Текущее время: Сб окт 03, 2026 04:14
 Заголовок сообщения: DES-3526 limited_multicast_addr
СообщениеДобавлено: Чт мар 11, 2010 17:08
Конфиг
config multicast port_filtering_mode 1-26 filter_unregistered_groups
enable igmp_snooping
create igmp_snooping multicast_vlan 38 38
config igmp_snooping multicast_vlan 38 state enable replace_source_ip 192.168.155.27 member_port 1-3,12-13 source_port 8-9,25-26
config igmp_snooping 38 host_timeout 260 router_timeout 260 leave_timer 2 state enable
config igmp_snooping querier 38 query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier 38 last_member_query_interval 1 state disable
create multicast_range drop1 from 224.0.0.0 to 234.5.2.0
create multicast_range drop2 from 234.5.2.255 to 239.255.255.255
config limited_multicast_addr ports 1-26 add multicast_range drop1
config limited_multicast_addr ports 1-26 add multicast_range drop2
config limited_multicast_addr ports 1-26 access deny state enable
Command: show igmp_snooping group
мусор
VLAN Name       : 38
Multicast group : 224.0.0.9
MAC address     : 01-00-5E-00-00-09
Reports         : 27
Port Member     : 25
VLAN Name       : 38
Multicast group : 224.0.0.22
MAC address     : 01-00-5E-00-00-16
Reports         : 90
Port Member     : 25-26
VLAN Name       : 38
Multicast group : 224.0.0.251
MAC address     : 01-00-5E-00-00-FB
Reports         : 609
Port Member     : 8-9,13,25-26
VLAN Name       : 38
Multicast group : 224.0.0.252
MAC address     : 01-00-5E-00-00-FC
Reports         : 1002
VLAN Name       : 38
Multicast group : 224.0.0.253
MAC address     : 01-00-5E-00-00-FD
Reports         : 20
Port Member     : 25
вещание
VLAN Name       : 38
Multicast group : 234.5.2.1
MAC address     : 01-00-5E-05-02-01
Reports         : 2
Port Member     : 3
VLAN Name       : 38
Multicast group : 234.5.2.2
MAC address     : 01-00-5E-05-02-02
Reports         : 11
Port Member     : 25
Total Entries : 22
Что я нетак делаю (мусор 224.0.0.251 с клиентских портов Port Member : 8-9,13,25-26 )?
СообщениеДобавлено: Пт мар 12, 2010 02:06
Во-первых выставите Multicast port filtering mode filter_unregistered_groups только на source портах. Во-вторых а зачем Вы закрываете служебные группу IGMP 224.0.0.1 - 224.0.0.2? И в третьих какая у Вас версия прошивки?
СообщениеДобавлено: Пт мар 12, 2010 09:42
1. Уже 10я попытка
2. Насколько я помню адреса 224.0.0.1 - 224.0.0.2 не просто броадкастовые, а броадкастовые ВО ВСЕХ СЕГМЕНТАХ..
3.
Boot PROM Version 5.00.009
Firmware Version 6.00.B23
Непонимаю как 1 и 2 связаны с "мусор 224.0.0.251 с клиентских портов Port Member : 8-9,13,25-26 "
СообщениеДобавлено: Пт мар 12, 2010 09:46
дурацкий вопрос
почему только на сурс ???
Умная книжка по теории сетей и настройкам свичей:
ftp://ftp.dlink.ru/pub/Trainings/Switch_D-Link_newest_Basic.pdf
СообщениеДобавлено: Пн мар 15, 2010 00:31
Потому что такая сейчас реализация этой функции.
СообщениеДобавлено: Пн мар 15, 2010 17:06
Чтобы убрать "мусор" нужно использовать cpu acl. limited_multicast запрещает пользователям подписываться на группы, но сами эти группы на коммутаторе всё равно появляются.
СообщениеДобавлено: Пн мар 15, 2010 17:57
VLAN Name : 38
Reports : 1002
Вопрс был именно про КЛИЕНТСКИЕ порты
СообщениеДобавлено: Ср мар 17, 2010 01:10
Я Вам просто конфигурацию подкорректировал.
СообщениеДобавлено: Ср мар 17, 2010 11:40
Спасибо!
А по существу вопроса?
СообщениеДобавлено: Ср мар 17, 2010 13:19
А каких моделей свитчей касается эта реализация? Или это на всех так?
СообщениеДобавлено: Ср мар 17, 2010 23:12
цитата с фака с вашего сайта http://dlink.ru/ru/faq/58/266.html
Настройка DES-3526:
create vlan v2 tag 2
create vlan v3 tag 3
config vlan default delete 1-26
config vlan v2 add untagged 1-12
config vlan v2 add tagged 25,26
config vlan v3 add untagged 13-24
config vlan v3 add tagged 25,26
create igmp_snooping multicast_vlan v100 100
config igmp_snooping multicast_vlan v100 member_port 1-24 source_port 25-26 replace_source_ip 100.0.0.150
state enable
так как же правильно :)
ps на практике работает мультикаст работает в обоих случаях
СообщениеДобавлено: Чт мар 18, 2010 00:44
Более правильно так как я сказал в новых прошивках.
To IvanI:
Вам же Александр Зайцев ответил.
СообщениеДобавлено: Чт мар 18, 2010 09:06
VLAN Name       : 38
Reports         : 1002
А это разве не подписка???
СообщениеДобавлено: Пт мар 19, 2010 01:43
А Вы CPU Interface filtering на эту группу настроили?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 40
