Текущее время: Вс авг 09, 2026 07:24
Начать новую тему Ответить на тему  [ Сообщений: 25 ]  На страницу 1, 2  След.
 Заголовок сообщения: Проблема с 2640U.
СообщениеДобавлено: Вс мар 01, 2009 10:22
Постоянные обрывы, уже не знаю что делать
ar 1 07:59:27 user warn dnsprobe[2312]: dns query failed
Mar 1 08:08:15 user warn dnsprobe[2312]: dns query failed
Mar 1 08:25:02 daemon crit pppd[539]: Clear IP addresses. Connection DOWN.
Mar 1 08:25:02 daemon crit pppd[539]: Clear IP addresses. PPP connection DOWN.
Mar 1 08:25:09 daemon notice pppd[539]: PPP: Start to connect ...
Mar 1 08:25:10 daemon crit pppd[539]: PPP LCP UP.
Mar 1 08:25:11 user debug syslog: route add default dev ppp_0_35_1 2>/dev/null
Mar 1 08:25:11 daemon crit pppd[539]: Received valid IP address from server. Connection UP.
Mar 1 08:25:11 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 1 08:25:11 user debug syslog: iptables -A FORWARD -o ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --set-mss 1452
Mar 1 08:25:11 user debug syslog: iptables -A FORWARD -i ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --set-mss 1452
Mar 1 08:25:11 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 1 08:25:11 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 1 08:50:09 user warn dnsprobe[2312]: dns query failed
Mar 1 08:53:49 syslog info -- MARK --
Mar 1 08:54:20 user warn dnsprobe[2312]: dns query failed
Mar 1 09:06:15 user warn dnsprobe[2312]: dns query failed
Mar 1 09:15:35 user warn dnsprobe[2312]: dns query failed
Mar 1 09:19:14 user warn dnsprobe[2312]: dns query failed
Mar 1 09:21:20 user warn dnsprobe[2312]: dns query failed
Mar 1 09:27:34 user warn dnsprobe[2312]: dns query failed
Mar 1 09:31:44 user warn dnsprobe[2312]: dns query failed
Mar 1 09:32:48 user warn dnsprobe[2312]: dns query failed
Mar 1 09:35:56 user warn dnsprobe[2312]: dns query failed
Mar 1 09:43:12 user warn dnsprobe[2312]: dns query failed
Mar 1 09:48:24 user warn dnsprobe[2312]: dns query failed
Mar 1 09:53:50 syslog info -- MARK --
Mar 1 09:59:48 user warn dnsprobe[2312]: dns query failed
Mar 1 10:06:23 daemon crit pppd[539]: Clear IP addresses. Connection DOWN.
Mar 1 10:06:23 daemon crit pppd[539]: Clear IP addresses. PPP connection DOWN.
Mar 1 10:06:29 daemon notice pppd[539]: PPP: Start to connect ...
Mar 1 10:06:31 daemon crit pppd[539]: PPP LCP UP.
Mar 1 10:06:32 daemon crit pppd[539]: Received valid IP address from server. Connection UP.
Mar 1 10:06:32 user debug syslog: route add default dev ppp_0_35_1 2>/dev/null
Mar 1 10:06:32 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 1 10:06:32 user debug syslog: iptables -A FORWARD -o ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --set-mss 1452
Mar 1 10:06:32 user debug syslog: iptables -A FORWARD -i ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --set-mss 1452
Mar 1 10:06:32 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 1 10:06:32 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 1 10:06:34 user warn dnsprobe[2312]: dns query failed
почему такое происходит? как вылечить? самое интересное, что если подключаю акорп 422, обрывов нет, но сёрфить не реально, страницы загружаются больше минуты.
СообщениеДобавлено: Вт мар 03, 2009 14:09
Никто ничего не подскажет? Завтра поеду куплю 2540U, который последний, D, может с ним такого не будет :(
СообщениеДобавлено: Вт мар 03, 2009 14:18
Асус бери...
СообщениеДобавлено: Вт мар 03, 2009 15:23
Поддерживаю создателя ветки!
