Текущее время: Пт авг 21, 2026 22:36
 Заголовок сообщения: DGS-3610-26G ip access-group {id} out
СообщениеДобавлено: Пт фев 05, 2010 21:57
Устанавливая свич:
DGS-3610#sh version
System description : DGS-3610-26G Gigabit Ethernet Switch
System start time : 2010-02-04 13:16:31
System uptime : 1:7:20:9
System hardware version : A1.0
System software version : v10.3(5), Release(70398)
System BOOT version : 10.3.70398
System CTRL version : 10.3.70398
Device information:
Device-1
Hardware version : A1.0
Software version : v10.3(5), Release(70398)
не смог привязать ip access-group {id|name} out на GigabitEthernet 0/2 интерфейс при таком конфиге
DGS-3610(config)#sh running-config
Building configuration...
Current configuration : 3021 bytes
version v10.3(5), Release(70398)(Mon Nov 30 20:26:30 CST 2009 -ngcf49)
co-operate enable
route-map local permit 10
match ip address 1
set ip next-hop 192.168.132.200
vlan 1
vlan 2
vlan 4
no service password-encryption
ip access-list standard 1
10 permit host 194.116.195.234
20 permit host 192.168.58.6
30 permit host 192.168.58.10
ip access-list extended 101
10 deny icmp any any
20 permit ip any any
interface GigabitEthernet 0/1
interface GigabitEthernet 0/2
no switchport
ip policy route-map local
no ip proxy-arp
ip access-group 101 out
ip address 213.151.2.246 255.255.255.252
interface GigabitEthernet 0/3
interface GigabitEthernet 0/8
switchport access vlan 2
interface GigabitEthernet 0/9
interface GigabitEthernet 0/13
interface GigabitEthernet 0/14
interface GigabitEthernet 0/15
interface GigabitEthernet 0/16
no switchport
no ip proxy-arp
interface GigabitEthernet 0/17
interface GigabitEthernet 0/18
interface GigabitEthernet 0/19
interface GigabitEthernet 0/20
interface GigabitEthernet 0/21
interface GigabitEthernet 0/22
switchport access vlan 4
interface GigabitEthernet 0/23
interface GigabitEthernet 0/24
no switchport
no ip proxy-arp
ip address 213.151.1.6 255.255.255.248
description Games
interface VLAN 1
no ip proxy-arp
interface VLAN 2
no ip proxy-arp
ip address 192.168.101.51 255.255.255.240
interface VLAN 4
no ip proxy-arp
ip address 192.168.132.199 255.255.255.240
line con 0
line vty 0 4
login
end
ip access-list extended 101 с блокировкой icmp взят для теста, на интерфейсах VLAN4 и GigabitEthernet 0/24 ip access-group 101 out отрабатывается, на GigabitEthernet 0/2 цепочка out не работает
отключение ip policy route-map local на GigabitEthernet 0/2 положения не меняет, в документации ответа не нашел, нужен свежий взгляд на проблему...
Последний раз редактировалось 4piligrim Пт фев 05, 2010 23:54, всего редактировалось 3 раз(а).
СообщениеДобавлено: Пт фев 05, 2010 22:42
В этой серии и нет ACL на out.
СообщениеДобавлено: Пт фев 05, 2010 22:56
странно, руководство DGS-3610_Series_Configuration_Guide_V10.3(5) на странице 54-1 в разделе "54 Access Control List Configuration" говорит обратное, кроме того в двух случаях из трех цепочка out отрабатывается
еще раз проверил (без перезагрузки свича), на SPAN сессии и на машинах в сегментах видна работа команд
DGS-3610(config-if-GigabitEthernet 0/24)#ip access-group 101 out
DGS-3610(config-if-GigabitEthernet 0/24)#no ip access-group 101 out
DGS-3610(config-if-VLAN 4)#ip access-group 101 out
DGS-3610(config-if-VLAN 4)#no ip access-group 101 out
прекращается icmp трафик на Gi0/22 (vlan4) и Gi0/24
DGS-3610(config-if-GigabitEthernet 0/2)#ip access-group 101 out
DGS-3610(config-if-GigabitEthernet 0/2)#no ip access-group 101 out
реакции на движение icmp трафика нет, все проходит
Последний раз редактировалось 4piligrim Сб фев 06, 2010 00:03, всего редактировалось 3 раз(а).
СообщениеДобавлено: Пт фев 05, 2010 23:08
Вы про ограничения на странице 54-5 читали?
СообщениеДобавлено: Пт фев 05, 2010 23:15
For DGS-3610 series, the ACL enabled at the outbounding direction of a physical port or AP port takes effect only for known packets like unicast and multicast packets, not unknown or broadcast packets.
в данном случае речь идет об ip (icmp) трафике, под ограничение не попадаем
СообщениеДобавлено: Пт фев 05, 2010 23:18
Ещё есть одно.
СообщениеДобавлено: Пт фев 05, 2010 23:28
спасибо, только сейчас заметил, If you need to match the destination IP address not in the subnet IP range of the associated SVI in the standard IP ACL, extended IP ACL or expert ACL, this ACL will not take effect.
т.е. фильтровать трафик на шлюз по умолчанию придется в in цепочках каждого интерфейса ? лишний расход acl списков...
СообщениеДобавлено: Пт фев 05, 2010 23:56
Именно так к сожалению.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 10
