Текущее время: Вс июл 05, 2026 15:50
СообщениеДобавлено: Пн мар 29, 2010 12:42
без поднятого ВПНа: не отправляется почта, тест на исходящий траф не могу пройти, не могу закачать на сервер файлы.
стабильно работает только с прошивкой 1.21WW, 2008/12/26, более поздние прошивки - глючит и перезагружается, сегодня пробовал поставить бету последнюю Firmware Version : 1.31WW, 2010/02/27 , повтерение истории : постоянные ребуты
ЛОГ:
[INFO] Mon Mar 29 12:40:17 2010 Blocked incoming UDP packet from 178.187.12.212:59887 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:17 2010 Blocked incoming TCP connection request from 94.233.116.228:56731 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:17 2010 Blocked incoming TCP connection request from 10.3.66.130:2511 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:17 2010 Blocked incoming TCP connection request from 10.2.128.118:2510 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:40:17 2010 Blocked incoming TCP connection request from 10.7.133.30:62878 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:17 2010 Blocked incoming TCP connection request from 188.122.255.80:59699 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:40:16 2010 Blocked incoming UDP packet from 94.233.116.228:50905 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:16 2010 Blocked incoming UDP packet from 83.228.15.87:8149 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:16 2010 Dropped packet from 192.160.0.180 to 109.226.91.99 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:40:16 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:40:16 2010 Blocked incoming packet from 65.55.158.79 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:40:16 2010 Blocked incoming TCP connection request from 188.122.255.80:4419 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:40:16 2010 Blocked incoming UDP packet from 93.151.251.134:45843 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:16 2010 Blocked incoming UDP packet from 203.218.118.187:22504 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:16 2010 Blocked incoming TCP connection request from 10.4.75.67:61696 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:16 2010 Blocked incoming UDP packet from 77.209.181.170:4662 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:15 2010 Blocked incoming UDP packet from 93.81.34.159:37310 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:15 2010 Blocked incoming UDP packet from 78.26.128.149:26899 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:15 2010 Blocked incoming UDP packet from 109.184.222.135:60473 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:15 2010 Blocked incoming UDP packet from 94.233.116.228:50905 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming packet from 65.55.158.78 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming TCP connection request from 109.226.68.74:50628 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming TCP connection request from 10.3.3.198:3451 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming TCP connection request from 10.2.128.140:2570 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming packet from 94.245.115.171 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming TCP connection request from 10.5.12.134:2260 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming UDP packet from 10.5.12.134:44778 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming UDP packet from 93.81.34.159:37310 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming TCP connection request from 10.2.128.118:2510 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming UDP packet from 125.60.243.125:11709 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming TCP connection request from 188.122.255.25:3112 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:40:14 2010 Blocked incoming TCP connection request from 188.122.255.80:59699 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming TCP connection request from 10.13.130.79:2804 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming UDP packet from 10.2.68.18:13436 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming TCP connection request from 10.0.130.42:2449 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming TCP connection request from 10.7.201.78:1216 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming TCP packet from 217.113.118.210:61300 to 188.122.248.117:64387 as RST:ACK received but there is no active connection
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming TCP connection request from 10.2.94.2:3756 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming UDP packet from 96.52.174.18:23462 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming UDP packet from 93.124.1.197:1061 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming TCP connection request from 10.2.65.161:4609 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming UDP packet from 196.217.237.190:15413 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming UDP packet from 62.194.84.33:24091 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:13 2010 Blocked incoming TCP connection request from 10.7.1.225:3155 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming packet from 94.245.115.170 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming TCP connection request from 10.2.5.16:3338 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming UDP packet from 217.9.92.118:63119 to 188.122.248.117:41574
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming UDP packet from 84.23.52.211:53533 to 188.122.248.117:62669
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming TCP connection request from 172.16.108.28:59222 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming UDP packet from 10.1.64.36:44033 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming TCP connection request from 10.1.147.181:3232 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming UDP packet from 10.4.75.34:30660 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming TCP connection request from 10.2.9.195:1843 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming UDP packet from 89.185.80.237:43348 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming UDP packet from 10.1.144.45:32433 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming TCP connection request from 10.1.194.201:4539 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:12 2010 Log viewed by IP address 192.154.0.197
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming TCP connection request from 77.45.238.110:2479 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:12 2010 Blocked incoming TCP connection request from 10.14.7.116:3214 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:11 2010 Blocked incoming TCP connection request from 10.3.3.198:3451 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:40:11 2010 Blocked incoming TCP connection request from 10.3.75.9:2123 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:40:11 2010 Blocked incoming UDP packet from 87.157.197.61:24035 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:11 2010 Blocked incoming TCP connection request from 10.3.69.73:26119 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:11 2010 Blocked incoming UDP packet from 92.113.94.144:43359 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:11 2010 Blocked incoming TCP connection request from 94.233.116.228:56731 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:11 2010 Blocked incoming TCP connection request from 10.3.66.130:2511 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:11 2010 Blocked incoming UDP packet from 85.26.232.139:13455 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:11 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:40:11 2010 Blocked incoming TCP connection request from 10.7.133.30:62878 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:10 2010 Blocked incoming TCP connection request from 89.185.80.237:62726 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:10 2010 Blocked incoming UDP packet from 85.84.253.144:16633 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:10 2010 Blocked incoming UDP packet from 62.45.242.184:57043 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:10 2010 Blocked incoming TCP connection request from 10.2.65.161:4609 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:10 2010 Blocked incoming UDP packet from 95.165.147.50:60289 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:10 2010 Blocked incoming TCP connection request from 10.4.75.67:61696 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:10 2010 Blocked incoming TCP connection request from 10.6.65.111:3365 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:10 2010 Blocked incoming TCP connection request from 10.7.1.225:3155 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:10 2010 Blocked incoming UDP packet from 195.144.14.200:56921 to 188.122.248.117:50814
[INFO] Mon Mar 29 12:40:09 2010 Blocked incoming TCP connection request from 10.2.5.16:3338 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:09 2010 Blocked incoming UDP packet from 84.252.18.127:24350 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:09 2010 Blocked incoming TCP connection request from 172.16.108.28:59222 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:40:09 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:40:09 2010 Blocked incoming TCP connection request from 10.1.147.181:3232 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:09 2010 Blocked incoming TCP connection request from 10.2.9.195:1843 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:09 2010 Blocked incoming TCP connection request from 10.1.194.201:4539 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:09 2010 Blocked incoming TCP connection request from 10.14.7.116:3214 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:08 2010 Blocked incoming UDP packet from 61.238.25.214:16143 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:08 2010 Blocked incoming TCP connection request from 109.226.68.74:50317 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:08 2010 Blocked incoming TCP connection request from 10.3.69.73:26119 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:08 2010 Blocked incoming TCP connection request from 94.233.116.228:56731 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:08 2010 Blocked incoming TCP connection request from 10.3.66.130:2511 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:08 2010 Blocked incoming TCP connection request from 10.7.133.30:62878 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:08 2010 Blocked incoming TCP connection request from 10.1.147.181:3232 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming TCP connection request from 10.13.130.79:2804 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming TCP connection request from 10.0.130.42:2449 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:07 2010 Blocked outgoing TCP packet from 192.154.0.197:61019 to 92.100.109.19:60625 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming TCP connection request from 10.7.201.78:1216 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming TCP connection request from 188.122.255.52:27694 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming UDP packet from 93.159.240.60:63429 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming TCP connection request from 188.122.255.80:4419 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming TCP connection request from 10.2.94.2:3756 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming TCP connection request from 188.122.255.68:3037 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming UDP packet from 93.124.1.197:1061 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming UDP packet from 220.244.41.137:41706 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming UDP packet from 95.165.147.50:60289 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming TCP connection request from 172.16.88.54:2777 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming TCP connection request from 10.4.75.67:61696 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming UDP packet from 95.132.155.87:60440 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming TCP connection request from 10.1.201.4:56569 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:07 2010 Blocked incoming UDP packet from 114.234.125.183:16001 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:06 2010 Blocked incoming TCP connection request from 195.98.167.2:1872 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:06 2010 Blocked incoming UDP packet from 172.16.73.190:52136 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:06 2010 Blocked incoming TCP connection request from 10.3.69.147:27606 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:06 2010 Blocked incoming TCP connection request from 10.2.131.208:3147 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:06 2010 Blocked incoming UDP packet from 118.0.114.8:8365 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:06 2010 Blocked incoming UDP packet from 81.196.162.140:51473 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:06 2010 Blocked incoming UDP packet from 89.185.80.237:43348 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:06 2010 Blocked incoming UDP packet from 10.4.192.71:52012 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:06 2010 Blocked incoming TCP connection request from 125.24.135.72:13294 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:05 2010 Blocked incoming TCP connection request from 10.3.75.9:2123 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:40:05 2010 Blocked incoming TCP connection request from 95.165.147.50:49462 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:05 2010 Blocked incoming TCP connection request from 10.13.3.228:4135 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:05 2010 Blocked incoming TCP connection request from 188.122.255.68:1561 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:40:05 2010 Blocked incoming UDP packet from 122.133.71.234:22953 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:05 2010 Blocked incoming TCP connection request from 188.122.255.25:3112 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:40:05 2010 Blocked incoming TCP connection request from 10.13.130.79:2804 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:05 2010 Blocked incoming UDP packet from 78.58.87.198:21420 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:04 2010 Blocked incoming TCP connection request from 10.0.130.42:2449 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:04 2010 Blocked incoming TCP connection request from 10.7.201.78:1216 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:04 2010 Blocked incoming UDP packet from 124.171.222.118:36724 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:04 2010 Blocked incoming TCP connection request from 10.2.94.2:3756 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:04 2010 Blocked incoming UDP packet from 84.23.52.211:54844 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:04 2010 Blocked incoming UDP packet from 93.124.1.197:1061 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:04 2010 Blocked incoming TCP connection request from 10.6.65.111:3365 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:04 2010 Blocked incoming TCP connection request from 10.1.201.4:56569 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:03 2010 Blocked incoming TCP connection request from 188.122.255.68:2021 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:40:03 2010 Blocked incoming UDP packet from 89.185.80.237:43348 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:03 2010 Blocked incoming TCP connection request from 77.45.238.110:2479 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:03 2010 Blocked incoming TCP connection request from 172.16.13.10:4642 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:03 2010 Blocked incoming UDP packet from 195.114.6.11:23989 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:02 2010 Blocked incoming TCP connection request from 10.3.75.9:2123 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:40:02 2010 Blocked incoming TCP connection request from 109.226.68.74:50317 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:02 2010 Blocked incoming TCP connection request from 213.231.15.228:4717 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:02 2010 Blocked incoming UDP packet from 10.7.133.80:58555 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:02 2010 Blocked incoming TCP connection request from 10.2.3.147:56667 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:02 2010 Blocked incoming TCP connection request from 95.78.8.44:38219 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:02 2010 Blocked incoming TCP connection request from 92.101.208.97:3654 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:02 2010 Blocked incoming UDP packet from 116.228.172.83:15887 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:02 2010 Blocked incoming UDP packet from 119.235.78.115:32597 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:01 2010 Blocked incoming TCP connection request from 89.185.80.237:62726 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:01 2010 Blocked incoming UDP packet from 89.185.80.237:43348 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:01 2010 Blocked incoming TCP connection request from 10.2.68.130:4526 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:01 2010 Blocked incoming TCP connection request from 10.6.129.51:2693 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:01 2010 Blocked incoming UDP packet from 93.100.108.53:58577 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:01 2010 Blocked incoming UDP packet from 93.159.240.60:63429 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:01 2010 Blocked incoming TCP connection request from 10.7.67.72:4516 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:01 2010 Blocked incoming TCP connection request from 172.16.88.54:2777 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:01 2010 Blocked incoming TCP connection request from 10.6.65.111:3365 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:00 2010 Blocked incoming UDP packet from 114.183.9.57:22935 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:00 2010 Blocked incoming TCP connection request from 10.3.69.147:27606 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:00 2010 Blocked incoming TCP connection request from 10.2.131.208:3147 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:00 2010 Blocked incoming TCP connection request from 172.16.6.136:1903 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:40:00 2010 Blocked incoming TCP connection request from 10.4.193.41:2839 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:59 2010 Blocked incoming TCP connection request from 10.6.145.35:2163 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:59 2010 Blocked incoming TCP connection request from 109.226.68.74:50317 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:59 2010 Blocked incoming UDP packet from 109.226.68.74:63512 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:59 2010 Blocked incoming TCP connection request from 113.53.84.51:13304 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:59 2010 Blocked outgoing TCP packet from 192.154.0.197:64105 to 89.108.79.237:80 as RST:ACK received but there is no active connection
[INFO] Mon Mar 29 12:39:59 2010 Blocked incoming TCP connection request from 10.13.3.228:4135 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:59 2010 Blocked incoming TCP connection request from 10.2.3.147:56667 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:59 2010 Blocked incoming UDP packet from 118.168.130.131:55789 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:59 2010 Blocked incoming UDP packet from 89.100.190.162:7609 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:59 2010 Blocked incoming TCP connection request from 10.1.1.31:2653 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:59 2010 Blocked incoming packet from 94.245.115.168 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:39:58 2010 Blocked incoming UDP packet from 10.2.132.59:23178 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:58 2010 Blocked incoming UDP packet from 93.100.108.53:58577 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:58 2010 Blocked incoming UDP packet from 93.159.240.60:63429 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:58 2010 Blocked incoming packet from 94.245.115.178 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:39:58 2010 Blocked incoming UDP packet from 84.23.52.211:54844 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:58 2010 Blocked incoming UDP packet from 195.131.208.24:49682 to 188.122.248.117:62669
[INFO] Mon Mar 29 12:39:58 2010 Blocked incoming TCP connection request from 172.16.88.54:2777 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:58 2010 Blocked incoming TCP connection request from 10.13.70.181:3700 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:58 2010 Blocked incoming UDP packet from 10.0.12.91:64338 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming TCP connection request from 188.122.255.68:2021 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming UDP packet from 142.162.48.0:26477 to 188.122.248.117:53312
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming TCP connection request from 10.3.69.147:27606 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming TCP connection request from 10.2.131.208:3147 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming TCP connection request from 172.16.6.136:1903 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming TCP connection request from 91.192.20.68:3658 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming UDP packet from 94.158.101.246:16344 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming TCP connection request from 10.0.202.146:2169 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming TCP connection request from 172.16.13.10:4642 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming TCP connection request from 10.7.11.146:4196 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming UDP packet from 93.159.240.60:63429 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:57 2010 Blocked incoming UDP packet from 60.248.19.58:25589 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:56 2010 Blocked incoming TCP connection request from 188.122.255.96:4950 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:56 2010 Blocked incoming TCP connection request from 84.23.52.211:60145 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:56 2010 Blocked incoming TCP connection request from 10.13.3.228:4135 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:56 2010 Blocked incoming TCP connection request from 188.122.255.68:1561 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:56 2010 Blocked incoming TCP connection request from 213.231.15.228:4717 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:56 2010 Blocked incoming TCP connection request from 109.248.151.159:2094 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:56 2010 Blocked incoming packet from 94.245.115.175 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:39:56 2010 Blocked incoming TCP connection request from 92.101.208.97:3654 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:55 2010 Blocked incoming UDP packet from 178.186.142.23:50127 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:55 2010 Blocked incoming TCP connection request from 91.203.168.153:54970 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:55 2010 Blocked incoming TCP connection request from 10.2.68.130:4526 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:55 2010 Blocked incoming TCP connection request from 10.6.129.51:2693 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:55 2010 Blocked incoming UDP packet from 174.106.12.47:12988 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:55 2010 Blocked incoming UDP packet from 84.23.52.211:54844 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:55 2010 Blocked incoming TCP connection request from 10.7.67.72:4516 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:55 2010 Blocked incoming TCP connection request from 188.122.255.68:2021 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:54 2010 Blocked incoming TCP connection request from 10.3.130.216:3561 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:54 2010 Blocked incoming UDP packet from 93.114.192.88:6881 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:54 2010 Blocked incoming UDP packet from 60.50.231.141:16791 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:54 2010 Blocked incoming TCP connection request from 10.3.69.73:26107 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:54 2010 Blocked incoming UDP packet from 89.149.104.84:59944 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:54 2010 Blocked incoming TCP connection request from 172.16.13.10:4642 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:54 2010 Blocked incoming TCP connection request from 10.4.193.41:2839 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:54 2010 Blocked incoming packet from 94.245.115.167 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:39:54 2010 Blocked incoming TCP connection request from 188.122.255.96:4950 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming UDP packet from 187.14.69.171:22463 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming TCP connection request from 213.231.27.26:3558 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming UDP packet from 199.1.152.10:14293 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming TCP connection request from 84.23.52.211:60145 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming UDP packet from 84.23.52.211:54844 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming TCP connection request from 10.6.145.35:2163 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming TCP connection request from 113.53.84.51:13304 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming UDP packet from 95.30.189.138:15332 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming TCP connection request from 213.231.15.228:4717 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming UDP packet from 95.132.154.113:13500 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming TCP connection request from 188.122.255.80:52649 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming TCP connection request from 10.5.193.133:3099 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming TCP connection request from 10.2.1.17:3529 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming UDP packet from 78.4.191.106:21548 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming TCP connection request from 92.101.208.97:3654 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:53 2010 Blocked incoming TCP connection request from 10.1.1.31:2653 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming TCP connection request from 172.16.10.47:60517 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming TCP connection request from 10.2.68.130:4526 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming packet from 94.245.115.169 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming TCP connection request from 10.6.129.51:2693 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming UDP packet from 93.159.240.60:59411 to 188.122.248.117:62669
