Текущее время: Пт окт 09, 2026 03:34
 Заголовок сообщения: DIR-400 - не соединяется PPPoE
СообщениеДобавлено: Пн апр 07, 2008 11:08
Не устанавливается соединение PPPoE. Со стороны провайдера видно вот что:
12:21:21.032758 PPPoE PADI [Service-Name]
12:21:21.033370 PPPoE PADO [AC-Name "mkc-salvation"] [Service-Name] [Service-Name "*"] [AC-Cookie 0x8076FBC6]
12:21:21.034805 PPPoE PADR [Service-Name] [AC-Cookie 0x8076FBC6]
12:21:21.034814 PPPoE PADS [ses 0x19e9] [AC-Name "mega-server"] [Service-Name] [AC-Cookie 0x8076FBC6]
12:21:21.039905 PPPoE  [ses 0x19e9] LCP, Conf-Request (0x01), id 1, length 22
12:21:21.039922 PPPoE  [ses 0x19e9] LCP, Conf-Request (0x01), id 1, length 22
12:21:21.040925 PPPoE  [ses 0x19e9] LCP, Conf-Request (0x01), id 1, length 22
12:21:21.040935 PPPoE  [ses 0x19e9] LCP, Conf-Request (0x01), id 1, length 22
12:21:21.040939 PPPoE  [ses 0x19e9] LCP, Conf-Request (0x01), id 1, length 22
12:21:21.143380 PPPoE  [ses 0x19e9] LCP, Conf-Request (0x01), id 1, length 35
12:21:21.143396 PPPoE  [ses 0x19e9] LCP, Conf-Reject (0x04), id 1, length 10
12:21:21.143410 PPPoE  [ses 0x19e9] LCP, Conf-Reject (0x04), id 1, length 10
12:21:21.143423 PPPoE  [ses 0x19e9] LCP, Conf-Reject (0x04), id 1, length 10
12:21:21.143431 PPPoE  [ses 0x19e9] LCP, Conf-Reject (0x04), id 1, length 10
12:21:21.143439 PPPoE  [ses 0x19e9] LCP, Conf-Reject (0x04), id 1, length 10
12:21:21.161216 PPPoE  [ses 0x19e9] LCP, Conf-Reject (0x04), id 1, length 14
12:21:21.161342 PPPoE  [ses 0x19e9] LCP, Conf-Request (0x01), id 2, length 27
12:21:21.162245 PPPoE  [ses 0x19e9] LCP, Conf-Request (0x01), id 2, length 18
12:21:21.162314 PPPoE  [ses 0x19e9] LCP, Conf-Ack (0x02), id 2, length 18
12:21:21.168417 PPPoE  [ses 0x19e9] LCP, Conf-Ack (0x02), id 2, length 27
12:21:21.168503 PPPoE  [ses 0x19e9] LCP, Echo-Request (0x09), id 0, length 18
12:21:21.168513 PPPoE  [ses 0x19e9] CHAP, Challenge (0x01), id 1, Value 36343432303936393035393934353332, Name
12:21:21.182808 PPPoE  [ses 0x19e9] HELLO
        0x0000:  001e 10f3 1fdd 68e5 f119 9c2d 4120 5513
        0x0010:  4fb0 c870 6f73 7065 6c6f 7632
12:21:21.182860 PPPoE  [ses 0x19e9] LCP, Prot-Reject (0x08), id 3, length 36
12:21:24.231055 PPPoE  [ses 0x19e9] CHAP, Challenge (0x01), id 2, Value 36343432303936393035393934353332, Name
12:21:24.237167 PPPoE  [ses 0x19e9] unknown PPP protocol (0x0202)
        0x0000:  001e 1039 f4a9 5633 1d01 ac22 b9f3 0070
        0x0010:  3a45 2670 6f73 7065 6c6f 7632
12:21:24.237220 PPPoE  [ses 0x19e9] LCP, Prot-Reject (0x08), id 3, length 36
12:21:26.515092 PPPoE  [ses 0x19e9] LCP, Term-Request (0x05), id 3, length 18
12:21:26.515140 PPPoE  [ses 0x19e9] LCP, Term-Ack (0x06), id 3, length 6
12:21:26.524357 PPPoE PADT [ses 0x19e9] [Generic-Error "session closed"]
Что смущает - так это то, что после Name при авторизации всегда идёт логин пользователя, а тут - пусто, потом обычно нет никакого HELLO и 2ух последующих строчек. Ну, и как следствие - unknown PPP protocol.
