Текущее время: Пн сен 14, 2026 17:48
СообщениеДобавлено: Чт фев 10, 2005 09:23
недавно получил письмо
В ближайшие 20 дней будет проводиться модернизация кроссового и кабельного
оборудования на Вашей АТС. Во время проведения работ возможны перерывы
в предоставлении Услуг связи продолжительностью от 20 минут до двух часов.
а Вчера, когда играл в интернете, вдруг пропало соединение.
перегрузил роутер, соединение так и не поднялось. лампочка ADSL сначала мигает, потом горит постоянно. В логах пишется вот это
Sep 8 12:00:07> Valid Configuration Tree
Sep 8 12:00:11> Firewall NAT service started
Sep 8 12:00:12> Bridge Created: br0
Sep 8 12:00:13> Bridge Interface Added: eth0
Sep 8 12:00:13> pppd 2.4.1 started by root, uid 0
Sep 8 12:00:15> DSL Carrier is down
Sep 8 12:00:35> DSL Carrier is training
Sep 8 12:00:45> DSL Carrier is up
Sep 8 12:01:53> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:01:53> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:01:53> Doing disconnect
Sep 8 12:01:54> System Call Error
Sep 8 12:01:54> pppd 2.4.1 started by root, uid 0
Sep 8 12:03:34> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:03:34> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:03:34> Doing disconnect
Sep 8 12:03:34> System Call Error
Sep 8 12:03:39> pppd 2.4.1 started by root, uid 0
Sep 8 12:05:19> System Call Error
Sep 8 12:05:19> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:05:19> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:05:19> Doing disconnect
Sep 8 12:05:19> pppd 2.4.1 started by root, uid 0
Sep 8 12:06:24> Tag error: TAG_HOST_UNIQ
Sep 8 12:06:24> Failed to negotiate PPPoE connection: 25
Sep 8 12:06:24> System Call Error
Sep 8 12:06:29> pppd 2.4.1 started by root, uid 0
Sep 8 12:07:48> Tag error: TAG_HOST_UNIQ
Sep 8 12:07:48> Failed to negotiate PPPoE connection: 25
Sep 8 12:07:48> System Call Error
Sep 8 12:07:53> pppd 2.4.1 started by root, uid 0
Sep 8 12:09:33> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Sep 8 12:09:33> Couldn't get channel number: Transport endpoint is not connected
Sep 8 12:09:33> Doing disconnect
Sep 8 12:09:33> System Call Error
можно ли по логу сказать проблемы у меня с роутером или все таки на стороне СТРИМа?
СообщениеДобавлено: Чт фев 10, 2005 09:50
Это оно.
СообщениеДобавлено: Чт фев 10, 2005 09:58
Это оно.
Спасибо за быстрое реагирование. Порадовали, что с роутером все в порядке, я уж волноваться начал
только вот лежит оно, к сожалению не 20 мин и даже не 2 часа, а с 22-30 и в 8-00 еще не работало (( Позвоню в СТРИМ, спрошу что за ерунда.
СообщениеДобавлено: Чт фев 10, 2005 10:05
только что пришло новое письмо
Сегодня на Вашей АТС будут проводиться работы по модернизации кроссового и кабельного
оборудования. Вследствие этого, возможен перерыв в предоставлении Услуг на срок
от 20 минут до двух часов. Приносим извинения за доставленные неудобства. Если до 22:00
работоспособность канала не восстановится, просим известить нас об этом через своего
оператора, заведя 'билет проблемы' с указанием признака 'переключение'.
СообщениеДобавлено: Пт фев 11, 2005 10:56
Вчера вечером заработало. Но недолго музыка играла. Утром опять не работает, правда симптомы другие. лампочка АДСЛ все время практически мигает. А если и загорится, то буквально на несколько секунд. У товарища похожие симптомы были на новый год. БУду звонить в стрим
Лог
Sep 8 12:00:06> Valid Configuration Tree
Aug 9 12:01:00> Bridge Created: br0
Aug 9 12:01:00> Bridge Interface Added: eth0
Aug 9 12:01:01> pppd 2.4.1 started by root, uid 0
Aug 9 12:01:03> DSL Carrier is training
Aug 9 12:02:33> DSL Carrier is up
Aug 9 12:02:41> System Call Error
Aug 9 12:02:41> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Aug 9 12:02:41> Couldn't get channel number: Transport endpoint is not connected
Aug 9 12:02:41> Doing disconnect
Aug 9 12:02:41> pppd 2.4.1 started by root, uid 0
Aug 9 12:02:43> DSL Carrier is down
Aug 9 12:02:53> DSL Carrier is training
Aug 9 12:04:11> Connecting PPPoE socket: 00:30:88:00:66:9f ae19 nas0 0x1000d3b8
Aug 9 12:04:11> Connect: ppp0 {--} nas0
Aug 9 12:04:12> WAN IP address 83.237.34.26
Aug 9 12:04:12> WAN gateway 83.237.34.1
Aug 9 12:04:12> PPPoE Connect with IP Address 83.237.34.26
Aug 9 12:04:12> PPPoE Connection Successfully Established
Aug 9 12:04:12> PPPoE Connect with Gateway IP Address: 83.237.34.1
Aug 9 12:04:13> DSL Carrier is up
Aug 9 12:04:23> DSL Carrier is training
Aug 9 12:04:43> DSL Carrier is up
Aug 9 12:04:52> Connection terminated.
Aug 9 12:04:52> Doing disconnect
Aug 9 12:04:53> DSL Carrier is training
Aug 9 12:04:53> pppd 2.4.1 started by root, uid 0
Aug 9 12:06:33> System Call Error
Aug 9 12:06:33> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Aug 9 12:06:33> Couldn't get channel number: Transport endpoint is not connected
Aug 9 12:06:33> Doing disconnect
Aug 9 12:06:34> pppd 2.4.1 started by root, uid 0
Aug 9 12:08:14> System Call Error
Aug 9 12:08:14> Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1000d3b8
Aug 9 12:08:14> Couldn't get channel number: Transport endpoint is not connected
Aug 9 12:08:14> Doing disconnect
Aug 9 12:08:14> pppd 2.4.1 started by root, uid 0
СообщениеДобавлено: Пт фев 11, 2005 10:57
Лог
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 85
