Текущее время: Ср ноя 11, 2026 07:33
СообщениеДобавлено: Ср июн 03, 2020 11:39
DXE-810S зависает и перестает обрабатывать трафик
Сервер
CentOS Linux release 7.8.2003 (Core) 3.10.0-1127.8.2.el7.x86_64
CPU: Dual Core Intel Core i3-6100 (-MT MCP-) speed/min/max: 3700/800/3700 MHz Kernel: 3.10.0-1127.8.2.el7.x86_64 x86_64
Up: 1d 16h 14m Mem: 983.2/7702.4 MiB (12.8%) Storage: 11.84 TiB (1.8% used) Procs: 199 Shell: bash 4.2.46 inxi: 3.1.00
Ethernet controller: Tehuti Networks Ltd. TN9310 10GbE SFP+ Ethernet Adapter
Subsystem: D-Link System Inc DXE-810S 10GbE SFP+ Ethernet Adapter
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 127
Region 0: Memory at f0100000 (64-bit, prefetchable) [size=64K]
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee0400c Data: 4172
Capabilities: [78] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [80] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <2us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 75.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #1, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <2us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range A, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Kernel driver in use: tn40xx
Kernel modules: tn40xx
filename: /lib/modules/3.10.0-1127.8.2.el7.x86_64/kernel/drivers/net/tehuti/tn40xx.ko
description: Tehuti Network Driver
author: Tehuti networks
version: 0.3.6.17.3
сервер в кластере Pacemaker 0.9.168 с drbd 9.0.22
драйвер скомпилирован с g_dbg=1 - дебаг включен
после запуска карты сообщения в логи с нее пишутся несколько минут, потом перестают приходить
через несколько часов карта перестает обрабатывать трафик, хотя линк физически не рвется, индикация на портах
карты и коммутатора зеленая
после того как вручную поднять/положить интерфейс трафик опять идет, в логах - по прежнему от карты ничего нет
пример лога ядра, в 16:59 поднял карту, в 17:03 перестала присылать логи, для проверки сислога в 17:56
дернул медную сетевуху - логи идут, потом менял настройки дрбд - логи идут
Jun 2 16:59:22 FTP1 kernel: tn40xx: Device removed
Jun 2 16:59:22 FTP1 kernel: tn40xx: Driver unloaded
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 0. 32
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 1. 40
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 2. 56
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 3. 64
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 4. 80
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 5. 88
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 6. 104
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 7. 112
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 8. 128
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 9. 136
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 10. 152
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 11. 160
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 12. 176
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 13. 184
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 14. 200
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 15. 208
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 16. 224
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 17. 232
Jun 2 16:59:39 FTP1 kernel: tn40xx: init_txd_sizes:3708 : 18. 248
Jun 2 16:59:39 FTP1 kernel: tn40xx: Tehuti Network Driver, 0.3.6.17.3
Jun 2 16:59:39 FTP1 kernel: tn40xx: Supported phys : QT2025 TLK10232 AQR105 MUSTANG
Jun 2 16:59:39 FTP1 kernel: tn40xx: srom 0x0 HWver 16 build 0 lane# 4 max_pl 0x1 mrrs 0x2
Jun 2 16:59:39 FTP1 kernel: tn40xx 0000:01:00.0: irq 127 for MSI/MSI-X
Jun 2 16:59:40 FTP1 kernel: tn40xx: bdx_mdio_look_for_phy:517 : LOOK FOR PHY: port=0x0
Jun 2 16:59:40 FTP1 kernel: tn40xx: bdx_mdio_read:432 : MDIO error after read command
Jun 2 16:59:40 FTP1 kernel: tn40xx: bdx_mdio_look_for_phy:517 : LOOK FOR PHY: port=0x1
Jun 2 16:59:40 FTP1 kernel: tn40xx: PHY detected on port 1 ID=43A400 - QT2025 10Gbps SFP+
Jun 2 16:59:41 FTP1 kernel: tn40xx: QT2025 FW version 2.0.3.3 module type 0x2
Jun 2 16:59:41 FTP1 kernel: tn40xx: bdx_speed_set:778 : speed 10000
Jun 2 16:59:41 FTP1 kernel: tn40xx: bdx_speed_set:787 : link_speed 10000
Jun 2 16:59:41 FTP1 kernel: tn40xx: bdx_fw_load:1310 : Loading FW...
