Текущее время: Ср ноя 04, 2026 10:22
 Заголовок сообщения: Постоянные дисконекты на DSL-504T
СообщениеДобавлено: Вс ноя 09, 2008 19:08
В последнее время участились дисконекты на DSL-504T, прошивка V3.02B01T01.RU.20071221, настроен роутером.
Вот лог:
Jan 3 10:45:48> DSL in Sync
Jan 3 10:45:56> DSL Carrier is up
Jan 3 10:45:56> sar read trained mode (5)(ADSL_2plus)
Jan 3 10:45:58> PPPD Terminated Through Signal
Jan 3 10:45:59> Connection terminated.
Jan 3 10:45:59> ppp0
Jan 3 10:46:02> pppd 2.4.3 started by root, uid 0
Jan 3 10:46:09> PPPoE Connect with IP Address 10.72.15.171
Jan 3 10:46:11> PPPoE Connection Successfully Established
Jan 3 10:46:11> PPPoE Connect with Gateway IP Address: 80.254.113.178
Jan 3 10:46:12> Connect: ppp0 {--} nas0
Jan 3 10:46:12> PAP authentication succeeded
Jan 3 10:46:12> peer from calling number 00:17:DF:6E:00:1B authorized
Jan 3 10:46:12> WAN IP address 10.72.15.171
Jan 3 10:46:12> WAN gateway 80.254.113.178
Jan 3 10:46:12> primary DNS address 80.254.111.254
Jan 3 10:46:12> nas1
Jan 3 10:46:12> ppp0
Jan 3 10:30:00> sar read trained mode (5)(ADSL_2plus)
Jan 3 10:30:02> PPPD Terminated Through Signal
Jan 3 10:30:02> Connection terminated.
Jan 3 10:30:02> ppp0
Jan 3 10:30:14> PPPoE Connect with IP Address 10.72.15.171
Jan 3 10:30:15> PPPoE Connection Successfully Established
Jan 3 10:30:15> PPPoE Connect with Gateway IP Address: 80.254.113.178
Jan 3 10:30:16> pppd 2.4.3 started by root, uid 0
Jan 3 10:30:16> Connect: ppp0 {--} nas0
Jan 3 10:30:16> PAP authentication succeeded
Jan 3 10:30:16> peer from calling number 00:17:DF:6E:00:1B authorized
Jan 3 10:30:16> WAN IP address 10.72.15.171
Jan 3 10:30:16> WAN gateway 80.254.113.178
Jan 3 10:30:16> primary DNS address 80.254.111.254
Jan 3 10:30:16> nas1
Jan 3 10:30:16> ppp0
Jan 3 10:45:25> DSL out of sync
Jan 3 10:45:36> DSL Carrier is down
Jan 3 10:27:49> ppp0
Jan 3 10:27:51> nas1
Jan 3 10:27:58> PPPoE Connect with IP Address 10.72.15.171
Jan 3 10:27:59> PPPoE Connection Successfully Established
Jan 3 10:27:59> PPPoE Connect with Gateway IP Address: 80.254.113.178
Jan 3 10:28:00> pppd 2.4.3 started by root, uid 0
Jan 3 10:28:00> Connect: ppp0 {--} nas0
Jan 3 10:28:00> PAP authentication succeeded
Jan 3 10:28:00> peer from calling number 00:17:DF:6E:00:1B authorized
Jan 3 10:28:00> WAN IP address 10.72.15.171
Jan 3 10:28:00> WAN gateway 80.254.113.178
Jan 3 10:28:00> primary DNS address 80.254.111.254
Jan 3 10:28:00> nas1
Jan 3 10:28:00> ppp0
Jan 3 10:29:36> DSL out of sync
Jan 3 10:29:40> DSL Carrier is training
Jan 3 10:29:50> DSL Carrier is down
Jan 3 10:29:59> DSL in Sync
Jan 3 10:30:00> DSL Carrier is up
В чем проблема???
СообщениеДобавлено: Ср ноя 12, 2008 18:35
ну кто-нибудь может мне ответить???
СообщениеДобавлено: Ср ноя 19, 2008 18:31
СообщениеДобавлено: Чт ноя 20, 2008 17:17
Возможно проблемы с линией, в т.ч. и в том проводе что идет от модема до сплиттера. Смотри статус ADSL(ATM) в веб-интерфейсе.
