Текущее время: Пт апр 03, 2026 21:17
Начать новую тему Ответить на тему  [ Сообщений: 981 ]  На страницу Пред.  1 ... 19, 20, 21, 22, 23, 24, 25 ... 66  След.
 Заголовок сообщения: Re: DVG-7111S вопросы
СообщениеДобавлено: Пн апр 25, 2011 23:52
Прошу прошения за задержку - вот примерно так:
20:44:49 [000093] Receive Cmd=1100, ParaLen=5, Para=[Login]
20:44:49 [000093] Login RU_1.00 == Ver(1.02.38.56.2876 2010/05/21 14:06:11) PId(281.DLink.RU.DecodeProf.DhcpOpt195.l2tp.DualAccess.NoPrefix.drtp) Drv(0.10.55.1
20:44:49 ) Hw(TSO) == 0.6.8
20:44:57 [000179] NetLink(0) On
20:44:57 [000179] NetLink(1) Off
20:44:57 [000179] NetLink(2) Off
20:44:57 [000179] NetLink(3) Off
20:44:57 [000179] NetLink(4) On
20:45:10 [000311] 0: Fxs Pickup
20:45:10 [000311] 0: ==4:GetDtmf
20:45:17 [000382] 0: DTMF Timeout #1
20:45:17 [000382] 0: End Input Default Route [0]
20:45:17 [000382] 0: Line DialNum_New [474961]
20:45:17 [000382] 0: Call Proxy with [474961]
20:45:17 [000382] 0: ==7:Inviting
20:45:17 [000382] 0: VoIP CallOut, Invite <sip:474961@217.73.112.14;user=phone>
20:45:18 [000383] 0: Stakmun=DIALING
20:45:18 [000386] 0: Stakmun=DISCONNECT
20:45:18 [000386] 0: Proxy Reject, Try Local Fxo ========
20:45:18 [000386] 0: Local Calling Fxo [474961]
20:45:18 [000387] 0: Get Local Fxo Line 1
20:45:18 [000387] 1: TrunkPrefix=, Dest=474961, Dialno=474961
20:45:18 [000387] 1: FxoHookOff
20:45:18 [000387] 1: InputGain(15)
20:45:18 [000387] 1: ==18:TrunkDialOut
20:45:19 [000398] 1: DialOut(474961)=0
20:45:20 [000411] 0: Change RTP to 95.52.11.197:9002, pt=0
20:45:20 [000411] 0: RtpApiTalk[1,1], Peer=95.52.11.197:9002, PT=0, FC=4, NewOOB=0
20:45:20 [000411] 1: FilterDtmf(0)=0
20:45:20 [000411] 1: RtpApiTalk[1,1], Peer=95.52.11.197:9000, PT=0, FC=4, NewOOB=0
20:45:20 [000411] 1: Substatus=3
20:45:29 [000498] 1: Too Many Cadence, Talk
20:45:29 [000498] 1: Fxo DialOut OK
20:45:29 [000498] 1: Local Talk at ToAnswer
20:45:29 [000498] 1: RtpApiTalk[1,1], Peer=95.52.11.197:9000, PT=0, FC=4, NewOOB=0
20:45:29 [000498] 0: Local Talk at RingBack
20:45:29 [000498] 0: RtpApiTalk[1,1], Peer=95.52.11.197:9002, PT=0, FC=4, NewOOB=0
20:45:29 [000498] 1: ==14:Talking
20:45:29 [000499] 0: ==14:Talking
20:45:38 [000586] 0: Fxs Hangup
20:45:38 [000586] 0: Bye at Talking
20:45:38 [000586] 0: ==3:Idle
20:45:38 [000586] 0: SetFax(1)=0
20:45:38 [000586] 0: SetModem(0)=-1
20:45:38 [000586] 1: ==15:PlayBusyTone
20:45:38 [000587] 1: Start Btc Learning
20:45:40 [000604] 1: Btc Learning Exception No Change
20:45:40 [000604] 1: FxoHookOn
20:45:40 [000604] 1: ==3:Idle
20:45:40 [000604] 1: InputGain(9)
20:45:40 [000604] 1: SetFax(1)=0
СообщениеДобавлено: Вт апр 26, 2011 10:48
попробуйте выход на FXO настроить через digit map
СообщениеДобавлено: Вт апр 26, 2011 22:16
Спасибо, попробую. А как прописать маску для 6-ти значных номеров? Типа ??????
