Текущее время: Сб сен 26, 2026 09:16
 Заголовок сообщения: Несколько вопросов, DSL-2640U
СообщениеДобавлено: Вс июл 01, 2012 12:57
Модем: DSL-2640U/BRU/C2
копипаста из веб интерфейса:
Software Version: RU_2.01
Bootloader (CFE) Version: 1.0.37-12.1
Release Date: Sun Nov 8 12:34:29 CST 2009
Wireless Driver Version: 4.174.64.19.cpe1.0sd
1.В логе модема заметил следующее:
System Log
Date/Time    Facility    Severity    Message
Jul 1 11:33:42    user    alert    kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=31.163.189.231 DST=95.133.133.218 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=52005 DF PROTO=TCP SPT=3215 DPT=65116 WINDOW=65535 RES=0x00 SYN URGP=0
Jul 1 11:33:42    user    alert    kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=95.57.21.97 DST=95.133.133.218 LEN=48 TOS=0x00 PREC=0x00 TTL=110 ID=16524 DF PROTO=TCP SPT=29298 DPT=65116 WINDOW=16384 RES=0x00 SYN URGP=0
Jul 1 11:33:42    user    alert    kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=212.42.103.73 DST=95.133.133.218 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=60159 DF PROTO=TCP SPT=1920 DPT=36504 WINDOW=65535 RES=0x00 SYN URGP=0
Jul 1 11:33:45    user    alert    kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=178.40.222.93 DST=95.133.133.218 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=32130 DF PROTO=TCP SPT=29748 DPT=65116 WINDOW=8192 RES=0x00 SYN URGP=0
Jul 1 11:33:47    user    alert    kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=94.241.230.80 DST=95.133.133.218 LEN=52 TOS=0x00 PREC=0x00 TTL=116 ID=12813 DF PROTO=TCP SPT=57071 DPT=65116 WINDOW=8192 RES=0x00 SYN URGP=0
Jul 1 11:33:48    user    alert    kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=31.163.189.231 DST=95.133.133.218 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=52168 DF PROTO=TCP SPT=3215 DPT=65116 WINDOW=65535 RES=0x00 SYN URGP=0
Jul 1 11:33:48    user    alert    kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=95.57.21.97 DST=95.133.133.218 LEN=48 TOS=0x00 PREC=0x00 TTL=110 ID=17108 DF PROTO=TCP SPT=29298 DPT=65116 WINDOW=16384 RES=0x00 SYN URGP=0
Jul 1 11:33:48    user    alert    kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=178.40.222.93 DST=95.133.133.218 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=32174 DF PROTO=TCP SPT=29748 DPT=65116 WINDOW=8192 RES=0x00 SYN URGP=0
Jul 1 11:33:48    user    alert    kernel: Intrusion -> IN=ppp_0_1_32_1 OUT= MAC= SRC=85.99.149.169 DST=95.133.133.218 LEN=52 TOS=0x00 PREC=0x00 TTL=114 ID=8730 DF PROTO=TCP SPT=61850 DPT=65116 WINDOW=8192 RES=0x00 SYN URGP=0
подобных алертов очень-очень много. p2p не использую. Что это такое? Кто-то ломится?)
2. Очень часто пропадает wifi сеть на несколько секунд, винда в момент пропадания показывает скорость соединения в 1 мегабит/сек и одну палку сигнала. Проблема наблюдается на 2х ноутбуках и телефоне, даже на расстоянии в 1 метр. В логе модема после падения сети про wifi ничего нет, ну или, я их не успеваю посмотреть из-за первой проблемы :lol:
Файл помойка подключенная по ethernet работает нормально.
