Текущее время: Пн июл 27, 2026 02:53
СообщениеДобавлено: Вт авг 23, 2011 16:53
День добрый!
после обновления прошивкой dgs3610_DI_94612_install.bin
имеем такой лог загрузки
System bootstrap ...
Nor Flash ID: 0x00C20049, SIZE: 2097152Bytes
Before reserved Memory , avamem = 0x1a15000
After reserved Memory , avamem = 0x1a15000
__start___param 018270c0, __stop___param 018270e0
Kernel parameter: Total read 2 parameters!
On node 0 totalpages: 25809
Begin init free area zone 0, start = 0x01B2F000
After reserved Zone 0 bitmap, start = 0x01B31000
zone(0): 25807 pages, 25807 realpages.
Begin init free area zone 1, start = 0x08000000
Zone 1 with no pages
Begin init free area zone 2, start = 0x08000000
Zone 2 with no pages
dconf: [config.id] = 0x20030040
dconf: [config.ProductName] = not found
dconf: [system.description] = not found
================Begin Subsystem Search===================
Start Address : 01826f40, End Address : 01826fb8
Find a subsystem <debug_init>!
Find a subsystem <BootLoader>!
==================End Subsystem Search=================
===========Check Subsystem Sequence
WARNING in subsystem <BootLoader>: sequence "root_fs_mount" no exist!
===========Check Subsystem Sequence end
==================Begin initialize subsystem=================
======Initialization Basic Subsystem
Initialize Subsystem <debug_init>......
Initialize Subsystem <BootLoader>......
Suspend thread BootLoader
======Initialization Basic Subsystem End
======Initialization Linklayer Subsystem
======Initialization Linklayer Subsystem End
======Initialization Networklayer Subsystem
======Initialization Networklayer Subsystem End
======Initialization Application Subsystem
======Initialization Application Subsystem End
======Initialization Driver Subsystem
======Initialization Driver Subsystem End
======Initialization Last Subsystem
======Initialization Last Subsystem End
==================End initialize subsystem===================
==== Phase 0 init threads BEGIN====
==== Phase 0 threads initial END====
==== Phase 1 init threads BEGIN====
==== Phase 1 threads initial END====
==== Phase 2 init threads BEGIN====
Resume thread BootLoader
==== Phase 2 threads initial END====
==== All threads is running !====
Press Ctrl+B to enter Boot Menu ......
Load Ctrl Program ...
Load Ctrl Program failed.
====== BOOT Menu("Ctrl+Z" to upper level) ======
TOP menu items.
0. XModem utilities.
1. Run CTRL.
2. SetMac utilities.
3. Scattered utilities.
Press a key to run the command:
подскажите что делать ?
обновлялся так ->
13)Q. как обновить ПО коммутатора в штатном режиме?
A. Подключиться консольным кабелем к активному модулю с помощью
программы схоже с Windows HYPER-TERMINAL, Putty, minicom и т.д.
Либо удаленно подключиться к оборудованию по протоколу Telenet.
Включить логирование всех вводимых команд и информации выводимой
терминалом!!! или скопировать их в текстовый файл вручную.
выполнить следующие операции по шагам:
ввести логин пароль если он есть
username:XXX
password:XXX
появится приглашение вида >
Switch-3610>
Далее ввести команду
enable
ввести пароль если потребуется
сделать копию текущей конфигурации!!!!!
sh run
далее ввести команду sh mainfile
Пример 1:
Switch-3610# show mainfile
MainFile name: firmware.bin
После этого надо либо переименовать файл текущего ПО
rename flash:/firmware.bin flash:/firmware2.bin
Либо удалить файл текущего ПО
del dirmware.bin
После чего выполнить следующие команды:
copy tftp: flash:
далее будут запрошены как указано в Примере 2
адрес tftp сервера источника (ввести нужный адрес)
имя файла источника (ввести нужное имя)
расширенные команды (ответить no)
имя файла которое будет на устройстве (ЗДЕСЬ ВНЕСТИ ТОЧНОЕ ИМЯ ПРОШИВКИ,
КОТОРОЕ МЫ ВЫЯСНИЛИ ДО ЭТОГО КОМАНДОЙ sh mainfile)
Пример 2
Switch-3610#copy tftp: flash:
Address of remote host []?1.1.1.1
Source filename []?dgs3610_install.bin
Extended commands [n]:
Destination filename [dgs3610_install.bin]?firmware.bin
Accessing tftp://1.1.1.1/dgs3610_install.bin...
