Текущее время: Сб окт 31, 2026 04:56
Начать новую тему Ответить на тему  [ Сообщений: 202 ]  На страницу Пред.  1, 2, 3, 4, 5 ... 14  След.
СообщениеДобавлено: Чт мар 19, 2009 01:08
Во чего делает, несколько раз не подходит пароль:
Mar 19 00:59:40 user crit kernel: ADSL link down
Mar 19 00:59:41 daemon crit pppd[255]: Clear IP addresses. Connection DOWN.
Mar 19 00:59:41 daemon crit pppd[255]: Clear IP addresses. PPP connection DOWN.
Mar 19 00:59:42 user warn dnsprobe[423]: dns query failed
Mar 19 00:59:42 user notice dnsprobe[423]: Primary DNS server Is Down... Switching To Secondary DNS server
Mar 19 00:59:47 user crit kernel: ADSL G.994 training
Mar 19 00:59:49 user crit kernel: ADSL G.992 started
Mar 19 00:59:51 user crit kernel: ADSL G.992 channel analysis
Mar 19 00:59:55 user crit kernel: ADSL link up, interleaved, us=512, ds=2048
Mar 19 00:59:58 daemon notice pppd[255]: PPP: Start to connect ...
Mar 19 00:59:58 daemon crit pppd[255]: PPP server detected.
Mar 19 00:59:58 daemon crit pppd[255]: PPP session established.
Mar 19 01:00:00 daemon crit pppd[255]: PPP LCP UP.
Mar 19 01:00:00 daemon err pppd[255]: User name and password authentication failed.
Mar 19 01:00:03 daemon notice pppd[255]: PPP: Start to connect ...
Mar 19 01:00:03 daemon crit pppd[255]: PPP server detected.
Mar 19 01:00:03 daemon crit pppd[255]: PPP session established.
Mar 19 01:00:05 daemon crit pppd[255]: PPP LCP UP.
Mar 19 01:00:05 daemon err pppd[255]: User name and password authentication failed.
Mar 19 01:00:08 daemon notice pppd[255]: PPP: Start to connect ...
Mar 19 01:00:08 daemon crit pppd[255]: PPP server detected.
Mar 19 01:00:08 daemon crit pppd[255]: PPP session established.
Mar 19 01:00:10 daemon crit pppd[255]: PPP LCP UP.
Mar 19 01:00:10 daemon err pppd[255]: User name and password authentication failed.
Mar 19 01:00:13 daemon notice pppd[255]: PPP: Start to connect ...
Mar 19 01:00:13 daemon crit pppd[255]: PPP server detected.
Mar 19 01:00:14 daemon crit pppd[255]: PPP session established.
Mar 19 01:00:14 user warn dnsprobe[423]: dns query failed
Mar 19 01:00:16 daemon crit pppd[255]: PPP LCP UP.
Mar 19 01:00:16 daemon err pppd[255]: User name and password authentication failed.
Mar 19 01:00:16 user warn dnsprobe[423]: dns query failed
Mar 19 01:00:18 user warn dnsprobe[423]: dns query failed
Mar 19 01:00:19 daemon notice pppd[255]: PPP: Start to connect ...
Mar 19 01:00:19 daemon crit pppd[255]: PPP server detected.
Mar 19 01:00:19 daemon crit pppd[255]: PPP session established.
Mar 19 01:00:21 daemon crit pppd[255]: PPP LCP UP.
Mar 19 01:00:21 daemon err pppd[255]: User name and password authentication failed.
Mar 19 01:00:24 daemon notice pppd[255]: PPP: Start to connect ...
Mar 19 01:00:24 daemon crit pppd[255]: PPP server detected.
Mar 19 01:00:24 daemon crit pppd[255]: PPP session established.
Mar 19 01:00:26 daemon crit pppd[255]: PPP LCP UP.
Mar 19 01:00:26 daemon crit pppd[255]: Received valid IP address from server. Connection UP.
Mar 19 01:00:49 user notice dnsprobe[423]: Switching Back To Primary DNS server
СообщениеДобавлено: Чт мар 19, 2009 07:02
Armen E. писал(а):
К нашему случаю это отношение не имеет. Другой модем работает и месяцами не виснет. Проблема не на аналоговой стороне. Там все в порядке, шестикратный запас по скорости. А даже если и там, то в любом случае в этой теме идет отработка версии с конденсаторами, и все, что мне нужно от местных читателей помочь статистикой. Все остальное можно обсуждать в других темах.
Нужны смелые, умеющие держать паяльник в руках. :)
тут я с тобой неочень согласен. В модеме много настроек, часть которых ты возможно не затронул. В другом модеме настройки другие, и значения по умолчанию могут быть другие.
а прежде чем браться за паяльник. нужно знать что и как исправлять, а метод тыка, в данном случае, не подходит.
Попробуй отыскать мануалы на чип, на сам модем, примени знания по радио технике.
