Текущее время: Пт окт 30, 2026 21:57
 Заголовок сообщения: Dvg 6004 Dvg 5004 не работает FLASH
СообщениеДобавлено: Пн ноя 02, 2009 10:37
Связка следуюшая
№126-->АТС-->Dvg 6004<-->Dvg 5004--->№134 (704)
АТС LG ip-LDK 100
Dvg 6004 Fw: 1.02.37.61
Dvg 5004 Fw: 1.02.37.61
При попытке перевода звонка с помощью клавиши FLASH c №134 в трубке идет сигнал "Занято" , №126 слышит мелодию удержания.
Лог звонка
10:33:06 *** SLMON start to log ***
10:33:16 [043396] Receive Cmd=1100, ParaLen=0, Para=[]
10:33:16 [043396] == Ver(1.02.37.61.8258 2008/02/20 08:19:47) PId(242.DLink.NoPrefix.drtp.vlan) Drv(0.9.5.1.735 29/Nov/2007 10:30:08) Hw(SA7S4) == 0.6.7-1
10:33:17 [043404] 3: 704=OFFERING
10:33:17 [043404] 3: Get CallerId=604
10:33:17 [043404] 3: Peer=192.168.1.2:9006, PT=18, RecvOnly=0
10:33:17 [043404] 3: ==12:Alerting
10:33:19 [043423] 3: Fxs Pickup
10:33:19 [043423] 3: 704=ACCEPT
10:33:19 [043423] 3: ==13:VoipAnswering
10:33:19 [043425] 3: 704=CONNECTED
10:33:19 [043425] 3: RtpApiTalk[1,1], Peer=192.168.1.2:9006, PT=18, FC=2, NewOOB=1
10:33:19 [043425] 3: SetFxsPolarity(1)=0 ---
10:33:19 [043425] 3: ==14:Talking
10:33:24 [043479] 3: Fxs Flash #1
10:33:24 [043479] 3: SetTalkMode[0,0]
10:33:24 [043480] 3: 704=ONHOLDING
10:33:24 [043480] 3: Substatus=5
10:33:24 [043481] 3: 704=ONHOLDING
10:33:25 [043483] 3: 704=ONHELD
10:33:25 [043483] 3: ==3:Idle
10:33:25 [043483] 3: SetFax(1)=0
10:33:25 [043483] 3: ==4:GetDtmf
10:33:25 [043483] 3: WarmLine with [604]
10:33:25 [043484] 3: End Input Default Route [0]
10:33:25 [043484] 3: Line DialNum_New [604]
10:33:25 [043484] 3: OutPinCode=<>, dial_no=<604>
10:33:25 [043484] 3: PhoneBook has GwNo=604, addr=192.168.1.2:5060
10:33:25 [043484] 3: ==7:Inviting
10:33:25 [043484] 3: VoIP CallOut, Invite <sip:604@192.168.1.2:5060;user=phone>
10:33:25 [043485] 3: 704=DIALING
10:33:25 [043486] 3: 704=PROCEEDING
10:33:25 [043487] 3: 704=BUSY
10:33:25 [043487] 3: Release Active Dlg
10:33:25 [043487] 3: ==15:PlayBusyTone
10:33:25 [043487] 3: 704=DISCONNECT
10:33:25 [043487] 3: Release Old Dlg #2
10:33:49 [043725] DSP_ch3_check=0
10:33:49 [043725] 3: Fxs Hangup
10:33:49 [043725] 3: ==3:Idle
10:33:49 [043725] 3: SetFax(1)=0
10:33:52 [043755] 3: 704=DISCONNECT
10:33:52 [043755] 3: Release Hold Dlg #1
Помогите разобратся пожалуста.
СообщениеДобавлено: Пн ноя 02, 2009 14:05
По всей видимости, у вас включен перевод звонка на 704 номере. При попытке перевода звонка его отрабатывает 5004, срабатывает хотлайн на 604, который уже занят (висит у того же 704 на холде).
Отключите перевод звонка, тогда флеш должен будет пройти на лыжи и отработать там правильно. Проверьте, чтобы способ предачи DTMF не был настроен на inband и был одинаков на 6004 и 5004.
СообщениеДобавлено: Вт ноя 03, 2009 09:32
А можно поподробней где это отключается ? Я первый раз такую связку настраиваю.
704 это внутренний номер 5004 шлюза
604 внутренний номер 6004 шлюза
СообщениеДобавлено: Вт ноя 03, 2009 11:29
В Calling Features отключите Call Hold, Call Transfer, Call Waiting.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 16