Третий день тираню ВебПлас на подобный предмет, только с некоторыми отличиями. У меня РРР не рвется, просто зверек теряет гетвей (по крайней мере выглядит со стороны модема так). Но со стороны прова говорят - конект РРР падает.
Если присовокупить еще потерю WiFi при ребуте, то одназначно хочется узнать о выходе новой прошивки!
СообщениеДобавлено: Вт мар 03, 2009 15:24
Укажите версию прошивки.
СообщениеДобавлено: Вт мар 03, 2009 16:00
Извините, Александр, у меня 2650.
Но проблемы теже
СообщениеДобавлено: Ср мар 04, 2009 10:06
Software Version: RU_DSL-2640U_3-06-04-3H00.A2pB023g2.d19b
СообщениеДобавлено: Ср мар 04, 2009 10:14
VerSerj писал(а):
Асус бери...
Брал как то асус AM604, у него не было настройки MTU, посоветовали прошить акорповской прошивкой:) Но акорп 422 есть у меня, ppp на нём не падает, но сёрфить не реально, страницы по минуте грузятся.
Вот я и сделал вывод, раз PPP на акорпе не падает, то пров ни при чём, значит с 2640U что то не то.
СообщениеДобавлено: Ср мар 04, 2009 10:29
Rostovchanin писал(а):
VerSerj писал(а):
Асус бери...
Я вот родителям тоже АМ604 купил, пока не подключал. Кстати, к нему есть прошивки от так называемого "Олега", гораздо лучше родных и с кучей доп. функций (на своем WL-500W с ней получилось поднять L2TP, в родной этого нет).
Просто был опыт общения с двумя Длинками и с обоими были проблемы - один, 624S, не держал FTP-сервер, точнее держал, но минут через 10 капитально падал, а второй не поднимает сессию после обрыва. Писал в поддержку, носил в ремонт... Никто ничего сделать не смог. Продал, купил WL-500W и уже почти 2 года ни одной проблемы, пашет круглосуточно. Такое впечатление, что саппорту только свою деятельность обозначить надо - уже куча тем про неподнятие сессии, и никаких результатов...
СообщениеДобавлено: Ср мар 04, 2009 11:22
Та же фигня на модеме DSL-2640U/BRU/C. Прошил до версии 1.12 - проблема осталась.
Что с этим делать?
СообщениеДобавлено: Ср мар 04, 2009 20:49
Купил 2540U/D, прошил последней прошивкой, ерунда какая то творится, вэб интерфейс тормозит жутко, уже не знаю, что делать, все браузеры перепробовал:(
СообщениеДобавлено: Ср мар 04, 2009 22:24
И что самое обидное, нет активной поддержки со стороны техников длинка, я трачу деньги, покупаю модемы один за другим, пляшу с бубном вокруг них, сейчас на 2540U я даже лог нормально посмотреть не могу, потому как обновляется окно по 2-3 минуты.
СообщениеДобавлено: Чт мар 05, 2009 00:02
Сбросить в дефоулт (можно кнопкой) и перенастроить заново, вручную, старые конфиги не загружать.
СообщениеДобавлено: Чт мар 05, 2009 00:30
сбрасывал кнопкой, заново настраивал, даже перепрошил ещё раз, жесть, после перезагрузки нормально некоторое время вэб морда работает, потом всё хуже и хуже, вплоть до зависания и пропадания инета. Выхода не нашёл, вернулся на глючный, но не зависающий 2640U. Думаю....
