Текущее время: Пт окт 23, 2026 03:43
СообщениеДобавлено: Пт май 11, 2007 10:25
АТС---1104TH---104SH Возникла проблема с работой 4 порта 104SH- порт не работает на прием т.е меня со стороны АТС очень плохо слышно с какимто сильным треском
ggdbg>spy hsmu 0
Password:
ggdbg>000148278 HSMU 0: CallingPartyId = "TA:192.168.1.16:1720,NAME:4FXO-26bad1,
Login failed. Try again
login:
Password:
TEL:1,TEL:2,TEL:3,TEL:4,4"
lo
000148278 HSMU 0: Remote caller ID number = 4y again
login:
000148278 HSMU 0: UserUserInfo = "4"
000148278 HSMU 0: remote CID number:"4", name:"O"
000148278 HSMU 0: received H323 call, processing ...
000148282 HSMU: Enter call_profile->capabilities
000148283 HSMU: Coding Profile Bit 6 ignored, no 'voice' usage.
000148283 HSMU: Exit call_profile->capabilities.
000149012 Remote capability codec "g729AnnexA".
000149026 Remote capability codec "g729".
000149026 Local capability codec "g711Ulaw64k".
000149026 Remote capability codec "g729AnnexA".
000149026 Remote capability codec "g729AnnexA".lue |
000149026 Remote capability codec "g729".ached TCP/IP interface to motfec u
000149026 Local capability codec "g711Alaw64k".----------------+------------------------------
Adding 37
000149026 Remote capability codec "g729AnnexA". | 0 | IP Address | 213.168
000149026 Remote capability codec "g729AnnexA".ateway Address | 192.168.1.1
000149026 Local capability codec "g7231".
| 2 | Netmask
000149026 Remote capability codec "g729AnnexA". BootROM ver 1.1
000149026 HSMU 0: cmEvCallMasterSlaveSt
>>> IP A
han=0x0,chanal name ="g729AnnexA"68.56.89 -> 192.168.1.18Area(0x20
000149027 hsmup_open_channel: nw_open(RTCP1), call_num=0 , port=30001, chan_num(
Gateway Address (dot form): 192.168.1.1 -> 192.168.1.1
i/o)=0o
000149027 HSMU 0: set timer for 10000 in state hsmup_state_master_wait_connect_a> 255.255.255.0 >>>
ll_lc-----
000149027 HSMU 0: Chan 0i cmEvChannelSetRTCPAddress_msg IP = 192.168.1.16, Port
| TOS(Type Of Service) Field |P0 Load ..
= 16409
000149027 hsmup_master_incoming_lc: nw_open(RTP2), call_num=0 , port=30000, chan
CRC OK ...
F
Goodg.006
>>> IP Addr
000151340 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000151661 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000152026 HSMU 0: timer triggered in state hsmup_state_voice_connected
000152026 HSMU 0: abort timer in state hsmup_state_voice_connected
000152026 HSMU 0: set timer for 30000 in state hsmup_state_voice_connected
000152301 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000152907 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000153379 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000153983 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000154281 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000154884 HSMU 0: abort timer in state hsmup_state_voice_connected
000154884 HSMU 0: cmCallDropParam(p_call=0x424558, h323_release_reason=11)
000154936 HSMU 0: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP0, RTC
P0)
000154936 HSMU 0: nw_close(inchan local RTCP1, RTP2)
000154936 HSMU 0: nw_close(inchan local RTCP65535, RTP65535)
000154936 HSMU 0: nw_close(outchan local RTCP65535)
ggdbg>
Сейчас этот форум просматривают: Baidu [Spider] и гости: 16
