Текущее время: Ср сен 23, 2026 12:57
СообщениеДобавлено: Пт апр 15, 2011 21:56
Добрый день, имею следующую проблему:
Регулярно несколько раз в час(на несколько минут) пропадает доступ в интернет, причем только к сайтам, а торренты, аська и т.п работают отлично.
Если смотрим логи то видем следующую картину
[INFO] Fri Apr 15 21:42:20 2011 DNS relay ALG rejected packet from 192.168.0.1:51280 to 83.166.113.2:53
[INFO] Fri Apr 15 21:42:20 2011 Dropped packet from 192.168.0.1 to 83.166.113.2 (IP protocol 17) as unable to create new session
[INFO] Fri Apr 15 21:42:20 2011 DNS relay ALG rejected packet from 192.168.0.1:51280 to 195.7.162.244:53
[INFO] Fri Apr 15 21:42:20 2011 Dropped packet from 192.168.0.1 to 195.7.162.244 (IP protocol 17) as unable to create new session
[INFO] Fri Apr 15 21:42:20 2011 DNS relay ALG rejected packet from 192.168.0.1:49430 to 83.166.113.2:53
[INFO] Fri Apr 15 21:42:20 2011 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.1 to 195.7.162.244
[INFO] Fri Apr 15 21:42:20 2011 Dropped packet from 192.168.0.1 to 217.69.134.241 (IP protocol 6) as unable to create new session
[INFO] Fri Apr 15 21:42:19 2011 DNS relay ALG rejected packet from 192.168.0.1:52487 to 83.166.113.2:53
[INFO] Fri Apr 15 21:42:19 2011 Dropped packet from 192.168.0.1 to 83.166.113.2 (IP protocol 17) as unable to create new session
[INFO] Fri Apr 15 21:42:19 2011 Dropped packet from 192.168.0.1 to 81.176.238.63 (IP protocol 6) as unable to create new session
[INFO] Fri Apr 15 21:42:19 2011 Blocked incoming UDP packet from 88.180.88.7:20438 to 83.166.107.97:40001
[INFO] Fri Apr 15 21:42:19 2011 Dropped packet from 192.168.0.1 to 88.180.88.7 (IP protocol 17) as unable to create new session
[INFO] Fri Apr 15 21:42:18 2011 DNS relay ALG rejected packet from 192.168.0.1:53590 to 83.166.113.2:53
[INFO] Fri Apr 15 21:42:18 2011 Dropped packet from 192.168.0.1 to 83.166.113.2 (IP protocol 17) as unable to create new session
[INFO] Fri Apr 15 21:42:17 2011 DNS relay ALG rejected packet from 192.168.0.1:52487 to 83.166.113.2:53
[INFO] Fri Apr 15 21:42:17 2011 Dropped packet from 192.168.0.1 to 83.166.113.2 (IP protocol 17) as unable to create new session
[INFO] Fri Apr 15 21:42:17 2011 Blocked incoming UDP packet from 71.170.125.203:12891 to 83.166.107.97:40001
[INFO] Fri Apr 15 21:42:17 2011 Dropped packet from 192.168.0.1 to 71.170.125.203 (IP protocol 17) as unable to create new session
[INFO] Fri Apr 15 21:42:17 2011 Blocked incoming UDP packet from 109.165.120.124:59781 to 83.166.107.97:40001
[INFO] Fri Apr 15 21:42:17 2011 Dropped packet from 192.168.0.1 to 109.165.120.124 (IP protocol 17) as unable to create new session
[INFO] Fri Apr 15 21:42:17 2011 Dropped packet from 192.168.0.1 to 81.176.238.63 (IP protocol 6) as unable to create new session
[INFO] Fri Apr 15 21:42:17 2011 Dropped packet from 192.168.0.1 to 81.176.238.8 (IP protocol 6) as unable to create new session
[INFO] Fri Apr 15 21:42:16 2011 DNS relay ALG rejected packet from 192.168.0.1:51280 to 83.166.113.2:53
[INFO] Fri Apr 15 21:42:16 2011 Dropped packet from 192.168.0.1 to 83.166.113.2 (IP protocol 17) as unable to create new session
[INFO] Fri Apr 15 21:42:16 2011 DNS relay ALG rejected packet from 192.168.0.1:51280 to 195.7.162.244:53
[INFO] Fri Apr 15 21:42:16 2011 Dropped packet from 192.168.0.1 to 195.7.162.244 (IP protocol 17) as unable to create new session
[INFO] Fri Apr 15 21:42:16 2011 DNS relay ALG rejected packet from 192.168.0.1:60460 to 83.166.113.2:53
где 83.166.113.2 сответвенно адрес ДНС
Вообще по логам он так дропает кучу разных адресов, и видимо переодически начинает дропать ДНС и в это время мне приходиться курить без инета....