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming TCP connection request from 188.114.43.226:4764 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming TCP connection request from 10.7.67.72:4516 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming TCP connection request from 10.3.69.73:26105 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming UDP packet from 188.26.156.47:13767 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming TCP connection request from 10.13.70.181:3700 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:52 2010 Blocked incoming TCP connection request from 10.2.8.91:51315 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming TCP connection request from 10.3.130.216:3561 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming packet from 95.165.147.50 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:39:51 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming TCP connection request from 10.3.69.73:26107 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming TCP connection request from 10.2.3.147:56649 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming packet from 94.245.115.174 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming TCP connection request from 10.0.202.146:2169 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming TCP connection request from 91.192.20.68:3658 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:51 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming UDP packet from 124.12.53.153:24948 to 188.122.248.117:41574
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming TCP connection request from 172.16.92.27:1472 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming TCP connection request from 10.7.11.146:4196 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:51 2010 Blocked incoming TCP connection request from 10.4.193.41:2839 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming TCP connection request from 10.14.4.169:2208 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming TCP connection request from 10.6.145.35:2163 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming UDP packet from 95.221.31.56:23885 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming TCP connection request from 188.122.255.124:1046 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming TCP connection request from 10.4.200.166:58460 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming TCP connection request from 109.248.151.159:2094 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming TCP connection request from 10.2.73.9:49344 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming TCP connection request from 10.1.1.31:2653 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming UDP packet from 87.154.80.191:14218 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming packet from 94.245.115.169 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming UDP packet from 93.85.167.32:64461 to 188.122.248.117:62669
[INFO] Mon Mar 29 12:39:50 2010 Blocked incoming TCP connection request from 95.30.212.175:2682 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:49 2010 Blocked incoming TCP connection request from 172.16.10.47:60517 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:49 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:49 2010 Blocked incoming UDP packet from 58.31.227.66:5107 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:49 2010 Blocked incoming UDP packet from 95.132.216.159:22001 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:49 2010 Blocked incoming TCP connection request from 10.3.69.73:26105 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:49 2010 Blocked incoming packet from 94.245.115.178 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:39:49 2010 Blocked incoming TCP connection request from 10.13.70.181:3700 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:49 2010 Blocked incoming TCP connection request from 203.113.85.29:30462 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:48 2010 Blocked incoming TCP connection request from 10.2.3.147:56649 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:48 2010 Blocked incoming TCP connection request from 10.13.0.60:55613 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:48 2010 Blocked incoming TCP connection request from 10.0.202.146:2169 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:48 2010 Blocked incoming TCP connection request from 172.16.92.27:1472 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:48 2010 Blocked incoming TCP connection request from 10.7.11.146:4196 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:48 2010 Blocked incoming TCP connection request from 10.3.68.206:2291 to 10.3.64.17:18768
[INFO] Mon Mar 29 12:39:47 2010 Blocked incoming TCP connection request from 10.6.133.20:2498 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:47 2010 Blocked incoming TCP connection request from 213.231.27.26:3558 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:47 2010 Blocked incoming UDP packet from 59.44.147.125:1614 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:47 2010 Blocked incoming TCP connection request from 188.122.255.80:52649 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:47 2010 Blocked incoming TCP connection request from 109.248.151.159:2094 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:47 2010 Blocked incoming TCP connection request from 10.5.193.133:3099 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:47 2010 Blocked incoming TCP connection request from 10.2.1.17:3529 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:46 2010 Blocked incoming UDP packet from 10.14.8.197:30494 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:46 2010 Blocked incoming TCP connection request from 10.2.8.91:51315 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:46 2010 Blocked incoming UDP packet from 92.202.83.87:11155 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:45 2010 Blocked incoming UDP packet from 95.70.68.43:33598 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:45 2010 Blocked incoming TCP connection request from 213.167.200.59:2878 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:45 2010 Blocked incoming TCP connection request from 10.3.69.147:27331 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:45 2010 Blocked incoming UDP packet from 118.90.121.106:41180 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:45 2010 Blocked incoming TCP connection request from 62.176.15.27:3008 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:45 2010 Blocked incoming TCP connection request from 213.231.27.26:3558 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:45 2010 Blocked incoming UDP packet from 67.160.101.249:19781 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:44 2010 Blocked incoming TCP connection request from 10.14.4.169:2208 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:44 2010 Blocked incoming TCP connection request from 10.3.68.206:2291 to 10.3.64.17:18768
[INFO] Mon Mar 29 12:39:44 2010 Blocked incoming TCP connection request from 188.122.255.80:52649 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:44 2010 Blocked incoming TCP connection request from 10.4.200.166:58460 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:44 2010 Blocked incoming TCP connection request from 10.5.193.133:3099 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:44 2010 Blocked incoming UDP packet from 203.113.85.29:40305 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:44 2010 Blocked incoming TCP connection request from 10.1.139.72:4634 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:44 2010 Blocked incoming TCP connection request from 10.2.73.9:49344 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:44 2010 Blocked incoming TCP connection request from 188.122.255.69:4090 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:44 2010 Blocked incoming TCP connection request from 10.2.1.17:3529 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:43 2010 Blocked incoming TCP connection request from 95.30.212.175:2682 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:43 2010 Blocked incoming UDP packet from 10.2.132.59:23178 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:43 2010 Blocked incoming packet from 94.245.115.169 to 188.122.248.117 (IP protocol 41)
[INFO] Mon Mar 29 12:39:43 2010 Blocked incoming UDP packet from 209.99.238.215:1932 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:43 2010 Blocked incoming TCP connection request from 79.165.175.1:2862 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:43 2010 Blocked incoming TCP connection request from 10.14.0.152:1416 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:43 2010 Blocked incoming TCP connection request from 10.1.200.77:2853 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:43 2010 Blocked incoming TCP connection request from 10.2.8.91:51315 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming TCP connection request from 203.113.85.29:30462 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming UDP packet from 78.144.34.31:20807 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming UDP packet from 10.5.10.92:13148 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming UDP packet from 94.96.104.245:23990 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming TCP connection request from 10.13.0.60:55613 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming UDP packet from 125.175.61.167:21224 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming UDP packet from 217.150.58.29:50309 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming TCP connection request from 10.3.71.102:1066 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming TCP connection request from 10.7.196.52:1841 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming UDP packet from 87.247.108.218:50954 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming TCP connection request from 188.122.255.88:63517 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:42 2010 Blocked incoming UDP packet from 93.159.240.60:59411 to 188.122.248.117:62669
[INFO] Mon Mar 29 12:39:41 2010 Blocked incoming TCP connection request from 10.6.133.20:2498 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:41 2010 Blocked incoming TCP connection request from 10.14.4.169:2208 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:41 2010 Blocked incoming TCP connection request from 10.4.200.166:58460 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:41 2010 Blocked incoming UDP packet from 203.113.85.29:40305 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:41 2010 Blocked incoming TCP connection request from 93.81.34.159:4526 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:41 2010 Blocked incoming TCP connection request from 10.2.73.9:49344 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:41 2010 Blocked incoming TCP connection request from 10.4.134.49:53869 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:41 2010 Blocked incoming TCP connection request from 95.30.212.175:2682 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:40 2010 Blocked incoming UDP packet from 79.7.249.56:11153 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:40 2010 Blocked incoming TCP connection request from 10.13.129.243:1178 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:40 2010 Blocked incoming UDP packet from 61.244.123.242:10759 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:40 2010 Blocked incoming TCP connection request from 188.122.255.76:54740 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:40 2010 Blocked incoming TCP connection request from 10.6.65.111:3160 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming TCP connection request from 203.113.85.29:30462 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming UDP packet from 203.113.85.29:40305 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming TCP connection request from 178.93.150.226:4941 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming TCP connection request from 213.167.200.59:2878 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming UDP packet from 180.180.77.140:9943 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:39 2010 Log viewed by IP address 192.154.0.199
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming TCP connection request from 10.3.69.147:27331 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming TCP connection request from 10.13.0.60:55613 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming UDP packet from 217.150.58.29:50309 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming TCP connection request from 10.6.133.20:2498 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming TCP connection request from 10.1.138.43:1728 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:39 2010 Blocked incoming TCP connection request from 10.2.197.157:4126 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:38 2010 Blocked incoming TCP connection request from 188.122.255.127:13405 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:38 2010 Blocked incoming UDP packet from 80.217.63.47:43453 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:38 2010 Blocked incoming UDP packet from 222.140.172.73:16001 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:38 2010 Blocked incoming TCP connection request from 10.1.139.72:4634 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:38 2010 Blocked incoming UDP packet from 98.225.175.3:36706 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:38 2010 Blocked incoming TCP connection request from 188.122.255.69:4090 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:38 2010 Blocked incoming UDP packet from 111.173.137.33:1413 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:38 2010 Dropped packet from 192.160.0.180 to 188.122.250.243 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:37 2010 Blocked incoming UDP packet from 222.140.172.73:16001 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:37 2010 Blocked incoming UDP packet from 94.245.115.186:3544 to 188.122.248.117:62669
[INFO] Mon Mar 29 12:39:37 2010 Blocked incoming TCP connection request from 10.2.73.9:49301 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:37 2010 Blocked incoming TCP connection request from 10.6.139.211:55116 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:37 2010 Blocked incoming TCP connection request from 10.1.200.77:2853 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:37 2010 Blocked incoming TCP connection request from 10.14.0.152:1416 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:36 2010 Blocked incoming TCP connection request from 10.2.193.156:1544 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:36 2010 Blocked incoming TCP connection request from 188.122.255.36:4927 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:36 2010 Blocked incoming TCP connection request from 10.3.69.147:27331 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:36 2010 Dropped packet from 192.160.0.180 to 188.122.250.243 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:36 2010 Blocked incoming UDP packet from 218.72.134.5:1832 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:36 2010 Blocked incoming TCP connection request from 10.4.131.77:3996 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:36 2010 Blocked incoming UDP packet from 95.67.212.153:13915 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:36 2010 Blocked incoming TCP connection request from 10.0.14.194:2427 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:36 2010 Blocked incoming TCP connection request from 10.7.196.52:1841 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:36 2010 Blocked incoming TCP connection request from 10.3.71.102:1066 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:36 2010 Blocked incoming TCP connection request from 188.122.255.88:63517 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:35 2010 Blocked incoming TCP connection request from 188.122.255.127:13405 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:35 2010 Blocked incoming UDP packet from 94.245.115.186:3544 to 188.122.248.117:62669
[INFO] Mon Mar 29 12:39:35 2010 Blocked incoming TCP connection request from 109.184.30.161:3195 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:35 2010 Blocked incoming TCP connection request from 10.7.75.196:3980 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:35 2010 Blocked incoming UDP packet from 88.118.32.204:33473 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:35 2010 Blocked incoming UDP packet from 213.138.92.194:35691 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:35 2010 Blocked incoming UDP packet from 77.34.178.144:32257 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:35 2010 Blocked incoming TCP connection request from 10.1.139.72:4634 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:35 2010 Blocked incoming TCP connection request from 10.4.134.49:53869 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:34 2010 Blocked incoming TCP connection request from 10.2.155.68:3447 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:34 2010 Blocked incoming UDP packet from 81.247.185.189:60012 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:34 2010 Blocked incoming UDP packet from 95.42.88.239:25196 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:34 2010 Blocked incoming UDP packet from 78.36.189.18:27461 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:34 2010 Blocked incoming TCP connection request from 10.13.129.243:1178 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:34 2010 Blocked incoming TCP connection request from 10.14.0.152:1416 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:34 2010 Blocked incoming TCP connection request from 10.1.200.77:2853 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:34 2010 Blocked incoming TCP connection request from 10.4.133.23:4654 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:34 2010 Blocked incoming TCP connection request from 10.6.65.111:3160 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming TCP connection request from 10.7.10.154:3578 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming UDP packet from 94.245.115.186:3544 to 188.122.248.117:62669
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming TCP connection request from 172.16.149.217:3399 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming TCP connection request from 10.1.133.96:2973 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming UDP packet from 98.114.227.110:21641 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming TCP connection request from 172.16.65.205:64265 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:33 2010 Dropped packet from 192.160.0.180 to 109.226.100.217 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming TCP connection request from 10.3.71.102:1066 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming TCP connection request from 10.7.196.52:1841 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming TCP connection request from 188.122.255.88:63517 to 188.122.248.117:54031
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming TCP connection request from 10.1.138.43:1728 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:33 2010 Blocked incoming TCP connection request from 10.2.197.157:4126 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:32 2010 Blocked incoming TCP connection request from 89.250.2.115:2702 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:39:32 2010 Blocked incoming TCP connection request from 10.2.3.147:56617 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:32 2010 WAN interface speed measurement aborted as they did not converge
