Текущее время: Чт апр 23, 2026 21:16
Начать новую тему Ответить на тему  [ Сообщений: 39 ]  На страницу Пред.  1, 2, 3  След.
СообщениеДобавлено: Пн мар 29, 2010 16:08
Тестовая конфигурация:
DES-3528:admin#show igmp_snooping forwarding
Command: show igmp_snooping forwarding
 VLAN Name                     : iptv
 Source IP                     : *
 Multicast Group               : 235.0.0.1
 Port Member                   : 5,25-26
 Total Entries : 1
DES-3528:admin#show igmp_snooping group
Command: show igmp_snooping group
 Source/Group                  : NULL/235.0.0.1
 VLAN Name/VID                 : iptv/555
 Member Ports                  : 5
 UP Time                       : 472
 Expiry Time                   : 179
 Filter Mode                   : EXCLUDE
 Total Entries: 1
DES-3528:admin#show igmp_snooping vlan iptv
Command: show igmp_snooping vlan iptv
 IGMP Snooping Global State              : Enabled
 Data Driven Learning Max Entries        : 1024
 VLAN Name                     : iptv
 Query Interval                : 125
 Max Response Time             : 10
 Robustness Value              : 2
 Last Member Query Interval    : 1
 Querier State                 : Disable
 Querier Role                  : Non-Querier
 Querier IP                    : 192.168.0.25
 Querier Expiry Time           : 159 secs
 State                         : Disable
 Fast Leave                    : Enable
 Report Suppression            : Disable
 Rate Limit                    : No Limitation
 Version                       : 2
 Data Driven Learning State    : Enable
 Data Driven Learning Aged Out : Enable
 Data Driven Group Expiry Time : 10
Total Entries: 1
DES-3528:admin#sh sw
Command: show switch
Device Type       : DES-3528 Fast Ethernet Switch
MAC Address       : 00-1E-58-50-15-10
IP Address        : 192.168.0.128 (Manual)
VLAN Name         : default
Subnet Mask       : 255.255.255.0
Default Gateway   : 0.0.0.0
Boot PROM Version : Build 1.00.B008
Firmware Version  : Build 2.21.B041
Hardware Version  : A1
# ISM_VLAN
create igmp_snooping multicast_vlan_group_profile 1
config igmp_snooping multicast_vlan_group_profile 1 add 235.0.0.1-235.0.0.100
enable igmp_snooping multicast_vlan
config igmp_snooping multicast_vlan forward_unmatched disable
create igmp_snooping multicast_vlan iptv 555
config igmp_snooping multicast_vlan iptv state enable replace_source_ip 0.0.0.0 remap_priority 5
config igmp_snooping multicast_vlan iptv add member_port 1-24
config igmp_snooping multicast_vlan iptv add source_port 25-26
config igmp_snooping multicast_vlan_group iptv add profile_name 1
# MCFILTER
config multicast vlan_filtering_mode vlanid 1 forward_unregistered_groups
config multicast vlan_filtering_mode vlanid 1313 forward_unregistered_groups
config multicast vlan_filtering_mode vlanid 555 filter_unregistered_groups
# IGMP_SNOOPING
config igmp_snooping data_driven_learning max_learned_entry 1024
config igmp_snooping vlan iptv fast_leave enable
config igmp_snooping querier vlan iptv state disable version 2
config igmp_snooping data_driven_learning vlan iptv state enable aged_out enable expiry_time 10
Бигаров Руслан.
СообщениеДобавлено: Пн мар 29, 2010 16:43
VLAN Name : iptv
Source IP : *
Multicast Group : 224.1.50.8
Port Member : 24-26
Total Entries : 1
Source/Group : NULL/224.1.50.8
VLAN Name/VID : iptv/109
Member Ports : 24
UP Time : 124
Expiry Time : 154
Total Entries: 1
VLAN Name : iptv
Querier IP : 11.0.108.250
Querier Expiry Time : 241 secs
State : Disable
Fast Leave : Enable
Report Suppression : Enable
Version : 2
Total Entries: 1
MAC Address : 00-21-91-25-F8-50
IP Address : 10.90.90.90 (Manual)
VLAN Name : default
Subnet Mask : 255.0.0.0
Firmware Version : Build 2.21.B036
Serial Number : P1UM187000031
System Name :
System Location :
System Contact :
Spanning Tree : Disabled
GVRP : Disabled
IGMP Snooping : Enabled
MLD Snooping : Disabled
VLAN Trunk : Disabled
TELNET : Enabled (TCP 23)
WEB : Enabled (TCP 80)
SNMP : Disabled
SSL Status : Disabled
SSH Status : Disabled
802.1x : Disabled
Jumbo Frame : Off
Clipaging : Enabled
MAC Notification : Disabled
Port Mirror : Disabled
SNTP : Disabled
HOL Prevention State : Enabled
Syslog Global State : Disabled
Single IP Management : Disabled
Dual Image : Supported
Password Encryption Status : Disabled
conf vlan default del 1-28
create vlan INET tag 211
conf vlan INET add tag 25-26
conf vlan INET add untag 17-24
config igmp_snooping multicast_vlan_group_profile 1 add 224.1.50.1-224.1.50.100
create igmp_snooping multicast_vlan iptv 109
config igmp_snooping multicast_vlan iptv state enable replace_source_ip 11.0.108.234 remap_priority 5
# MCFILTER
config multicast vlan_filtering_mode vlanid 211 forward_unregistered_groups
config multicast vlan_filtering_mode vlanid 109 filter_unregistered_groups
# IGMP_SNOOPING
Нет картинки нет даже намека на картинку ( т.е. нет даже буферизации подвисшей)
На 3028 с элементарными настройками все работает
Как настраивал и вывод команд привел выше.
