Текущее время: Вт сен 22, 2026 06:21
 Заголовок сообщения: Постоянно рвет соединение vpn dir 620
СообщениеДобавлено: Сб мар 03, 2018 21:35
Постоянно рвет соединение vpn DIR-620.
Пробовал перепрошивать- не помогает.
04:04:43 pptp[1748]: Plugin /usr/lib/pppd/pptp.so loaded.
Jan  1 04:04:43 pptp[1748]: PPTP plugin version 0.8.3 compiled against pppd 2.4.4
Jan  1 04:04:43 pptp[1751]: pppd 2.4.4 started by admin, uid 0
Jan  1 04:04:43 pptp[1751]: Check server vpn.apanet.local
Jan  1 04:04:43 pptp[1751]: route_add: have route to host on this dev eth2.5
Jan  1 04:04:43 pptp[1752]: IP: 172.22.222.115
Jan  1 04:04:43 pptp[1752]: control connection
Jan  1 04:04:43 pptp[1752]: unix_sock
Jan  1 04:04:43 pptp[1753]: Sent control packet type is 1 'Start-Control-Connection-Request'
Jan  1 04:04:43 pptp[1753]: Received Start Control Connection Reply
Jan  1 04:04:43 pptp[1753]: Client connection established.
Jan  1 04:04:44 pptp[1753]: Sent control packet type is 7 'Outgoing-Call-Request'
Jan  1 04:04:44 pptp[1753]: Received Outgoing Call Reply.
Jan  1 04:04:44 pptp[1753]: Outgoing call established (call ID 1, peer's call ID 3044).
Jan  1 04:04:44 pptp[1751]: Using interface ppp0
Jan  1 04:04:44 pptp[1751]: Connect: ppp0 <--> pptp (vpn.apanet.local)
Jan  1 04:04:46 pptp[1751]: CHAP authentication succeeded
Jan  1 04:04:46 pptp[1751]: CCP terminated by peer
Jan  1 04:04:46 pptp[1751]: Compression disabled by peer.
Jan  1 04:04:46 pptp[1751]: Peer refused to agree to our IP address
Jan  1 04:04:46 pptp[1751]: Connect time 4.8 minutes.
Jan  1 04:04:46 pptp[1751]: Sent 168 bytes, received 126 bytes.
Jan  1 04:04:46 pptp[1751]: Down ppp with status (10)10
Jan  1 04:04:46 pptp[1751]: lcp_close: unit:0, reason: "No network protocols running" (status: 10, state: 9, was_ip_down: 0)
Jan  1 04:04:46 kernel: [4294954.594000] Ralink HW NAT Module Disabled
Jan  1 04:04:46 kernel: [4294954.634000] Ralink HW NAT Module Enabled
Jan  1 04:04:46 pptp[1751]: Connection terminated.
Jan  1 04:04:46 pptp[1751]: lcp_close: unit:0, reason: "" (status: 10, state: 0, was_ip_down: 0)
Jan  1 04:04:46 pptp[1753]: Closing connection (unhandled)
Jan  1 04:04:46 pptp[1753]: Sent control packet type is 12 'Call-Clear-Request'
Jan  1 04:04:46 pptp[1753]: Closing connection (call state)
Jan  1 04:04:46 pptp[1751]: Terminating on signal 15
Jan  1 04:04:46 pptp[1751]: Exit.(5)
Jan  1 04:04:46 triggerPingRespond: OK
Jan  1 04:04:46 dnsmasq[1350]: exiting on receipt of SIGTERM
Jan  1 04:04:49 dnsmasq[1771]: started, version 2.63 cachesize 512
Jan  1 04:04:49 dnsmasq[1771]: compile time options: no-IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack
Jan  1 04:04:49 dnsmasq-dhcp[1771]: DHCP, IP range 192.168.0.2 -- 192.168.0.100, lease time 1d
Jan  1 04:04:49 dnsmasq[1771]: read /tmp/hosts - 2 addresses
Jan  1 04:04:49 dnsmasq-dhcp[1771]: read /etc/ethers - 0 addresses
Jan  1 04:04:49 dnsmasq[1771]: using nameserver 172.22.220.4#53
Jan  1 04:04:49 dnsmasq[1771]: using nameserver 172.22.220.3#53
Jan  1 04:05:34 autoupdate: Downloading file: fwupdate.dlink.ru/dislocation
Jan  1 04:05:34 resident_ppp_handler: record = action:trouble;iface:ppp0;status:10;link:eth2.5_2;
Jan  1 04:05:34 resident: resident_ipoe_handler - Set default type: ipv4
Jan  1 04:05:34 resident: resident_ppp_handler - l2:eth2.5, l3:eth2.5_1, tun:eth2.5_2
Jan  1 04:05:35 get_sta_table: ifname: ra0
Jan  1 04:06:05 get_sta_table: ifname: ra0
СообщениеДобавлено: Сб мар 03, 2018 21:53
и еще немогу прошить с версии 2,0,1 на 1,3,6 пишет некорректная прошивка.
так же на некоторые другие пишет некорректная прошивка
СообщениеДобавлено: Пн мар 05, 2018 19:08
1. После перепрошивки необходимо производить сброс к заводским настройкам.
2. Если соединение разорвется, пришлите скриншот раздела Статус->Сетевая Статистика
3. Для прехода с прошивки серии 2.0.х до 1.х.х необходимо производить обновление ПО через режим аварийного восстановления.