[INFO] Mon Mar 29 12:39:32 2010 Blocked incoming TCP connection request from 10.4.134.49:53869 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:32 2010 Dropped packet from 192.160.0.180 to 188.122.250.243 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:32 2010 Blocked incoming TCP connection request from 10.12.2.225:4834 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:31 2010 Blocked incoming TCP connection request from 10.4.200.6:4163 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:31 2010 Blocked incoming TCP connection request from 172.16.73.212:3917 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:31 2010 Blocked incoming TCP connection request from 172.16.7.254:2690 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:31 2010 Blocked incoming TCP connection request from 10.2.73.9:49301 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:31 2010 Blocked incoming TCP connection request from 10.13.129.243:1178 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:31 2010 Blocked incoming TCP connection request from 10.6.139.211:55116 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:31 2010 Blocked incoming TCP connection request from 10.6.65.111:3160 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:31 2010 Blocked incoming TCP connection request from 10.1.129.77:64262 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:30 2010 Blocked incoming TCP connection request from 10.2.193.156:1544 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:30 2010 Dropped packet from 192.160.0.180 to 188.122.250.243 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:30 2010 Blocked incoming TCP connection request from 10.4.131.77:3996 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:30 2010 Blocked incoming TCP connection request from 10.4.133.220:1960 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:30 2010 Blocked incoming TCP connection request from 10.0.14.194:2427 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:30 2010 Blocked incoming TCP connection request from 10.1.138.43:1728 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:29 2010 Blocked incoming TCP connection request from 10.4.71.68:1680 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:29 2010 Blocked incoming TCP connection request from 10.2.197.157:4126 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:29 2010 Blocked incoming TCP connection request from 10.7.64.88:1220 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:29 2010 Blocked incoming TCP connection request from 10.6.67.216:3292 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:29 2010 Blocked incoming TCP connection request from 10.7.75.196:3980 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:29 2010 Blocked incoming TCP connection request from 10.2.3.147:56617 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:29 2010 Dropped packet from 192.160.0.180 to 188.122.250.243 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:28 2010 Blocked incoming TCP connection request from 10.2.155.68:3447 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:28 2010 Blocked incoming TCP connection request from 10.6.134.146:42919 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:28 2010 Blocked incoming TCP connection request from 172.16.73.212:3917 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:28 2010 Blocked incoming TCP connection request from 10.7.75.92:2269 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:28 2010 Blocked incoming TCP connection request from 10.2.73.9:49301 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:28 2010 Blocked incoming TCP connection request from 10.6.139.211:55116 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:28 2010 Blocked incoming TCP connection request from 10.6.136.145:1556 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:28 2010 Blocked incoming TCP connection request from 10.4.133.23:4654 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:27 2010 Blocked incoming TCP connection request from 10.2.193.156:1544 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:27 2010 Blocked incoming TCP connection request from 10.7.10.154:3578 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:27 2010 Blocked incoming TCP connection request from 10.1.133.96:2973 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:27 2010 Blocked incoming TCP connection request from 172.16.149.217:3399 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:27 2010 Dropped packet from 192.160.0.180 to 188.122.250.243 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:27 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:39:27 2010 Blocked incoming TCP connection request from 10.4.131.77:3996 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:27 2010 Blocked incoming UDP packet from 10.4.131.77:16271 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:27 2010 Blocked incoming TCP connection request from 172.16.65.205:64265 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:27 2010 Blocked incoming UDP packet from 10.3.68.73:27701 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:27 2010 Blocked incoming TCP connection request from 10.0.14.194:2427 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:26 2010 Blocked incoming TCP connection request from 10.7.64.88:1220 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:26 2010 Blocked incoming TCP connection request from 10.3.19.134:49317 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:26 2010 Blocked incoming TCP connection request from 10.3.19.134:49315 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:26 2010 Blocked incoming TCP connection request from 10.7.75.196:3980 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:26 2010 Blocked incoming TCP connection request from 10.12.2.225:4834 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:26 2010 Blocked incoming TCP connection request from 172.16.88.31:4687 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:26 2010 Blocked incoming TCP connection request from 10.4.200.6:4163 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:25 2010 Blocked incoming TCP connection request from 10.2.155.68:3447 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:25 2010 Blocked incoming TCP connection request from 172.16.7.254:2690 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:25 2010 Blocked incoming TCP connection request from 10.3.130.66:58505 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:25 2010 Blocked incoming TCP connection request from 10.4.133.23:4654 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:25 2010 Blocked incoming TCP connection request from 10.1.129.77:64262 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:24 2010 Blocked incoming TCP connection request from 10.7.10.154:3578 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:24 2010 Blocked incoming TCP connection request from 172.16.149.217:3399 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:24 2010 Blocked incoming TCP connection request from 10.1.133.96:2973 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:24 2010 Blocked incoming TCP connection request from 10.4.133.220:1960 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:24 2010 Blocked incoming TCP connection request from 172.16.65.205:64265 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:23 2010 Blocked incoming TCP connection request from 10.4.71.68:1680 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:23 2010 Blocked incoming TCP connection request from 10.6.67.216:3292 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:23 2010 Blocked incoming TCP connection request from 172.16.44.104:2526 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:23 2010 Blocked incoming TCP connection request from 10.14.0.152:1392 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:23 2010 Blocked incoming TCP connection request from 10.12.2.225:4834 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:23 2010 Blocked incoming TCP connection request from 172.16.88.31:4687 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:23 2010 Blocked incoming TCP connection request from 10.4.200.6:4163 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:22 2010 Blocked incoming TCP connection request from 10.6.134.146:42919 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:22 2010 Blocked incoming TCP connection request from 10.13.129.11:4674 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:22 2010 Blocked outgoing ICMP packet (ICMP type 3) from 188.122.248.117 to 188.122.255.16
[INFO] Mon Mar 29 12:39:22 2010 Blocked incoming TCP connection request from 10.7.75.92:2269 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:22 2010 Blocked incoming TCP connection request from 172.16.7.254:2690 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:22 2010 Blocked incoming TCP connection request from 10.6.136.145:1556 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:22 2010 Blocked incoming TCP connection request from 172.16.112.164:5514 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:22 2010 Blocked incoming TCP connection request from 10.3.3.241:4222 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:22 2010 Blocked incoming TCP connection request from 10.1.129.77:64262 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:21 2010 Blocked incoming TCP connection request from 10.4.133.220:1960 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:21 2010 Blocked incoming UDP packet from 10.3.68.73:27701 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:21 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:39:21 2010 Blocked incoming TCP connection request from 10.3.11.153:33173 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:21 2010 Blocked incoming TCP connection request from 10.4.71.68:1680 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:21 2010 Blocked incoming TCP connection request from 172.16.108.133:4833 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:21 2010 Blocked incoming TCP connection request from 10.7.144.228:4548 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:20 2010 Blocked incoming TCP connection request from 10.4.72.26:4460 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:20 2010 Blocked incoming TCP connection request from 10.3.19.134:49317 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:20 2010 Blocked incoming TCP connection request from 10.3.19.134:49315 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:20 2010 Blocked incoming TCP connection request from 10.6.67.216:3292 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:20 2010 Blocked incoming TCP connection request from 10.13.136.75:56249 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:19 2010 Blocked incoming TCP connection request from 10.13.6.71:2277 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:19 2010 Blocked incoming TCP connection request from 10.6.134.146:42919 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:19 2010 Blocked incoming TCP connection request from 10.1.68.227:1661 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:19 2010 Blocked incoming TCP connection request from 10.7.75.92:2269 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:19 2010 Blocked incoming TCP connection request from 10.6.136.145:1556 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:19 2010 Blocked incoming TCP connection request from 10.3.130.66:58505 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:18 2010 Blocked outgoing ICMP packet (ICMP type 3) from 188.122.248.117 to 213.178.40.40
[INFO] Mon Mar 29 12:39:18 2010 Blocked incoming TCP connection request from 10.2.75.149:1347 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:18 2010 Blocked incoming UDP packet from 10.3.68.73:27701 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:18 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:39:18 2010 Blocked incoming TCP connection request from 172.16.6.136:1874 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:17 2010 Blocked incoming TCP connection request from 10.3.19.134:49317 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:17 2010 Blocked incoming TCP connection request from 10.3.19.134:49315 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:17 2010 Blocked incoming TCP connection request from 10.1.67.223:2200 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:17 2010 Blocked incoming TCP connection request from 172.16.44.104:2526 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:17 2010 Blocked incoming TCP connection request from 10.4.6.139:2128 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:17 2010 Blocked incoming TCP connection request from 10.14.0.152:1392 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:17 2010 Blocked incoming UDP packet from 10.4.201.74:62541 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:16 2010 Blocked incoming UDP packet from 10.3.68.73:27701 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:16 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:39:16 2010 Blocked incoming TCP connection request from 10.13.129.11:4674 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:16 2010 Blocked incoming TCP connection request from 10.5.19.21:1507 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:16 2010 Blocked incoming TCP connection request from 10.3.130.66:58505 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:16 2010 Blocked incoming TCP connection request from 172.16.112.164:5514 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:16 2010 Blocked incoming TCP connection request from 10.3.3.241:4222 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:15 2010 Blocked incoming TCP connection request from 172.16.6.136:1874 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:15 2010 Blocked incoming TCP connection request from 172.16.95.16:8770 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:15 2010 Blocked incoming TCP connection request from 10.3.11.153:33173 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:15 2010 Blocked incoming TCP connection request from 172.16.108.133:4833 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:15 2010 Blocked incoming TCP connection request from 10.7.144.228:4548 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:14 2010 Blocked incoming TCP connection request from 10.4.72.26:4460 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:14 2010 Blocked incoming TCP connection request from 172.16.44.104:2526 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:14 2010 Blocked incoming TCP connection request from 10.14.0.152:1392 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:14 2010 Blocked incoming TCP connection request from 10.13.136.75:56249 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:13 2010 Blocked incoming TCP connection request from 172.16.149.217:3319 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:13 2010 Blocked incoming TCP connection request from 10.13.129.11:4674 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:13 2010 Blocked incoming TCP connection request from 10.7.70.125:3244 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:13 2010 Blocked incoming TCP connection request from 10.1.68.227:1661 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:13 2010 Blocked incoming TCP connection request from 172.16.112.164:5514 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:13 2010 Blocked incoming TCP connection request from 10.3.3.241:4222 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:13 2010 Blocked incoming UDP packet from 172.16.15.203:19182 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:12 2010 Blocked incoming TCP connection request from 10.2.75.149:1347 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:12 2010 Blocked outgoing ICMP packet (ICMP type 3) from 188.122.248.117 to 213.178.40.40
[INFO] Mon Mar 29 12:39:12 2010 Blocked incoming TCP connection request from 10.3.11.153:33173 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:12 2010 Blocked incoming TCP connection request from 10.4.200.6:4108 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:12 2010 Blocked incoming TCP connection request from 10.7.144.228:4548 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:12 2010 Blocked incoming TCP connection request from 172.16.108.133:4833 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:11 2010 Blocked incoming TCP connection request from 10.3.11.140:3961 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:11 2010 Blocked incoming TCP connection request from 10.4.72.26:4460 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:11 2010 Blocked incoming TCP connection request from 10.1.67.223:2200 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:11 2010 Blocked incoming TCP connection request from 10.4.6.139:2128 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:11 2010 Blocked incoming TCP connection request from 10.13.136.75:56249 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:39:10 2010 Blocked incoming UDP packet from 10.0.205.66:33048 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:10 2010 Blocked incoming TCP connection request from 10.1.68.227:1661 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:10 2010 Blocked incoming TCP connection request from 10.3.75.9:2087 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:10 2010 Blocked incoming TCP connection request from 10.5.19.21:1507 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:10 2010 Blocked incoming TCP connection request from 172.16.95.232:2618 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:09 2010 Blocked incoming TCP connection request from 10.2.75.149:1347 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:09 2010 Blocked incoming TCP connection request from 10.3.69.73:26080 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:09 2010 Blocked incoming TCP connection request from 172.16.95.16:8770 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:08 2010 Blocked incoming TCP connection request from 10.2.128.140:2441 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:08 2010 Blocked incoming TCP connection request from 10.4.6.139:2128 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:08 2010 Blocked incoming TCP connection request from 10.1.67.223:2200 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:08 2010 Blocked incoming UDP packet from 10.1.67.223:31916 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:08 2010 Blocked incoming TCP connection request from 10.3.67.83:54727 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:08 2010 Blocked incoming TCP connection request from 10.4.75.34:4403 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:08 2010 Blocked incoming TCP connection request from 10.2.192.223:2745 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:08 2010 Blocked incoming TCP connection request from 10.2.196.37:1876 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:08 2010 Dropped packet from 192.160.0.180 to 188.122.250.42 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:07 2010 Blocked incoming TCP connection request from 10.3.9.173:2142 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:07 2010 Blocked incoming TCP connection request from 172.16.149.217:3319 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:07 2010 Blocked incoming TCP connection request from 10.7.70.125:3244 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:07 2010 Blocked incoming TCP connection request from 10.5.19.21:1507 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:07 2010 Blocked incoming TCP connection request from 10.1.135.51:3696 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:07 2010 Blocked incoming TCP connection request from 10.6.65.111:2924 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:07 2010 Blocked incoming TCP connection request from 10.2.198.4:3195 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:07 2010 Blocked incoming TCP connection request from 109.226.81.153:52258 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:07 2010 Blocked incoming TCP connection request from 172.16.95.232:2618 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:06 2010 Blocked incoming TCP connection request from 10.1.5.143:3913 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:06 2010 Blocked incoming UDP packet from 10.2.69.201:63030 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:06 2010 Dropped packet from 192.160.0.180 to 188.122.250.42 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:06 2010 Blocked incoming UDP packet from 10.0.138.44:28701 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:06 2010 Blocked incoming TCP connection request from 172.16.95.16:8770 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:06 2010 Blocked incoming TCP connection request from 10.3.69.73:26080 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:06 2010 Blocked incoming TCP connection request from 10.4.200.6:4108 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:05 2010 Blocked incoming TCP connection request from 10.3.11.140:3961 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:05 2010 Blocked incoming TCP connection request from 109.226.67.228:1971 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:05 2010 Blocked incoming TCP connection request from 10.4.75.34:4403 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:04 2010 Blocked incoming TCP connection request from 10.7.70.125:3244 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:04 2010 Blocked incoming TCP connection request from 172.16.149.217:3319 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:04 2010 Blocked incoming TCP connection request from 10.3.75.9:2087 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:04 2010 Blocked incoming TCP connection request from 10.3.131.209:1562 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:03 2010 Blocked incoming TCP connection request from 10.2.72.137:4665 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:03 2010 Blocked incoming TCP connection request from 10.3.69.73:26076 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:03 2010 Blocked incoming TCP connection request from 10.2.128.140:2441 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:02 2010 Blocked incoming TCP connection request from 10.4.200.6:4108 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:02 2010 Blocked incoming TCP connection request from 10.3.11.140:3961 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:02 2010 Blocked incoming TCP connection request from 10.7.12.11:3361 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:02 2010 Blocked incoming TCP connection request from 10.0.195.150:3606 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:02 2010 Blocked incoming TCP connection request from 10.2.192.223:2745 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:02 2010 Blocked incoming TCP connection request from 10.3.67.83:54727 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:02 2010 Blocked incoming TCP connection request from 10.2.65.161:4401 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:02 2010 Blocked incoming TCP connection request from 10.2.196.37:1876 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:02 2010 Blocked incoming TCP connection request from 10.0.198.89:3454 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:02 2010 Dropped packet from 192.160.0.180 to 188.122.250.42 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:01 2010 Blocked incoming TCP connection request from 10.3.9.173:2142 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:01 2010 Blocked incoming TCP connection request from 10.3.75.9:2087 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:01 2010 Blocked incoming TCP connection request from 10.1.135.51:3696 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:39:01 2010 Blocked incoming TCP connection request from 10.3.131.209:1562 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:01 2010 Blocked incoming TCP connection request from 10.6.65.111:2924 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:01 2010 Blocked incoming TCP connection request from 10.2.198.4:3195 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:01 2010 Blocked incoming TCP connection request from 109.226.81.153:52258 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:00 2010 Blocked incoming TCP connection request from 10.1.5.143:3913 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:00 2010 Dropped packet from 192.160.0.180 to 188.122.250.42 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:39:00 2010 Blocked incoming TCP connection request from 10.7.85.17:51138 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:00 2010 Blocked incoming TCP connection request from 10.3.69.73:26076 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:39:00 2010 Blocked incoming TCP connection request from 10.2.128.140:2441 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:59 2010 Blocked incoming TCP connection request from 10.3.132.69:1868 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:59 2010 Blocked incoming TCP connection request from 10.2.89.16:4735 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:59 2010 Blocked incoming TCP connection request from 109.226.67.228:1971 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:59 2010 Blocked incoming TCP connection request from 10.2.192.223:2745 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:59 2010 Blocked incoming TCP connection request from 10.3.67.83:54727 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:59 2010 Blocked incoming TCP connection request from 10.0.198.89:3454 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:59 2010 Blocked incoming TCP connection request from 10.2.196.37:1876 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:59 2010 Dropped packet from 192.160.0.180 to 188.122.250.42 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:59 2010 Blocked incoming TCP connection request from 10.3.9.173:2142 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:58 2010 Blocked incoming TCP connection request from 10.1.135.51:3696 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:58 2010 Blocked incoming TCP connection request from 10.6.65.111:2924 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:58 2010 Blocked incoming TCP connection request from 109.226.81.153:52258 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:58 2010 Blocked incoming TCP connection request from 10.2.198.4:3195 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:57 2010 Blocked incoming TCP connection request from 10.1.5.143:3913 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:57 2010 Dropped packet from 192.160.0.180 to 188.122.250.42 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:57 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:38:57 2010 Blocked incoming TCP connection request from 172.16.93.16:3895 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:57 2010 Blocked incoming TCP connection request from 10.0.2.230:3163 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:57 2010 Blocked incoming TCP connection request from 10.2.72.137:4665 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:57 2010 Blocked incoming TCP connection request from 10.3.67.213:4419 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:56 2010 Blocked incoming TCP connection request from 10.7.12.11:3361 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:56 2010 Blocked incoming TCP connection request from 10.0.195.150:3606 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:56 2010 Blocked incoming TCP connection request from 109.226.67.228:1971 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:56 2010 Blocked incoming TCP connection request from 10.2.65.161:4401 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:55 2010 Estimating speed of WAN interface
[INFO] Mon Mar 29 12:38:55 2010 PPP network up with IP Address 188.122.248.117
[INFO] Mon Mar 29 12:38:55 2010 MSCHAP authentication successful.