СообщениеДобавлено: Ср апр 27, 2011 10:13
именно так, шесть знаков вопроса.
СообщениеДобавлено: Чт апр 28, 2011 19:39
Приобрёл железку и мучает несколько вопросов
Как настроить 7111 так, чтобы при наборе короткого семизначного номера автоматически добавлялся заданый код страны и код города.
т.е я набираю семизначный городской номер а железка передаёт сипнету полный номер с кодом города и страны.
Возможно-ли принимать звонки со скайпа и как это настроить ?
СообщениеДобавлено: Пт апр 29, 2011 09:39
через digit map
СообщениеДобавлено: Ср май 04, 2011 14:15
Настроил сабж с сипнетом. Звоню со скайпа через шлюз skype.sipnet.ru - идёт входящий, телефон выдаёт caller id, но чтобы отклонить вызов приходиться
сначала поднимать трубку и точко потом её ложить, возможно это сделать только по кнопке "положить трубку" ?
При звонке на скайп пишу в DigitMap scan code 556 VoIP Dial-Out номер X@skype.com или X@skype.sipnet.ru, где Х - мой логин Скайпа User Dial Length ставил и 3 и disable при наборе результат один - короткие гудки :( в скайпе on-line, как победить ?
СообщениеДобавлено: Пт май 06, 2011 02:38
Ребята, с последней прошивкой что-то явно не так. Связь односторонняя, абонент FXS ничего не слышит. Если абонент FXS звонит на другой IP телефон внутри сети, связь просто рвется.
Посмотрел логи. Удивлен. На всех телефонах выставлен G.711U, а в логах вот такая муть.
Снес новую прошивку нахрен, задумался над дальнейшим приоретением VoIP оборудования Dlink. Устал...
02:31:45 [000500] 0: Fxs Pickup
02:31:45 [000500] 0: ==4:GetDtmf
02:31:48 [000534] 0: DTMF Timeout #1
02:31:48 [000534] 0: End Input Default Route [0]
02:31:48 [000534] 0: Line DialNum_New [202]
02:31:48 [000535] 0: Call Proxy with [202]
02:31:48 [000535] 0: ==7:Inviting
02:31:48 [000535] 0: VoIP CallOut, Invite <sip:202@192.168.0.2;user=phone>
02:31:48 [000536] 0: 200=DIALING
02:31:49 [000540] 0: 200=PROCEEDING
02:31:49 [000543] 0: 200=RINGBACK
02:31:49 [000543] 0: ==8:RingBack
02:31:50 [000558] 0: 200=CONNECTED
02:31:50 [000558] 0: No Matched AudioCodec
02:31:50 [000558] 0: PeerSdp Error #1
02:31:51 [000560] 0: 200=DISCONNECT
02:31:51 [000560] 0: Proxy Reject, Try Local Fxo ========
02:31:51 [000560] 0: Local Calling Fxo [202]
02:31:51 [000561] 0: Get Local Fxo Line 1
02:31:51 [000561] 1: TrunkPrefix=, Dest=202, Dialno=202
02:31:51 [000561] 1: FxoHookOff
02:31:51 [000561] 1: InputGain(0)
02:31:51 [000561] 1: ==18:TrunkDialOut
02:31:52 [000572] 1: DialOut(202)=0
02:31:53 [000580] 1: Fxo DialOut OK
02:31:53 [000580] 1: Local Talk at ToAnswer
02:31:53 [000580] 1: FilterDtmf(0)=0
02:31:53 [000580] 1: RtpApiTalk[1,1], Peer=192.168.0.3:9000, PT=0, FC=4, NewOOB=0
02:31:53 [000580] 0: Local Talk at RingBack
02:31:53 [000580] 0: RtpApiTalk[1,1], Peer=192.168.0.3:9002, PT=0, FC=4, NewOOB=0
02:31:53 [000580] 1: ==14:Talking
02:31:53 [000580] 0: ==14:Talking
http://www.3cx.com.ua - VoIP АТС 3CX. Работает под Windows XP/7/2003/2008. Интергация с Outlook, 1С, CRM. Работает с оборудованием D-link. Идеальна для Windows админов.
