Текущее время: Ср окт 07, 2026 20:36
 Заголовок сообщения: Виснет интернет на модеме 2540U/BRU/C
СообщениеДобавлено: Ср май 06, 2009 18:58
Прошивка последняя.
Примерно раз в сутки интернет виснет.
Т.е. лапочки все горят, в модем захожу нормально, но интернета нет.
Вот статистика АДСЛ
Statistics -- ADSL
Mode: ADSL2+
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 6.9 26.5
Attenuation (dB): 60.5 34.7
Output Power (dBm): 12.9 0.0
Attainable Rate (Kbps): 1948 864
Rate (Kbps): 1023 252
MSGc (number of bytes in overhead channel message): 76 10
B (number of bytes in Mux Data Frame): 12 36
M (number of Mux Data Frames in FEC Data Frame): 1 1
T (Mux Data Frames over sync bytes): 2 1
R (number of check bytes in FEC Data Frame): 6 0
S (ratio of FEC over PMD Data Frame length): 0.3907 4.5538
L (number of bits in PMD Data Frame): 389 65
D (interleaver depth): 320 1
Delay (msec): 31 1
Super Frames: 10536823 57493
Super Frame Errors: 156210 4294967264
RS Words: 1728039052 0
RS Correctable Errors: 30142945 0
RS Uncorrectable Errors: 10284145 N/A
HEC Errors: 67800 4294967289
OCD Errors: 1874 0
LCD Errors: 42 0
Total Cells: 404746901 371642
Data Cells: 77367653 0
Bit Errors: 0 0
Total ES: 3760 0
Total SES: 2686 0
Total UAS: 15 0
Делаю диагностику - выдаёт следующее:
Inet Diagnostics
Your modem is capable of testing your DSL connection. The individual tests are listed below. If a test displays a fail status, click "Rerun Diagnostic Tests" at the bottom of this page to make sure the fail status is consistent. If the test continues to fail, click "Help" and follow the troubleshooting procedures.
Test the connection to your local network
Test your ENET(1-3) Connection: FAIL
Test your ENET4 Connection: PASS
Test the connection to your DSL service provider
Test ADSL Synchronization: PASS
Test ATM OAM F5 segment ping:
PASS
Test ATM OAM F5 end-to-end ping:
PASS
Test the connection to your Internet service provider
Test PPP server connection: PASS
Test authentication with ISP: PASS
Test the assigned IP address: PASS
Ping default gateway: FAIL
Ping primary Domain Name Server: FAIL
После ребута всё опять ок. В чем проблема?
СообщениеДобавлено: Ср май 06, 2009 19:15
303, если у тебя РРРоЕ, и биллинг твоего провайдера использует 24-часовые сессии, то тебе сюда - DSL-2640U/BRU/C: ошибка в коде?......
PS Да, модем другой, но грабли скорее всего те же...
Всё знать нельзя;-)...
СообщениеДобавлено: Ср май 06, 2009 19:37
Еще это может влиять:
И еще неплохо бы посмотреть на DeviceInfo-Summary и DeviceInfo-WAN (Status-DeviceInfo, Status-WANInfo), конкретнее, что назначено в этот момент как IP, шлюз и DNS.
СообщениеДобавлено: Ср май 06, 2009 20:00
WAN Info
Port/VPI/VCI Con. ID Category Service Interface Protocol Igmp QoS State Status IPv4 Address
0/0/35 1 UBR Inet ppp_0_0_35_1 PPPoE Disabled Disabled Enabled Up **.***.164.84
Device Info
BoardID: DSL-2540U
Software Version: RU_1.12
Bootloader (CFE) Version: 1.0.37-12.1
This information reflects the current status of your DSL connection.
Line Rate - Upstream (Kbps): 252
Line Rate - Downstream (Kbps): 1023
LAN IPv4 Address: ***.***.*.*
MAC Address: 00-21-91-cd-71-6f
Default Gateway: ppp_0_0_35_1
Primary DNS Server: **.***.0.250
Secondary DNS Server: **.***.0.202
Date/Time: Wed May 6 04:59:28 2009
Последний раз редактировалось 303 Ср май 06, 2009 20:01, всего редактировалось 1 раз.
SGAIL, да у меня РPPoE.
СообщениеДобавлено: Ср май 06, 2009 21:29
303 писал(а):
WAN Info
Ну что вы шифруетесь, как в детском саду?? Вас ломать собрались?
Боитесь - вышлите данные почтой, в асю постучите...
Вы не понимаете, что необходимы _реальные_ адреса (может, еще и адресация сетей понадобится), чтобы понять (и что-то посоветовать), отчего у вас шлюз и ДНС провайдера недоступны?
СообщениеДобавлено: Ср май 06, 2009 21:47
Приват сообщением скинул.
СообщениеДобавлено: Ср май 06, 2009 22:46
Ну, как обычно - ЮТК-Краснодар :)
Сколько копий об него уже сломано...
