Текущее время: Вт авг 18, 2026 20:52
 Заголовок сообщения: DI-604 не подключается по pptp
СообщениеДобавлено: Сб фев 09, 2008 16:56
Подскажите что делать.
Есть сервер - на нем поднято pptp
Есть Di-604 на нем пытаюсь настроить подключение по pptp
логи Di-604 (время не выставлено)
Monday August 20, 2007 00:26:08 LCP1: terminate request
Monday August 20, 2007 00:26:09 PPP1: TX(0) LCP Request
Monday August 20, 2007 00:26:11 PPP1: TX(1) LCP Request
Monday August 20, 2007 00:26:11 PPTP:error=-200
Monday August 20, 2007 00:26:12 PPP1: TX(2) LCP Request
Monday August 20, 2007 00:26:13 PPP1: TX(3) LCP Request
Monday August 20, 2007 00:26:14 PPP1: TX(4) LCP Request
Monday August 20, 2007 00:26:16 PPP1: TX(5) LCP Request
Monday August 20, 2007 00:26:16 PPP1: closed
на стороне сервера
Feb  9 15:32:43 ns ppp[28922]: Phase: Using interface: tun5
Feb  9 15:32:43 ns ppp[28922]: Phase: deflink: Created in closed state
Feb  9 15:32:43 ns ppp[28922]: Phase: Listening at port 3005.
Feb  9 15:32:43 ns ppp[28922]: Phase: PPP Started (direct mode).
Feb  9 15:32:43 ns ppp[28922]: Phase: bundle: Establish
Feb  9 15:32:43 ns ppp[28922]: Phase: deflink: closed -> opening
Feb  9 15:32:43 ns ppp[28922]: Phase: deflink: Connected!
Feb  9 15:32:43 ns ppp[28922]: Phase: deflink: opening -> carrier
Feb  9 15:32:43 ns ppp[28922]: Phase: deflink: carrier -> lcp
Feb  9 15:32:45 ns ppp[28922]: Phase: deflink: Too many LCP REQs sent - abandoning negotiation
Feb  9 15:32:45 ns ppp[28922]: Phase: deflink: Disconnected!
Feb  9 15:32:45 ns ppp[28922]: Phase: deflink: Connect time: 2 secs: 416 octets in, 1001 octets out, Local: 0 0
Feb  9 15:32:45 ns ppp[28922]: Phase: deflink: 16 packets in, 17 packets out
Feb  9 15:32:45 ns ppp[28922]: Phase:  total 708 bytes/sec, peak 0 bytes/sec on Sat Feb  9 15:32:43 2008
Feb  9 15:32:45 ns ppp[28922]: Phase: deflink: lcp -> closed
В тех же условиях planet XRT-401D работает нормально
Прошивки менял и 604_704P_707P_321RU и более ранние.
Допускаю что проблемы могут быть и на стороне сервера.
На сервере используется mppe и mschapV2.
Как победить данную ситуацию.
Заранее благодарен
что то подобное описано viewtopic.php?t=52311&highlight=LCP+REQUEST
СообщениеДобавлено: Сб фев 09, 2008 17:10
DI-604 не поддерживает mppe. Самое интересное, что у меня очень похожие логи на роутере, но вот посмотреть, что на стороне сервера я, к сожалению, не могу.
 Заголовок сообщения: Re: DI-604 не подключается по pptp
СообщениеДобавлено: Сб фев 09, 2008 17:20
Ещё заметил. У вас сервер пишет:
Т.е. роутер и сервер пытаются согласовать соединение, но роутера что - то не устраивает, поэтому он посылает ещё запросы:
На что сервер отвечает, что типа много запросов и делает вывод, что "договориться" с роутером не удалось.
Спасибо, про mppe я и не знал
СообщениеДобавлено: Сб фев 09, 2008 17:37
mppe на сервере отключал - результат, увы, тот же
СообщениеДобавлено: Сб фев 09, 2008 17:47
Не понятно, что не нравится роутеру. В faq dlink'a написано, что ошибка -200 - общая ошибка pptp подключения. Интересно, можно ли где-то уточнить, в чём именно проблема?
У меня раньше тоже mppe было включено и ничего не соединялось, думал, что это из-за него. Но вчера провайдер наконец-то отключил шифрование, но проблема сохранилась. Сколько в инете не искал, никаких дополнительный требований роутера к pptp не нашёл.
СообщениеДобавлено: Сб фев 09, 2008 17:57
дело в том что есть старый сервер (переходим на новый и тестируем - отсюда и проблемы), и на нем энтот Длинк работает по pptp.
Тоесть проблема (я так думаю) на стороне сервера.
Смущает что Планет - то работает, а Длинк нет.
Сравнивать конфиги - вариантов мало - разное программное обеспечение.
СообщениеДобавлено: Пн фев 11, 2008 14:15
Все, тема закрыта.
Указаный Dlink не поддерживает ни mppe ни mschapV2.
Получилось соеденится, только когда на сервере оставил pap.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 50