СообщениеДобавлено: Чт мар 19, 2009 12:18
Sky-Net писал(а):
Согласен, я пол года решал проблему другими способами. Не помогло и судя по форуму и у других та же проблема. Сейчас мне нужна статистика по этому методу. ТОЛЬКО по нему, заниматься всем одновременно нет желания. Как только я переберу все варианты с конденсаторами, я либо выкину модем, либо займусь другим методом.
Есть возможность помочь, помогай.
СообщениеДобавлено: Сб мар 21, 2009 08:45
другой модем, который работает, это какой?
СообщениеДобавлено: Сб мар 21, 2009 12:43
Zyxel P-662HW EE
СообщениеДобавлено: Сб мар 21, 2009 18:28
Armen E. писал(а):
Zyxel P-662HW EE
Если честно, то Zyxel лучше чем D-Link. По крайней мере по моему опыту использования и отзывам моих друзей и знакомых.
Zyxel я бы поставил на первое место, а вот D-Link на 2.
НО!!! Zyxel в 1,5-2 раза дороже, а для большинства пользователей вполне сгодились бы и какие-нибудь калисто.
Я это к тому, что скорее всего довести твой длинк до желаемого зайкселя не получится, у них даже чипсеты другие.
Одним паяльником особо тоже не исправишь, тут ещё и программный метод нужен.
СообщениеДобавлено: Сб мар 21, 2009 19:19
Sky-Net писал(а):
По крайней мере по моему опыту использования…
Скай, эти устройства имеют в цене разницу 5,5 раза. :!: Это разный класс железа. Но разговор не об этом.
Эта тема открыта для ремонта конкретного модема, конкретным способом. Можешь помочь со статистикой, пожалуйста, помоги, не можешь не засоряй тему.
СообщениеДобавлено: Вс мар 22, 2009 12:36
я тебе пытаюсь объяснить, что твой модем не сломан.
СообщениеДобавлено: Вс мар 22, 2009 14:51
Спасибо конечно за желание, убедить меня в том, что то, что я вижу это иллюзия.
Если есть желание продолжать в том же духе, есть смысл почитать и поболтать вот тут:
viewtopic.php?t=56876&postdays=0&postorder=asc&start=0
А если хватит сил добраться до пятой страници, то внизу можно прочитать следующее:
viewtopic.php?t=56876&postdays=0&postorder=asc&start=60
Да всё просто, эта линейка (как минимум 2500U, и судя по форуму - и 2640U) неграмотно спроектирована, и критична к перегреву. Там от перегрева падают характеристики конденсаторов в цепи питания.
Мне на днях отдали вот 2500U, который тоже примерно через год эксплуатации стал систематически виснуть. Поменял все конденсаторы, присобачил радиатор на чип, и сделал в корпусе по торцам огромные дыры для вентиляции - не виснет теперь!
Именно это я проверяю, только у меня есть желание менять не все, а только неисправные конденсаторы. И сейчас я по очереди меняю все конденсаторы, вызывающие у меня подозрения, до пропадания указанного в теме эффекта.
Для того что бы ускорить эту проверку и убедиться в том, что причина найдена правильная, нужны добровольцы, проводящие эксперимент параллельно.
СообщениеДобавлено: Вс мар 22, 2009 18:43
Так ты выпаивай и измеряй емкость, может некоторые нормальные
И сразу видно который виноват
DSL-2500U/BRU/D1 | F/W 1.58 | Укртелеком ОГО! - 10
СообщениеДобавлено: Вс мар 22, 2009 20:36
Armen E., после такого разъяснения... могу помочь вот чем, вернее для начала я попрошу тебя попытаться зарисовать цепь питания модема с номиналами детелей (на крайняк сфотографируй ещё обратную сторону платы в добавок к той, которую ты уже выложил и напиши номиналы и марки конденсаторов, но лучше схему зарисуй) и по возможности измерить выходное напряжение с блока питания, а так же напиши что там на самом блоке питания написано про напряжение. Напряжение с блока питания должно идти переменное если что.
Возможно даже будет полезно впаять стабилизатор напряжения, если там его нет.
Последний раз редактировалось Sky-Net Вс мар 22, 2009 21:36, всего редактировалось 1 раз.
СообщениеДобавлено: Вс мар 22, 2009 21:18
модем DSL-2500U/BRU/D та же ерунда но, разрыв каждые пол часа, посмотрел плату совсем другая не знаю что паять, сам в этом всём не разбираюсь но паять умею.
СообщениеДобавлено: Вс мар 22, 2009 21:31
X_Devil_X у тебя показатели линии какие?
Про аппаратную доработку: если есть желание что-либо впаять, то впаяй конденсатор С148, он находится в цепи питания, под него даже место выделено, номинал такой же как соседний конденсатор.
СообщениеДобавлено: Вс мар 22, 2009 21:39
Линия не супер, но в режиме бриджа работало отлично. Хорошо найду впаяю.
СообщениеДобавлено: Пн мар 23, 2009 00:08
Это не единственный показатель, который может приводить к неправильной работе. Например, при определенной температуре конденсатор пробивается, а замеры при обычных условиях дают нормальные значения. Так что уйти от экспериментальной замены не удастся.
Сейчас этот форум просматривают: Google [Bot] и гости: 19