Jun 2 16:59:41 FTP1 kernel: tn40xx: bdx_tx_push_desc_safe:4141 : about to push 32760 bytes starting ffffffffc0a893a0 size 42784
Jun 2 16:59:41 FTP1 kernel: tn40xx: bdx_tx_push_desc_safe:4141 : about to push 9728 bytes starting ffffffffc0a91398 size 10024
Jun 2 16:59:41 FTP1 kernel: tn40xx: bdx_tx_push_desc_safe:4141 : about to push 296 bytes starting ffffffffc0a93998 size 296
Jun 2 16:59:41 FTP1 kernel: tn40xx: bdx_fw_load:1333 : enp1s0 firmware loading success
Jun 2 16:59:41 FTP1 kernel: tn40xx: fw 0xe
Jun 2 16:59:41 FTP1 kernel: tn40xx: enp1s0, Port A
Jun 2 16:59:41 FTP1 kernel: tn40xx: 1 1fc9:4022:1186:4d00
Jun 2 16:59:41 FTP1 kernel: tn40xx: detected 1 cards, 1 loaded
Jun 2 16:59:42 FTP1 kernel: tn40xx: bdx_restore_mac:1349 : mac0 =0 mac1 =0 mac2 =0
Jun 2 16:59:42 FTP1 kernel: tn40xx: bdx_restore_mac:1364 : mac0 =f3d7 mac1 =54ff mac2 =b0c5
Jun 2 16:59:42 FTP1 kernel: tn40xx: QT2025_link_changed:172 : QT2025 no link, setting 1/5 sec timer
Jun 2 16:59:42 FTP1 kernel: IPv6: ADDRCONF(NETDEV_UP): enp1s0: link is not ready
Jun 2 16:59:42 FTP1 kernel: tn40xx: bdx_isr_extra:989 : isr = 0x40
Jun 2 16:59:43 FTP1 kernel: tn40xx: bdx_isr_extra:989 : isr = 0x40
Jun 2 16:59:43 FTP1 kernel: tn40xx: QT2025_link_changed:172 : QT2025 no link, setting 1/5 sec timer
Jun 2 16:59:44 FTP1 kernel: tn40xx: bdx_isr_extra:989 : isr = 0x40
Jun 2 16:59:44 FTP1 kernel: tn40xx: QT2025_link_changed:172 : QT2025 no link, setting 1/5 sec timer
Jun 2 16:59:44 FTP1 kernel: tn40xx: QT2025_link_changed:166 : QT2025 trying to recover link after 10 tries
Jun 2 16:59:44 FTP1 kernel: tn40xx: bdx_speed_set:778 : speed 0
Jun 2 16:59:44 FTP1 kernel: tn40xx: bdx_speed_set:778 : speed 10000
Jun 2 16:59:44 FTP1 kernel: tn40xx: bdx_speed_set:787 : link_speed 10000
Jun 2 16:59:44 FTP1 kernel: tn40xx: bdx_isr_extra:989 : isr = 0x8000000
Jun 2 16:59:44 FTP1 kernel: tn40xx: QT2025_link_changed:159 : QT2025 link speed is 10G
Jun 2 16:59:44 FTP1 kernel: tn40xx: enp1s0 Link Up 10G
Jun 2 16:59:44 FTP1 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp1s0: link becomes ready
Jun 2 16:59:44 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 0 vtag 0 len 60 vlan_id 0 cfi 0 prio 0 va_lo 0 va_hi 0
Jun 2 16:59:44 FTP1 kernel: tn40xx: bdx_rx_receive:3275 : tn40xx: * RX 60 *
Jun 2 16:59:44 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 259584 dma 0000000206d3f600
Jun 2 16:59:44 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2896 : _bdx_rx_alloc_buffers is at ffffffffc0a7d130
Jun 2 16:59:44 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2899 : dno 1 page_size 1536 buf_size 1536
Jun 2 16:59:44 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac606c12300 size 1536
Jun 2 16:59:44 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 00000001b048c000
Jun 2 16:59:44 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2983 : nPages 1
Jun 2 16:59:44 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x7ff8
Jun 2 16:59:44 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2988 : READ_REG 0x40d0 f->m.reg_RPTR=0x400
Jun 2 16:59:44 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x7ff8
Jun 2 16:59:44 FTP1 kernel: tn40xx: dbg_printFifo:234 : RXF fifo:
Jun 2 16:59:44 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x7ff8 RPTR 0x40d0 = 0x0
Jun 2 16:59:45 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 1 vtag 0 len 74 vlan_id 3495 cfi 0 prio 2 va_lo 1 va_hi 0
Jun 2 16:59:45 FTP1 kernel: tn40xx: bdx_rx_receive:3275 : tn40xx: * RX 74 *
Jun 2 16:59:45 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 258048 dma 0000000206d3f000
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2896 : _bdx_rx_alloc_buffers is at ffffffffc0a7d130
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2899 : dno 1 page_size 1536 buf_size 1536
Jun 2 16:59:45 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac6062386c0 size 1536
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 0000000188e1b000
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2978 : Wrapped descriptor