[INFO] Mon Mar 29 12:38:55 2010 MSCHAP authentication details were sent to authenticator.
[INFO] Mon Mar 29 12:38:55 2010 MSCHAP authentication challenge received from peer.
[INFO] Mon Mar 29 12:38:55 2010 LCP sets local options: ACCM: 00000000, ACFC: 1, PFC: 1, MRU: 1462
[INFO] Mon Mar 29 12:38:54 2010 Blocked incoming TCP connection request from 172.16.108.50:2384 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:54 2010 Blocked incoming TCP connection request from 10.7.85.17:51138 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:54 2010 Blocked incoming TCP connection request from 10.2.72.137:4665 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:54 2010 Blocked incoming TCP connection request from 172.16.15.176:62410 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:54 2010 LCP sets remote auth: C223
[INFO] Mon Mar 29 12:38:54 2010 LCP sets remote options: ACCM: 00000000, ACFC: 1, PFC: 1, MRU: 1462
[INFO] Mon Mar 29 12:38:54 2010 PPTP connected to server "local" with ID 0xB9B8
[INFO] Mon Mar 29 12:38:54 2010 The PPTP transmit window is 8192
[INFO] Mon Mar 29 12:38:54 2010 Attempting to establish a PPTP connection.
[INFO] Mon Mar 29 12:38:54 2010 Attempting to re-connect on-demand WAN connection
[INFO] Mon Mar 29 12:38:53 2010 Blocked incoming TCP connection request from 10.7.12.11:3361 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:53 2010 Blocked incoming TCP connection request from 10.3.132.69:1868 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:53 2010 Blocked incoming TCP connection request from 10.0.195.150:3606 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:53 2010 Blocked incoming TCP connection request from 10.0.143.67:1050 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:53 2010 PPP network down
[INFO] Mon Mar 29 12:38:53 2010 PPTP tunnel ID 0xD13C has been closed
[INFO] Mon Mar 29 12:38:53 2010 Blocked incoming TCP connection request from 10.2.89.16:4735 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:53 2010 Blocked incoming TCP connection request from 10.2.65.161:4401 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:53 2010 Blocked incoming TCP connection request from 10.0.135.115:4066 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:52 2010 Blocked incoming TCP connection request from 10.2.66.8:2371 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:52 2010 Blocked incoming TCP connection request from 10.13.137.133:2755 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:51 2010 Blocked incoming TCP connection request from 10.4.195.224:52503 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:51 2010 Blocked incoming TCP connection request from 10.0.2.230:3163 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:51 2010 Blocked incoming TCP connection request from 10.7.85.17:51138 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:51 2010 Blocked incoming TCP connection request from 172.16.93.16:3895 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:51 2010 Blocked incoming TCP connection request from 10.3.67.213:4419 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:51 2010 Blocked incoming TCP connection request from 10.5.193.167:3251 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:50 2010 Blocked incoming TCP connection request from 10.3.132.69:1868 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:50 2010 Blocked incoming TCP connection request from 10.0.198.71:3048 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:50 2010 Blocked incoming TCP connection request from 10.2.89.16:4735 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:50 2010 Blocked incoming TCP connection request from 10.7.66.14:2064 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:49 2010 Blocked incoming TCP connection request from 10.0.147.196:1848 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:49 2010 Blocked incoming TCP connection request from 10.3.68.73:4882 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:49 2010 Blocked incoming TCP connection request from 10.7.10.154:2862 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:49 2010 Blocked incoming UDP packet from 10.3.68.73:27701 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:48 2010 Blocked incoming TCP connection request from 10.12.0.140:1866 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:48 2010 Blocked incoming TCP connection request from 10.7.0.196:2245 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:48 2010 Blocked incoming TCP connection request from 172.16.108.50:2384 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:48 2010 Blocked incoming TCP connection request from 10.0.2.230:3163 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:48 2010 Blocked incoming TCP connection request from 10.6.4.134:63634 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:48 2010 Blocked incoming TCP connection request from 172.16.93.16:3895 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:48 2010 Blocked incoming UDP packet from 10.1.200.77:61643 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:48 2010 Blocked incoming TCP connection request from 172.16.15.176:62410 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:48 2010 Blocked incoming TCP connection request from 10.3.67.213:4419 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:48 2010 Blocked incoming TCP connection request from 10.5.193.167:3251 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:47 2010 Blocked incoming TCP connection request from 10.0.198.71:3048 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:47 2010 Blocked incoming TCP connection request from 10.0.143.67:1050 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:47 2010 Blocked incoming TCP connection request from 10.0.135.115:4066 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:47 2010 Blocked incoming UDP packet from 79.120.120.14:35526 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:47 2010 Blocked incoming TCP connection request from 89.207.222.11:2219 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:46 2010 Blocked incoming TCP connection request from 10.2.66.8:2371 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:46 2010 Blocked incoming TCP connection request from 10.6.136.145:1279 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:46 2010 Blocked incoming TCP connection request from 10.13.137.133:2755 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:45 2010 Blocked incoming TCP connection request from 172.16.108.50:2384 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:45 2010 Blocked incoming TCP connection request from 10.4.195.224:52503 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:45 2010 Blocked incoming TCP connection request from 10.3.71.102:4977 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:45 2010 Blocked incoming TCP connection request from 10.2.67.163:49337 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:45 2010 Blocked incoming TCP connection request from 172.16.15.176:62410 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:45 2010 Blocked incoming TCP connection request from 10.5.194.18:53623 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:45 2010 Blocked incoming TCP connection request from 10.1.129.77:64246 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:44 2010 Blocked incoming TCP connection request from 172.16.137.249:3006 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:44 2010 Blocked incoming TCP connection request from 10.0.143.67:1050 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:44 2010 Blocked incoming TCP connection request from 94.231.171.85:4689 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:44 2010 Blocked incoming UDP packet from 109.111.95.17:26387 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:44 2010 Blocked incoming TCP connection request from 10.0.135.115:4066 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:44 2010 Blocked incoming TCP connection request from 10.0.147.196:1848 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:44 2010 Blocked incoming TCP connection request from 10.7.66.14:2064 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:43 2010 Blocked incoming TCP connection request from 10.2.66.8:2371 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:43 2010 Blocked incoming UDP packet from 10.2.66.8:35691 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:43 2010 Blocked incoming TCP connection request from 109.188.186.183:58785 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:43 2010 Blocked incoming TCP connection request from 10.7.10.154:2862 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:43 2010 Blocked incoming TCP connection request from 10.3.68.73:4882 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:43 2010 Blocked incoming UDP packet from 10.3.68.73:27701 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:43 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:43 2010 Blocked incoming TCP connection request from 10.13.137.133:2755 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming TCP connection request from 10.5.194.107:51577 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming TCP connection request from 10.12.0.140:1866 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming TCP connection request from 10.4.195.224:52503 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming TCP connection request from 10.7.0.196:2245 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming TCP connection request from 10.0.202.248:1041 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming TCP connection request from 10.6.4.134:63634 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming UDP packet from 79.120.120.14:35526 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming TCP connection request from 10.3.21.220:4995 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming UDP packet from 188.122.255.56:35428 to 188.122.249.3:41574
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming TCP connection request from 10.5.194.18:53623 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming TCP connection request from 10.3.67.213:4313 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:42 2010 Blocked incoming TCP connection request from 172.16.128.125:1444 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:41 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:41 2010 Blocked incoming TCP connection request from 172.16.92.27:1313 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:41 2010 Blocked incoming TCP connection request from 10.0.147.196:1848 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:41 2010 Blocked incoming TCP connection request from 10.7.196.52:64819 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:41 2010 Blocked incoming TCP connection request from 10.7.66.14:2064 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:40 2010 Blocked incoming TCP connection request from 10.3.68.73:4882 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:40 2010 Blocked incoming TCP connection request from 10.7.10.154:2862 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:40 2010 Blocked incoming TCP connection request from 10.2.193.156:4938 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:40 2010 Blocked incoming UDP packet from 84.242.233.91:35691 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:40 2010 Blocked incoming UDP packet from 188.122.255.64:26179 to 188.122.249.3:41574
[INFO] Mon Mar 29 12:38:40 2010 Blocked incoming TCP connection request from 10.6.136.145:1279 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:40 2010 Blocked incoming UDP packet from 10.3.68.73:27701 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:40 2010 Blocked incoming UDP packet from 10.1.200.77:61643 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:40 2010 Blocked incoming TCP connection request from 172.16.137.249:3006 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:40 2010 Blocked incoming TCP connection request from 84.242.233.91:2776 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:39 2010 Blocked incoming TCP connection request from 10.12.0.140:1866 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:39 2010 Blocked incoming TCP connection request from 10.7.0.196:2245 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:39 2010 Blocked incoming TCP connection request from 10.2.67.163:49337 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:39 2010 Blocked incoming TCP connection request from 10.3.71.102:4977 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:39 2010 Blocked incoming TCP connection request from 10.4.68.166:4096 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:39 2010 Blocked incoming TCP connection request from 10.6.4.134:63634 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:39 2010 Blocked incoming TCP connection request from 10.1.129.77:64246 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:38 2010 Blocked incoming UDP packet from 10.3.68.73:27701 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:38 2010 Blocked incoming TCP connection request from 10.7.3.57:49958 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:38 2010 Blocked incoming TCP connection request from 10.3.64.194:4692 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:38 2010 Dropped packet from 192.160.0.180 to 188.122.248.202 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:38 2010 Blocked incoming TCP connection request from 172.16.92.27:1313 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:37 2010 Blocked incoming TCP connection request from 10.7.85.166:49406 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:37 2010 Blocked incoming TCP connection request from 10.0.1.161:63852 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:37 2010 Blocked incoming TCP connection request from 10.6.136.145:1279 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:37 2010 Blocked incoming TCP connection request from 10.248.129.220:3962 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:37 2010 Blocked incoming TCP connection request from 172.16.88.31:4618 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:37 2010 Blocked incoming UDP packet from 89.112.122.221:40230 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:37 2010 Blocked incoming TCP connection request from 10.7.11.146:3056 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:37 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:36 2010 Blocked incoming TCP connection request from 10.5.194.107:51577 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:36 2010 Blocked incoming TCP connection request from 10.3.71.102:4977 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:36 2010 Blocked incoming TCP connection request from 10.2.67.163:49337 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:36 2010 Blocked incoming TCP connection request from 10.0.202.248:1041 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:36 2010 Dropped packet from 192.160.0.180 to 188.122.248.202 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:36 2010 Blocked incoming TCP connection request from 10.3.21.220:4995 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:36 2010 Blocked incoming TCP connection request from 172.16.137.249:3006 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:36 2010 Blocked incoming TCP connection request from 10.3.67.213:4313 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:36 2010 Blocked incoming TCP connection request from 10.1.129.77:64246 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:35 2010 Blocked incoming TCP connection request from 172.16.128.125:1444 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:35 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:35 2010 Blocked incoming TCP connection request from 10.7.3.57:49958 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:35 2010 Blocked outgoing TCP packet from 192.154.0.199:2865 to 194.146.142.4:55555 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:38:35 2010 Blocked incoming TCP connection request from 10.1.194.201:3922 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:35 2010 Dropped packet from 192.160.0.180 to 188.122.248.159 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:35 2010 Blocked incoming TCP connection request from 10.7.196.52:64819 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:34 2010 Blocked incoming UDP packet from 188.114.32.237:47182 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:34 2010 Blocked incoming TCP connection request from 10.2.193.156:4938 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:34 2010 Blocked outgoing TCP packet from 192.154.0.197:60017 to 109.188.202.242:27974 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:38:34 2010 Blocked incoming TCP connection request from 172.16.88.31:4618 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:33 2010 Blocked incoming TCP connection request from 10.5.194.107:51577 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:33 2010 Blocked incoming TCP connection request from 10.0.202.248:1041 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:33 2010 Dropped packet from 192.160.0.180 to 188.122.248.159 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:33 2010 Blocked incoming TCP connection request from 10.4.68.166:4096 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:33 2010 Blocked incoming TCP connection request from 10.3.21.220:4995 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:33 2010 Blocked incoming TCP connection request from 10.3.67.213:4313 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:32 2010 Blocked incoming TCP connection request from 172.16.128.125:1444 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:32 2010 Blocked incoming TCP connection request from 10.3.64.194:4692 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:32 2010 Blocked incoming UDP packet from 89.31.88.139:53067 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:32 2010 Blocked incoming TCP connection request from 10.7.196.52:64819 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:32 2010 Dropped packet from 192.160.0.180 to 188.122.248.202 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:31 2010 Blocked incoming TCP connection request from 10.2.193.156:4938 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:31 2010 Blocked incoming TCP connection request from 10.7.85.166:49406 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:31 2010 Blocked incoming TCP connection request from 172.16.108.28:58919 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:31 2010 Blocked incoming TCP connection request from 10.7.64.88:1122 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:31 2010 Blocked incoming TCP connection request from 10.0.1.161:63852 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:31 2010 Blocked incoming TCP connection request from 10.3.64.194:4335 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:31 2010 Blocked incoming TCP connection request from 10.248.129.220:3962 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:31 2010 Blocked incoming TCP connection request from 10.7.11.146:3056 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:30 2010 Blocked incoming UDP packet from 10.2.193.156:27299 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:30 2010 Blocked incoming TCP connection request from 10.4.68.166:4096 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:30 2010 Dropped packet from 192.160.0.180 to 188.122.248.202 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:29 2010 Blocked incoming TCP connection request from 10.2.69.138:1099 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:29 2010 Blocked incoming UDP packet from 109.226.101.126:22972 to 188.122.249.3:41574
[INFO] Mon Mar 29 12:38:29 2010 Blocked incoming TCP connection request from 10.3.64.194:4692 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:29 2010 Blocked incoming TCP connection request from 10.1.194.201:3922 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:29 2010 Dropped packet from 192.160.0.180 to 188.122.248.159 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:29 2010 Dropped packet from 192.160.0.180 to 188.122.248.202 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:28 2010 Blocked incoming TCP connection request from 10.7.85.166:49406 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:28 2010 Blocked incoming TCP connection request from 10.7.64.88:1122 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:28 2010 Blocked incoming TCP connection request from 10.0.1.161:63852 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:28 2010 Blocked incoming TCP packet from 217.113.118.210:61300 to 188.122.249.3:62721 as RST:ACK received but there is no active connection
