Текущее время: Чт окт 15, 2026 22:26
 Заголовок сообщения: Теряется связь
СообщениеДобавлено: Пн дек 21, 2009 04:23
Есть DIR-300NRU
Клиентская машинка c D-link dwa-510
Постоянно стопорится связь, хотя клиент находится через стенку несущую в пяти метрах от роутера.
ип-адресс прописан на постоянно по маку клиента.
Статус клиента.
0 days, 00:47:8 00:1E:58:A4:D3:41 192.168.0.103 11g
Уровнеь сигнала - 50%-60%
В логах точки
Time Message
Dec 21 01:57:42 DHCP: Server receive REQUEST from 00:1e:58:a4:d3:41.
Dec 21 01:57:42 DHCP: Server sending OFFER of 192.168.0.103 for static DHCP client.
Dec 21 01:57:42 DHCP: Server receive DISCOVER from 00:1e:58:a4:d3:41.
Dec 21 01:57:18 DHCP: Server sending OFFER of 192.168.0.103 for static DHCP client.
Dec 21 01:57:18 DHCP: Server receive DISCOVER from 00:1e:58:a4:d3:41.
Dec 21 01:57:13 DHCP: Server sending OFFER of 192.168.0.103 for static DHCP client.
Dec 21 02:34:27 DHCP: Server sending ACK to 192.168.0.103. (Lease time = -1)
Dec 21 02:34:27 DHCP: Server receive REQUEST from 00:1e:58:a4:d3:41.
Dec 21 02:34:19 DHCP: Server sending ACK to 192.168.0.103. (Lease time = -1)
Dec 21 02:34:19 DHCP: Server receive REQUEST from 00:1e:58:a4:d3:41.
Dec 21 03:02:30 DHCP: Server sending NAK to 00:1e:58:a4:d3:41.
Dec 21 03:02:30 DHCP: Server receive REQUEST from 00:1e:58:a4:d3:41.
Dec 21 03:02:22 DHCP: Server sending NAK to 00:1e:58:a4:d3:41.
Dec 21 03:02:22 DHCP: Server receive REQUEST from 00:1e:58:a4:d3:41.
Dec 21 03:02:18 DHCP: Server sending NAK to 00:1e:58:a4:d3:41.
Dec 21 03:02:18 DHCP: Server receive REQUEST from 00:1e:58:a4:d3:41.
Dec 21 02:59:52 DHCP: Server sending NAK to 00:1e:58:a4:d3:41.
Dec 21 02:59:52 DHCP: Server receive REQUEST from 00:1e:58:a4:d3:41.
Dec 21 02:59:43 DHCP: Server sending NAK to 00:1e:58:a4:d3:41.
Dec 21 02:59:43 DHCP: Server receive REQUEST from 00:1e:58:a4:d3:41.
СообщениеДобавлено: Ср дек 23, 2009 14:12
Версия прошивки на роутере?Драйвер под адаптер и по какую ОС?
СообщениеДобавлено: Пт дек 25, 2009 15:28
Роутер
Hardware Version : B1 Firmware Version : 2.01
Адаптер
WinXP SP3
драйвер 1.2.5.0
P.S. Кстати, со странички карточки линк на драйвера битый.
http://ftp.dlink.ru/pub/Wireless/DWA-51 ... 301%29.zip
Последний раз редактировалось AlleyCat Пт янв 15, 2010 02:17, всего редактировалось 2 раз(а).
СообщениеДобавлено: Пт янв 15, 2010 02:08
Уровень сигнала на клиенте показывает от 42% до 54%
Пинг с клиента точки
Ответ от 192.168.0.1: число байт=32 время=6мс TTL=64
Ответ от 192.168.0.1: число байт=32 время=10мс TTL=64
Превышен интервал ожидания для запроса.
Ответ от 192.168.0.1: число байт=32 время=9мс TTL=64
СообщениеДобавлено: Вт янв 19, 2010 14:32
Для начала обновите на этот драйвер.Отключите в ОС службу настройки беспроводной сети
СообщениеДобавлено: Чт фев 04, 2010 00:56
Драйвер обновлен. Служба отключена. Наблюдается все то же самое.
Проверял, если этот комп стоит в одной комнате с роутером, то все нормально работает. Грешил бы на связь, но в том же месте ноут асус работает нормально при том же уровне сигнала.
Вот скриншот из роутера. Ноут первый - комп с карточкой второй.
http://i.piccy.info/i4/4a/10/96d1e230fe ... 83db9.jpeg
СообщениеДобавлено: Чт фев 04, 2010 11:17
А если не делать резервирование адреса 0.103, а прописать его в настройках TCP/IP компа (вне диапазона аренды DHCP-сервера, например, 192.168.0.13)? Пинги так же себя ведут?
СообщениеДобавлено: Пт фев 05, 2010 20:38
Проверил, тоже самое.
СообщениеДобавлено: Ср фев 10, 2010 11:07
Отписал на мейл
СообщениеДобавлено: Вт мар 02, 2010 16:07
Отписал на мейл
Спасибо. Те дрова к сожалению не смогли стать на карточку. Писало что совместимые карты не обнаружены.
P.S. Может в сервис ее подвезти?
СообщениеДобавлено: Вт мар 02, 2010 16:51
Подвезите.Посмотрим и потестим
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 49