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2983 : nPages 1
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x10
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2988 : READ_REG 0x40d0 f->m.reg_RPTR=0x400
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x10
Jun 2 16:59:45 FTP1 kernel: tn40xx: dbg_printFifo:234 : RXF fifo:
Jun 2 16:59:45 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x10 RPTR 0x40d0 = 0x0
Jun 2 16:59:45 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 0 vtag 0 len 60 vlan_id 82 cfi 0 prio 0 va_lo 2 va_hi 0
Jun 2 16:59:45 FTP1 kernel: tn40xx: bdx_rx_receive:3275 : tn40xx: * RX 60 *
Jun 2 16:59:45 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 256512 dma 0000000206d3ea00
Jun 2 16:59:45 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac60850cec0 size 1536
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 000000021433b000
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x28
Jun 2 16:59:45 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x28
Jun 2 16:59:45 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x28 RPTR 0x40d0 = 0x0
Jun 2 16:59:46 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 1 vtag 0 len 74 vlan_id 0 cfi 0 prio 0 va_lo 3 va_hi 0
Jun 2 16:59:46 FTP1 kernel: tn40xx: bdx_rx_receive:3275 : tn40xx: * RX 74 *
Jun 2 16:59:46 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 254976 dma 0000000206d3e400
Jun 2 16:59:46 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 1 vtag 0 len 74 vlan_id 146 cfi 0 prio 0 va_lo 4 va_hi 0
Jun 2 16:59:46 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 253440 dma 0000000206d3de00
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2896 : _bdx_rx_alloc_buffers is at ffffffffc0a7d130
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2899 : dno 2 page_size 3072 buf_size 1536
Jun 2 16:59:46 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac608aea040 size 3072
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 3072 off 1536 dma 000000022ba81600
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 3072 off 0 dma 000000022ba81000
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2983 : nPages 1
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x58
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2988 : READ_REG 0x40d0 f->m.reg_RPTR=0x400
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x58
Jun 2 16:59:46 FTP1 kernel: tn40xx: dbg_printFifo:234 : RXF fifo:
Jun 2 16:59:46 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x58 RPTR 0x40d0 = 0x0
Jun 2 16:59:46 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 2 vtag 0 len 82 vlan_id 98 cfi 0 prio 0 va_lo 5 va_hi 0
Jun 2 16:59:46 FTP1 kernel: tn40xx: bdx_rx_receive:3275 : tn40xx: * RX 82 *
Jun 2 16:59:46 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 251904 dma 0000000206d3d800
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2899 : dno 1 page_size 1536 buf_size 1536
Jun 2 16:59:46 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac608a91340 size 1536
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 000000022a44d000
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x70
Jun 2 16:59:46 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x70
Jun 2 16:59:46 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x70 RPTR 0x40d0 = 0x0
Jun 2 17:03:40 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 0 vtag 0 len 60 vlan_id 0 cfi 0 prio 0 va_lo 808 va_hi 0
Jun 2 17:03:40 FTP1 kernel: tn40xx: bdx_rx_receive:3275 : tn40xx: * RX 60 *
Jun 2 17:03:40 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 62976 dma 000000019c14f600
Jun 2 17:03:40 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2896 : _bdx_rx_alloc_buffers is at ffffffffc0a7d130
Jun 2 17:03:40 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2899 : dno 1 page_size 1536 buf_size 1536
Jun 2 17:03:40 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac6082dc700 size 1536
Jun 2 17:03:40 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 000000020b71c000
