Текущее время: Сб сен 26, 2026 20:55
СообщениеДобавлено: Пн ноя 27, 2006 11:51
Привет всем.
G604T очень долго (10 минут) связывается с провайдером. Прошивка - от января 2006 г, Modulation - multimode.
USBAus.Linx на той-же самой телефонной розетке связь устанавливает около минуты. Лог ниже.
Что можно сделать чтобы ускорить процесс?
Спасибо.
Jan 1 12:00:10> Valid Configuration Tree
Jan 1 12:00:11> NTP Polling Timer for DHCP Started succesfully.
Jan 1 12:00:11> DSL Polling Timer Started succesfully.
Jan 1 12:00:11> doing modulation_set.
Jan 1 12:00:11> Firewall NAT service started
Jan 1 12:00:13> starting on port 80
Jan 1 12:00:13> Init the gre conntrack!
Jan 1 12:00:13> Init the gre nat!
Jan 1 12:00:13> ip_conntrack_pptp version 1.9 loaded
Jan 1 12:00:13> ip_nat_pptp version 1.5 loaded
Jan 1 12:00:13> (c)2000 Netfilter core team
Jan 1 12:00:13> netfilter PSD loaded - (c) astaro AG
Jan 1 12:00:13> Initializing the WAN Bridge.
Jan 1 12:00:13> Please set the MAC Address for the WAN Bridge.
Jan 1 12:00:13> Set the Environment variable 'wan_br_mac'.
Jan 1 12:00:13> xx.xx.xx.xx.xx.xx
Jan 1 12:00:13> Mounted root (squashfs filesystem) readonly.
Jan 1 12:00:13> Mounted devfs on /dev
Jan 1 12:00:13> 60k freed
Jan 1 12:00:13> Algorithmics/MIPS FPU Emulator v1.5
Jan 1 12:00:13> registered device TI Avalanche SAR
Jan 1 12:00:13> version:[4.03.03.00]
Jan 1 12:00:13> Default Asymmetric MTU for nas0 1500
Jan 1 12:00:13> Registering protocol inspector: 0x94168224 for VCC:0x9401fa00
Jan 1 12:00:13> Default Asymmetric MTU for br0 1500
Jan 1 12:00:13> Bridge Created: br0
Jan 1 12:00:14> Bridge Created: br1
Jan 1 12:00:15> Bridge Interface Added: eth0
Jan 1 12:00:16> ZIPB............
Jan 1 12:00:16> 2
Jan 1 12:00:16> Default Asymmetric MTU for br1 1500
Jan 1 12:00:16> 2
Jan 1 12:00:18> Default Asymmetric MTU for wlan0 1500
Jan 1 12:00:18> AP Driver configuration successful
Jan 1 12:00:22> AP IS UP
Jan 1 12:00:22>
Jan 1 12:00:22> No Module Description from Interface Below
Jan 1 12:00:22> disabled.
Jan 1 12:00:22> 802.11h is 188: disabled.
Jan 1 12:00:22> Configuration succeeded !!!
Jan 1 12:00:22> WLAN driver database is up
Jan 1 12:00:22> Resetting the remote device.
Jan 1 12:00:22> Un-resetting the remote device.
Jan 1 12:00:22> About to re-init the VLYNQ.
Jan 1 12:00:22> Re-initialized the VLYNQ.
Jan 1 12:00:22> AcxRegAddr = 0xA4040000, AcxMemAddr = 0xA4000000
Jan 1 12:00:22> whal_acxProcInitiate: found DEVICE_VENDOR ID = 0x9066104c
Jan 1 12:00:22> whal_acxProcInitiate: Cpu halt -} download code
Jan 1 12:00:22> whal_acxProcLoadFwImage: 0xa4000000, 0x0
Jan 1 12:00:22> whal_acxProcLoadFwImage() -- Loading FW image189: Compiled for RADIA (bg) radio
Jan 1 12:00:22> whal_acxProcLoadFwImage: 1, pBuf=0xc00a2000, len=0x15564. Extra pBuf=0x0, len=0x3
Jan 1 12:00:22> whal_acxProcLoadFwImage: 2, pBuf=0xc00a2000, len=0x15564. Extra pBuf=0x0, len=0x3
Jan 1 12:00:22> whal_acxProcLoadFwImage: 3, pBuf=0xc00a2000, len=0x15564, DataLen=0x1555c
Jan 1 12:00:22> whal_acxProcLoadFwImage: 4, pBuf=0xc00a2000, len=0x15564
Jan 1 12:00:22> whal_acxProcLoadFwImage: Checksum, calc=0x71e76f, file=0x71e76f
Jan 1 12:00:22> BssBridge is up
Jan 1 12:00:22> Mgmt is up
Jan 1 12:00:22> Rx is up
Jan 1 12:00:22> Tx is up
Jan 1 12:00:22> Bridge Interface Added: wlan0
Jan 1 12:00:22> MemMngr is up
Jan 1 12:00:22> main state machine is up
Jan 1 12:00:22> WDRV_MAINSM: WLAN Driver initialized successfully
Jan 1 12:00:22>
Jan 1 12:00:22> WDRV_4X: 4x Disabled
Jan 1 12:00:22> WDRV_4X: Concatenation Disabled
Jan 1 12:00:22> WDRV_4X: Ack Emulation Disabled
Jan 1 12:00:22> whal_apiStartBss: Enable Tx, Rx and Start the Bss
Jan 1 12:00:22> ----------------------------------------------------------------
Jan 1 12:00:22> START BSS, SSID=tss, BSSID=00-17-9A-1C-09-C8
Jan 1 12:00:22> DSL Carrier is down
Jan 1 12:00:22> AP Power Level = 1
Jan 1 12:00:22> Regulatory Domain = ETSI
Jan 1 12:00:22> Net[0] : Channel=6
Jan 1 12:00:22> FW Watchdog is Enabled
Jan 1 12:10:36> DSL in Sync
Jan 1 12:10:42> DSL Carrier is up
Jan 1 12:10:43> pppd 2.4.3 started by root, uid 0
Jan 1 12:10:43> Connect: ppp0 {--} nas0
Jan 1 12:10:45> peer from calling number 00:30:88:01:15:86 authorized
Jan 1 12:10:45> ppp0
Jan 1 12:10:45> WAN IP address 85.140.153.63
Jan 1 12:10:45> WAN gateway 85.140.152.1
Jan 1 12:10:45> primary DNS address 212.188.4.10
Jan 1 12:10:45> secondary DNS address 195.34.32.116
Jan 1 12:10:45> PPPoE Connect with IP Address 85.140.153.63
Jan 1 12:10:45> PPPoE Connection Successfully Established
Jan 1 12:10:45> PPPoE Connect with Gateway IP Address: 85.140.152.1
СообщениеДобавлено: Пн ноя 27, 2006 12:00
В настройках устройства выберите тот тип модуляции, который используется у вашего оператора.
С уважением, Давыдов Денис.
СообщениеДобавлено: Пн ноя 27, 2006 13:58
Спасибо, попробую.
Сейчас этот форум просматривают: Google [Bot] и гости: 19
