Текущее время: Вт сен 29, 2026 10:20
СообщениеДобавлено: Вт мар 15, 2005 14:47
После всех настроек отваливается соединение с провайдером в DSL-504T.
C 504G таких проблем нет. Линия одна и таже.
Может чего не так делаю???
Спасибо.
СообщениеДобавлено: Вт мар 15, 2005 14:50
Спасибо.
Версия прошивки?
СообщениеДобавлено: Вт мар 15, 2005 14:57
DLinkRU_DSL-504T_fs_V1.00B02T02.RU.20041014
СообщениеДобавлено: Вт мар 15, 2005 16:29
что в логах пишет ?
СообщениеДобавлено: Вт мар 15, 2005 16:58
Sep 8 12:00:06> Valid Configuration Tree
Sep 8 12:00:11> Firewall NAT service started
Sep 8 12:00:12> Bridge Created: br0
Sep 8 12:00:12> Bridge Interface Added: eth0
Sep 8 12:00:13> pppd 2.4.1 started by root, uid 0
Sep 8 12:00:15> DSL Carrier is down
Sep 8 12:00:25> DSL Carrier is up
Sep 8 12:00:45> DSL Carrier is training
Sep 8 12:00:55> DSL Carrier is up
Sep 8 12:01:05> DSL Carrier is training
Sep 8 12:01:15> DSL Carrier is up
Sep 8 12:01:25> DSL Carrier is down
Sep 8 12:01:35> DSL Carrier is up
Sep 8 12:01:55> DSL Carrier is training
Sep 8 12:01:55> pppd 2.4.1 started by root, uid 0
Sep 8 12:02:05> DSL Carrier is up
Sep 8 12:02:15> DSL Carrier is training
Sep 8 12:02:25> DSL Carrier is up
Sep 8 12:02:35> DSL Carrier is down
Sep 8 12:02:45> DSL Carrier is up
Sep 8 12:03:05> DSL Carrier is training
Sep 8 12:03:15> DSL Carrier is up
Sep 8 12:03:42> pppd 2.4.1 started by root, uid 0
Sep 8 12:03:43> Connecting PPPoE socket: 00:30:88:00:87:ba 9f00 nas0 0x1000d3b8
Sep 8 12:03:43> Connect: ppp0 {--} nas0
Sep 8 12:03:43> WAN IP address 83.237.185.30
Sep 8 12:03:43> PPPoE Connect with IP Address 83.237.185.30
Sep 8 12:03:43> WAN gateway 83.237.185.1
Sep 8 12:03:43> PPPoE Connection Successfully Established
Sep 8 12:03:43> PPPoE Connect with Gateway IP Address: 83.237.185.1
Sep 8 12:03:43> primary DNS address 212.188.4.10
Sep 8 12:03:43> secondary DNS address 195.34.32.116
Sep 8 12:04:15> Timeout on response: flan:settings//block
СообщениеДобавлено: Вт мар 15, 2005 17:04
в настройках Connection1 возле on demand галочка стоит?
нет
СообщениеДобавлено: Вт мар 15, 2005 17:13
а при каких условиях он разрывает ? при активной работие или простое ?
СообщениеДобавлено: Вт мар 15, 2005 17:26
При включении, после того как удается связаться работает нормально.
СообщениеДобавлено: Вт мар 15, 2005 18:25
Судя по всему, разобрался изза чего так.
Если не ошибаюсь проблема в некорректном отключении модема.
Возможно я не прав........
