Текущее время: Ср сен 23, 2026 12:45
СообщениеДобавлено: Ср апр 01, 2009 13:51
ЮТК - Волгоград
Не работает в режиме Роутер.
Jan 1 11:47:00 daemon crit pppd[301]: Clear IP addresses. Connection DOWN.
Jan 1 11:47:00 daemon crit pppd[301]: Clear IP addresses. PPP connection DOWN.
Jan 1 11:47:06 daemon crit pppd[301]: PPP server detected.
Jan 1 11:47:09 daemon crit pppd[301]: PPP server detected.
Jan 1 11:47:09 daemon crit pppd[301]: PPP session established.
Jan 1 11:47:21 daemon crit pppd[301]: PPP server detected.
Jan 1 11:47:25 daemon crit pppd[301]: PPP server detected.
Jan 1 11:47:25 daemon crit pppd[301]: PPP session established.
Jan 1 11:47:37 daemon crit pppd[301]: PPP server detected.
Jan 1 11:47:40 daemon crit pppd[301]: PPP server detected.
Jan 1 11:47:40 daemon crit pppd[301]: PPP session established.
Jan 1 11:47:52 daemon crit pppd[301]: PPP server detected.
Jan 1 11:47:55 daemon crit pppd[301]: PPP server detected.
Jan 1 11:47:55 daemon crit pppd[301]: PPP session established.
Jan 1 11:48:07 daemon crit pppd[301]: PPP server detected.
Jan 1 11:48:10 daemon crit pppd[301]: PPP server detected.
Jan 1 11:48:10 daemon crit pppd[301]: PPP session established.
Jan 1 11:48:22 daemon crit pppd[301]: PPP server detected.
Jan 1 11:48:25 daemon crit pppd[301]: PPP server detected.
Jan 1 11:48:25 daemon crit pppd[301]: PPP session established.
Jan 1 11:48:37 daemon crit pppd[301]: PPP server detected.
Jan 1 11:48:41 daemon crit pppd[301]: PPP server detected.
Jan 1 11:48:41 daemon crit pppd[301]: PPP session established.
Jan 1 11:48:53 daemon crit pppd[301]: PPP server detected.
Jan 1 11:48:56 daemon crit pppd[301]: PPP server detected.
Jan 1 11:48:56 daemon crit pppd[301]: PPP session established.
Помогает ток ребут модема. Галка Keep Alive стоит.
Можно решить эту проблему. Прошивка [V.3-06-04-3H00]
СообщениеДобавлено: Чт апр 02, 2009 07:44
UP
СообщениеДобавлено: Пт апр 03, 2009 12:33
UP
СообщениеДобавлено: Пт апр 03, 2009 12:39
ждёмс......... ответа.........
dsl-2540u_RU ЮТК Волгоград
СообщениеДобавлено: Пт апр 03, 2009 16:16
Hunter34 писал(а):
ЮТК - Волгоград
К сожалению, данный лог практически не содержит полезной информации. Здесь потребуется помощь провайдера.
Необходимо смотреть логи на стороне BRAS (причина по которой произошёл обрыв PPPoE-сессии). Или поставить перед PPPoE-сервером сниффер и получить дамп пакетов для последующего анализа.
СообщениеДобавлено: Пт апр 03, 2009 22:27
Официальный ответ ЮТК.
Вопрос уже поднимался в разделе "Проблемном". Проблема связана с абонентским оборудованием (данный "глюк" замечен на Dlink и Acorp). Проблема вызвана сбоем в работе вышеуказанного оборудования, при получении ответа от нескольких серверов авторизации по протоколу PPPoE. Вопрос касается не только ЮТК, на форуме Длинка данный вопрос поднимался не однократно (на акорпе не смотрел).
Доказательство того, что проблема связанна именно с абонентским оборудование заключается в том, что если перенастроить модем в режим Bridge (когда работает PPPoE клиент Windows а не внутренний модема) проблема исчезает. Со стороны ЮТК же в этот момент никаких изменений не происходит.
СообщениеДобавлено: Ср апр 08, 2009 13:31
UP
СообщениеДобавлено: Пт апр 10, 2009 09:46
Перепайка кондеров помогает. ищите на форуме. сам мучаюсь хотя оператор стрим. дело в модеме 100%.
СообщениеДобавлено: Пт апр 10, 2009 10:14
boltik0
мне не помогло. полностью всё перепаял на новые.