[INFO] Mon Mar 29 12:38:28 2010 Blocked incoming TCP connection request from 10.248.129.220:3962 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:28 2010 Blocked incoming TCP connection request from 10.7.11.146:3056 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:28 2010 Blocked incoming UDP packet from 10.7.11.146:59039 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:27 2010 Blocked incoming TCP connection request from 10.1.2.200:1859 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:27 2010 Dropped packet from 192.160.0.180 to 188.122.248.159 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:27 2010 Blocked incoming UDP packet from 10.0.202.248:63030 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:27 2010 Dropped packet from 192.160.0.180 to 188.122.248.202 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:27 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:38:27 2010 Blocked incoming TCP connection request from 10.3.75.9:2064 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:27 2010 Blocked incoming UDP packet from 95.65.21.238:35691 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:26 2010 Blocked incoming TCP connection request from 10.7.75.92:1308 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:26 2010 Blocked incoming TCP connection request from 10.1.194.201:3922 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:26 2010 Dropped packet from 192.160.0.180 to 188.122.248.159 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:25 2010 Blocked incoming TCP connection request from 172.16.108.28:58919 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:25 2010 Blocked incoming TCP connection request from 10.3.64.194:4335 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:25 2010 Blocked incoming TCP connection request from 10.2.5.16:3200 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:24 2010 Dropped packet from 192.160.0.180 to 188.122.248.159 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:24 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:38:23 2010 Blocked incoming TCP connection request from 10.2.69.138:1099 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:23 2010 Blocked incoming TCP connection request from 10.7.130.108:56390 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:23 2010 Blocked incoming TCP connection request from 172.16.93.60:56464 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:23 2010 Blocked incoming UDP packet from 89.31.88.139:53067 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:23 2010 Blocked incoming TCP connection request from 85.234.63.250:16796 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:22 2010 Blocked incoming UDP packet from 10.7.144.228:48016 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:22 2010 Blocked incoming TCP connection request from 172.16.108.28:58919 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:22 2010 Blocked incoming UDP packet from 172.16.108.28:28931 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:22 2010 Blocked incoming TCP connection request from 10.5.66.66:1848 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:22 2010 Blocked incoming TCP connection request from 10.5.66.66:1847 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:22 2010 Blocked incoming TCP packet from 217.113.118.210:61300 to 188.122.249.3:62721 as RST:ACK received but there is no active connection
[INFO] Mon Mar 29 12:38:22 2010 Blocked incoming TCP connection request from 10.0.197.102:3833 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:22 2010 Blocked incoming TCP connection request from 10.3.64.194:4335 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:22 2010 Blocked incoming TCP connection request from 10.3.69.73:26053 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:21 2010 Blocked incoming TCP connection request from 10.1.2.200:1859 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:21 2010 Blocked incoming UDP packet from 89.31.88.139:53067 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:21 2010 Blocked incoming TCP connection request from 10.2.131.208:3017 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:21 2010 Blocked incoming TCP connection request from 10.3.75.9:2064 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:21 2010 Blocked incoming UDP packet from 95.65.21.238:35691 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:20 2010 Blocked incoming TCP connection request from 10.0.209.219:1444 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:20 2010 Blocked incoming TCP connection request from 172.16.7.254:2101 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:20 2010 Blocked incoming TCP connection request from 10.2.69.138:1099 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:20 2010 Blocked incoming TCP connection request from 10.7.75.92:1308 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:20 2010 Blocked incoming TCP connection request from 109.226.101.70:3644 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:20 2010 Blocked incoming TCP connection request from 10.2.94.2:3053 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:20 2010 Blocked incoming TCP connection request from 10.14.11.153:3450 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:19 2010 Blocked incoming TCP connection request from 172.16.12.7:5621 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:19 2010 Blocked incoming TCP connection request from 10.3.69.73:26053 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:19 2010 Blocked incoming TCP connection request from 10.2.5.16:3200 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:18 2010 Blocked incoming TCP connection request from 10.1.2.200:1859 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:18 2010 Blocked incoming TCP connection request from 10.3.75.9:2064 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:18 2010 Blocked incoming TCP connection request from 92.243.183.114:34014 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:18 2010 Blocked incoming TCP connection request from 10.4.87.24:63512 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:18 2010 Blocked incoming TCP connection request from 10.4.196.137:16184 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:18 2010 Blocked incoming UDP packet from 123.14.255.151:23024 to 188.122.249.3:41574
[INFO] Mon Mar 29 12:38:18 2010 Blocked incoming TCP connection request from 92.112.65.127:1345 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:18 2010 Blocked incoming UDP packet from 95.65.21.238:35691 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:18 2010 Blocked incoming UDP packet from 85.141.73.47:42653 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:17 2010 Blocked incoming TCP connection request from 10.7.130.108:56390 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:17 2010 Blocked incoming TCP connection request from 10.7.75.92:1308 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:17 2010 Blocked incoming TCP connection request from 172.16.6.215:1417 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:17 2010 Blocked incoming TCP connection request from 172.16.93.60:56464 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:16 2010 Blocked incoming TCP connection request from 172.16.12.7:5621 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:16 2010 Blocked incoming TCP connection request from 10.5.66.66:1848 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:16 2010 Blocked incoming TCP connection request from 10.5.66.66:1847 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:16 2010 Blocked incoming TCP connection request from 10.1.2.3:4608 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:16 2010 Blocked incoming UDP packet from 95.65.21.238:35691 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:16 2010 Blocked incoming TCP connection request from 10.0.197.102:3833 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:16 2010 Dropped packet from 192.160.0.180 to 188.122.252.151 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:16 2010 Blocked incoming TCP connection request from 10.14.7.116:2824 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:16 2010 Blocked incoming TCP connection request from 10.2.5.16:3200 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:15 2010 Blocked incoming TCP connection request from 10.2.131.208:3017 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:15 2010 Blocked incoming TCP connection request from 172.16.7.254:2101 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:14 2010 Blocked incoming TCP connection request from 10.0.209.219:1444 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:14 2010 Dropped packet from 192.160.0.180 to 188.122.252.151 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:14 2010 Blocked incoming TCP connection request from 10.7.130.108:56390 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:14 2010 Blocked incoming TCP connection request from 10.2.94.2:3053 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:14 2010 Blocked incoming TCP connection request from 172.16.6.215:1417 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:14 2010 Blocked incoming TCP connection request from 10.13.0.60:55227 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:14 2010 Blocked incoming TCP connection request from 172.16.93.60:56464 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:14 2010 Blocked incoming TCP connection request from 10.14.11.153:3450 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:13 2010 Blocked incoming TCP connection request from 10.5.66.66:1848 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:13 2010 Blocked incoming TCP connection request from 10.5.66.66:1847 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:13 2010 Blocked incoming UDP packet from 85.141.73.47:42653 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:13 2010 Blocked incoming TCP connection request from 10.0.197.102:3833 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:13 2010 Blocked incoming UDP packet from 89.222.193.145:55800 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:12 2010 Blocked incoming TCP connection request from 10.1.194.136:1465 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:12 2010 Blocked incoming TCP connection request from 10.4.129.66:49400 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:12 2010 Blocked incoming TCP connection request from 10.2.131.208:3017 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:12 2010 Blocked incoming TCP connection request from 10.4.87.24:63512 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:12 2010 Blocked incoming TCP connection request from 10.4.196.137:16184 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:12 2010 Blocked incoming TCP connection request from 10.2.73.9:65314 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:12 2010 Blocked incoming TCP connection request from 92.112.65.127:1345 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:12 2010 Blocked incoming TCP connection request from 172.16.7.254:2101 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:11 2010 Blocked incoming TCP connection request from 10.0.209.219:1444 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:11 2010 Blocked incoming TCP connection request from 10.14.64.178:2271 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:11 2010 Blocked incoming TCP connection request from 10.2.94.2:3053 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:11 2010 Blocked incoming TCP connection request from 79.142.173.155:3119 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:11 2010 Blocked incoming TCP connection request from 10.14.11.153:3450 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:11 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:10 2010 Blocked incoming TCP connection request from 10.1.2.3:4608 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:10 2010 Dropped packet from 192.160.0.180 to 188.122.252.151 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:10 2010 Blocked incoming TCP connection request from 10.14.7.116:2824 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:09 2010 Blocked incoming TCP connection request from 10.14.1.156:2520 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:09 2010 Blocked incoming TCP connection request from 92.243.183.114:34014 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:09 2010 Blocked incoming TCP connection request from 10.4.196.137:16184 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:09 2010 Blocked incoming TCP connection request from 10.4.87.24:63512 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:09 2010 Blocked incoming TCP connection request from 10.7.69.219:2191 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:08 2010 Blocked incoming UDP packet from 80.90.10.114:55170 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:08 2010 Dropped packet from 192.160.0.180 to 188.122.252.151 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:08 2010 Blocked incoming TCP connection request from 10.13.0.60:55227 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:08 2010 Blocked incoming TCP connection request from 10.5.196.102:1554 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:07 2010 Blocked incoming UDP packet from 10.5.194.107:58995 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:07 2010 Blocked incoming TCP connection request from 10.7.68.194:56922 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:07 2010 Blocked incoming TCP connection request from 10.1.2.3:4608 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:07 2010 Blocked incoming TCP connection request from 10.6.1.78:1474 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:07 2010 Dropped packet from 192.160.0.180 to 188.122.252.151 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:07 2010 Blocked incoming TCP connection request from 10.14.7.116:2824 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:07 2010 Blocked incoming TCP connection request from 10.6.136.117:3309 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:06 2010 Blocked incoming TCP connection request from 10.1.194.136:1465 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:06 2010 Blocked incoming TCP connection request from 10.4.129.66:49400 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:06 2010 Blocked incoming TCP connection request from 10.2.73.9:65314 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:06 2010 Blocked incoming TCP connection request from 10.7.2.200:1034 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:05 2010 Blocked incoming UDP packet from 10.4.68.103:51168 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:05 2010 Blocked incoming UDP packet from 10.13.65.14:64572 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:05 2010 Blocked incoming TCP connection request from 10.14.64.178:2271 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:05 2010 Blocked incoming TCP connection request from 172.16.149.217:3003 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:05 2010 Dropped packet from 192.160.0.180 to 188.122.252.151 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:05 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:38:05 2010 Blocked incoming UDP packet from 188.122.255.76:55590 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:05 2010 Blocked incoming TCP connection request from 10.13.0.60:55227 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:04 2010 Blocked incoming UDP packet from 89.222.193.145:55800 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:03 2010 Blocked incoming TCP connection request from 10.1.194.136:1465 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:03 2010 Blocked incoming TCP connection request from 10.14.1.156:2520 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:03 2010 Blocked incoming TCP connection request from 10.4.129.66:49400 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:03 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:03 2010 Blocked incoming TCP connection request from 10.2.199.135:3275 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:03 2010 Blocked incoming TCP connection request from 10.7.69.219:2191 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:03 2010 Blocked incoming UDP packet from 172.16.42.22:35691 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:03 2010 Blocked incoming TCP connection request from 10.2.73.9:65314 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:03 2010 Blocked incoming TCP connection request from 10.2.67.5:49175 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:03 2010 Blocked incoming ICMP error message (ICMP type 3) from 98.248.48.10 to 188.122.249.3 as there is no UDP session active between 188.122.249.3:41574 and 192.168.1.105:19095
[INFO] Mon Mar 29 12:38:02 2010 Blocked incoming TCP connection request from 10.14.64.178:2271 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:02 2010 Blocked incoming TCP connection request from 172.16.65.205:63800 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:02 2010 Blocked incoming UDP packet from 89.222.193.145:55800 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:38:02 2010 Blocked incoming TCP connection request from 10.5.196.102:1554 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:02 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:02 2010 Blocked incoming TCP connection request from 10.7.1.225:2992 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:01 2010 Blocked incoming UDP packet from 10.1.2.3:14263 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:38:01 2010 Blocked incoming TCP connection request from 10.7.68.194:56922 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:01 2010 Blocked incoming TCP connection request from 10.6.1.78:1474 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:01 2010 Blocked incoming TCP connection request from 10.5.128.2:4914 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:38:00 2010 Blocked incoming TCP connection request from 10.6.136.117:3309 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:00 2010 Blocked incoming TCP connection request from 10.14.1.156:2520 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:00 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:38:00 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:38:00 2010 Blocked incoming UDP packet from 10.0.193.29:26016 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:00 2010 Blocked incoming TCP connection request from 10.240.66.131:51543 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:00 2010 Blocked incoming TCP connection request from 10.7.69.219:2191 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:38:00 2010 Blocked incoming TCP connection request from 10.7.2.200:1034 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:59 2010 Blocked outgoing TCP packet from 192.154.0.199:2868 to 74.125.87.99:80 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:59 2010 Blocked incoming UDP packet from 80.90.10.114:55170 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:59 2010 Blocked incoming TCP connection request from 172.16.149.217:3003 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:59 2010 Blocked incoming TCP connection request from 10.2.197.245:2102 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:59 2010 Blocked outgoing TCP packet from 192.154.0.199:2791 to 195.128.76.180:80 as ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:59 2010 Blocked incoming TCP connection request from 10.5.196.102:1554 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:59 2010 Blocked incoming TCP connection request from 10.7.68.3:60563 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:58 2010 Blocked incoming TCP connection request from 10.7.68.194:56922 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:58 2010 Blocked incoming TCP connection request from 10.6.1.78:1474 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:58 2010 Blocked incoming UDP packet from 80.90.10.114:55170 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:58 2010 Blocked outgoing TCP packet from 192.154.0.199:2782 to 91.215.125.107:6900 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:58 2010 Blocked outgoing TCP packet from 192.154.0.199:2791 to 195.128.76.180:80 as ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:57 2010 Blocked incoming TCP connection request from 10.6.136.117:3309 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:57 2010 Blocked incoming TCP connection request from 10.2.199.135:3275 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:57 2010 Blocked incoming TCP connection request from 10.2.67.5:49175 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:57 2010 Blocked incoming TCP connection request from 10.7.2.200:1034 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:57 2010 Blocked outgoing TCP packet from 192.154.0.199:2791 to 195.128.76.180:80 as ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:57 2010 Blocked incoming TCP connection request from 10.3.3.198:3189 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:57 2010 Blocked incoming UDP packet from 94.188.30.26:50774 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:57 2010 Blocked incoming TCP connection request from 10.5.128.2:4914 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:56 2010 Blocked incoming TCP connection request from 172.16.149.217:3003 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:56 2010 Blocked incoming TCP connection request from 10.2.128.67:3664 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:56 2010 Blocked outgoing TCP packet from 192.154.0.199:2842 to 95.79.208.198:48283 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:56 2010 Blocked incoming TCP connection request from 172.16.65.205:63800 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:56 2010 Blocked incoming TCP connection request from 10.7.1.225:2992 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:56 2010 Blocked outgoing TCP packet from 192.154.0.197:63943 to 85.174.86.168:48602 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:55 2010 Blocked outgoing TCP packet from 192.154.0.199:2791 to 195.128.76.180:80 as ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:55 2010 Blocked incoming TCP connection request from 10.0.132.79:3151 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:55 2010 Blocked outgoing TCP packet from 192.154.0.197:62347 to 109.248.66.89:54248 as ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:55 2010 Blocked incoming TCP connection request from 78.106.68.35:3842 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:55 2010 Blocked incoming TCP connection request from 94.153.244.67:3510 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:55 2010 Blocked incoming TCP connection request from 10.4.71.94:2994 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:55 2010 Blocked incoming TCP connection request from 172.16.112.107:4731 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:55 2010 Blocked incoming TCP connection request from 10.5.128.2:4914 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:54 2010 Blocked outgoing TCP packet from 192.154.0.199:2791 to 195.128.76.180:80 as ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:54 2010 Blocked incoming ICMP error message (ICMP type 3) from 110.33.164.105 to 188.122.249.3 as there is no UDP session active between 188.122.249.3:41574 and 192.168.1.66:16790
