Текущее время: Пт сен 18, 2026 12:16
 Заголовок сообщения: New to the area, need brake pads done soon
СообщениеДобавлено: Пт сен 18, 2026 09:32
New to the area, need brake pads done soon, any trusted shops near ICAD?
I just moved to Abu Dhabi a few months ago for work and my 2016 Wrangler is due for new brake pads, the wear indicator is starting to squeak and I don't want to ignore it. I work in ICAD so I'd prefer somewhere close by that I can drop the car off during lunch or after work, but I don't know the area well yet. Back home I had a mechanic I trusted, but here I'm starting from scratch and honestly a bit nervous about getting ripped off or having cheap pads put on that squeal after a week. A colleague mentioned there's a Reliable brake pad repair near ICAD that some of the guys at the office use for their Jeeps, but I wanted to see if anyone here has actual experience with them or can recommend another shop. I'm not looking for the cheapest option, just somewhere that uses decent pads and does the job properly, including checking the rotors. Any suggestions would be appreciated.
