Текущее время: Сб сен 26, 2026 10:41
 Заголовок сообщения: Проблема с DSL-2640U
СообщениеДобавлено: Сб май 16, 2009 11:30
Каждые 10-30 минут происходит зависание интернет соединения на 10 секунд, Пробовал обновить прошивку, не помогло, причину найти не могу, вот логи роутера.
May 16 09:40:40 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=77.66.151.182 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x00 TTL=126 ID=15457 DF PROTO=TCP SPT=1946 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 09:50:37 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=87.255.8.21 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=118 ID=48623 DF PROTO=TCP SPT=2590 DPT=42309 WINDOW=16384 RES=0x00 SYN URGP=0
May 16 09:50:37 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=77.37.163.252 DST=77.66.233.238 LEN=64 TOS=0x00 PREC=0x20 TTL=52 ID=42185 DF PROTO=TCP SPT=57815 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 09:50:37 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=77.222.129.66 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=120 ID=53616 DF PROTO=TCP SPT=1395 DPT=42309 WINDOW=64512 RES=0x00 SYN URGP=0
May 16 09:50:38 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=94.241.16.229 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=30438 DF PROTO=TCP SPT=2469 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 09:50:38 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=77.37.163.252 DST=77.66.233.238 LEN=64 TOS=0x00 PREC=0x20 TTL=52 ID=63134 DF PROTO=TCP SPT=57815 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:00:39 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=195.5.36.22 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=111 ID=15482 DF PROTO=TCP SPT=3585 DPT=42309 WINDOW=16384 RES=0x00 SYN URGP=0
May 16 10:09:19 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=78.60.190.103 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=120 ID=5980 DF PROTO=TCP SPT=4069 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:09:21 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=95.132.183.41 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=110 ID=51995 DF PROTO=TCP SPT=44694 DPT=42309 WINDOW=16384 RES=0x00 SYN URGP=0
May 16 10:09:21 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=62.63.90.118 DST=77.66.233.238 LEN=48 TOS=0x08 PREC=0x40 TTL=118 ID=3423 DF PROTO=TCP SPT=1231 DPT=42309 WINDOW=16384 RES=0x00 SYN URGP=0
May 16 10:09:23 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=89.178.198.134 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=55 ID=6679 DF PROTO=TCP SPT=53337 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:09:25 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=78.60.190.103 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=120 ID=6108 DF PROTO=TCP SPT=4069 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:10:40 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=78.137.6.194 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=53 ID=53787 DF PROTO=TCP SPT=63694 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:10:44 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=79.142.173.118 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=116 ID=47119 DF PROTO=TCP SPT=3916 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:10:45 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=77.74.14.195 DST=77.66.233.238 LEN=48 TOS=0x08 PREC=0x40 TTL=56 ID=23930 DF PROTO=TCP SPT=50523 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:10:47 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=81.200.20.153 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=2085 DF PROTO=TCP SPT=2304 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:10:48 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=78.137.6.194 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=53 ID=46162 DF PROTO=TCP SPT=63694 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:10:50 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=81.200.20.153 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=3332 DF PROTO=TCP SPT=2304 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:20:47 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=77.37.167.145 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=115 ID=40471 DF PROTO=TCP SPT=3867 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:30:45 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=91.76.76.60 DST=77.66.233.238 LEN=44 TOS=0x00 PREC=0x20 TTL=119 ID=17202 PROTO=TCP SPT=4693 DPT=42309 WINDOW=16384 RES=0x00 SYN URGP=0
May 16 10:30:47 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=79.139.244.103 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=1539 DF PROTO=TCP SPT=53360 DPT=42309 WINDOW=8192 RES=0x00 SYN URGP=0
May 16 10:30:48 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=81.222.187.159 DST=77.66.233.238 LEN=52 TOS=0x00 PREC=0x20 TTL=54 ID=26601 DF PROTO=TCP SPT=3248 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:30:51 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=91.76.76.60 DST=77.66.233.238 LEN=44 TOS=0x00 PREC=0x20 TTL=119 ID=17332 PROTO=TCP SPT=4693 DPT=42309 WINDOW=16384 RES=0x00 SYN URGP=0
May 16 10:30:52 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=62.63.90.118 DST=77.66.233.238 LEN=48 TOS=0x08 PREC=0x40 TTL=118 ID=58386 DF PROTO=TCP SPT=3585 DPT=42309 WINDOW=16384 RES=0x00 SYN URGP=0
May 16 10:30:52 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=79.164.26.9 DST=77.66.233.238 LEN=52 TOS=0x00 PREC=0x20 TTL=117 ID=9438 DF PROTO=TCP SPT=4203 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:30:55 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=79.164.26.9 DST=77.66.233.238 LEN=52 TOS=0x00 PREC=0x20 TTL=117 ID=11393 DF PROTO=TCP SPT=4203 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:40:48 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=79.142.173.118 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=116 ID=31208 DF PROTO=TCP SPT=3594 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:50:48 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=92.124.11.245 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=121 ID=8586 DF PROTO=TCP SPT=33506 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:50:49 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=77.39.14.153 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x00 TTL=120 ID=1693 DF PROTO=TCP SPT=1436 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:50:51 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=81.200.20.153 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=23772 DF PROTO=TCP SPT=2182 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:50:54 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=89.204.59.215 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=64892 DF PROTO=TCP SPT=2185 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:50:57 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=86.62.73.169 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=32055 DF PROTO=TCP SPT=61307 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:51:05 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=89.232.124.209 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=116 ID=22531 DF PROTO=TCP SPT=1827 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 10:51:08 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=217.23.189.54 DST=77.66.233.238 LEN=64 TOS=0x00 PREC=0x20 TTL=57 ID=22814 DF PROTO=TCP SPT=10391 DPT=42309 WINDOW=16384 RES=0x00 SYN URGP=0