[INFO] Mon Mar 29 12:37:54 2010 Blocked incoming TCP connection request from 10.2.199.135:3275 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:54 2010 Blocked incoming TCP connection request from 10.240.66.131:51543 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:54 2010 Blocked incoming TCP connection request from 10.2.67.5:49175 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:54 2010 Blocked incoming UDP packet from 10.2.67.5:14824 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:53 2010 Blocked incoming TCP connection request from 10.2.155.68:2781 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:53 2010 Blocked incoming TCP connection request from 172.16.65.205:63800 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:53 2010 Blocked incoming TCP connection request from 10.2.197.245:2102 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:53 2010 Blocked outgoing TCP packet from 192.154.0.199:2812 to 94.181.8.89:13579 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:53 2010 Blocked outgoing TCP packet from 192.154.0.199:2825 to 84.52.29.40:49988 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:53 2010 Blocked incoming TCP connection request from 10.7.1.225:2992 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:53 2010 Blocked incoming TCP connection request from 10.7.68.3:60563 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:52 2010 Blocked incoming UDP packet from 87.255.17.215:63036 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:52 2010 Blocked incoming TCP connection request from 178.167.54.183:62216 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:52 2010 Blocked incoming TCP connection request from 10.1.194.201:3593 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:52 2010 Blocked outgoing TCP packet from 192.154.0.197:60065 to 94.100.181.62:2041 as RST:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:52 2010 Blocked incoming UDP packet from 94.137.214.133:34596 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:52 2010 Blocked incoming UDP packet from 10.5.198.61:59039 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:51 2010 Blocked incoming TCP connection request from 92.101.129.159:3288 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:51 2010 Blocked incoming UDP packet from 109.87.120.247:40777 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:51 2010 Blocked incoming TCP connection request from 10.240.66.131:51543 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:51 2010 Blocked incoming TCP connection request from 172.16.112.107:4731 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:51 2010 Blocked incoming TCP connection request from 93.185.189.61:64127 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:51 2010 Blocked incoming TCP connection request from 87.255.17.215:50185 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:51 2010 Blocked incoming TCP connection request from 10.7.71.150:54610 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:50 2010 Blocked incoming TCP connection request from 10.3.3.198:3189 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:50 2010 Blocked incoming TCP connection request from 10.2.197.157:3426 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:50 2010 Blocked incoming TCP connection request from 10.2.128.67:3664 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:50 2010 Blocked incoming TCP connection request from 10.2.197.245:2102 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:50 2010 Dropped packet from 192.160.0.180 to 5.15.242.14 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:50 2010 Blocked incoming TCP connection request from 10.7.68.3:60563 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:49 2010 Blocked incoming TCP connection request from 10.0.132.79:3151 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:49 2010 Blocked outgoing TCP packet from 192.154.0.197:60879 to 89.178.94.83:52848 as RST:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:49 2010 Blocked incoming TCP connection request from 78.106.68.35:3842 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:49 2010 Blocked incoming TCP connection request from 10.4.71.94:2994 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:49 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:49 2010 Blocked incoming UDP packet from 94.137.214.133:34596 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:48 2010 Blocked outgoing TCP packet from 192.154.0.199:2885 to 212.142.92.142:19507 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:48 2010 Blocked outgoing TCP packet from 192.154.0.199:2795 to 195.64.203.210:36999 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:48 2010 Blocked outgoing TCP packet from 192.154.0.199:2835 to 93.80.76.51:32119 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:48 2010 Blocked incoming TCP connection request from 10.3.71.102:4873 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:48 2010 Blocked outgoing TCP packet from 192.154.0.197:61519 to 81.195.28.62:49442 as RST:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:48 2010 Dropped packet from 192.160.0.180 to 5.15.242.14 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:48 2010 Blocked incoming UDP packet from 188.122.255.64:26179 to 188.122.249.3:41574
[INFO] Mon Mar 29 12:37:47 2010 Blocked incoming TCP connection request from 10.2.155.68:2781 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:47 2010 Blocked incoming TCP connection request from 10.3.3.198:3189 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:47 2010 Blocked incoming TCP connection request from 10.6.67.211:3910 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:47 2010 Blocked incoming TCP connection request from 10.2.128.67:3664 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:47 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:47 2010 Blocked incoming TCP connection request from 172.16.148.17:1719 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:47 2010 Blocked incoming TCP connection request from 10.0.132.79:3151 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:47 2010 Blocked incoming TCP connection request from 10.4.200.6:3874 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:46 2010 Blocked incoming UDP packet from 87.255.17.215:63036 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:46 2010 Blocked incoming TCP connection request from 178.167.54.183:62216 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:46 2010 Blocked incoming TCP connection request from 10.1.194.201:3593 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:46 2010 Blocked incoming TCP connection request from 78.106.68.35:3842 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:46 2010 Blocked incoming TCP connection request from 10.4.71.94:2994 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:46 2010 Dropped packet from 192.160.0.180 to 1.1.1.18 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:45 2010 Blocked incoming TCP connection request from 10.2.72.161:1075 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:45 2010 Blocked incoming TCP connection request from 92.101.129.159:3288 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:45 2010 Blocked incoming UDP packet from 109.87.120.247:40777 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:45 2010 Blocked incoming TCP connection request from 93.185.189.61:64127 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:45 2010 Blocked incoming TCP connection request from 109.124.8.69:1190 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:45 2010 Blocked incoming TCP connection request from 10.7.71.150:54610 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:44 2010 Blocked incoming TCP connection request from 10.2.155.68:2781 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:44 2010 Blocked incoming TCP connection request from 172.16.149.217:2931 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:44 2010 Blocked incoming TCP connection request from 188.122.255.8:3578 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:44 2010 Blocked incoming TCP connection request from 10.2.197.157:3426 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:44 2010 Blocked incoming TCP connection request from 10.2.67.163:65080 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:44 2010 Dropped packet from 192.160.0.180 to 1.1.1.18 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:44 2010 Blocked incoming UDP packet from 92.101.129.159:55686 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:44 2010 Dropped packet from 192.160.0.180 to 5.15.242.14 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:44 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:44 2010 Blocked outgoing TCP packet from 192.154.0.199:2821 to 67.82.59.100:46340 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:43 2010 Blocked incoming TCP connection request from 10.0.197.197:4579 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:43 2010 Blocked incoming TCP connection request from 10.3.68.206:2229 to 10.3.64.17:18768
[INFO] Mon Mar 29 12:37:43 2010 Blocked incoming UDP packet from 87.255.17.215:63036 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:43 2010 Blocked incoming TCP connection request from 10.1.194.201:3593 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:43 2010 Blocked incoming UDP packet from 10.2.73.9:39956 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:43 2010 Blocked incoming TCP connection request from 188.122.255.76:15630 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:43 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:42 2010 Blocked incoming TCP connection request from 10.3.71.102:4873 to 10.3.64.17:41574
[WARN] Mon Mar 29 12:37:42 2010 A network computer (Nokia-N900-51-1) was assigned the IP address of 192.154.0.196.
[INFO] Mon Mar 29 12:37:42 2010 Dropped packet from 192.160.0.180 to 5.15.242.14 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:42 2010 Dropped packet from 192.160.0.180 to 95.27.16.21 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:42 2010 Blocked incoming UDP packet from 109.87.120.247:40777 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:42 2010 Blocked incoming TCP connection request from 93.185.189.61:64127 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:42 2010 Blocked incoming TCP connection request from 87.255.17.215:50185 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:41 2010 Blocked incoming TCP connection request from 10.7.71.150:54610 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:41 2010 Blocked incoming TCP connection request from 10.0.202.8:62372 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:41 2010 Blocked incoming TCP connection request from 10.2.197.157:3426 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:41 2010 Blocked incoming TCP connection request from 10.7.82.7:61395 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:41 2010 Blocked incoming TCP connection request from 10.6.67.211:3910 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:41 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:41 2010 Blocked incoming TCP connection request from 172.16.73.212:3847 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:41 2010 dlink: Wireless system with MAC address A87B39C3F238 secured and linked
[INFO] Mon Mar 29 12:37:41 2010 Blocked outgoing TCP packet from 192.154.0.199:2822 to 188.112.147.95:58294 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:41 2010 Dropped packet from 192.160.0.180 to 5.15.242.14 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:41 2010 Blocked incoming TCP connection request from 10.4.200.6:3874 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:41 2010 Blocked incoming UDP packet from 109.87.120.247:40777 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:41 2010 Blocked incoming UDP packet from 213.5.241.43:60113 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:41 2010 Blocked incoming TCP connection request from 172.16.148.17:1719 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:40 2010 Blocked incoming TCP connection request from 10.3.68.206:2229 to 10.3.64.17:18768
[INFO] Mon Mar 29 12:37:40 2010 Blocked incoming TCP connection request from 10.7.149.48:57216 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:40 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:40 2010 Dropped packet from 192.160.0.180 to 1.1.1.18 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:39 2010 Blocked incoming TCP connection request from 10.3.71.102:4873 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:39 2010 Blocked incoming TCP connection request from 10.2.72.161:1075 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:39 2010 Blocked incoming TCP connection request from 10.13.129.11:4072 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:39 2010 Blocked incoming TCP connection request from 89.112.122.221:3062 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:39 2010 Dropped packet from 192.160.0.180 to 5.15.242.14 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:39 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:37:39 2010 Blocked incoming TCP connection request from 62.106.105.55:3406 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:39 2010 Blocked incoming TCP connection request from 172.16.21.81:3832 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:39 2010 Blocked incoming TCP connection request from 10.2.66.8:1778 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:38 2010 Blocked incoming TCP connection request from 10.6.67.211:3910 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:38 2010 Blocked incoming TCP connection request from 172.16.149.217:2931 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:38 2010 Blocked incoming TCP connection request from 188.122.255.8:3578 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:38 2010 Blocked incoming TCP connection request from 10.2.67.163:65080 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:38 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:38 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:37:38 2010 Dropped packet from 192.160.0.180 to 1.1.1.18 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:38 2010 Blocked incoming TCP connection request from 172.16.73.212:3847 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:38 2010 Blocked incoming UDP packet from 213.178.42.169:56836 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:38 2010 Allowed configuration authentication by IP address 192.154.0.197
[INFO] Mon Mar 29 12:37:38 2010 dlink: Wireless system with MAC address A87B39C3F238 associated
[INFO] Mon Mar 29 12:37:38 2010 Blocked incoming TCP connection request from 10.0.198.89:3231 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:38 2010 Blocked incoming TCP connection request from 10.4.200.6:3874 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:37 2010 Blocked incoming TCP connection request from 172.16.148.17:1719 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:37 2010 Blocked incoming TCP connection request from 10.0.197.197:4579 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:37 2010 Blocked outgoing TCP packet from 192.154.0.199:2784 to 79.165.181.39:60522 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:37 2010 Blocked outgoing TCP packet from 192.154.0.199:2781 to 95.25.86.122:48633 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:37 2010 Blocked incoming TCP connection request from 188.122.255.76:15630 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:37 2010 DNS relay ALG rejected packet from 0.0.0.0:4107 to 81.28.160.111:53
[INFO] Mon Mar 29 12:37:37 2010 Dropped packet from 0.0.0.0 to 81.28.160.111 (IP protocol 17) as unable to create new session
[INFO] Mon Mar 29 12:37:37 2010 Dropped packet from 192.160.0.180 to 109.226.70.19 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:37 2010 Dropped packet from 192.160.0.180 to 1.1.1.18 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:37 2010 Dropped packet from 192.160.0.180 to 109.226.66.63 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:36 2010 Allowed configuration authentication by IP address 192.154.0.199
[INFO] Mon Mar 29 12:37:36 2010 Blocked incoming TCP connection request from 10.2.72.161:1075 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:36 2010 Blocked incoming TCP connection request from 62.106.105.55:3406 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:36 2010 Dropped packet from 192.160.0.180 to 95.27.16.21 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:36 2010 Blocked incoming UDP packet from 213.5.241.43:60113 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:35 2010 Blocked incoming TCP connection request from 10.0.202.8:62372 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:35 2010 Blocked incoming UDP packet from 10.2.129.145:14055 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:35 2010 Blocked incoming TCP connection request from 172.16.149.217:2931 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:35 2010 Blocked incoming TCP connection request from 188.122.255.8:3578 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:35 2010 Blocked incoming TCP connection request from 10.7.82.7:61395 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:35 2010 Blocked incoming TCP connection request from 10.2.67.163:65080 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:35 2010 Dropped packet from 192.160.0.180 to 1.1.1.18 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:35 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:37:35 2010 Dropped packet from 192.160.0.180 to 109.226.66.63 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:35 2010 Dropped packet from 192.160.0.180 to 109.226.70.19 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:35 2010 Blocked incoming TCP connection request from 10.5.12.134:1196 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:35 2010 Blocked incoming TCP connection request from 10.0.198.89:3231 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:35 2010 Blocked incoming TCP connection request from 10.3.3.241:4166 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:35 2010 Dropped packet from 192.160.0.180 to 95.79.10.22 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:35 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:34 2010 Blocked incoming TCP connection request from 10.0.197.197:4579 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:34 2010 Blocked incoming TCP connection request from 10.3.64.17:61173 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:34 2010 Blocked incoming TCP connection request from 10.2.9.195:1590 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:34 2010 Blocked incoming TCP connection request from 188.122.255.76:15630 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:34 2010 Blocked incoming TCP connection request from 10.7.149.48:57216 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:34 2010 Blocked outgoing TCP packet from 192.154.0.199:2786 to 193.46.201.186:6112 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:34 2010 Blocked incoming TCP connection request from 10.6.65.111:2227 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:34 2010 Blocked incoming TCP connection request from 172.16.27.33:2494 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:33 2010 Blocked incoming TCP connection request from 10.13.129.11:4072 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:33 2010 Dropped packet from 192.160.0.180 to 192.88.99.1 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:33 2010 Dropped packet from 192.160.0.180 to 95.27.16.21 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:33 2010 Dropped packet from 192.160.0.180 to 95.79.10.22 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:33 2010 Blocked incoming TCP connection request from 10.2.89.16:3607 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:33 2010 Blocked incoming UDP packet from 113.132.237.19:12885 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:33 2010 Dropped packet from 192.160.0.180 to 109.226.103.139 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:33 2010 Blocked incoming TCP connection request from 172.16.21.81:3832 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:33 2010 Blocked incoming TCP connection request from 10.2.66.8:1778 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:32 2010 Blocked incoming TCP connection request from 10.0.202.8:62372 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:32 2010 Blocked incoming TCP connection request from 10.0.195.150:3526 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:32 2010 Blocked incoming TCP connection request from 10.7.82.7:61395 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:32 2010 Blocked incoming UDP packet from 10.0.209.122:6546 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:32 2010 Blocked incoming UDP packet from 10.1.200.75:63030 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:32 2010 Blocked incoming TCP connection request from 10.1.130.189:4499 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:31 2010 Blocked incoming TCP connection request from 113.132.237.19:3332 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:31 2010 Blocked incoming TCP connection request from 10.3.130.216:3521 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:31 2010 Dropped packet from 192.160.0.180 to 109.226.103.139 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:31 2010 Blocked incoming TCP connection request from 10.5.193.133:3421 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:31 2010 Blocked incoming UDP packet from 10.7.149.48:41916 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:31 2010 Dropped packet from 192.160.0.180 to 109.226.66.63 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:31 2010 Dropped packet from 192.160.0.180 to 109.226.70.19 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:31 2010 Blocked outgoing TCP packet from 192.154.0.199:2893 to 114.39.97.157:23692 as FIN:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:30 2010 Blocked incoming TCP connection request from 10.3.69.73:26028 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:30 2010 Blocked incoming TCP connection request from 10.13.129.11:4072 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:30 2010 Blocked incoming TCP connection request from 109.226.101.70:3565 to 188.122.249.3:35159