Обновление прошивки не помогло. Не работает как PPPOE, так и Russian PPPoE
СообщениеДобавлено: Вт апр 08, 2008 12:32
Что за сервер у провайдера?
СообщениеДобавлено: Ср апр 09, 2008 05:27
Сервер - pppoed
Сегодня ещё один dir-400 принесли - то же самое.
А с DI-604, DI-624 и др. старыми моделями нормально работает, как и с железками других производителей (например, Asus и Apple)
СообщениеДобавлено: Ср апр 09, 2008 14:23
попробуй залить прошивку версии 1.01 - хоть и работает кривовато (в частности, раз в 10 снижает скорость соединения) но pptp поднимает... возможно, и pppoe поднимет...
СообщениеДобавлено: Чт апр 10, 2008 17:16
Так я залил уже... я ж писал, что не помогло обновление...
Странно то, что если б действительно была такая проблема, то давно бы уже завалили форум подобными сообщениями...
Была мысль, что может он какое-нить сжатие / шифрование использует?
СообщениеДобавлено: Пт апр 11, 2008 12:01
Аналогичная ситуация с DIR-400.
12:12:48.257038 PPPoE  [ses 0x7457] unknown PPP protocol (0x0001)
        0x0000:  0700 160a 7065 3130 3130 3337 3232 0631
        0x0010:  3430 3436 32
прошивка 1.01 не спасает.
другие роутеры (компы, другие вендоры, да и длинки типа DI-604) - работают без проблем.
СообщениеДобавлено: Вс апр 13, 2008 09:50
Попрошу "счастливых" обладателей DIR-400 отписаться по проблеме - были у кого-нибудь случаи нормального подключения PPPoE?
СообщениеДобавлено: Вс апр 13, 2008 10:27
Проверили: оно таки соединяется, но не с pppoed/ppp.
Работает с mpd5 и микротиком.
По словам нашего сотрудника, который ковырялся в этом, в DIR400 какой-то косяк на этапе согласнования, он вроде соглашается на предложенные параметры (ack есть), но потом его что-то не устраивает и он дропается.
 Заголовок сообщения: Re: DIR-400 - не соединяется PPPoE
СообщениеДобавлено: Пн апр 14, 2008 21:31
Абсолютно то же самое у меня с моим провайдером. Вот лог провайдера (шифрования нет, авторизация CHAP MD5):
21:36:41.963152 PPPoE PADO [AC-Name "demos"] [Service-Name] [Service-Name "*"] [AC-Cookie 0x0067BFC2]
0x0000: 000c 76c0 5031 0007 e909 ea3f 8100 000e ..v.P1.....?....
0x0010: 8863 1107 0000 001a 0102 0005 6465 6d6f .c..........demo
0x0020: 7301 0100 0001 0100 012a 0104 0004 0067 s........*.....g
0x0030: bfc2 ..
21:36:42.144160 PPPoE PADR [Service-Name] [AC-Cookie 0x0067BFC2] [TAG-0x1] [EOL]
0x0000: 0007 e909 ea3f 000c 76c0 5031 8100 000e .....?..v.P1....
0x0010: 8863 1119 0000 000c 0101 0000 0104 0004 .c..............
0x0020: 0067 bfc2 0001 0000 0000 0000 0000 0000 .g..............
0x0030: 0000 0000 4d90 0000 4d90 0000 0005 0000 ....M...M.......
21:36:42.144210 PPPoE PADS [ses 0x4e22] [AC-Name "demos"] [Service-Name] [AC-Cookie 0x0067BFC2]
0x0010: 8863 1165 4e22 0015 0102 0005 6465 6d6f .c.eN"......demo
0x0020: 7301 0100 0001 0400 0400 67bf c2 s.........g..
21:36:42.873055 PPPoE [ses 0x4e22] LCP, Conf-Request (0x01), id 1, ACCM 00000000, Magic-Num 0xfc73fc97, PFC , ACFC , length 20
0x0000: c021 0101 0014 0206 0000 0000 0506 fc73
0x0010: fc97 0702 0802
0x0010: 8864 1100 4e22 0016 c021 0101 0014 0206 .d..N"...!......
