Текущее время: Пн июн 15, 2026 10:38
 Заголовок сообщения: Гроза, DES-3200, хваленная защита
СообщениеДобавлено: Пт май 11, 2012 11:27
На чердаках, 3200, линки по подъездам.
Проходит гроза и в логах начинается:
May  8 15:08:24 192.168.11.103 INFO: Port 5 link down
May  8 15:08:30 192.168.11.103 INFO: Port 5 link up, 100Mbps  FULL duplex
May  8 15:08:39 192.168.11.103 CRIT: Port 5 LBD loop occurred. Port blocked
May  8 15:08:40 192.168.11.103 INFO: Port 5 link down
May  8 15:23:04 192.168.11.103 INFO: Port 7 link down
May  8 15:29:03 192.168.11.103 INFO: Port 7 link up, 100Mbps  FULL duplex
May  8 15:29:53 192.168.11.103 INFO: Port 2 link up, 100Mbps  FULL duplex
May  8 15:38:39 192.168.11.103 INFO: Port 5 LBD port recovered. Loop detection restarted
May  8 15:38:42 192.168.11.103 INFO: Port 5 link up, 100Mbps  FULL duplex
May  8 15:38:49 192.168.11.103 CRIT: Port 5 LBD loop occurred. Port blocked
May  8 15:38:49 192.168.11.103 INFO: Port 5 link down
May  8 16:02:08 192.168.11.103 INFO: Port 2 link down
May  8 16:03:47 192.168.11.103 INFO: Port 7 link down
May  8 16:08:49 192.168.11.103 INFO: Port 5 LBD port recovered. Loop detection restarted
May  8 16:08:52 192.168.11.103 INFO: Port 5 link up, 100Mbps  FULL duplex
May  8 16:08:59 192.168.11.103 CRIT: Port 5 LBD loop occurred. Port blocked
May  8 16:08:59 192.168.11.103 INFO: Port 5 link down
May  8 16:33:00 192.168.11.103 INFO: Port 7 link up, 100Mbps  FULL duplex
May  8 16:38:59 192.168.11.103 INFO: Port 5 LBD port recovered. Loop detection restarted
May  8 16:39:04 192.168.11.103 INFO: Port 5 link up, 100Mbps  FULL duplex
May  8 16:39:59 192.168.11.103 INFO: Port 2 link up, 100Mbps  FULL duplex
May  8 16:40:17 192.168.11.103 INFO: Port 3 link down
May  8 16:40:22 192.168.11.103 INFO: Port 3 link up, 100Mbps  FULL duplex
May  8 16:55:59 192.168.11.103 INFO: Port 1 link down
May  8 17:02:15 192.168.11.103 INFO: Port 7 link down
May  8 17:02:21 192.168.11.103 INFO: Port 3 link down
Дальше интересней, на всем свиче перестает проходить брудкастовый трафик, тот который нужен чтобы абон получил адрес по dhcp серверу, вижу что запросы на сервер приходят, сервер отвечает, но абон ответа не видет, и на его интерфейсе в той же хз и т.д. висит отправленно 10-20 пакетов, принято 0
Через show util ports вижу что периодами байтики бегают мелкие.
show error ports ошибок на порту не показывает.
Если прописать ip ручками то все пучком, работает, но что мне теперь 8 портов на 5шт свичей ручками все прописывать?
Свичи были класса Metro и должны иметь встроенную защиту и прочие, но какого от малейшего чиха он дохнет? у меня небольшой шок если честно, и первые мысли пока есть возможность засунуть всю продукцию dlink далеко и надолго, если не будет нормального ответа по поводу этой ситуации.
Ситуация одинаковая, на всех 5 свичах, до этого все работало, гроза была еле заметная, дистанция между свичами 500м-1км.
Отключение порта, перевод mdix в normal все равно не дает возможности портам которые не срут LBD получать ip от dhcp, другого брудкаст трафика нету.
 Заголовок сообщения: Re: Гроза, DES-3200, хваленная защита
СообщениеДобавлено: Пт май 11, 2012 12:14
Устройство заземлено? Какая модель коммутатора, ревизия, прошивка?