[INFO] Mon Mar 29 12:37:30 2010 Blocked incoming TCP connection request from 10.14.2.102:2588 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:30 2010 Blocked incoming TCP connection request from 10.0.135.115:2762 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:30 2010 Blocked incoming TCP connection request from 172.16.21.81:3832 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:30 2010 Blocked incoming TCP connection request from 10.5.136.26:9273 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:29 2010 Blocked incoming TCP connection request from 10.2.66.8:1778 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:29 2010 Blocked incoming TCP connection request from 172.16.81.86:1873 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:29 2010 Blocked outgoing TCP packet from 192.154.0.199:2783 to 95.105.5.83:64004 as FIN:PSH:ACK received but there is no active connection
[INFO] Mon Mar 29 12:37:29 2010 Dropped packet from 192.160.0.180 to 109.226.66.63 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:29 2010 Dropped packet from 192.160.0.180 to 109.226.70.19 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:29 2010 Blocked incoming TCP connection request from 10.5.12.134:1196 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:29 2010 Blocked incoming TCP connection request from 10.3.3.241:4166 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:29 2010 Dropped packet from 192.160.0.180 to 95.79.10.22 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:29 2010 Blocked incoming TCP connection request from 10.1.130.189:4499 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:29 2010 Blocked incoming TCP connection request from 10.7.196.52:61165 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:28 2010 WAN interface speed measurement aborted as they did not converge
[INFO] Mon Mar 29 12:37:28 2010 Blocked incoming TCP connection request from 10.3.130.216:3521 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:28 2010 Blocked incoming TCP connection request from 10.3.4.12:2555 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:28 2010 Blocked incoming TCP connection request from 10.3.64.17:61173 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:28 2010 Blocked incoming TCP connection request from 10.2.9.195:1590 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:28 2010 Blocked incoming TCP connection request from 10.13.136.75:55890 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:28 2010 Blocked incoming UDP packet from 172.16.94.204:38636 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:28 2010 Blocked incoming TCP connection request from 172.16.27.33:2494 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:28 2010 Blocked incoming TCP connection request from 10.3.69.73:26028 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:28 2010 Blocked incoming TCP connection request from 10.6.65.111:2227 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:27 2010 Blocked incoming TCP connection request from 10.2.89.16:3607 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:27 2010 Blocked incoming TCP connection request from 10.3.66.130:1429 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:27 2010 Blocked incoming TCP connection request from 10.4.200.6:3826 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:26 2010 Blocked incoming TCP connection request from 10.14.4.169:1205 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:26 2010 Blocked incoming TCP connection request from 10.0.195.150:3526 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:26 2010 Blocked incoming TCP connection request from 10.5.12.134:1196 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:26 2010 Blocked incoming TCP connection request from 10.3.3.241:4166 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:25 2010 Blocked incoming TCP connection request from 10.3.64.17:61173 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:25 2010 Blocked incoming TCP connection request from 10.2.9.195:1590 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:25 2010 Blocked incoming TCP connection request from 10.5.193.133:3421 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:25 2010 Blocked incoming TCP connection request from 10.6.65.111:2227 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:25 2010 Blocked incoming TCP connection request from 172.16.27.33:2494 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:25 2010 Blocked incoming TCP connection request from 10.3.67.213:3975 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:25 2010 Blocked incoming TCP connection request from 10.2.198.4:2951 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:24 2010 Blocked incoming TCP connection request from 10.2.89.16:3607 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:24 2010 Blocked incoming TCP connection request from 10.14.2.102:2588 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:24 2010 Blocked incoming TCP connection request from 10.0.135.115:2762 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:24 2010 Blocked incoming TCP connection request from 10.5.136.26:9273 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:23 2010 Blocked incoming TCP connection request from 10.0.195.150:3526 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:23 2010 Blocked incoming TCP connection request from 172.16.81.86:1873 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:23 2010 Blocked incoming UDP packet from 10.0.209.122:6546 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:23 2010 Blocked incoming TCP connection request from 10.7.196.52:61165 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:22 2010 Blocked incoming TCP connection request from 10.2.65.227:4486 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:22 2010 Blocked incoming TCP connection request from 172.16.97.102:1178 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:22 2010 Blocked incoming TCP connection request from 10.3.4.12:2555 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:22 2010 Blocked incoming TCP connection request from 10.0.198.71:2874 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:22 2010 Blocked incoming TCP connection request from 10.5.193.133:3421 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:22 2010 Blocked incoming TCP connection request from 10.13.136.75:55890 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:22 2010 Blocked incoming TCP connection request from 172.16.94.153:1998 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:21 2010 Blocked incoming TCP connection request from 10.3.64.17:62455 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:21 2010 Blocked incoming TCP connection request from 10.0.143.67:4715 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:21 2010 Blocked incoming TCP connection request from 10.14.2.102:2588 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:21 2010 Blocked incoming TCP connection request from 10.0.135.115:2762 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:21 2010 Blocked incoming TCP connection request from 10.3.66.130:1429 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:21 2010 Blocked incoming TCP connection request from 10.4.200.6:3826 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:21 2010 Blocked incoming TCP connection request from 10.5.136.26:9273 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:20 2010 Blocked incoming TCP connection request from 10.14.4.169:1205 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:20 2010 Blocked incoming TCP connection request from 172.16.81.86:1873 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:20 2010 Blocked incoming TCP connection request from 10.2.197.242:3714 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:20 2010 Blocked incoming TCP connection request from 10.7.2.10:2692 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:20 2010 Blocked incoming UDP packet from 10.7.11.32:43812 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:20 2010 Blocked incoming TCP connection request from 10.7.196.52:61165 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:19 2010 Blocked incoming TCP connection request from 10.0.198.71:2874 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:19 2010 Blocked incoming TCP connection request from 10.3.4.12:2555 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:19 2010 Blocked incoming TCP connection request from 10.13.136.75:55890 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:19 2010 Blocked incoming TCP connection request from 10.3.67.213:3975 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:18 2010 Blocked incoming TCP connection request from 10.2.198.4:2951 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:18 2010 Blocked incoming UDP packet from 10.7.201.101:10227 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:18 2010 Blocked incoming TCP connection request from 10.6.4.134:63587 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:18 2010 Blocked incoming TCP connection request from 10.7.75.92:4049 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:18 2010 Blocked incoming TCP connection request from 10.3.66.130:1429 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:18 2010 Blocked incoming TCP connection request from 10.4.200.6:3826 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:17 2010 Blocked incoming UDP packet from 10.4.200.6:28176 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:17 2010 Blocked incoming TCP connection request from 10.14.4.169:1205 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:17 2010 Blocked incoming TCP connection request from 10.7.66.14:1808 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:16 2010 Blocked incoming TCP connection request from 10.2.65.227:4486 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:16 2010 Blocked incoming TCP connection request from 172.16.97.102:1178 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:16 2010 Blocked incoming TCP connection request from 10.3.64.17:62447 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:16 2010 Blocked incoming TCP connection request from 172.16.94.153:1998 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:16 2010 Blocked incoming TCP connection request from 10.3.67.213:3975 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:15 2010 Blocked incoming TCP connection request from 10.2.198.4:2951 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:15 2010 Blocked incoming TCP connection request from 10.3.64.17:62455 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:15 2010 Blocked incoming TCP connection request from 10.0.143.67:4715 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:15 2010 Blocked incoming TCP connection request from 10.3.65.157:3899 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:14 2010 Blocked incoming UDP packet from 10.0.14.133:19913 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:14 2010 Blocked incoming TCP connection request from 10.2.197.242:3714 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:14 2010 Dropped packet from 192.160.0.180 to 85.114.172.201 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:14 2010 Blocked incoming TCP connection request from 10.7.2.10:2692 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:14 2010 Blocked incoming UDP packet from 10.2.197.245:24728 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:14 2010 Blocked incoming TCP connection request from 10.5.192.224:53122 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:13 2010 Blocked incoming UDP packet from 10.0.155.19:56287 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:13 2010 Blocked incoming TCP connection request from 10.2.65.227:4486 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:13 2010 Blocked incoming TCP connection request from 172.16.97.102:1178 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:13 2010 Blocked incoming TCP connection request from 172.16.94.153:1998 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:12 2010 Blocked incoming TCP connection request from 10.0.143.67:4715 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:12 2010 Blocked incoming UDP packet from 10.0.143.67:32100 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:12 2010 Blocked incoming TCP connection request from 10.6.4.134:63587 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:12 2010 Blocked incoming TCP connection request from 10.3.64.17:62455 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:12 2010 Dropped packet from 192.160.0.180 to 85.114.172.201 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:12 2010 Blocked incoming TCP connection request from 10.7.75.92:4049 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:11 2010 Blocked incoming TCP connection request from 10.2.197.242:3714 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:37:11 2010 Blocked incoming TCP connection request from 10.7.2.10:2692 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:11 2010 Blocked incoming TCP connection request from 10.7.196.52:60767 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:11 2010 Blocked incoming TCP connection request from 10.7.66.14:1808 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:10 2010 Blocked incoming TCP connection request from 10.3.64.17:62447 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:10 2010 Blocked incoming TCP connection request from 172.16.138.91:59742 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:09 2010 Blocked incoming TCP connection request from 10.6.4.134:63587 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:09 2010 Blocked incoming TCP connection request from 10.7.75.92:4049 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:09 2010 Blocked incoming UDP packet from 10.6.136.145:63030 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:09 2010 Blocked incoming TCP connection request from 10.3.65.157:3899 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:09 2010 Blocked incoming TCP connection request from 10.5.15.18:51348 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:08 2010 Blocked incoming UDP packet from 10.0.195.150:48384 to 10.3.64.17:41575
[INFO] Mon Mar 29 12:37:08 2010 Dropped packet from 192.160.0.180 to 85.114.172.201 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:08 2010 Blocked incoming TCP connection request from 10.5.192.224:53122 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:08 2010 Blocked incoming TCP connection request from 10.7.66.14:1808 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:07 2010 Blocked incoming TCP connection request from 10.3.64.17:62447 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:07 2010 Blocked incoming TCP connection request from 172.16.95.16:8358 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:07 2010 Blocked incoming TCP connection request from 10.5.193.167:3122 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:06 2010 Blocked incoming TCP connection request from 172.16.7.254:1474 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:06 2010 Dropped packet from 192.160.0.180 to 85.114.172.201 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:06 2010 Blocked incoming TCP connection request from 172.16.6.215:1404 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:06 2010 Blocked incoming TCP connection request from 10.3.65.157:3899 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:05 2010 Blocked incoming TCP connection request from 10.2.69.138:4414 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:05 2010 Blocked incoming TCP connection request from 10.3.69.73:26019 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:05 2010 Dropped packet from 192.160.0.180 to 85.114.172.201 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:05 2010 Blocked incoming TCP connection request from 10.5.192.224:53122 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:05 2010 Blocked incoming TCP connection request from 10.7.196.52:60767 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:04 2010 Blocked incoming TCP connection request from 10.1.129.77:64221 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:04 2010 Blocked incoming TCP connection request from 172.16.138.91:59742 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:04 2010 Blocked incoming TCP connection request from 172.16.94.97:57999 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:04 2010 Dropped packet from 192.160.0.180 to 85.114.161.224 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:04 2010 Blocked incoming TCP connection request from 10.5.193.167:3122 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:03 2010 Dropped packet from 192.160.0.180 to 85.114.172.201 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:03 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:37:03 2010 Blocked incoming TCP connection request from 172.16.129.197:2901 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:03 2010 Blocked incoming TCP connection request from 10.2.65.12:54901 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:03 2010 Blocked incoming TCP connection request from 172.16.6.215:1404 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:03 2010 Blocked incoming TCP connection request from 10.5.195.140:63821 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:03 2010 Blocked incoming TCP connection request from 10.5.15.18:51348 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:02 2010 Dropped packet from 192.160.0.180 to 85.114.161.224 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:02 2010 Blocked incoming TCP connection request from 10.3.69.73:26019 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:02 2010 Blocked incoming TCP connection request from 10.7.75.162:4705 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:02 2010 Blocked incoming TCP connection request from 10.7.196.52:60767 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:01 2010 Blocked incoming UDP packet from 10.2.65.12:22049 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:01 2010 Blocked incoming TCP connection request from 172.16.95.16:8358 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:01 2010 Blocked incoming TCP connection request from 172.16.138.91:59742 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:01 2010 Blocked incoming TCP connection request from 10.3.65.157:3856 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:01 2010 Blocked incoming TCP connection request from 10.2.8.91:51167 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:00 2010 Blocked incoming TCP connection request from 172.16.7.254:1474 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:00 2010 Blocked incoming TCP connection request from 10.2.199.135:2366 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:37:00 2010 Dropped packet from 192.160.0.180 to 62.106.105.221 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:37:00 2010 Blocked incoming TCP connection request from 10.5.15.18:51348 to 10.3.64.17:41574
[WARN] Mon Mar 29 12:36:59 2010 A network computer (EEE) was assigned the IP address of 192.154.0.198.
[WARN] Mon Mar 29 12:36:59 2010 A network computer (00179AFA5A1C) was assigned the IP address of 192.154.0.197.