0x0020: 0000 0000 0506 fc73 fc97 0702 0802 6f6e .......s......on
0x0030: 6652 6571 2069 643d 3078 3120 3c61 7379 fReq.id=0x1.<asy
21:36:42.873227 PPPoE [ses 0x4e22] LCP, Conf-Request (0x01), id 1, ACCM 00000000, MRU 1492, Magic-Num 0x1c8dd473, Qual-Prot LQR, Auth-Prot CHAP, MD5, length 33
0x0000: c021 0101 0021 0206 0000 0000 0104 05d4
0x0010: 0506 1c8d d473 0408 c025 0000 03e8 0305
0x0020: c223 05
0x0010: 8864 1100 4e22 0023 c021 0101 0021 0206 .d..N".#.!...!..
0x0020: 0000 0000 0104 05d4 0506 1c8d d473 0408 .............s..
0x0030: c025 0000 03e8 0305 c223 05 .%.......#.
21:36:42.873245 PPPoE [ses 0x4e22] LCP, Conf-Reject (0x04), id 1, ACFC , length 6
0x0000: c021 0401 0006 0802
0x0010: 8864 1100 4e22 0008 c021 0401 0006 0802 .d..N"...!......
21:36:42.882677 PPPoE [ses 0x4e22] LCP, Conf-Reject (0x04), id 1, Qual-Prot LQR, length 12
0x0000: c021 0401 000c 0408 c025 0000 03e8
0x0010: 8864 1100 4e22 000e c021 0401 000c 0408 .d..N"...!......
0x0020: c025 0000 03e8 0000 0000 0000 0000 0000 .%..............
21:36:42.882800 PPPoE [ses 0x4e22] LCP, Conf-Request (0x01), id 2, ACCM 00000000, Magic-Num 0xfc73fc97, PFC , length 18
0x0000: c021 0102 0012 0206 0000 0000 0506 fc73
0x0010: fc97 0702
0x0010: 8864 1100 4e22 0014 c021 0102 0012 0206 .d..N"...!......
21:36:42.882859 PPPoE [ses 0x4e22] LCP, Conf-Request (0x01), id 2, ACCM 00000000, MRU 1492, Magic-Num 0x1c8dd473, Auth-Prot CHAP, MD5, length 25
0x0000: c021 0102 0019 0206 0000 0000 0104 05d4
0x0010: 0506 1c8d d473 0305 c223 05
0x0010: 8864 1100 4e22 001b c021 0102 0019 0206 .d..N"...!......
0x0020: 0000 0000 0104 05d4 0506 1c8d d473 0305 .............s..
0x0030: c223 05 .#.
21:36:42.882874 PPPoE [ses 0x4e22] LCP, Conf-Nack (0x03), id 2, MRU 1492, length 8
0x0000: c021 0302 0008 0104 05d4
0x0010: 8864 1100 4e22 000a c021 0302 0008 0104 .d..N"...!......
0x0020: 05d4 ..
21:36:42.889424 PPPoE [ses 0x4e22] LCP, Conf-Ack (0x02), id 2, ACCM 00000000, MRU 1492, Magic-Num 0x1c8dd473, Auth-Prot CHAP, MD5, length 25
0x0000: c021 0202 0019 0206 0000 0000 0104 05d4
0x0010: 8864 1100 4e22 001b c021 0202 0019 0206 .d..N"...!......
0x0030: c223 0571 2069 643d 3078 3120 3c61 7379 .#.q.id=0x1.<asy
21:36:42.889431 PPPoE [ses 0x4e22] LCP, Conf-Request (0x01), id 3, MRU 1492, ACCM 00000000, Magic-Num 0xfc73fc97, PFC , length 22
0x0000: c021 0103 0016 0104 05d4 0206 0000 0000
0x0010: 0506 fc73 fc97 0702
0x0010: 8864 1100 4e22 0018 c021 0103 0016 0104 .d..N"...!......
0x0020: 05d4 0206 0000 0000 0506 fc73 fc97 0702 ...........s....
21:36:42.889669 PPPoE [ses 0x4e22] LCP, Conf-Ack (0x02), id 3, MRU 1492, ACCM 00000000, Magic-Num 0xfc73fc97, PFC , length 22
0x0000: c021 0203 0016 0104 05d4 0206 0000 0000
0x0010: 8864 1100 4e22 0018 c021 0203 0016 0104 .d..N"...!......
