Текущее время: Вт окт 27, 2026 07:51
СообщениеДобавлено: Вт ноя 11, 2003 20:36
Вобщем дело такое:
имеем DVG и DG
работают в режиме hotline
с DVG на DG звонки проходят отлично.
а вот наоборот - приходится сначала набирать например "1" и ждать пока образуется тоннель - затем ждать гудка и далее набирать номер.
вот лог события
cmEvNewCall(hsCall=7069828) runs
Set Tunnelling TRUE.
*-*-*-*-*-* Enter SSE section
*-*-*-*-*-* SSE section completed!
cmEvCallStateChanged(state=cmCallStateOffering, statemode=cmCallStateModeOfferingCreate)
0-Offering-cmEvCallStateChanged
cmEvCallStateChanged(state=cmCallStateConnected, statemode=cmCallStateModeConnectedCallSetup)
0-Connected-cmEvCallStateChanged
Callee----->
fs_flag[0]=0
------statemode: ConnectedCallSetup------
0-ControlStateTransportConnected
Enter cmEvCallCapabilities()
## Remote Capability Set
## [1] g711Ulaw64k: Audio Receive and Transmit
## [2] g711Alaw64k: Audio Receive and Transmit
## [3] g7231: Audio Receive and Transmit
## [4] g7231: Audio Receive and Transmit
## [5] g729AnnexA: Audio Receive and Transmit
First entry of matched remote TCS: (0)g729AnnexA
the best matched codec is g729AnnexA
MSDetermination: Master
0-cmControlStateConnected
cmEvCallStateChanged(state=cmCallStateConnected, statemode=cmCallStateModeConnectedCall)
Callee----->
fs_flag[0]=0
Calling party creating channel...
=== Channel New
=== Channel Set RTCP Address
call0 ch1-ChannelState: Dialtone
call0 ch1-ChannelState: RingBack
=== Channel open with codec: g729AnnexA, TxM=0
cmEvChannelSetRTCPAddress hsChan = 6afbfc
RTCP call: 0, channel: 1
cmEvChannelSetAddress hsChan = 6afbfc
call0 ch1-217.24.180.61: 30008-cmEvChannelSetAddress
cmEvChannelParameters hsChannel: 6afbfc channeName = (null)
call0 ch1-ChannelState: Connected
Enter EvChannelNew..6afd94
call0 hsChanIn-cmEvChannelNew Send
cmEvChannelSetRTCPAddress hsChan = 6afd94
RTCP call: 0, channel: 0
cmEvChannelParameters hsChannel: 6afd94 channeName = g729AnnexA
incoming channel codec: g729AnnexA
call0 ch0-ChannelState: Offering
call0 ch0-ChannelState: Connected
0-Enter openDeviceChannel
H323ap select codec g729AnnexA
H323ap select codec g729AnnexA, TxM=2 echo=1
After connect, h245 connect
========================после этого идет гудок
Detect Alphanumeric: 1[1]
Detect Alphanumeric: 7[7]
Detect Alphanumeric: 5[5]
Detect Alphanumeric: 2[2]
Detect Alphanumeric: 6[6]
============================доп набор цифр, которого хочется избежать
call0 ch0-ChannelState: Disconnected
call0 ch0-ChannelState: Idle
call0 ch1-ChannelState: Disconnected
call0 ch1-ChannelState: Idle
0-cmControlStateTransportDisconnected
cmEvCallStateChanged(state=cmCallStateDisconnected, statemode=cmCallStateModeDisconnectedNormal)
0-Disconnected-cmEvCallStateChanged reason = 11
cmEvCallStateChanged(state=cmCallStateIdle, statemode=cmCallStateModeDisconnectedBusy)
H323ap select codec g711Ulaw64k
H323ap select codec g711Ulaw64k, TxM=2 echo=1
самое интересное - что с прошивкой 1.0 все отлично "пролетало наружу", но почему то с ней DVG весилась раза по 2 на день.
что посоветуете в этой связи??
на DG-104SH прошивка boot b13 runtime b42
СообщениеДобавлено: Ср ноя 12, 2003 16:51
ну что ?
так никто и не поможет?
СообщениеДобавлено: Ср ноя 12, 2003 17:11
Anton писал(а):
ну что ?
Антон у сожалению у меня сейчас нет 1104, как он появится я смоделирую Вашу ситуацию и напишу о результатах.
С уважением, Дмитрий Письменов
СообщениеДобавлено: Ср ноя 12, 2003 22:43
А на какой срок появления расчитвать?
И вот еще я тут все копаю эту тему - может попробовать организовать режиим не Hotline а Line-to-line ?
Чем они отличаются?
СообщениеДобавлено: Чт ноя 13, 2003 11:06
Чем они отличаются?
В начале след неделе будет,
лайн-ту-лайн это ТОЛЬКО для 2-х 1104 - там пробрасывается не на айпи+номер-телефона а на айпи+номер-порта.
СообщениеДобавлено: Ср ноя 26, 2003 09:36
Какие подвижки по моему вопросу?
А то все зависают и зависают и обратно не звоняться... :evil:
СообщениеДобавлено: Ср ноя 26, 2003 12:11
Можно воспользоваться командой
set tcid 0 dial_in plar 91(например) - тогда пользователю нужно будет просто подождать зуммера от 1104.