Сбрасывал и перепрошивал роутер миллион раз строго в соответствии с выложенными тут инструкциями - нипомогает :(
Текущая Firmware Version : 2.27RU, 2010/06/17
Connection Type : Russia PPTP
Сил больше нет, что делать??????
СообщениеДобавлено: Ср апр 20, 2011 16:47
ап :roll:
СообщениеДобавлено: Вт апр 26, 2011 20:46
ап2 :cry:
СообщениеДобавлено: Вт апр 26, 2011 22:02
SPI и QoS отключены?
СообщениеДобавлено: Чт апр 28, 2011 14:37
угу :(
http://floomby.ru/content/GNpirr5Lu0/
http://floomby.ru/content/EKHRbUksjk/
СообщениеДобавлено: Чт апр 28, 2011 21:40
В QoS Engine поставьте верхнюю галочку, отключите автоопределение скорости и задайте 102400. Тип соединения выберите Broadband. Я на всякий случай еще оставлял галку Dynamic Fragmentation. Сохраните в таком виде. Снова зайдите в QoS Engine и отключите верхнюю галку. Еще раз сохраните настройки.
В настройках файрвола можете поставить в TCP и UDP Endpoint Independent. Так обычно лучше работает.
Если не поможет, тогда на компьютере в настройках сетевого соединения явно задайте DNS. Возьмите адреса DNS серверов провайдера.
СообщениеДобавлено: Вс май 01, 2011 19:48
Все сделал, увы не помогло.
Проблема осталась.
Sun May 01 20:32:07 2011 DNS relay ALG rejected packet from 192.168.0.2:60718 to 195.7.162.244:53
Sun May 01 20:32:07 2011 Dropped packet from 192.168.0.2 to 195.7.162.244 (IP protocol 17) as unable to create new session
На компе DNS и так были прописаны явным образом
Что это вообще за дропы странные, почему он их делает?!
СообщениеДобавлено: Вс май 01, 2011 20:38
У меня такое тоже иногда попадается в логах, но на интернет никак не влияет. Я так понимаю, что DNS сервера время от времени становятся недоступными. Либо роутер не может установить соединение по какой-то своей софтовой причине. Хотя, если SPI отключен и по UDP поставлено Endpoint Independent, то вроде ничего не должно мешать этому трафику.
В Advanced - Firewall settings галочка Anti-spoof checking тоже убрана? Или стоит? Попробуйте убрать.
СообщениеДобавлено: Пн май 02, 2011 13:32
Нет галки не стоит :(
Судя по логам это происходит не только с ДНС, он начинает дропать все подряд адреса, но как мне кажется именно обращенные по 80 порту, т.к аська, скайп и торренты работают всегда нормально, падает только HTTP, да и падает на 2-3 минут потом восстанавливается сам, как будто у него какойто блок временной срабатывает.....
СообщениеДобавлено: Пн май 02, 2011 21:04
Если судить по логу, дропаются UDP пакеты (IP Protocol 17), причем относящиеся именно к DNS, о чем говорит порт 53. Да и DNS ALG упоминается. HTTP не дропается, но так как DNS запросы не проходят, комп не может понять, к каким ip адресам в инете ему обращаться.
Может, вам перепрошиться 2.27 beta14, предыдущей версией? Она мне как-то чуть больше нравилась, хотя и эта у меня нормально работает.
http://ifolder.ru/23297933
СообщениеДобавлено: Ср май 04, 2011 09:58
Сниффы с LAN и WAN интерфейса можете предоставить?
СообщениеДобавлено: Ср май 04, 2011 18:39
Как это сделать?
СообщениеДобавлено: Сб май 28, 2011 22:42
Привет!
У меня практически та же проблема :evil: - сил больше нет... аська отваливается местами (джабер как-то лучше держит), торренты не отмечал, страдает почта и собственно работа в браузере...
http://forum.dlink.ru/viewtopic.php?f=3&t=140543
Если найдете причину - помогите, плиз...
DIR-615 B2, DWA-140 (просто выкинут DWA-120)