21:36:42.889690 PPPoE [ses 0x4e22] LCP, Echo-Request (0x09), id 0, Magic-Num 0x1c8dd473, length 16
0x0000: c021 0900 0010 1c8d d473 594e 4f54 0000
0x0010: 0000
0x0010: 8864 1100 4e22 0012 c021 0900 0010 1c8d .d..N"...!......
0x0020: d473 594e 4f54 0000 0000 .sYNOT....
21:36:42.889710 PPPoE [ses 0x4e22] Chal(1), Value 39313536323337313039373237383631, Name
0x0010: 8864 1100 4e22 0017 c223 0101 0015 1039 .d..N"...#.....9
0x0020: 3135 3632 3337 3130 3937 3237 3836 31 156237109727861
21:36:42.906055 PPPoE [ses 0x4e22] unknown PPP protocol (0x0201)
0x0000: 0017 109d e51b 6538 38a3 c356 3e59 f39a
0x0010: 144c b437 38
0x0010: 8864 1100 4e22 0017 0201 0017 109d e51b .d..N"..........
0x0020: 6538 38a3 c356 3e59 f39a 144c b437 3868 e88..V>Y...L.78h
0x0030: 616c 6c65 6e67 6520 6964 3d30 7831 203c allenge.id=0x1.<
21:36:42.906330 PPPoE [ses 0x4e22] LCP, Prot-Reject (0x08), id 3, Rejected HELLO Protocol (0x0201), length 27
0x0000: c021 0803 001b 0201 0017 109d e51b 6538
0x0010: 38a3 c356 3e59 f39a 144c b437 38
0x0010: 8864 1100 4e22 001d c021 0803 001b 0201 .d..N"...!......
0x0020: 0017 109d e51b 6538 38a3 c356 3e59 f39a ......e88..V>Y..
0x0030: 144c b437 38 .L.78
21:36:45.865661 PPPoE [ses 0x4e22] Chal(2), Value 39313536323337313039373237383631, Name
0x0010: 8864 1100 4e22 0017 c223 0102 0015 1039 .d..N"...#.....9
21:36:45.871465 PPPoE [ses 0x4e22] unknown PPP protocol (0x0202)
0x0000: 0017 10ec b813 1ee1 9b3e f4a9 9ee0 a648
0x0010: a9ba 8037 38
0x0010: 8864 1100 4e22 0017 0202 0017 10ec b813 .d..N"..........
0x0020: 1ee1 9b3e f4a9 9ee0 a648 a9ba 8037 3865 ...>.....H...78e
0x0030: 7370 6f6e 7365 2069 643d 3078 3220 3c65 sponse.id=0x2.<e
21:36:45.871593 PPPoE [ses 0x4e22] LCP, Prot-Reject (0x08), id 3, Rejected unknown Protocol (0x0202), length 27
0x0000: c021 0803 001b 0202 0017 10ec b813 1ee1
0x0010: 9b3e f4a9 9ee0 a648 a9ba 8037 38
0x0010: 8864 1100 4e22 001d c021 0803 001b 0202 .d..N"...!......
0x0020: 0017 10ec b813 1ee1 9b3e f4a9 9ee0 a648 .........>.....H
0x0030: a9ba 8037 38 ...78
21:36:48.869223 PPPoE [ses 0x4e22] Chal(3), Value 39313536323337313039373237383631, Name
0x0010: 8864 1100 4e22 0017 c223 0103 0015 1039 .d..N"...#.....9
21:36:48.875144 PPPoE [ses 0x4e22] unknown PPP protocol (0x0203)
0x0000: 0017 1033 03c8 3941 5a09 5455 acc3 b567
0x0010: c971 d937 38
0x0010: 8864 1100 4e22 0017 0203 0017 1033 03c8 .d..N".......3..
0x0020: 3941 5a09 5455 acc3 b567 c971 d937 3865 9AZ.TU...g.q.78e
0x0030: 7370 6f6e 7365 2069 643d 3078 3320 3c33 sponse.id=0x3.<3
21:36:48.875374 PPPoE [ses 0x4e22] LCP, Prot-Reject (0x08), id 3, Rejected unknown Protocol (0x0203), length 27
0x0000: c021 0803 001b 0203 0017 1033 03c8 3941
0x0010: 5a09 5455 acc3 b567 c971 d937 38
0x0010: 8864 1100 4e22 001d c021 0803 001b 0203 .d..N"...!......
