Текущее время: Вс сен 06, 2026 14:42
СообщениеДобавлено: Вт мар 28, 2006 11:08
Произошел сбой с появлением BSOD экрана с кодом 0xC5, анализ ситуации указывает на сбой вероятно в работе драйвера DLKRTS.SYS
Сведения о системе:
CPU Intel Pentium IV
Windows 2000 SP4
RAM 1Gb
LAN: 2 x DLink DFE-530TX+
Вот информация из minidump-файла:
*                        Bugcheck Analysis                                    *
DRIVER_CORRUPTED_EXPOOL (c5)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is
caused by drivers that have corrupted the system pool.  Run the driver
verifier against any new (or suspect) drivers, and if that doesn't turn up
the culprit, then use gflags to enable special pool.
Arguments:
Arg1: 00000080, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: 80469962, address which referenced memory
Debugging Details:
BUGCHECK_STR:  0xC5_2
CURRENT_IRQL:  2
FAULTING_IP:
nt!ExAllocatePoolWithTag+522
80469962 8913             mov     [ebx],edx
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  INTEL_CPU_MICROCODE_ZERO
LAST_CONTROL_TRANSFER:  from 80469962 to 80466d47
STACK_TEXT:
80470470 80469962 84a17d88 80467951 8046795c nt!KiTrap0E+0x20b
80470508 8041590d 00000000 00000000 42504354 nt!ExAllocatePoolWithTag+0x522
80470524 ef097e00 00000000 00000204 42504354 nt!ExAllocatePoolWithTagPriority+0x67
WARNING: Stack unwind information not available. Following frames may be wrong.
80470550 ef097ea6 804706e8 804705a4 000001e0 tcpip+0x17e00
80470590 ef097c3e 843ed1e8 000003d4 804706e8 tcpip+0x17ea6
804705cc ef083466 8472dfec 00001850 804706e8 tcpip+0x17c3e
80470634 ef08115d 00000000 a332a8c0 a132a8c0 tcpip+0x3466
80470680 ef08105d ef0831c7 8496a0c8 84a132f6 tcpip+0x115d
80470738 ef08098c 8496a0c8 84968008 84969008 tcpip+0x105d
80470778 ef08537d 00000000 84a17008 84a132e8 tcpip+0x98c
804707a8 f74a4e5e 84970c28 84a17008 84a132e8 tcpip+0x537d
804707dc eb2a86f3 84a314a8 84a17008 84a132e8 NDIS+0x21e5e
80470850 80463417 84a17074 84a17060 00000000 DLKRTS+0x6f3
80470864 804633b2 0000000e 00000000 00000000 nt!KiRetireDpcList+0x30
ffdff800 00000000 00000000 80470868 0355143b nt!KiIdleLoop+0x26
STACK_COMMAND:  kb
FOLLOWUP_IP:
DLKRTS+6f3
eb2a86f3 ??               ???
FAULTING_SOURCE_CODE:
SYMBOL_STACK_INDEX:  c
FOLLOWUP_NAME:  MachineOwner
SYMBOL_NAME:  DLKRTS+6f3
MODULE_NAME:  DLKRTS
IMAGE_NAME:  DLKRTS.SYS
DEBUG_FLR_IMAGE_TIMESTAMP:  3b84ff39
FAILURE_BUCKET_ID:  0xC5_2_DLKRTS+6f3
Followup: MachineOwner
СообщениеДобавлено: Вт мар 28, 2006 18:23
Драйвер с диска или отсюда: ftp://ftp.dlink.ru/pub/Adapter/DFE-530T ... driver.exe ???
Бигаров Руслан.
СообщениеДобавлено: Вт мар 28, 2006 18:53
http://support.microsoft.com/?kbid=291810
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\DisablePagingExecutive = 1
СообщениеДобавлено: Пн апр 03, 2006 12:56
С диска, входящего в комплект к карте.
СообщениеДобавлено: Пн апр 03, 2006 12:59
Чтож попробую, а точно поможет?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 1