СообщениеДобавлено: Пт май 06, 2011 09:49
А на сервере тоже 711U стоит?
СообщениеДобавлено: Пт май 06, 2011 10:51
Да другом клиенте естественно g.711U.
Мало того, откат на старую прошивку не помог. Сейчас несу шлюз в сервис.
После отката шлюз перестал пробрасывать вызовы с VoIP на FXO линию. Просто дает гудок. После этого нужно повторно набирать номер.
СообщениеДобавлено: Чт май 19, 2011 18:01
Читал мануал и темы про DVG-7111S, вопросы остались:
Планируется обычное подключение: FXO - PSTN, FXS - Phone, SIP - собственный астериск. Входящие с PSTN идут на Phone внутри самого шлюза или через астериск - не суть, главное передать CID на Phone. Исходящие с Phone в зависимости от маршрута идут либо на PSTN, либо на астериск (либо все на астериск, а он разруливает: в сеть или в FXO).
Вопрос: Есть в DVG-7111S что-то вроде режима bypass, когда при проблемах регистрации на SIP шлюз как-бы соединит напрямую FXS и FXO?
СообщениеДобавлено: Пт май 20, 2011 10:16
Default call route - AUTO
СообщениеДобавлено: Сб май 21, 2011 19:45
Обнаружил у себя в логах такую запись:
May 21 17:39:06 dlink7111 XXXXXXXXXXXX-sip: asterisk CallIn 30442070661000
May 21 17:39:06 dlink7111 XXXXXXXXXXXX-sip: 1: TrunkDialOut
May 21 17:39:07 dlink7111 XXXXXXXXXXXX-sip: 1: PSTN Dial 30442070661000
May 21 17:39:27 dlink7111 XXXXXXXXXXXX-sip: 1: VoipAnswering
May 21 17:39:28 dlink7111 XXXXXXXXXXXX-sip: 1: Connected As Callee
May 21 17:39:28 dlink7111 XXXXXXXXXXXX-sip: 1: Talking
May 21 17:39:28 dlink7111 XXXXXXXXXXXX-sip: 1: Released By Peer
May 21 17:39:28 dlink7111 XXXXXXXXXXXX-sip: 1: PlayBusyTone
May 21 17:39:31 dlink7111 XXXXXXXXXXXX-sip: 1: Idle
Если я правильно понял, то пришел несанкционированный входящий звонок извне через sip,
после чего он ушел через мою городскую линию!!!
Прошивка последняя, Caller Filter все по умолчанию ( Allow и пустой список правил ).
Это чтож получается Caller Filter имеет дырку даже в последней прошивке? или я что-то не то настроил?
СообщениеДобавлено: Вс май 22, 2011 03:39
Не пойму.
В последней прошивке перестал пробрасывать вызов на PSTN. Что только не делал. Звоню на город - слышу гудок. Потом набираю номер повторно - гудок продолжается, а потом вдруг абонент отвечает...
Что это за бред?
До прошивки все работало отлично.
Вот тут я пытаюсь позвонить на 7885142 с SIP телефона, а потом еще раз набираю этот номер. Почему?