Что нетак делаю подскажите плиз
СообщениеДобавлено: Пн мар 29, 2010 17:02
Все настроил
нехватало
config igmp_snooping vlanid 109 report_suppression disable
Ща заготовлю шаблоний для настройки и отпишусь, думаю пригодится.
В особенности для тех кто на ТЕСТ берет сей девайс, ибо FAQ недает возможности тв на данном девайсе настроить
СообщениеДобавлено: Пн мар 29, 2010 17:10
Итак, вот конфига для теста ( незабываем указывать свои №вланов и АЙПИ мультикастинга)
# MCFILTER
# IGMP_SNOOPING
Наконцто настроено.
Ну теперь осталось ещещ , чтоб ВЕБ морда не скисалась и давала возможность хотяб простые вещи делать(таг антаг вланов и проччую мелочь), ваще ништь станет.
СообщениеДобавлено: Пн мар 29, 2010 17:38
Итак ПРимер на FAQ рабочий, но в специфике 3528 для работы ИСМ вланы нужна строчка в конфиге
config igmp_snooping vlanid (№вашей ИСМ вланы) report_suppression disable
Как только добавляеш данную строку все работает, при ентом вся настройка действительно по аналогии с 3028
Если несложно расскажите что-же енто за report_suppression и зачем он нужен и почему на ИСМ влане его необходимо отключить, чтоб мультикаст пошел.
СообщениеДобавлено: Вт мар 30, 2010 14:14
Пока информации мало по этой подфункции, из manual:
report_suppression [enable | disable] – Allows users to enable or disable IGMP snooping report suppression for the specified VLAN.
Бигаров Руслан.
СообщениеДобавлено: Вт мар 30, 2010 17:16
Данную фразу сам видел, от нее нелегче ( смысл данной функции неясен)
Теперь к более странным вещам новенький 3552, почемуто напрочь забывает как работать, за последние 2 недели 3 раза помогало только ребут по питанию, телнет и веб были в ауте, даже непинговался ( из всей кучи настроек используем только упр влан и настройку вланов на нем + вкл IGMP + вкл Лупбекдетект по вланам, увы в логах пусто.
Сегодня покопаюсь на нем, выложу сюда конфигу.
За 3528 такого замечено пока небыло ( при условии если в веб нелазить, т.к. при работе в вебе возможны подобные исходы))
СообщениеДобавлено: Вт мар 30, 2010 17:29
Конфиг лучше отдельным файлом на почту. А также когда происходит подобное, то лучше подключаться по RS-232 и смотреть загрузку CPU и портов.
Бигаров Руслан.
СообщениеДобавлено: Вт мар 30, 2010 19:14
Ах еслиб это было возможно.
Но увы ехать 300 км до коммутатора и смотреть, что у него по RS-232 что то неулыбается.
100% происходит если зайти под веб и тупо поросматривать настройки( даже невнося в них изменения)
Скис когда флуд в сети был ( Лупбекдетект по вланам был ВКЛ), флуд был вызван пеллей на более старшем коммутаторе.
Подробности позже направлю, сейчас Очень сильно занят
СообщениеДобавлено: Чт апр 01, 2010 18:35
1 число полет нормальный
Все зависания были после посещения ВЕБ ( при этом из под ВЕБа настройки нетрогались)
СообщениеДобавлено: Чт апр 15, 2010 07:22
Итак имеем схему
DGS3627G==(mcast vlanid105 inet vlanid95) транком 2-ух портов==>DGS3200-16(обе вланы проходят транзитом igmp вкл, фильтеринг он влан на каждой вкл)=в 51 и 52 порт транком=>DES3552 (все сначала настроил как описано выше, результат НЕРАБОТАЕТ)
Теперь странности все, что описано выше незаработало, сделал следующее в вланах вкл репорт супрешен и дата драйвенг лерн вкл, igmp на влане выкл, глобально igmp вкл. Работает подписка и отписка от груп нормальная, но работает почемуто непостоянно, то есть то нет, где капать?
СообщениеДобавлено: Ср апр 21, 2010 21:40
А для чего эта опция (replace_source_ip) и что за адрес такой?
config igmp_snooping multicast_vlan 109 replace_source_ip 11.0.108.234
СообщениеДобавлено: Ср апр 21, 2010 22:01
фун-я подмены айпи адреса, т.е. все запросы со всех портов данного коммутатора на мультикаст, уходят с данного айпи.
Жизть так сложилась, что у нас в сети енто серые айпи =)
СообщениеДобавлено: Ср апр 21, 2010 22:03
Т.е. это ip комутатора?
СообщениеДобавлено: Пт апр 23, 2010 12:55
Не совсем, этот IP нужен для Proxy-ирования подписок и отписок.
Бигаров Руслан.