СообщениеДобавлено: Чт мар 05, 2009 20:33
2540U благополучно сдан в магазин, продолжаю юзать глючный 2640U
Mar 5 18:56:12 syslog info -- MARK --
Mar 5 18:59:28 user warn dnsprobe[563]: dns query failed
Mar 5 19:00:01 user warn dnsprobe[563]: dns query failed
Mar 5 19:02:07 user warn dnsprobe[563]: dns query failed
Mar 5 19:07:19 user warn dnsprobe[563]: dns query failed
Mar 5 19:12:00 user warn dnsprobe[563]: dns query failed
Mar 5 19:12:33 user warn dnsprobe[563]: dns query failed
Mar 5 19:18:16 user warn dnsprobe[563]: dns query failed
Mar 5 19:19:20 user warn dnsprobe[563]: dns query failed
Mar 5 19:19:22 user warn dnsprobe[563]: dns query failed
Mar 5 19:20:57 user warn dnsprobe[563]: dns query failed
Mar 5 19:28:13 user warn dnsprobe[563]: dns query failed
Mar 5 19:36:49 user debug syslog: kill 3280
Mar 5 19:36:49 user debug syslog: dhcpc -i nas_0_37 &
Mar 5 19:38:04 user warn dnsprobe[563]: dns query failed
Mar 5 19:38:49 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 5 19:38:49 user debug syslog: iptables -t nat -D POSTROUTING -o nas_0_37 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 5 19:38:49 user debug syslog: iptables -t nat -A POSTROUTING -o nas_0_37 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 5 19:38:50 user debug syslog: iptables -D INPUT -i nas_0_37 -j DROP
Mar 5 19:38:50 user debug syslog: iptables -A INPUT -i nas_0_37 -j DROP
Mar 5 19:50:31 user warn dnsprobe[563]: dns query failed
Mar 5 19:53:30 daemon crit pppd[434]: Clear IP addresses. Connection DOWN.
Mar 5 19:53:30 daemon crit pppd[434]: Clear IP addresses. PPP connection DOWN.
Mar 5 19:53:33 daemon notice pppd[434]: PPP: Start to connect ...
Mar 5 19:53:38 daemon crit pppd[434]: PPP LCP UP.
Mar 5 19:53:39 user warn dnsprobe[563]: dns query failed
Mar 5 19:53:39 daemon crit pppd[434]: Received valid IP address from server. Connection UP.
Mar 5 19:53:39 user debug syslog: route add default dev ppp_0_35_1 2>/dev/null
Mar 5 19:53:39 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 5 19:53:39 user debug syslog: iptables -A FORWARD -o ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 5 19:53:39 user debug syslog: iptables -A FORWARD -i ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 5 19:53:39 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 5 19:53:39 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 5 19:53:41 user warn dnsprobe[563]: dns query failed
Mar 5 19:56:12 syslog info -- MARK --
Mar 5 20:05:05 user warn dnsprobe[563]: dns query failed
Mar 5 20:11:15 daemon crit pppd[434]: Clear IP addresses. Connection DOWN.
Mar 5 20:11:15 daemon crit pppd[434]: Clear IP addresses. PPP connection DOWN.
Mar 5 20:11:19 user warn dnsprobe[563]: dns query failed
Mar 5 20:11:21 daemon notice pppd[434]: PPP: Start to connect ...
Mar 5 20:11:21 user warn dnsprobe[563]: dns query failed
Mar 5 20:11:23 daemon crit pppd[434]: PPP LCP UP.
Mar 5 20:11:23 user warn dnsprobe[563]: dns query failed
Mar 5 20:11:23 user notice dnsprobe[563]: Primary DNS server Is Down... Switching To Secondary DNS server
Mar 5 20:11:24 daemon crit pppd[434]: Received valid IP address from server. Connection UP.
Mar 5 20:11:24 user debug syslog: route add default dev ppp_0_35_1 2>/dev/null
Mar 5 20:11:24 user debug syslog: route add -net 10.253.0.0 netmask 255.255.255.0 metric 1 gw 10.253.11.1 2>/dev/null
Mar 5 20:11:24 user debug syslog: iptables -A FORWARD -o ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 5 20:11:24 user debug syslog: iptables -A FORWARD -i ppp_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Mar 5 20:11:24 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Mar 5 20:11:24 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Mar 5 20:11:54 user notice dnsprobe[563]: Switching Back To Primary DNS server
Mar 5 20:31:03 user warn dnsprobe[563]: dns query failed
у техподдержки есть идеи?)
