Текущее время: Вт окт 27, 2026 15:27
 Заголовок сообщения: DFL-600 и OpenSWAN и Racoon подробно
СообщениеДобавлено: Пт мар 25, 2005 17:19
настройки DFL-600 v 3.00
Tunnel Name: t1
Peer Tunnel Type: Static IP address
Termination IP: XXX.XXX.XXX.XXX
DomainName:
Peer ID Type: Address(IPV4_Addr)
Peer ID:
Shared Key: XXXXXX
IKE MOde: Main
Encapsulation: Tunnel
NAT traversal: Normal
IPSec Operation: ESP
P1 Proposals: P1Param NOT_SET
NOT_SET NOT_SET
P2 Proposals: P2Param NOT_SET
NOT_SET NOT_SET
Target Host Range
Starting Taget Host: 192.168.0.1
Subnet Mask: 255.255.255.0
Phase 1 Proposal
DH Group: Group 2
IKE Life Duration: 28800
IKE Encryption: 3DES
IKE Hash: MD5
Phase 2 Proposal
PFS MOde: Group 2
Encapsulation: ESP
IPSec Life Duration: 28800
Encryption: 3DES
Auth. : HMAC-MD5
настройки OpenSWAN
config setup
interfaces="ipsec1=eth2" # new default is %defaultroute
plutodebug=all
klipsdebug=all
nat_traversal=yes
pluto=yes
conn Test
type=tunnel
left=192.168.2.2
leftnexthop=10.0.0.1
#leftsubnet=192.168.1.0/24
right=192.168.2.1
rightnexthop=10.0.0.2
#rightsubnet=192.168.0.0/24
keyexchange=ike
ikelifetime=1h
auth=esp
pfs=yes
authby=secret
auto=start
include /etc/ipsec.d/examples/no_oe.conf
после запуска ipsec сваливается при проверки секрета
Mar 25 10:41:04 route1 pluto[3132]: | started looking for secret for 192.168.2.2->192.168.2.1 of kind PPK_PSK
Mar 25 10:41:04 route1 pluto[3132]: | actually looking for secret for 192.168.2.2->192.168.2.1 of kind PPK_PSK
Mar 25 10:41:04 route1 pluto[3132]: | 1: compared PSK 192.168.2.1 to 192.168.2.2 / 192.168.2.1 -> 2
Mar 25 10:41:04 route1 pluto[3132]: | 2: compared PSK 192.168.2.2 to 192.168.2.2 / 192.168.2.1 -> 6
Mar 25 10:41:04 route1 pluto[3132]: | best_match 0>6 best=0x9b106e0 (line=2)
Mar 25 10:41:04 route1 pluto[3132]: | concluding with best_match=6 best=0x9b106e0 (lineno=2)
Mar 25 10:41:04 route1 pluto[3132]: | ******parse ISAKMP Oakley attribute:
Mar 25 10:41:04 route1 pluto[3132]: | af+type: OAKLEY_GROUP_DESCRIPTION
Mar 25 10:41:04 route1 pluto[3132]: | length/value: 4
Mar 25 10:41:04 route1 pluto[3132]: | [4 is OAKLEY_GROUP_GP185]
Mar 25 10:41:04 route1 pluto[3132]: "Test" #1: only OAKLEY_GROUP_MODP1024 and OAKLEY_GROUP_MODP1536 supported. Attribute OAKLEY_GROUP_DESCRIPTION
Mar 25 10:41:04 route1 pluto[3132]: "Test" #1: no acceptable Oakley Transform
при попытки обменяться ключами через racoon.
настройки racoon
path include "/etc/racoon";
path pre_shared_key "/etc/racoon/psk.txt";
path certificate "/etc/racoon/certs";
listen
isakmp 192.168.2.2 [500];
remote 192.168.2.1
exchange_mode aggressive, main;
my_identifier address;
proposal {
encryption_algorithm 3des;
hash_algorithm md5;
authentication_method pre_shared_key;
dh_group 2 ;
sainfo anonymous
pfs_group 2;
lifetime time 1 hour ;
authentication_algorithm hmac_md5;
compression_algorithm deflate ;
первая фаза проходит вторая нет.
2005-03-25 17:09:13: INFO: 192.168.2.2[500] used as isakmp port (fd=9)
2005-03-25 17:09:13: INFO: 192.168.2.2[500] used for NAT-T
2005-03-25 17:09:17: INFO: respond new phase 1 negotiation: 192.168.2.2[500]<=>192.168.2.1[500]
2005-03-25 17:09:17: INFO: begin Identity Protection mode.
2005-03-25 17:09:17: INFO: ISAKMP-SA established 192.168.2.2[500]-192.168.2.1[500] spi:cda240abe404b2ab:7d6ae8408106039c
2005-03-25 17:09:19: INFO: respond new phase 2 negotiation: 192.168.2.2[0]<=>192.168.2.1[0]
2005-03-25 17:09:19: ERROR: no policy found: 192.168.0.0/24[0] 192.168.2.1/24[0] proto=any dir=in
2005-03-25 17:09:19: ERROR: failed to get proposal for responder.
2005-03-25 17:09:19: ERROR: failed to pre-process packet.
ike-scan выдает
192.168.2.1 Main Mode Handshake returned SA=(Enc=3DES Hash=SHA1 Auth=PSK Group=2:modp1024 LifeType=Seconds LifeDuration(4)=0x00007080)
Hash=SHA1 хотя должен MD5
так как же это все завязать что бы все работало.[/b]
СообщениеДобавлено: Пн мар 28, 2005 09:09
Target Host Range
Starting Taget Host - 192.168.0.0
Что у Вас прописано в ipsec.conf?
Дополнительно можете посмотреть http://www.dlink.ru/technical/faq_vpn_17.php, пример достаточно подробный и действовать можно по аналогии.
СообщениеДобавлено: Вт мар 29, 2005 16:01
/etc/ipsec.conf
config setup
plutodebug=all
klipsdebug=all
nat_traversal=yes
pluto=yes
conn Test
type=tunnel
left=192.168.2.2
right=192.168.2.1
keyexchange=ike
ikelifetime=1h
auth=esp
pfs=yes
authby=secret
auto=start
СообщениеДобавлено: Ср мар 30, 2005 10:18
Какая операционная система на soft сервере?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 97