Jun 2 17:03:40 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2983 : nPages 1
Jun 2 17:03:40 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x4bb8
Jun 2 17:03:40 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2988 : READ_REG 0x40d0 f->m.reg_RPTR=0x4e00
Jun 2 17:03:40 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x4bb8
Jun 2 17:03:40 FTP1 kernel: tn40xx: dbg_printFifo:234 : RXF fifo:
Jun 2 17:03:40 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x4bb8 RPTR 0x40d0 = 0x0
Jun 2 17:03:40 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 2 vtag 0 len 359 vlan_id 3495 cfi 0 prio 2 va_lo 809 va_hi 0
Jun 2 17:03:40 FTP1 kernel: tn40xx: bdx_rx_receive:3275 : tn40xx: * RX 359 *
Jun 2 17:03:40 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 61440 dma 000000019c14f000
Jun 2 17:03:40 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac60806f080 size 1536
Jun 2 17:03:40 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 0000000201bc2000
Jun 2 17:03:40 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x4bd0
Jun 2 17:03:40 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x4bd0
Jun 2 17:03:40 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x4bd0 RPTR 0x40d0 = 0x0
Jun 2 17:03:41 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 0 vtag 0 len 60 vlan_id 82 cfi 0 prio 0 va_lo 810 va_hi 0
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_receive:3275 : tn40xx: * RX 60 *
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 59904 dma 000000019c14ea00
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2896 : _bdx_rx_alloc_buffers is at ffffffffc0a7d130
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2899 : dno 1 page_size 1536 buf_size 1536
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac6084cc2c0 size 1536
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 000000021330b000
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2983 : nPages 1
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x4be8
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2988 : READ_REG 0x40d0 f->m.reg_RPTR=0x5000
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x4be8
Jun 2 17:03:41 FTP1 kernel: tn40xx: dbg_printFifo:234 : RXF fifo:
Jun 2 17:03:41 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x4be8 RPTR 0x40d0 = 0x0
Jun 2 17:03:41 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 0 vtag 0 len 60 vlan_id 0 cfi 0 prio 0 va_lo 811 va_hi 0
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 58368 dma 000000019c14e400
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac6083d0cc0 size 1536
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 000000020f433000
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x4c00
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x4c00
Jun 2 17:03:41 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x4c00 RPTR 0x40d0 = 0x0
Jun 2 17:03:41 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 0 vtag 0 len 60 vlan_id 146 cfi 0 prio 0 va_lo 812 va_hi 0
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 56832 dma 000000019c14de00
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac6084d8400 size 1536
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 0000000213610000
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x4c18
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x4c18
Jun 2 17:03:41 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x4c18 RPTR 0x40d0 = 0x0
Jun 2 17:03:41 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 0 vtag 0 len 60 vlan_id 98 cfi 0 prio 0 va_lo 813 va_hi 0
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 55296 dma 000000019c14d800
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac608a94880 size 1536
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 000000022a522000
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x4c30
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x4c30
Jun 2 17:03:41 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x4c30 RPTR 0x40d0 = 0x0