0x0020: 0017 1033 03c8 3941 5a09 5455 acc3 b567 ...3..9AZ.TU...g
0x0030: c971 d937 38 .q.78
21:36:51.872779 PPPoE [ses 0x4e22] LCP, Term-Request (0x05), id 3
0x0010: 8864 1100 4e22 0006 c021 0503 0004 .d..N"...!....
21:36:51.878783 PPPoE [ses 0x4e22] LCP, Term-Ack (0x06), id 3
0x0010: 8864 1100 4e22 0006 c021 0603 0004 3436 .d..N"...!....46
0x0020: 5d3a 2073 656e 7420 5b4c 4350 2054 6572 ]:.sent.[LCP.Ter
0x0030: 6d41 636b 2069 643d 3078 335d 0005 0000 mAck.id=0x3]....
21:36:51.878984 PPPoE PADT [ses 0x4e22] [Generic-Error "session closed"]
0x0010: 8863 11a7 4e22 0012 0203 000e 7365 7373 .c..N"......sess
0x0020: 696f 6e20 636c 6f73 6564 ion.closed
21:36:51.880997 PPPoE PADT [ses 0x4e22] [Generic-Error "Received PADT from peer"]
Вот лог извините за выражение "маршрутизатора" DIR 400:
Apr 14 18:21:11 info Plugin /lib/pppd/2.4.3/rp-pppoe.so loaded.
Apr 14 18:21:11 info RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3
Apr 14 18:21:12 notice pppd 2.4.3 started by root, uid 0
Apr 14 18:21:12 debug using channel 2
Apr 14 18:21:12 info Using interface ppp0
Apr 14 18:21:12 notice Connect: ppp0 '--' /dev/pts/0
Apr 14 18:21:12 info rp_pppoe =' Send PADT to terminate the session ID that sent last time
Apr 14 18:21:12 info Sent PADT
Apr 14 18:21:12 debug PADS: Service-Name: ''
Apr 14 18:21:12 info PPP session is 19659 (0x4ccb)
Apr 14 18:21:13 debug sent [LCP ConfReq id=0x1 'asyncmap 0x0' 'magic 0xaad0ee9c' 'pcomp' 'accomp']
Apr 14 18:21:13 debug rcvd [LCP ConfReq id=0x1 'asyncmap 0x0' 'mru 1492' 'magic 0x1d29b499' 'quality lqr 00 00 03 e8' 'auth chap MD5']
Apr 14 18:21:13 debug sent [LCP ConfRej id=0x1 'quality lqr 00 00 03 e8']
Apr 14 18:21:13 debug rcvd [LCP ConfRej id=0x1 'accomp']
Apr 14 18:21:13 debug sent [LCP ConfReq id=0x2 'asyncmap 0x0' 'magic 0xaad0ee9c' 'pcomp']
Apr 14 18:21:13 debug rcvd [LCP ConfReq id=0x2 'asyncmap 0x0' 'mru 1492' 'magic 0x1d29b499' 'auth chap MD5']
Apr 14 18:21:13 debug sent [LCP ConfAck id=0x2 'asyncmap 0x0' 'mru 1492' 'magic 0x1d29b499' 'auth chap MD5']
Apr 14 18:21:13 debug rcvd [LCP ConfNak id=0x2 'mru 1492']
Apr 14 18:21:13 debug sent [LCP ConfReq id=0x3 'mru 1492' 'asyncmap 0x0' 'magic 0xaad0ee9c' 'pcomp']
Apr 14 18:21:13 debug rcvd [LCP ConfAck id=0x3 'mru 1492' 'asyncmap 0x0' 'magic 0xaad0ee9c' 'pcomp']
Apr 14 18:21:13 debug sent [LCP EchoReq id=0x0 magic=0xaad0ee9c]
Apr 14 18:21:13 debug rcvd [LCP EchoReq id=0x0 magic=0x1d29b499 00 00 00 00 aa d0 ee 9c]
Apr 14 18:21:13 debug sent [LCP EchoRep id=0x0 magic=0xaad0ee9c 00 00 00 00 aa d0 ee 9c]
Apr 14 18:21:13 debug rcvd [CHAP Challenge id=0x1 '35353934333436353735313238323533', name = ]
Apr 14 18:21:13 debug sent [CHAP Response id=0x1 '47ac1bae1533dbbfa85d534db991ead4', name = 78 ]
Apr 14 18:21:13 debug rcvd [LCP ProtRej id=0x3 02 01 00 17 10 47 ac 1b ae 15 33 db bf a8 5d 53 4d b9 91 ea d4 37 38]
Apr 14 18:21:14 info DNS started
