 0: HotLineEnabled with [0701]
13:55:24 [015223] 0: End Input Default Route [0]
13:55:24 [015223] 0: Call Proxy with [0701]
13:55:24 [015223] 0: ==7:Inviting
13:55:24 [015224] 0: VoIP CallOut, Invite <sip:0701@172.16.16.92;user=phone>
13:55:24 [015225] 0: 701=DIALING
13:55:25 [015228] 0: 701=PROCEEDING
13:55:25 [015229] 0: 701=RINGBACK
13:55:25 [015229] 0: ==8:RingBack
13:55:28 [015264] 0: RingTime Stopped
13:55:28 [015264] 0: Cancel at Ringback
13:55:28 [015264] 0: 701=CANCEL
13:55:28 [015264] 0: ==15:PlayBusyTone
13:55:28 [015265] DSP_ch0_check=0
13:55:28 [015265] 0: FxoHookOn
13:55:28 [015265] 0: ==3:Idle
13:55:28 [015265] 0: SetInputGain(4)
13:55:28 [015265] 0: SetFax(1)=0
13:55:28 [015265] 0: 701=DISCONNECT
13:55:28 [015265] 0: Release Old Dlg #2
13:55:36 [015342] 0: Fxo Ringing
13:55:36 [015343] 0: RingTime(136) First Stop
13:55:43 [015412] 0: RingTime Stopped
13:55:43 [015412] 0: ==3:Idle
13:55:43 [015412] 0: SetInputGain(4)
13:55:43 [015412] 0: SetFax(1)=0
 Заголовок сообщения: Re: DVG-6004S RingBack
СообщениеДобавлено: Пн авг 27, 2012 08:35
Что значит не распознется?
СообщениеДобавлено: Пн авг 27, 2012 09:57
Первый вызов пропускает, на втором вызове переводит линию RingBack при этом начинает звонить sip номер на который подключена линия, потом через несколько сек линия переходит в Idle, sip звонить перестает, дальше может несколько вызовов пропустить и снова перевести линию в RingBack, получаем как не один входящий звонок а как несколько, межгород понимает нормально. Я думаю что большой интервал между сигналами вызова от атс, на другой атс все работает.
СообщениеДобавлено: Пн авг 27, 2012 10:36
Может быть... Поставьте галку agressive ring detection.
Сейчас этот форум просматривают: Google [Bot] и гости: 4