СообщениеДобавлено: Пт май 11, 2012 12:23
Занулена жила в розетке.
Des3200-10
rev хз. оно далеко стоит.
Firmware Version : Build 1.70.B006
СообщениеДобавлено: Пт май 11, 2012 12:34
sh sw - в выводе покажет ревизию
СообщениеДобавлено: Пт май 11, 2012 13:13
Если на корпусе свича на жопе сделан специальный болт, рядом с которым нарисован значек заземления, то подключение к этому болту заземления решает все проблемы с выгоранием портов не зависимо от аппаратной ревизии и типа свича. Проверено неоднократно.
Откатите прошивку на 1.60.В009 и дхцп заработает самым волшебным способом. Тоже проверено и тоже неоднократно. ;)
В 1.70.В006 присутствует недоразумение с дхцп, в котором саппорт д-линка пока сознаваться сильно не хочет.
СообщениеДобавлено: Пт май 11, 2012 13:28
InventoR
Зануление и заземление - разные вещи.
alex_ov
Проблемы с релеем рассматриваются в соседней теме, и как только проблема будет выявлена - ее обязательно будут исправлять.
СообщениеДобавлено: Пт май 11, 2012 17:29
Происходит подобное периодически в момент грозы, пока что заметил на двух DES-3200 из 400+ всего в сети, и там и там стоит
Boot PROM Version : Build 1.00.B004
Firmware Version : Build 1.21.B006
Hardware Version : A1
На одном умерло сразу 3 порта, 3,5,9 постоянно писал об обнаружении петли, пока что решилось отключением этих портов.
В грозу сразу же посыпалось в логи, если включить порт моментально начинает срабатывать лбд.
70 2012-05-07 10:13:35 Port 1 link up, 100Mbps FULL duplex
69 2012-05-07 10:13:32 Port 1 link down
68 2012-05-07 10:13:15 SSH session timed out (Username: admin, IP:
67 2012-05-07 10:12:01 Port 13 LBD port recovered. Loop detection restarted
66 2012-05-07 10:11:55 Successful login through SSH (Username: admin, IP:
65 2012-05-07 10:11:47 Port 28 link up, 1000Mbps FULL duplex
64 2012-05-07 10:11:46 Port 28 link up, 1000Mbps FULL duplex
63 2012-05-07 10:11:18 Port 13 link down
62 2012-05-07 10:11:18 Port 13 LBD loop occurred. Port blocked
61 2012-05-07 10:11:15 Port 13 link up, 100Mbps FULL duplex
Последний раз редактировалось hsvt Пт май 11, 2012 17:37, всего редактировалось 1 раз.
СообщениеДобавлено: Пт май 11, 2012 17:30
Отлично можете дальше удалять замечания о работе прошивки 1.70, так держать.
СообщениеДобавлено: Сб май 12, 2012 07:56
InventoR
Я уже указал на то, что обсуждение проблем с релеем на 1.70.B06 - в соседней ветке. Не надо разводить здесь флуд и делать безосновательные заявления.
hsvt
С выгоревшими портами рекомендую обращаться в сервисный центр.
СообщениеДобавлено: Вс май 13, 2012 10:57
...и.... "устройство снято с гарантии..". 40 баксов (четверть от стоимости закупки!) "доплачиваем" за недоработку производителя. :evil:
P.S. Порты на свитче сдохли в спокойном безгрозовом январе.
Последний раз редактировалось KovAl59 Вс май 13, 2012 20:22, всего редактировалось 1 раз.
СообщениеДобавлено: Вс май 13, 2012 13:21
У нас тоже выгорают с образованием петли, стока гемора из-за них, как же я рад, что отказался от 3200 в пользу 3528 когда планировали закупки..
СообщениеДобавлено: Вс май 13, 2012 20:18
Цена вопроса? ИМХО, НЕ_сопоставимо.. Учитывая то, что в большинстве случаев для решения задачи, 10 портов - "позаглаза"..
Поэтому и "колемся, но всё одно кушаем 3200-XX кактус"... :(