Apr 14 18:21:14 debug reading /etc/hosts
Apr 14 18:21:14 debug reading /etc/resolv.conf
Apr 14 18:21:14 info using nameserver 0.0.0.0
Apr 14 18:21:14 info using nameserver 10.132.104.2
Apr 14 18:21:16 debug rcvd [CHAP Challenge id=0x2 '35353934333436353735313238323533', name = ]
Apr 14 18:21:16 debug sent [CHAP Response id=0x2 '5dd40a2c3e5d8d38776e1a8bc1ddc27a', name = 78 ]
Apr 14 18:21:16 debug rcvd [LCP ProtRej id=0x3 02 02 00 17 10 5d d4 0a 2c 3e 5d 8d 38 77 6e 1a 8b c1 dd c2 7a 37 38]
Apr 14 18:21:19 debug rcvd [CHAP Challenge id=0x3 '35353934333436353735313238323533', name = ]
Apr 14 18:21:19 debug sent [CHAP Response id=0x3 '647abcbdc59735f3f64393efd6aa8121', name = 78 ]
Apr 14 18:21:19 debug rcvd [LCP ProtRej id=0x3 02 03 00 17 10 64 7a bc bd c5 97 35 f3 f6 43 93 ef d6 aa 81 21 37 38]
Apr 14 18:21:22 debug rcvd [LCP TermReq id=0x3]
Apr 14 18:21:22 info LCP terminated by peer
Apr 14 18:21:22 debug sent [LCP TermAck id=0x3]
Apr 14 18:21:22 info Session 19659 terminated -- received PADT from peer
Apr 14 18:21:22 info Sent PADT
Apr 14 18:21:22 debug Script pppoe -I eth0 finished (pid 375), status = 0x0
Apr 14 18:21:22 notice Modem hangup
Apr 14 18:21:22 notice ppp auth: Connection terminated.
Apr 14 18:21:22 info Exit.
PS: И не надо рассказывать про неправильное имя пользователя и пароль. Когда же у D-Link что-нибудь заработает?! И почему я не заглянул в форум _перед_ покупкой?!
СообщениеДобавлено: Вт апр 15, 2008 11:01
den1049
Не могли бы Вы прислать сниф, что Вы привели в более удобочитаемом формате - pcap и скинуть его мне на почту?
СообщениеДобавлено: Пн авг 17, 2009 06:08
Что то решилось по проблеме подклчюения ПППоЕ?
мой DIR 400 криво подключается - в режиме DynamicIP подключается, слева горит надпись Internet online - но Интернет не доступен.
В режиме StaticIP не подключается...
СообщениеДобавлено: Пн авг 17, 2009 16:31
С прошивкой из папки beta уже работает.
СообщениеДобавлено: Ср авг 19, 2009 03:42
именно эта прошивка стоит. роутер подключается, но как то странно:
если указать в параметрах WAN DynamicIP - pppoe подключается, присвается IP адрес 82.194.160.202... доступа в Интернет нет. Провайдер говорит что нужно указывать свой внутренний IP, т.е. StaticIP
если указать в WAN в StaticIP мой внутренний адрес, то PPPoE не подключается, мне кажется роутер передаёт не мой внутренний адрес (10.х.х.х), а адрес LAN интерфейса 192.168.0.1 - ниже лог роутера
в качестве эксперимента сделал следующее, бред конечно, но всё таки:
назначил на LAN интерфейс роутера мой адрес который выдал мне провайдер 10.8.111.215 (т.е. вместо 192.168.0.1), WAN настроил на DynamicIP - роутер подключился по PPPoE и на ноутбуке заработал Интернет, подключен к роутеру по WIFI, т.е. у внутреняя сеть роутера 10.8.111.0, естественно это не правильно и не выход из ситуации, но так работает.
<30>pppd[1759]: Plugin /lib/pppd/2.4.3/rp-pppoe.so loaded.