03:42:44 [000207] 0: Fxs Pickup
03:42:44 [000207] 0: ==4:GetDtmf
03:42:48 [000249] 0: DTMF Timeout #1
03:42:48 [000249] 0: End Input Default Route [0]
03:42:48 [000249] 0: Line DialNum_New [7885142]
03:42:48 [000249] 0: Call Proxy with [7885142]
03:42:48 [000249] 0: ==7:Inviting
03:42:48 [000249] 0: VoIP CallOut, Invite <sip:7885142@192.168.0.2;user=phone>
03:42:48 [000252] 0: 200=DIALING
03:42:49 [000256] 0: 200=PROCEEDING
03:42:49 [000258] 3: =OFFERING
03:42:49 [000258] 3: Get CallerId=Igor
03:42:49 [000258] 3: Hunting Trunk Line
03:42:49 [000258] 1: Peer=192.168.0.3:9000, PT=0, RecvOnly=0
03:42:49 [000258] 1: TrunkPrefix=, Dest=7885142, Dialno=7885142
03:42:49 [000258] 1: FxoHookOff
03:42:49 [000258] 1: InputGain(0)
03:42:49 [000258] 1: ==18:TrunkDialOut
03:42:50 [000269] 1: DialOut(7885142)=0
03:42:52 [000284] 1: Fxo DialOut OK
03:42:52 [000284] 1: RtpApiTalk[1,1], Peer=192.168.0.3:9000, PT=0, FC=2, NewOOB=1
03:42:52 [000285] 3: =ACCEPT
03:42:52 [000285] 1: ==13:VoipAnswering
03:42:52 [000287] 3: =CONNECTED
03:42:52 [000287] 1: ==14:Talking
03:42:52 [000288] 0: 200=CONNECTED
03:42:52 [000288] 0: Peer=192.168.0.3:9002, PT=0, RecvOnly=0
03:42:52 [000288] 0: RtpApiTalk[1,1], Peer=192.168.0.3:9002, PT=0, FC=2, NewOOB=1
03:42:52 [000288] 0: ==14:Talking
03:43:04 [000406] 1: Play(7)
03:43:04 [000406] 0: Get(7)
03:43:04 [000409] 1: Play(8)
03:43:04 [000409] 0: Get(8)
03:43:04 [000411] 1: Play(8)
03:43:04 [000412] 0: Get(8)
03:43:05 [000415] 1: Play(5)
03:43:05 [000416] 0: Get(5)
03:43:05 [000420] 1: Play(1)
03:43:05 [000420] 0: Get(1)
03:43:06 [000424] 0: Get(4)
03:43:06 [000424] 1: Play(4)
03:43:06 [000427] 1: Play(2)
03:43:06 [000428] 0: Get(2)
03:43:14 [000513] 0: Fxs Hangup
03:43:14 [000513] 0: Bye at Talking
03:43:14 [000513] 0: ==3:Idle
03:43:15 [000513] 0: SetFax(1)=0
03:43:15 [000513] 0: SetModem(0)=-1
03:43:15 [000515] 0: 200=DISCONNECT
03:43:15 [000515] 0: Release Old Dlg #2
03:43:15 [000516] 3: =DISCONNECT
03:43:15 [000516] 1: Release Active Dlg
03:43:15 [000516] 1: ==15:PlayBusyTone
03:43:15 [000516] 1: Start Btc Learning
03:43:17 [000533] 1: Btc Learning Exception No Change
03:43:17 [000533] 1: FxoHookOn
03:43:17 [000533] 1: ==3:Idle
03:43:17 [000533] 1: InputGain(6)
03:43:17 [000534] 1: SetFax(1)=0
03:43:17 [000534] 1: SetModem(0)=-1
СообщениеДобавлено: Пн май 23, 2011 10:11
to snezhko: Какой абонент отвечает, у Вас до шлюза доходит номер для набора, а потом вы его еще раз передаете тональными сигналами.
to suleman1971: инструкция для caller filter: http://dlink.ru/ru/faq/95/1018.html