[INFO] Mon Mar 29 12:36:59 2010 Blocked incoming TCP connection request from 10.2.69.138:4414 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:59 2010 Blocked incoming TCP connection request from 10.6.136.145:2676 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:59 2010 Blocked incoming UDP packet from 10.0.207.83:62387 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:58 2010 Blocked incoming TCP connection request from 10.1.129.77:64221 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:58 2010 Dropped packet from 192.160.0.180 to 62.106.105.221 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:36:58 2010 dlink: Wireless system with MAC address 000C283AB7D3 secured and linked
[INFO] Mon Mar 29 12:36:58 2010 dlink: Wireless system with MAC address 000C283AB7D3 associated
[INFO] Mon Mar 29 12:36:58 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:36:58 2010 Blocked incoming TCP connection request from 172.16.95.16:8358 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:58 2010 Blocked incoming TCP connection request from 172.16.94.97:57999 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:58 2010 Dropped packet from 192.160.0.180 to 85.114.161.224 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:36:58 2010 Blocked incoming TCP connection request from 10.7.76.93:53980 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:36:57 2010 Blocked incoming TCP connection request from 10.7.10.154:1076 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:57 2010 Blocked incoming TCP connection request from 172.16.7.254:1474 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:57 2010 Blocked incoming TCP connection request from 172.16.129.197:2901 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:57 2010 Blocked incoming TCP connection request from 10.1.199.36:58174 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:57 2010 Blocked incoming TCP connection request from 10.2.65.12:54901 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:57 2010 Blocked incoming TCP connection request from 10.5.195.140:63821 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:56 2010 Blocked incoming TCP connection request from 10.2.197.157:3116 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:56 2010 Blocked incoming TCP connection request from 10.2.69.138:4414 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:56 2010 Wireless link is up
[INFO] Mon Mar 29 12:36:56 2010 Dropped packet from 192.160.0.180 to 85.114.161.224 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:36:56 2010 Blocked incoming UDP packet from 10.7.3.57:62697 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:56 2010 Blocked incoming TCP connection request from 10.7.140.236:1408 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:56 2010 Blocked incoming TCP connection request from 172.16.93.16:3514 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:56 2010 Blocked incoming TCP connection request from 10.4.71.94:2889 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:56 2010 Blocked incoming TCP connection request from 10.7.75.162:4705 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:55 2010 Blocked incoming TCP connection request from 10.1.129.77:64221 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:55 2010 Firmware upgrade server wrpd.dlink.com.tw is at IP address 210.242.32.129
[INFO] Mon Mar 29 12:36:55 2010 Blocked incoming TCP connection request from 172.16.94.97:57999 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:55 2010 Blocked incoming TCP connection request from 10.3.65.157:3856 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:55 2010 Dropped packet from 192.160.0.180 to 85.114.161.224 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:36:55 2010 Blocked incoming TCP connection request from 10.2.8.91:51167 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:54 2010 Blocked incoming TCP connection request from 10.2.199.135:2366 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:54 2010 Blocked incoming TCP connection request from 172.16.129.197:2901 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:54 2010 Blocked incoming TCP connection request from 10.2.65.12:54901 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:54 2010 Blocked incoming TCP connection request from 172.16.6.215:1403 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:54 2010 Blocked incoming TCP connection request from 10.5.195.140:63821 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:54 2010 Dropped packet from 192.160.0.180 to 62.106.105.221 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:36:53 2010 Dropped packet from 192.160.0.180 to 85.114.161.224 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:36:53 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:36:53 2010 Blocked incoming TCP connection request from 10.3.69.147:25754 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:36:53 2010 Blocked incoming TCP connection request from 10.6.136.145:2676 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:53 2010 Blocked incoming TCP connection request from 10.7.75.162:4705 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:53 2010 Blocked incoming TCP connection request from 10.13.128.195:4798 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:52 2010 Dropped packet from 192.160.0.180 to 62.106.105.221 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:36:52 2010 Blocked incoming TCP connection request from 10.7.137.11:2599 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:52 2010 Blocked incoming TCP connection request from 10.3.65.157:3856 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:52 2010 Blocked incoming TCP connection request from 10.3.71.102:4790 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:52 2010 Blocked incoming TCP connection request from 10.7.76.93:53980 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:36:52 2010 Blocked incoming TCP connection request from 10.2.8.91:51167 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:51 2010 Starting DHCP server
[INFO] Mon Mar 29 12:36:51 2010 Blocked incoming TCP connection request from 10.7.10.154:1076 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:51 2010 Blocked incoming TCP connection request from 10.2.199.135:2366 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:51 2010 Blocked incoming TCP connection request from 172.16.18.23:64359 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:51 2010 Blocked incoming UDP packet from 109.226.70.139:47281 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:51 2010 Blocked incoming TCP connection request from 10.1.199.36:58174 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:51 2010 Blocked incoming TCP connection request from 172.16.6.215:1403 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:51 2010 Dropped packet from 192.160.0.180 to 62.106.105.221 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:36:50 2010 Blocked incoming TCP connection request from 10.2.197.157:3116 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:50 2010 Blocked incoming TCP connection request from 10.1.139.96:4848 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:50 2010 Blocked incoming TCP connection request from 172.16.93.16:3514 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:50 2010 Blocked incoming TCP connection request from 10.7.140.236:1408 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:50 2010 Blocked incoming TCP connection request from 10.6.136.145:2676 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:50 2010 Blocked incoming TCP connection request from 10.4.71.94:2889 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:50 2010 Firmware upgrade server wrpd.dlink.com.tw is at IP address 210.242.32.129
[INFO] Mon Mar 29 12:36:50 2010 Blocked incoming TCP connection request from 10.13.128.195:4798 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:49 2010 Blocked incoming TCP connection request from 172.16.112.107:4617 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:36:49 2010 Dropped packet from 192.160.0.180 to 62.106.105.221 (IP protocol 41) as unable to create new session
[INFO] Mon Mar 29 12:36:49 2010 Above message repeated 1 times
[INFO] Mon Mar 29 12:36:49 2010 Blocked incoming TCP connection request from 172.16.11.41:2590 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:49 2010 Blocked incoming TCP connection request from 10.7.76.93:53980 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:36:48 2010 Blocked incoming TCP connection request from 10.7.10.154:1076 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:48 2010 Blocked incoming TCP connection request from 10.1.199.36:58174 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:48 2010 Blocked incoming TCP connection request from 10.3.72.5:3143 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:47 2010 Blocked incoming TCP connection request from 10.2.197.157:3116 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:47 2010 Blocked incoming UDP packet from 172.16.13.41:57605 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:47 2010 Blocked incoming TCP connection request from 10.7.140.236:1408 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:47 2010 Blocked incoming TCP connection request from 10.3.69.147:25754 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:36:47 2010 Blocked incoming TCP connection request from 10.4.133.220:1547 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:47 2010 Blocked incoming TCP connection request from 172.16.93.16:3514 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:47 2010 Blocked incoming TCP connection request from 10.4.71.94:2889 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:47 2010 Estimating speed of WAN interface
[INFO] Mon Mar 29 12:36:47 2010 PPP network up with IP Address 188.122.249.3
[INFO] Mon Mar 29 12:36:47 2010 MSCHAP authentication successful.
[INFO] Mon Mar 29 12:36:47 2010 MSCHAP authentication details were sent to authenticator.
[INFO] Mon Mar 29 12:36:47 2010 MSCHAP authentication challenge received from peer.
[INFO] Mon Mar 29 12:36:47 2010 LCP sets local options: ACCM: 00000000, ACFC: 1, PFC: 1, MRU: 1462
[INFO] Mon Mar 29 12:36:46 2010 Blocked incoming TCP connection request from 10.6.66.54:53361 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:46 2010 Blocked incoming TCP connection request from 172.16.112.107:4617 to 10.3.64.17:50954
[INFO] Mon Mar 29 12:36:46 2010 Blocked incoming UDP packet from 10.4.194.225:35691 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:46 2010 Blocked incoming TCP connection request from 10.7.137.11:2599 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:46 2010 Blocked incoming TCP connection request from 10.3.71.102:4790 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:46 2010 Blocked incoming TCP connection request from 10.3.67.213:3791 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:46 2010 LCP sets remote auth: C223
[INFO] Mon Mar 29 12:36:46 2010 LCP sets remote options: ACCM: 00000000, ACFC: 1, PFC: 1, MRU: 1462
[INFO] Mon Mar 29 12:36:46 2010 PPTP connected to server "local" with ID 0xD13C
[INFO] Mon Mar 29 12:36:46 2010 The PPTP transmit window is 8192
[INFO] Mon Mar 29 12:36:46 2010 Attempting to establish a PPTP connection.
[INFO] Mon Mar 29 12:36:46 2010 Attempting to re-connect on-demand WAN connection
[INFO] Mon Mar 29 12:36:45 2010 Blocked incoming TCP connection request from 10.13.65.27:4590 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:45 2010 Blocked incoming TCP connection request from 172.16.18.23:64359 to 10.3.64.17:41574
[INFO] Mon Mar 29 12:36:45 2010 Attempting to re-connect on-demand WAN connection
[INFO] Mon Mar 29 12:36:44 2010 Above message repeated 17 times
[INFO] Mon Mar 29 12:36:44 2010 Obtained IP Address using DHCP. IP address is 10.3.64.17
[INFO] Mon Mar 29 12:36:44 2010 Russia DHCP Options 121 created !!
[INFO] Mon Mar 29 12:36:44 2010 Attempting to re-connect on-demand WAN connection
[INFO] Mon Mar 29 12:36:44 2010 Above message repeated 15 times
[INFO] Mon Mar 29 12:36:44 2010 Bringing up WAN using Russia PPTP
[INFO] Mon Mar 29 12:36:44 2010 WAN interface cable has been connected
[INFO] Mon Mar 29 12:36:44 2010 LAN interface is up
[INFO] Mon Mar 29 12:36:44 2010 LAN Ethernet Carrier Detected
[INFO] Mon Mar 29 12:36:43 2010 Above message repeated 10 times
[INFO] Mon Mar 29 12:36:43 2010 Attempting to start WAN connection on-demand
[INFO] Mon Mar 29 12:36:43 2010 Device initialized
[WARN] Mon Mar 29 12:36:42 2010 Wireless schedule init
[INFO] Mon Mar 29 12:36:42 2010 One or more Internet access policies are in effect. Internet access will be restricted according to these policies
СообщениеДобавлено: Пн мар 29, 2010 19:56
Попробуйте для начала уменьшить значение MTU.
У меня при значении 1400 исходящая скорость практически никакая....
При 1280 все отлично.
С торрентами по РРТР проблема. Как я вижу, у вас именно от них все.
Есть возможность поставить L2TP? Если есть, ставьте. Соединение будет устойчивое.
DIR-100 на полке, DIR-655 в использовании...
СообщениеДобавлено: Пн мар 29, 2010 21:15
по каким критериям уменьшать MTU ??
с версией 31 роутер перезагружается каждые 2 мин., откатился обратно на 21 версию, здесь все работает кроме описанных выше (без поднятия ВПН):
не отправляется почта и не закачивается на сервер.
PPTP - нормально работает, только его удалось поднять на ДИР-655, ДИР-100 не справился с поставленной задачей
не пойму почему пишут что в 30 и 31 версии прошивки исправили ребуты на ППТП, у меня стабильно работает только на 21 версии :(
СообщениеДобавлено: Пн мар 29, 2010 21:54
Наверно, я вас не понимаю... к сожалению...
"Не отправляется почта без поднятого ВПН"? Почта в локальной сети провайдера? На какой сервер без ВПН вы хотите закачать файлы? Опять же на локальный?
Отваливается связь, уже написал почему - торренты виноваты.
У меня не отваливается на L2TP при любой нагрузке. На РРТР - ну, не через две минуты, но через пять-десять, точно. Но это только при включенном торрент клиенте, без него на РРТР не обрывается.
Про MTU. Какие критерии вам нужны? Я дал совет, кстати, почерпнутый на этом же форуме. Воспользовался, разницу увидел, посоветовал вам.
Еще, DIR-100 прекрасно держит РРТР и при включенных торрентах. Что у вас с ним-то не заладилось? Странно, этот роутер рекомендует ваш провайдер, может им "капнуть" на мозги? Пусть настроят.
СообщениеДобавлено: Вт мар 30, 2010 09:37
alex83 писал(а):
без поднятого ВПНа: не отправляется почта, тест на исходящий траф не могу пройти, не могу закачать на сервер файлы.
стабильно работает только с прошивкой 1.21WW, 2008/12/26, более поздние прошивки - глючит и перезагружается, сегодня пробовал поставить бету последнюю Firmware Version : 1.31WW, 2010/02/27 , повтерение истории : постоянные ребуты
ЛОГ:
[INFO] Mon Mar 29 12:40:17 2010 Blocked incoming UDP packet from 178.187.12.212:59887 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:17 2010 Blocked incoming TCP connection request from 94.233.116.228:56731 to 188.122.248.117:20312
[INFO] Mon Mar 29 12:40:17 2010 Blocked incoming TCP connection request from 10.3.66.130:2511 to 10.3.64.17:41574
1. После прошивки сбрасывали настройки в дефолт? Кнопочкой или через веб-интерфейс? ЭТО ОЧЕНЬ ВАЖНО!
2. Слишком много блокированных подключений на порт 41574. Вероятно это порт вашего торрент-клиента. Вы уверены что он открыт в роутере? (Можно конечно пробросить через UPNP, которую в свою очередь необходимо включить и в роутере и в клиенте, но рекомендуется это делать через Virtual Server в веб-интерфейсе.)
3. Если есть возможность - используйте Russia L2TP соединение, у меня с ним торрент-клиент работает на пределе (10.5/5.5мбАйт/c загрузка/отдача НЕДЕЛЯМИ).
4. Если все это не помогает - попробуйте отключить лог. Совсем.
СообщениеДобавлено: Вт мар 30, 2010 11:36
проблема, скорее всего, у товарища не в MTU, а в не отключеном QOS, рекомендовано его отключить при использовании VPN соединения...
а так, не плохо было бы для начала привести список настроек, так как гадать, что у товарища включено, а что нет, смысла нет...
PS. у меня тоже на последней "beta04" все работает неделями на Russia PPTP, торренты раздают гигов по 100 в сутки, и никаких проблем...
PPS. правильный роут-лист тоже вносит большой вклад в стабильность работы самого роутера.
DIR 655 (HW A3) и DWA 547, DWA 556
СообщениеДобавлено: Вт мар 30, 2010 12:58
Вот QOS то как раз народ не отключает, отключают Traffic shaping, который не имеет смысла при подключении типа Russia(Dual-access).
СообщениеДобавлено: Ср мар 31, 2010 20:21
отключение внутреннего QoS Engine помогло - спасибо за советы, теперь и почту отправляет и закачивает на сервак, в полной мере теперь могу наладиться 4Мбитами
осталось ИПТВ настроить, помечу-то не прописывает маршрут 232.0.0.0 Маска 255.255.252.0
можете подсказать?
вот все требования:
http://forums.avtograd.ru/index.php?showtopic=117619
# Прописываем самостоятельно для вещания ТВ:
Скрытый текст
route -p add 232.0.0.0 mask 255.255.252.0 <твой IP получаемый по локальной сети>
Для сервиса SAP (автоматическое формирование списка всех ТВ каналов) необходимо добавить следующий маршрут:
route -p add 224.2.127.254 mask 255.255.255.255 <твой IP получаемый по локальной сети>
ВНИМАНИЕ! При использовании локальной сети и дополнительного оборудования, не забудьте правильно прописать маршрутизацию на каждом ПК, либо на дополнительном оборудовании (в зависимости от организации сети).
# Вещание проходит в 2 диапазонах:
Цитата
232.0.1.1 - 75
232.0.2.1 - 75
СообщениеДобавлено: Ср мар 31, 2010 22:03
Если отключить трафик шейпинг, QoS разве доступно?
Поясните.
Можно ли включить Гостевую зону при отключенном общем Wi-Fi?
У вас же получается, что можно.
Галки снимать и ставить на Qos можно только при включенном Traffic shaping.
Может я чего-то не понимаю?
СообщениеДобавлено: Чт апр 01, 2010 11:30
Поясните.
Все правильно понимаешь. Галка Traffic Shaping отключает и QoS тоже.
Но иногда бывает достаточно отключить просто QoS для того, чтобы перестал падать VPN, а Traffic Shaping можно оставить включенным. Опытным путем установлено, что на маленьких скоростях (а 4 мегабита это мало) и с включеным Traffic Shaping-ом VPN не падает.
Хотя, судя по логу, у товарища стоит "Russia PPTP", поэтому, как уже было сказано выше в этом случае правильней было бы отключить полностью Traffic Shaping. Но, можно и оставить, так как скорость маленькая.
СообщениеДобавлено: Вс апр 04, 2010 03:52
трафик шейпинг отлючен, вернее отключили его и соответственно отключился QOS
с "Russia PPTP" - верно он и есть
VPN никогда и не падал!
у меня 2 вопроса:
1) как прописать описанные выше маршруты? т.к. без них не хочет показывать IPTV (при прописывании пишет - маршрут такой-то - invalid. Хотя все остальные маршруты прописались)
2) почему после перепрошивки постоянные перезагрузки и имеет ли смысл переходить на новые прошивки, сейчас в принципе все устраивает (жаль ИПТВ не показывает)