<30>pppd[1759]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3
<29>pppd[1760]: pppd 2.4.3 started by root, uid 0
<30>pppd[1760]: rp_pppoe => Send PADT to terminate the session ID that sent last time
<30>pppd[1760]: Sent PADT
<31>pppd[1760]: PADS: Service-Name: ''
<30>pppd[1760]: PPP session is 42831
<31>pppd[1760]: using channel 15
<30>pppd[1760]: Using interface ppp0
<29>pppd[1760]: Connect: ppp0 <--> eth0
<31>pppd[1760]: sent [LCP ConfReq id=0x1 <mru 1492> <magic 0xf2ab1f49>]
<31>pppd[1760]: rcvd [LCP ConfReq id=0x1 <mru 1492> <auth chap MD5> <magic 0x66ac2982>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1760]: sent [LCP ConfAck id=0x1 <mru 1492> <auth chap MD5> <magic 0x66ac2982>]
<31>pppd[1760]: rcvd [LCP ConfAck id=0x1 <mru 1492> <magic 0xf2ab1f49>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1760]: sent [LCP EchoReq id=0x0 magic=0xf2ab1f49]
<31>pppd[1760]: rcvd [CHAP Challenge id=0x1 <4a252dc35e87859ab5f301afc314eaa0>, name = "c7204vt-inode"] 00 00 00 00
<31>pppd[1760]: sent [CHAP Response id=0x1 <9a3efeb314446fc819a6cbd3554fcdf5>, name = "10.8.111.215"]
<31>pppd[1760]: rcvd [LCP EchoRep id=0x0 magic=0x66ac2982] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1760]: rcvd [CHAP Success id=0x1 ""] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
<30>pppd[1760]: CHAP authentication succeeded
<29>pppd[1760]: peer from calling number 00:0A:8B:61:F4:19 authorized
<31>pppd[1760]: sent [IPCP ConfReq id=0x1 <addr 10.8.111.215> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
<31>pppd[1760]: rcvd [IPCP ConfReq id=0x1 <addr 192.168.0.1>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1760]: sent [IPCP ConfAck id=0x1 <addr 192.168.0.1>]
<31>pppd[1760]: rcvd [IPCP ConfRej id=0x1 <ms-dns3 0.0.0.0>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1760]: sent [IPCP ConfReq id=0x2 <addr 10.8.111.215> <ms-dns1 0.0.0.0>]
<31>pppd[1760]: rcvd [IPCP ConfNak id=0x2 <addr 82.194.160.202> <ms-dns1 212.16.193.34>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1760]: sent [IPCP ConfReq id=0x3 <addr 10.8.111.215> <ms-dns1 212.16.193.34>]
<31>pppd[1760]: rcvd [IPCP ConfNak id=0x3 <addr 82.194.160.202>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1760]: sent [IPCP ConfReq id=0x4 <addr 10.8.111.215> <ms-dns1 212.16.193.34>]
<31>pppd[1760]: rcvd [IPCP ConfNak id=0x4 <addr 82.194.160.202>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1760]: sent [IPCP ConfReq id=0x5 <addr 10.8.111.215> <ms-dns1 212.16.193.34>]
<31>pppd[1760]: rcvd [IPCP ConfNak id=0x5 <addr 82.194.160.202>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1760]: sent [IPCP ConfReq id=0x6 <addr 10.8.111.215> <ms-dns1 212.16.193.34>]
<31>pppd[1760]: rcvd [IPCP ConfNak id=0x6 <addr 82.194.160.202>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1760]: sent [IPCP ConfReq id=0x7 <ms-dns1 212.16.193.34>]
<31>pppd[1760]: rcvd [IPCP ConfAck id=0x7 <ms-dns1 212.16.193.34>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<27>pppd[1760]: Peer refused to agree to our IP address
<30>pppd[1760]: Connect time 0.1 minutes.
<30>pppd[1760]: Sent 122 bytes, received 304 bytes.
<31>pppd[1760]: sent [IPCP TermReq id=0x8 "Refused our IP address"]
<31>pppd[1760]: rcvd [IPCP TermAck id=0x8] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
<31>pppd[1760]: sent [LCP TermReq id=0x2 "No network protocols running"]
<31>pppd[1760]: rcvd [LCP TermAck id=0x2] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
<29>pppd[1760]: ppp auth: Connection terminated.
<27>pppd[1760]: Fatal signal 11
<30>pppd[1760]: Exit.