Дождаться пока копирование будет завершено.
После чего надо набрать команду reload:
Пример 3
Switch-3610#reload
Proceed with reload? [no] Yes (нажать ввод)
Далее мониторить процесс перезагрузки...
После перезагрузки убедиться командой
sh ver
что ПО обновилось
СообщениеДобавлено: Ср авг 24, 2011 09:28
Попробуйте залить ПО через Xmodem, выбрав 0 в меню.
СообщениеДобавлено: Чт авг 25, 2011 09:49
при попытке залить через Xmodem получаю вот такую ругань
XModem utilities.
0. Upgrade BOOT.
1. Upgrade CTRL.
2. Upload Flash ROM to PC.
Press a key to run the command: 0
Now, begin download program through XModem...
CCXModem download OK, 8923264 bytes received!
Executable file information:
Program type: main
Version: 10.3.94612
Load Address: 0x01800000
Entry Offset: 0x00000000
Raw Bin Size: 543616
Total Length: 8923200
Config Index: 0x008821E0
Total CRC: 0x9A07AF86
THE PROGRAM VERSION: RGOS 10.3.*, Release(94612)
CURRENT PRODUCT INFORMATION :
PRODUCT ID: 0x20030040
PRODUCT DESCRIPTION: N/A
ERROR: NOT A VALID BOOT FILE WHEN UPGRADING BOOT !!!
You can ignore this error, but this maybe cause system crashed.
Choose No and stop upgrading, if you do not know what to do next !!!
IGNORE IT ? Timeout in 0s [N/y]
судя по всему тот файл который лежит на ftp несет в себе только часть main, а требуется файл который несет в себе часть ctrl.
СообщениеДобавлено: Пн авг 29, 2011 11:27
Приношу извинения за то что ввел в заблуждение. Тему немного почистил чтобы больше никого не путать.
При включении устройства пропустите момент CTRL+B, ждите, пока не высветится Press Ctrl+C.
Нажимаете Ctrl+C, и затем уже через Х modem обновляете main.
Если обновляете на 115200, то после перезагрузки и decompressed image скорость опять переведется на 9600, так что нужно будет переподключиться на данной скорости.
СообщениеДобавлено: Пн авг 29, 2011 12:56
День Добрый
у меня при загрузке происходит следующее не высвечивается Press Ctrl+C.
сразу после приглашения :
TOP menu items.
1. Run CTRL.
ps. есть возможность по этому вопросу пообщатся в реальном времени?
СообщениеДобавлено: Пн авг 29, 2011 14:00
Ответил в почту.
СообщениеДобавлено: Ср окт 12, 2022 18:03
Добрый день
можно и мне прошивку, boot, CTRL, на почту для обновления
коммутатор DGS-3610-26G A2
DGS-3627G(2.40.B77, 1.10-B09)|DGS-3200-24(1.62.B017, 1.00.B012)|DES-1228(1.00.B05, 1.00.B01)|DES-3028(2.10.B09)|DES-3026(4.20.003)|DES-3010G(4.30.B05)|DGS-3200-18(1.00.B004, 1.51.B009)
DIR-100 B1|DIR-120 A1|DIR-300 B1|DIR-320 А1|DIR-615 E4|DIR-620
СообщениеДобавлено: Чт окт 13, 2022 08:45
vit2002 писал(а):
Добрый день
Ответил на почту
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 55