Jun 2 17:03:41 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 0 vtag 0 len 60 vlan_id 0 cfi 0 prio 0 va_lo 814 va_hi 0
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 53760 dma 000000019c14d200
Jun 2 17:03:41 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac60810edc0 size 1536
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 00000002043b7000
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x4c48
Jun 2 17:03:41 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x4c48
Jun 2 17:03:41 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x4c48 RPTR 0x40d0 = 0x0
Jun 2 17:03:42 FTP1 kernel: tn40xx: print_rxdd:3407 : rxdd bc 2 rxfq 0 to 0 type 2 err 0 rxp 0 pkt_id 0 vtag 0 len 60 vlan_id 0 cfi 0 prio 0 va_lo 815 va_hi 0
Jun 2 17:03:42 FTP1 kernel: tn40xx: bdx_rx_receive:3275 : tn40xx: * RX 60 *
Jun 2 17:03:42 FTP1 kernel: tn40xx: bdx_rx_reuse_page:2677 : dm size 262144 off 52224 dma 000000019c14cc00
Jun 2 17:03:42 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2896 : _bdx_rx_alloc_buffers is at ffffffffc0a7d130
Jun 2 17:03:42 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2899 : dno 1 page_size 1536 buf_size 1536
Jun 2 17:03:42 FTP1 kernel: tn40xx: bdx_rx_get_page:2641 : map page ffffdac6027872c0 size 1536
Jun 2 17:03:42 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2945 : dm size 1536 off 0 dma 000000009e1cb000
Jun 2 17:03:42 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2983 : nPages 1
Jun 2 17:03:42 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2987 : WRITE_REG 0x4090 f->m.reg_WPTR 0x4c60
Jun 2 17:03:42 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2988 : READ_REG 0x40d0 f->m.reg_RPTR=0x5000
Jun 2 17:03:42 FTP1 kernel: tn40xx: _bdx_rx_alloc_buffers:2989 : READ_REG 0x4090 f->m.reg_WPTR=0x4c60
Jun 2 17:03:42 FTP1 kernel: tn40xx: dbg_printFifo:234 : RXF fifo:
Jun 2 17:03:42 FTP1 kernel: tn40xx: dbg_printFifo:236 : WPTR 0x4090 = 0x4c60 RPTR 0x40d0 = 0x0
Jun 2 17:56:32 FTP1 kernel: nm-bond1: Releasing backup interface enp3s0
Jun 2 17:56:32 FTP1 kernel: nm-bond1: the permanent HWaddr of enp3s0 - 2c:4d:54:58:59:85 - is still in use by nm-bond1 - set the HWaddr of enp3s0 to a different address to avoid conflicts
Jun 2 17:56:32 FTP1 kernel: RTL8211E Gigabit Ethernet r8169-300:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-300:00, irq=-2)
Jun 2 17:56:32 FTP1 kernel: IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
Jun 2 17:56:38 FTP1 kernel: libphy: r8169-300:00 - Link is Up - 1000/Full
Jun 2 17:56:38 FTP1 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
Jun 2 17:56:48 FTP1 kernel: RTL8211E Gigabit Ethernet r8169-300:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-300:00, irq=-2)
Jun 2 17:56:48 FTP1 kernel: libphy: r8169-300:00 - Link is Down
Jun 2 17:56:48 FTP1 kernel: nm-bond1: Enslaving enp3s0 as an active interface with a down link
Jun 2 17:56:52 FTP1 kernel: libphy: r8169-300:00 - Link is Up - 1000/Full
Jun 2 17:56:52 FTP1 kernel: nm-bond1: link status definitely up for interface enp3s0, 1000 Mbps full duplex
Jun 2 22:14:03 FTP1 kernel: nfsd: last server has exited, flushing export cache
Jun 2 22:14:05 FTP1 kernel: XFS (drbd2): Unmounting Filesystem
Jun 2 22:14:05 FTP1 kernel: drbd fast_data: role( Primary -> Secondary )
Jun 2 22:14:05 FTP1 kernel: drbd data: role( Primary -> Secondary )
Jun 2 22:14:05 FTP1 kernel: drbd fast_data FTP2: Preparing remote state change 2316491288
Jun 2 22:14:05 FTP1 kernel: drbd fast_data FTP2: Committing remote state change 2316491288 (primary_nodes=2)
Jun 2 22:14:05 FTP1 kernel: drbd fast_data FTP2: peer( Secondary -> Primary )
Jun 2 22:14:05 FTP1 kernel: drbd data FTP2: Preparing remote state change 3585368181
Jun 2 22:14:05 FTP1 kernel: drbd data FTP2: Committing remote state change 3585368181 (primary_nodes=2)
Jun 2 22:14:05 FTP1 kernel: drbd data FTP2: peer( Secondary -> Primary )
в 22:00 карта повисла, трафик через нее встал - в логах ни слова, в 22:14 выключил-включил интерфейс - опять ни слова,
но трафик через карту пошел
ситуация наблюдается на разных версиях ядра и драйвера