СообщениеДобавлено: Ср авг 19, 2009 12:39
вот лог, при настройках, когда подключение проходит успешно, но интернет не доступен, недоступен даже выданный провайдером ДНС
<30>pppd[1727]: PPP session is 45808
<31>pppd[1727]: using channel 3
<30>pppd[1727]: Using interface ppp0
<29>pppd[1727]: Connect: ppp0 <--> eth0
<31>pppd[1727]: sent [LCP ConfReq id=0x1 <mru 1092> <magic 0xecec6bf2>]
<31>pppd[1727]: rcvd [LCP ConfReq id=0x1 <mru 1492> <auth chap MD5> <magic 0x6b1c23ae>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1727]: sent [LCP ConfAck id=0x1 <mru 1492> <auth chap MD5> <magic 0x6b1c23ae>]
<31>pppd[1727]: rcvd [LCP ConfNak id=0x1 <mru 1492>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1727]: sent [LCP ConfReq id=0x2 <mru 1492> <magic 0xecec6bf2>]
<31>pppd[1727]: rcvd [LCP ConfAck id=0x2 <mru 1492> <magic 0xecec6bf2>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1727]: sent [LCP EchoReq id=0x0 magic=0xecec6bf2]
<31>pppd[1727]: rcvd [CHAP Challenge id=0x1 <cded48ad2f9eb055b5f301af35c5ba01>, name = "c7204vt-inode"] 00 00 00 00
<31>pppd[1727]: sent [CHAP Response id=0x1 <4339eeed7a3a46bc836a39398ac552b8>, name = "10.8.111.215"]
<31>pppd[1727]: rcvd [LCP EchoRep id=0x0 magic=0x6b1c23ae] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1727]: rcvd [CHAP Success id=0x1 ""] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
<30>pppd[1727]: CHAP authentication succeeded
<29>pppd[1727]: peer from calling number 00:0A:8B:61:F4:19 authorized
<31>pppd[1727]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
<31>pppd[1727]: rcvd [IPCP ConfReq id=0x1 <addr 192.168.0.1>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1727]: sent [IPCP ConfAck id=0x1 <addr 192.168.0.1>]
<31>pppd[1727]: rcvd [IPCP ConfRej id=0x1 <ms-dns3 0.0.0.0>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1727]: sent [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 0.0.0.0>]
<31>pppd[1727]: rcvd [IPCP ConfNak id=0x2 <addr 82.194.160.202> <ms-dns1 212.16.193.34>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1727]: sent [IPCP ConfReq id=0x3 <addr 82.194.160.202> <ms-dns1 212.16.193.34>]
<31>pppd[1727]: rcvd [IPCP ConfAck id=0x3 <addr 82.194.160.202> <ms-dns1 212.16.193.34>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<31>pppd[1727]: ppp create_resolv in ipcp
<31>pppd[1727]: peerdns1 : 212.16.193.34
<31>pppd[1727]: dhcp_dns : nameserver 212.16.193.34
<30>dnsmasq[1620]: reading /etc/resolv.conf
<30>dnsmasq[1620]: using nameserver 212.16.193.34#53
<27>pppd[1727]: default route ioctl(SIOCADDRT): Network is unreachable
<29>pppd[1727]: ipcp_up: Open /var/tmp/pptp_server_ip.txt (l2tp_server_ip.txt) fail or Using PPPoE
<29>pppd[1727]: ipcp_up: local PPP IP address 82.194.160.202
<29>pppd[1727]: ipcp_up: remote PPP IP address 192.168.0.1
<29>pppd[1727]: primary   DNS address 212.16.193.34
<29>pppd[1727]: pppd check for rc to be idle ?
<29>pppd[1727]: pppd sent restart signal to rc
<30>dnsmasq[1620]: exiting on receipt of SIGTERM
<15>syslog: gpio create pidfile /var/run/gpio.pid
<30>dnsmasq[1780]: started, version 2.41 cachesize 150
<30>dnsmasq[1780]: compile time options: no-IPv6 GNU-getopt no-ISC-leasefile no-DBus no-I18N no-TFTP
<30>dnsmasq[1780]: reading /etc/resolv.conf
<30>dnsmasq[1780]: using nameserver 212.16.193.34#53
<30>dnsmasq[1780]: read /etc/hosts - 1 addresses
<27>pppd[1708]: Fatal signal 11
<30>pppd[1708]: Exit.
СообщениеДобавлено: Ср авг 19, 2009 14:59
1. Опишите топологию. (Тип подключения, данные предоставленные провайдером и т.д.)
2.Александ Зайцев несколькими постави выше просил предоставить dump в нужном формате с последней прошивкой, вы так этого и не сделали.
3.Возможно у вас используются DNS из сети совпадающей с LAN, поэтому и не ходит трафик.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 85