May 16 11:00:51 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=91.122.166.97 DST=77.66.233.238 LEN=60 TOS=0x08 PREC=0x40 TTL=55 ID=50791 DF PROTO=TCP SPT=60594 DPT=42309 WINDOW=5840 RES=0x00 SYN URGP=0
May 16 11:10:49 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=212.77.133.38 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=118 ID=27982 DF PROTO=TCP SPT=24938 DPT=42309 WINDOW=16384 RES=0x00 SYN URGP=0
May 16 11:10:49 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=84.245.212.94 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=18346 DF PROTO=TCP SPT=2944 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:10:50 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=62.182.87.50 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=118 ID=40957 DF PROTO=TCP SPT=1077 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:10:50 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=77.41.108.165 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=118 ID=41363 DF PROTO=TCP SPT=2484 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:10:50 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=188.16.43.19 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=43694 DF PROTO=TCP SPT=14871 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:10:51 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=93.80.183.168 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=8479 DF PROTO=TCP SPT=3259 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:10:52 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=92.124.11.245 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=121 ID=20272 DF PROTO=TCP SPT=34163 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:10:52 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=212.77.133.38 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=118 ID=28088 DF PROTO=TCP SPT=24938 DPT=42309 WINDOW=16384 RES=0x00 SYN URGP=0
May 16 11:20:55 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=79.139.244.103 DST=77.66.233.238 LEN=52 TOS=0x00 PREC=0x20 TTL=117 ID=16032 DF PROTO=TCP SPT=55989 DPT=42309 WINDOW=8192 RES=0x00 SYN URGP=0
May 16 11:30:52 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=91.124.36.102 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=111 ID=5087 DF PROTO=TCP SPT=4587 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:30:52 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=89.204.59.215 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=15008 DF PROTO=TCP SPT=4122 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:30:55 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=89.204.59.215 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=15274 DF PROTO=TCP SPT=4122 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:30:56 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=91.77.32.140 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=118 ID=26012 DF PROTO=TCP SPT=2763 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:30:57 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=87.166.126.112 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=112 ID=11251 DF PROTO=TCP SPT=55899 DPT=42309 WINDOW=8192 RES=0x00 SYN URGP=0
May 16 11:30:59 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=78.60.190.103 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=120 ID=63772 DF PROTO=TCP SPT=4955 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:30:59 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=91.77.32.140 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=118 ID=26107 DF PROTO=TCP SPT=2763 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:40:58 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=87.117.35.90 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=39523 DF PROTO=TCP SPT=2012 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:50:55 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=89.204.59.215 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=41369 DF PROTO=TCP SPT=1160 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:50:56 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=91.143.52.129 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=122 ID=7887 DF PROTO=TCP SPT=9119 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:50:56 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=195.3.148.205 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=705 DF PROTO=TCP SPT=61538 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:50:59 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=91.143.52.129 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=122 ID=7921 DF PROTO=TCP SPT=9119 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:51:01 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=89.204.59.215 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=41446 DF PROTO=TCP SPT=1160 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:51:02 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=195.3.148.205 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=117 ID=26606 DF PROTO=TCP SPT=61538 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:51:05 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=91.143.52.129 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=122 ID=7981 DF PROTO=TCP SPT=9119 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 11:51:11 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=62.182.87.50 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=118 ID=51934 DF PROTO=TCP SPT=1528 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 12:01:00 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=94.241.16.229 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=26237 DF PROTO=TCP SPT=1055 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 12:10:59 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=95.134.148.252 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=111 ID=15726 DF PROTO=TCP SPT=58261 DPT=42309 WINDOW=8192 RES=0x00 SYN URGP=0
May 16 12:10:59 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=89.204.59.215 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=2541 DF PROTO=TCP SPT=2174 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 12:11:01 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=87.226.229.88 DST=77.66.233.238 LEN=52 TOS=0x08 PREC=0x40 TTL=121 ID=36590 DF PROTO=TCP SPT=60527 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 12:11:01 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=81.222.187.159 DST=77.66.233.238 LEN=52 TOS=0x00 PREC=0x20 TTL=54 ID=40838 DF PROTO=TCP SPT=2795 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 12:11:02 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=89.204.59.215 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=119 ID=2583 DF PROTO=TCP SPT=2174 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 12:11:04 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=81.222.187.159 DST=77.66.233.238 LEN=52 TOS=0x00 PREC=0x20 TTL=54 ID=41309 DF PROTO=TCP SPT=2795 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
May 16 12:11:05 user alert kernel: Intrusion -> IN=ppp_0_33_1 OUT= MAC= SRC=62.182.87.50 DST=77.66.233.238 LEN=48 TOS=0x00 PREC=0x20 TTL=118 ID=59002 DF PROTO=TCP SPT=1741 DPT=42309 WINDOW=65535 RES=0x00 SYN URGP=0
Сейчас этот форум просматривают: Majestic-12 [Bot] и гости: 14
